1002-015
1002-015
    MEGGER
    MEGGER - 1002-015 - Test Lead Kit, Fused, 2 x Fused Test Leads, 2 x Short Probes, 2 x Crocodile Clip...
1002-015 数据手册
1 2 3 4 5 7 6 8 A A RED KIT COMPRISES 1 X RED 3 PIECE 500mA KIT - 1003-159 1 X GREEN 3 PIECE 500mA KIT - 1003-160 1 x USER GUIDE - 2002-855 B BLACK B USER GUIDE (ITEM 5) TO BE PLACED AGAINST BACK FACE OF ACCESSORY BOX (ITEM 4) WITH PRODUCT NAME FACING THE FRONT FACE OF THE BOX. C C NOTES: 1. TAKE LEADS (ITEMS 1, 2) OUT OF PRE PACKED BAGS. 2. REMOVE FUSE HOLDER. FIT 500mA 30kA FUSE (ITEM 3) 3. RETIGHTEN FUSE HOLDER FINGER TIGHT. 4. PLACE NEATLY INTO ACCESSORY BOX. D D BLACK MEGGER SERIAL NUMBER (ITEM 6) LABEL TO BE PLACED ON THE BOTTOM OF BOX AS SHOWN. RED E E BLACK Material RED DIMENSIONS IN MILLIMETRES TOLERANCES UNLESS STATED NOMINAL 0.5 TO 1 DECIMAL PLACE 0.15 ANGULAR 1 HOLES TO BS EN ISO 286-2 H11 INSPECTION DIMENSION Finish Weight First used on 150 g LEADSETS Document type ASSEMBLY DRAWING DO NOT SCALE IF IN DOUBT, ASK! Drawn by Checked by J.Yarwood M.Pollard COLOUR TOLERANCE AS AGREED WITH SUPPLIER AND DEFINED VIA A MASTER SAMPLE © MEGGER INSTRUMENTS LTD. Reproduction in whole or in part without prior permission from the copyright owner is strictly prohibited Title F 1 PCD5768 JY 15/10/2015 Rev CN No. Rev By DATE A3N/E2 1 2 3 4 5 RoHS Part Number Revision Date of Issue FF500mA 30kA (BOXED) 6 1 7 F 1002-015B 2 LEADSET BLACK, RED FUSED Megger Instruments Ltd. Archcliffe Road Dover, Kent CT17 9EN, U.K. www.megger.com  +44 (0) 1304 502100  All materials used for this component MUST be RoHS compliant PROVEN COMPLIANT Scale Sheet 15/10/2015 1:1.5 1/1 8 CONFORMS TO BS 8888/D
1002-015 价格&库存
很抱歉,暂时无法提供与“1002-015”相匹配的价格&库存,您可以联系我们找货
    • 1+4221.70706
    库存:148
