5015663
5015663
    ANSMANN
5015663 数据手册
Alkaline Manganese (Mercury free) IEC: LR6; JIS: AM-3; ANSI: AA; MN1500; Mignon Zn / KOH-H2O / MnO2 battery type: battery size: chemical system: Conditions 1.5 V 1.57...1.62 V 1.55...1.62 V nominal voltage: open circuit voltage: capacity rated: 2900 mAh 2700 mAh minimum: 2550 mAh 800 mAh new battery after 1 year storage at 20°C all measurements at 20°C ambient discharge at 10mA load; 24hours/day End Voltage (EV): 0.8V discharge at 75ohms load; 24hours/day End Voltage (EV): 0.8V discharge at 35mA constant current End Voltage (EV): 0.8V discharge at 1000mA constant current End Voltage (EV): 0.8V typical service output (new batteries) ≥470 cycles discharge at 1000mA; EV: 0.9V discharge 10s/m 1h/d internal resistance: ≥ 88 h discharge at 43Ω resistive load; EV: 0.9V discharge 4h/d ≥ 46 min discharge at 1000mA constant current; EV: 0.9V discharge 24h/d ≥ 19 h discharge at 10Ω resistive load; EV: 0.9V discharge 24h/d ≥ 7.3 h discharge at 250mA; EV: 0.9V discharge 1h/d ≤ 0.2 Ω at 1kHz, sine wave measurement according to IEC 896-2 7 years shelf life: leakage resistance over discharge: high temperature: no leakage no leakage ambient temperature range: recommended storage conditions: mechanical specifications cell dimensions diameter d1: diameter d2: height h1: height h2: weight: under proper storage conditions 10ohms continuous discharge for 48h; ta: 20°C; RH: 60±15% store 20days at ta: 60°C; RH:90±5% - 10...50 °C 5....25 °C 45...75 % 14.4 5.4 50.4 1.7 23 - 0.5 - 0.5 - 0.5 - 0.5 ±2 ambient temperature rel. humidity mm mm mm mm g 43 ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date Alkaline Battery X-Power AA - size 701381 TG / 30.07.2018 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
5015663 价格&库存
很抱歉,暂时无法提供与“5015663”相匹配的价格&库存,您可以联系我们找货
