5266CR
5266CR
    MARINCO
    15A 125V 2P 3W SB PLUG CR
5266CR 数据手册
SPECIFICATION SHEET Web site: www.marinco.com Phone: 800-307-6702 Date: January, 2012 Rev: 00 Plug, straight 15A, 125V NEMA 5-15P Catalog Number: 5266CR Item: Plug, straight blade, corrosion-resistant Rating: 15 amperes, 125 volts, NEMA Configuration 5-15P Materials: Housing and plug body are nylon with CTI greater than 600 volts. Blades are solid brass, nickel-plated. Terminals: Tempered brass, lug style, Perma-Lock™ design. Terminals visible through clear end cap. Terminal Identification: Terminal screws are color coded. Ground wire entrance hot stamped green and marked "GR." Line wire entrance hot stamped black. Cord Clamp: Internal. Accommodates 18/3 SJ through 12/3 S cable. Overall Design: Two assembly screws, U-drive style. All screws are combination slot/cross head, stainless steel. Beveled housing, yellow. Dust seal at cord entry. Cable strip length gauge molded into plug body. Listings: UL listed, File E57672 CSA certified, File LR81290 Dimensions: Dimensions shown in inches
5266CR 价格&库存
很抱歉,暂时无法提供与“5266CR”相匹配的价格&库存,您可以联系我们找货
