12VRC.PG
12VRC.PG
    MARINCO
    12V RECEPTACLE W/GASKET
12VRC.PG 数据手册
product specifications for: DC connectors Item #: 12VRC & 12VRC.OEM Description Sealink receptacle, 12 volt Electrical Specifications 12V, 15A Terminals: NEMA .250" quick connect tabs. Material Specifications Housing Material: Nylon Contact Material: Brass Cover: Molded flexible vinyl Mechanical Specification Mounting: Provision for two mounting means. Front mount - provided with mounting plate and black coated stainless steel #6 tapping screws. Rear mount - provided with non-metallic 1-1/8 X 16 UN locknut. Mounting plate not included with 12VRC.OEM Overall Design: Provided with vinyl cap to seal receptacle when not in use. Sealing ring on Marinco Sealink plug (cat. no. 12VPG) provides weather seal while in use. Receptacle provided with recesses to lock Marinco Sealink plug to prevent inadvertent disconnection; disengages when plug is rotated 30°. Dimensions shown in inches.
12VRC.PG 价格&库存
很抱歉,暂时无法提供与“12VRC.PG”相匹配的价格&库存,您可以联系我们找货
