1307-0003
1307-0003
    ANSMANN
    ANSMANN - 1307-0003 - Rechargeable Battery, 3.6 V, Lithium Ion, 3.4 Ah, 18650, Raised Positive and F...
1307-0003 数据手册
cell type: cell size: built-in cell: Li-Ion 18650 LG INR 18650 F1L 3350mAh Conditions nominal voltage: 3.6 V capacity nominal: minimum: 3400 mAh 3250 mAh 3000 mAh discharge at 0.2C discharge at 0.2C discharge at 1C ta: 20°C; EV(Discharge End Voltage): 2.50V discharge max. continuous discharge current: 4875 mA ta: 0....45°C important: avoid cell temperature above 60°C discharge end voltage: ≥ 2.5 V (recommended) external charge (at +/ - poles) charging method: CC - CV (Constant Current - Constant Voltage) charge current: max. charge current: 650 mA 1625 mA charge end voltage: 4.2 V charge cut off by time: by current drop: 5...6 h 2.75...3.25 h 50 mA at standard charge at rapid charge ± 50mV at standard charge at rapid charge end current - cut off charge via micro USB connector (with USB charger) supply voltage: 5 V ± 0.25V charge current: ≤ 1150 mA charge time: ≤4 h at 1A charge internal resistance: ≤ 100 mΩ energy: 12.24 Wh protection functions overcharge cut off voltage: deep disch.cut off voltage: overload cut off current: LED charge indicator (w. micro USB charge) life time expectance (C>70% of min. capacity) self discharge: ambient temperature range: recommended SOC: (SOC = state of charge) mechanical specifications cell dimensions (incl. sleeve) diameter d1: diameter d2: height h1: height h2: weight: 4.3 V 2.5 V 12 A lights red lights green at 1kHz, sine wave measurement according to IEC 896-2 ± 0.05V ± 0.1V max. during charge end of charge; battery fully charged ≥ 300 cycles at 0.5C charge/discharge rate ≤ 2 %/month ≤ 5 %/month ≤ 10 %/month 0...45 - 20...60 - 20...25 - 20...45 °C °C °C °C 30...50 % 18.5 5 70.0 0.5 49 ± 0.3 ± 0.5 –2 + 0.3 ±3 at 20°C at 30°C at 40°C charge discharge storage max. 1year storage max. 3months for long-time stoarge mm mm mm mm g ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date 111 Protected 18650 Li-Ion Battery 3.6V 3400mAh w. Micro USB Charge 704507 TG / 19.07.2019 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
1307-0003 价格&库存
很抱歉,暂时无法提供与“1307-0003”相匹配的价格&库存,您可以联系我们找货
