2004-780
2004-780
    MEGGER
    MEGGER - 2004-780 - Voltage Tester, 90V to 600V, LED, -10 °C, 50 °C
2004-780 数据手册
VF3 AC Voltage detector VF3 AC Voltage detector ■■ Exclusive Megger design ■■ Non-contact detection of AC voltage ■■ Automatic audible warning buzzer ■■ Bright red voltage indicator in tip ■■ Ultra bright LED torch ■■ CAT IV 600 V DESCRIPTION The Megger VF3 Voltage detector is a compact pen-style instrument to identify the presence of live AC voltages from 90 V to 600 V at 50 or 60 Hz. Voltage is capacitively detected, signalled on the VF3 by the illumination of a bright red LED situated within the white nylon tip. The VF3 has the additional feature of an audible warning device actuated simultaneously to the red LED. The VF3 incorporates a flashlight torch. Extended battery life is achieved by the use of a bright-white LED. APPLICATION The VF3 can be used for identifying the presence of ac voltage at socket outlets, switches, circuit breakers, fuses, luminaries, wires and cables. It can identify breaks in conductors by tracing along the cable from the source to the point where the indicator no longer illuminates; and also identify a blown fuse while in circuit. SPECIFICATIONS AC voltage (auto-ranging) 90 to 600 V AC 50/60 Hz Torch Ultra bright LED Power supply 2 piles 1,5 V type AAA LR03 Dimensions 178 mm x 26 mm Weight 48 g Environmental Operating temperature range -10 - +50 °C Humidity 90% max. IP rating IP65 Safety CAT IV 600 V Compliance EN 61010-1:2010 ORDERING INFORMATION Description Order Code Box of 12 VF3 voltage detectors UK Archcliffe Road Dover CT17 9EN England T +44 (0) 1304 502101 F +44 (0) 1304 207342 UKsales@megger.com 2004-780 UNITED STATES 4271 Bronze Way Dallas TX 75237-1019 USA T 800 723 2861 (USA only) T +1 214 333 3201 F +1 214 331 7399 USsales@megger.com OTHER TECHNICAL SALES OFFICES Valley Forge USA, College Station USA, Sydney AUSTRALIA, Täby SWEDEN, Ontario CANADA, Trappes FRANCE, Oberursel GERMANY, Aargau SWITZERLAND, Kingdom of BAHRAIN, Mumbai INDIA, Johannesburg SOUTH AFRICA, Chonburi THAILAND 2 CERTIFICATION ISO Registered to ISO 9001:2000 Cert. no. Q 09290 Registered to ISO 14001-1996 Cert. no. EMS 61597 VF3_ds_en_V02 www.megger.com Megger is a registered trademark
2004-780 价格&库存
很抱歉,暂时无法提供与“2004-780”相匹配的价格&库存,您可以联系我们找货
