5035082
5035082
    ANSMANN
    ANSMANN - 5035082 - Rechargeable Battery, Pack of 2, 1.2 V, Nickel Metal Hydride, 2.85 Ah, AA
5035082 数据手册
Conditions NiMH AA cell type: cell size: 1.2 V 1.5 V nominal voltage: max. charge voltage: capacity nominal: minimum: 2850 mAh 2650 mAh 2450 mAh Diagrams standard charge at standard charge (0.1C / 20°C) discharge at 0.2C discharge at 0.2C discharge at 1C 1.0V end discharge voltage ta: 20°C fast charge max. continuous discharge current: 5000 mA ta: 0....45°C charge standard charge: quick charge: fast charge: current 285 mA 800 mA 2850 mA time 14....16hrs 4hrs 1hr recommended charge termination control parameters: 0…5 mV 0.8...1 °C 45...50 °C - ΔV (-deltaV) temperature rise per minute TCO (temperature cut off) trickle charge current: 20…80 mA (recommended) low rate discharge continuous overcharge: (less than 1 year) ≤ 200 mA ≤ 30 mΩ internal resistance: (impedance) no conspicuous deformation no leakage at 1KHz battery fully charged ≥ 500 cycles acc. IEC standard life expectance: self discharge charge retention: ≥ 60 % ≥ 900 mAh initial capacity: ambient temperature range: QCT1: QCT2: 0...45 10...40 20...65 20...50 20...40 20...30 °C °C °C °C °C °C after 28 days storage at 20°C high rate discharge within 30 days after delivery discharge at 0.2C standard charge fast charge discharge storage (≤1month) storage (≤3months) storage (≤12months) 20/2500/35 30/2350/40 mechanical specifications cell dimensions diameter d1: diameter d2: max. height h1: height h2: min. weight: 14.5 - 0.7 5.5 50.5 - 0.5 1.2 31 ± 2 mm mm mm mm g blister card dimensions: 123 x 85 blister card weight (incl. batteries): 70 mm g 35 ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date AA - 2850mAh 2pcs blister package 5035202 701372 TG / 13.06.2018 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
5035082 价格&库存
很抱歉,暂时无法提供与“5035082”相匹配的价格&库存,您可以联系我们找货
