2311-3003
2311-3003
    ANSMANN
    ANSMANN - 2311-3003 - Rechargeable Battery, 1.2 V, Nickel Metal Hydride, 800 mAh, AAA, Opposing Tags...
2311-3003 数据手册
Conditions cell type: cell size: nominal voltage: max. charge voltage: 1.2 1.5 V V 800 800 760 mAh mAh mAh discharge at 0.2C discharge at 0.2C discharge at 1C 1.0V end discharge voltage ta: 20°C max. continuous discharge current: 1600 mA ta: 0....45°C charge standard charge: quick charge: fast charge: current 80 250 800 mA mA mA time 14....16hrs 4hrs 1.1hrs recommended charge termination control parameters: 0…5 0.8...1 45...50 mV °C °C - delta V temperature rise per minute TCO (temperature cut off) trickle charge current: 8...30 mA (recommended) continuous overcharge: (less than 1 year) ≤ 80 mA no conspicuous deformation no leakage internal resistance: (impedance) ≤ 45 mΩ at 1KHz battery fully charged life expectance: ≥ 500 cycles acc. IEC standard self discharge charge retention: ≥ 75 % after 12 months storage at 20°C initial capacity: ≥ 550 mAh within 30 days after delivery discharge at 0.2C 0...45 10...40 20...55 20...50 20...40 20...30 °C °C °C °C °C °C standard charge fast charge discharge storage (≤3months) storage (≤6months) storage (≤24months) capacity nominal: minimum: ambient temperature range: QCT1: QCT2: at standard charge (0.1C / 20°C) 20/700/50 30/600/50 mechanical specifications cell dimensions (incl. label) diameter d1: diameter d2: height h1: height h2: weight: Diagrams NiMH AAA 10.5 5.0 44.5 0 - 0.3 ±1 - 1.5 +1 12 ± 2 battery shrinked with green shrink tube mm mm mm mm soldering tags in Z-shape; plated battery packed in PE bag g 51 ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date AAA - 800mAh NiMH RTU battery Flat Top with tags packed in PE bag 2311-3003 701344 TG / 10.03.2016 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
2311-3003 价格&库存
很抱歉,暂时无法提供与“2311-3003”相匹配的价格&库存,您可以联系我们找货
