5015453
5015453
    ANSMANN
5015453 数据手册
Alkaline Manganese Dioxide (mercury free) IEC: LR1; JIS: AM-5; ANSI: N; Lady Zn / KOH-H2O / MnO2 battery type: battery size: chemical system: Conditions 1.5 V 1.56… 1.63 V 1.54… 1.63 V nominal voltage: open circuit voltage: new battery after 1 year storage at 20°C all measurements at 22 ± 2°C ambient capacity rated: 940 mAh discharge under 300Ω load; 12hours/day End Voltage (E.V.): 0.9V minimum: 750 mAh at 5mA constant current discharge; E.V.: 0.8V (for QC measurement) 550 mAh at 60mA constant current discharge; E.V.: 0.8V typical service output new battery: norm. min. 12.5 h 10.5 h at 20Ω load; discharge 24h/d; E.V.: 0.9V after 1 year storage: norm. min. 10.0 h 8.5 h at 20Ω load; discharge 24h/d; E.V.: 0.9V new battery: norm. min. 140 min 110 min at 5.1Ω load; discharge 5min/d; E.V.: 0.9V after 1 year storage: norm. min. 110 min 80 min at 5.1Ω load; discharge 5min/d; E.V.: 0.9V new battery: norm. min. 215 h 208 h at 300Ω load; discharge 12h/d; E.V.: 0.9V after 1 year storage: norm. min. 200 h 185 h at 300Ω load; discharge 12h/d; E.V.: 0.9V Discharge diagrams: 1.7 1.7 1.5 1.5 1.4 1.4 V o ltage(V ) V o lta g e (V ) 20Ω 24h/d discharge curve 1.6 300Ω 12h/d discharge curve 1.6 1.3 1.2 1.1 1.3 1.2 1.1 1 1 0.9 0.9 0.8 0.8 0 25 50 75 100 125 150 175 200 225 250 0 2 4 6 hours of service(h) ≤ 0.3 Ω internal resistance: 5 years shelf life: 8 10 under proper storage conditions (ta: ≤ 22°C; RH: 60 ± 15%) no leakage 20Ω continuous discharge for 48h; ta: 20°C; RH: 60±15% high temperature: no leakage store 20days at ta: 60°C; RH:90±5% mechanical specifications: cell dimensions diameter d1: 12.0 diameter d2: 3.7 height h1: 30.2 height h2: 1.3 weight: 9 14 at 1kHz, sine wave measurement according to IEC 896-2 leakage resistance over discharge: operating temperature range: 12 hours of service(h) - 20...60 °C - 1.1 - 0.4 - 1.1 - 0.4 ±1 mm mm mm mm g dimensions: 56 x 71.5mm ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date blister card weight: 10.8g (incl. battery) LR1 (N, AM-5) Alkaline Battery "Hg free" blister package 5015453 701381 TG / 27.06.2018 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice 43
5015453 价格&库存
很抱歉,暂时无法提供与“5015453”相匹配的价格&库存,您可以联系我们找货
