1501-0009
1501-0009
    ANSMANN
    ANSMANN - 1501-0009 - Battery, 1.5 V, AAA, Alkaline, 1.2 Ah, Raised Positive and Flat Negative, 10.4...
1501-0009 数据手册
Alkaline Manganese (Mercury free) IEC: LR03; JIS: AM-4; ANSI: 24A; MN2400; AAA, Micro Zn / KOH-H2O / MnO2 battery type: battery size: chemical system: Conditions 1.5 V 1.57...1.65 V 1.55...1.65 V nominal voltage: open circuit voltage: capacity rated: 1250 mAh 1200 mAh minimum: (for IQC measurement) 17.5 h 32 min new battery after 1 year storage at 20°C all measurements at 20°C ambient discharge at 10mA load; 24hours/day End Voltage (EV): 0.8V discharge at 75ohms load; 4hours/day End Voltage (EV): 0.9V at 20ohms constant resistance discharge 24h/d; End Voltage (EV): 0.9V at 600mA constant current discharge 24h/d; End Voltage (EV): 0.9V typical service output ≤ 0.3 Ω internal resistance: (new battery) 7 years shelf life: leakage resistance over discharge: high temperature: no leakage no leakage ambient temperature range: recommended storage conditions: mechanical specifications cell dimensions diameter d1: diameter d2: height h1: height h2: weight: at 1kHz, sine wave measurement according to IEC 896-2 under proper storage conditions 20ohms continuous discharge for 48h; ta: 20°C; RH: 60±15% store 20days at ta: 60°C; RH:90±5% - 10...50 °C 5....25 °C 45...75 % 10.4 - 0.5 3.6 - 0.4 44.4 - 0.6 1.2 - 0.35 11.5 ± 1.5 ambient temperature rel. humidity mm mm mm mm g 43 ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date High Quality Alkaline Battery AAA - size 701381 TG / 27.06.2019 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
1501-0009 价格&库存
很抱歉,暂时无法提供与“1501-0009”相匹配的价格&库存,您可以联系我们找货
