5013223
5013223
    ANSMANN
5013223 数据手册
battery type: battery size: chemical system: Zinc-Air button cell (hearing aid battery) A10; PR70 Zinc - Air / Zn-O2 Conditions nominal voltage: open circuit voltage: 1.45 V 1.35...1.45 V 1.35...1.45 V capacity new battery (pull off tap min. 30 minutes before measurement) after 1 year storage at 20°C all measurements at 22 ± 2°C ambient typical: 100 mAh minimum: 90 mAh Standard discharge time minimum: Discharge current standard: available current: impulse load voltage: 200 h ditto ditto (for QC measurement) ≤ 1.0 mA 3.0 mA ≥ 1.1 V ≤8 Ω impedance: discharge at 3kΩ load; discharge 24hours/day End Voltage (EV): 0.9V at 1.1V measured after 2s load load resistance 270Ω measured at 1kHz Discharge diagram: shelf life: 4 years operating temperature range: under proper storage conditions (ta: ≤ 22°C; RH: 60 ± 15%) 0....50 °C mechanical specifications: dimensions: Volume: 0.08 cm³ Nominal weight: 0.30 g Blister card dimensions: 44 x 96 mm ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date 103 A10 Zinc Air Battery "mercury free" 6pcs blister package 5013223 703619 TG / 23.03.2015 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
5013223 价格&库存
很抱歉,暂时无法提供与“5013223”相匹配的价格&库存,您可以联系我们找货
