5266.OEM
5266.OEM
    MARINCO
    15A 125V 2P 3W Sb Plug Master/50
5266.OEM 数据手册
SPECIFICATION SHEET Web site: www.marinco.com Phone: 800-307-6702 Date: July, 2011 Rev: 03 Plug, straight 15A, 125V NEMA 5-15P Catalog Number: 5266 Item: Plug, straight blade Rating: 15 amperes, 125 volts, NEMA Configuration 5-15P Materials: Housing and plug body are nylon with CTI greater than 600 volts. Blades are solid brass. Terminals: Tempered brass, lug style, Perma-Lock™ design. Terminals visible through clear end cap. Terminal Identification: Terminal screws are color coded. Ground wire entrance hot stamped green and marked "GR." Line wire entrance hot stamped black. Cord Clamp: Internal. Accommodates 18/3 SJ through 12/3 S cable. Overall Design: Two assembly screws, U-drive style. All screws are combination slot/cross head. Beveled housing. Dust seal at cord entry. Cable strip length gauge molded into plug body. Listings: UL listed, File E57672 CSA certified, File LR81290 Dimensions: Dimensions shown in inches
5266.OEM 价格&库存
很抱歉,暂时无法提供与“5266.OEM”相匹配的价格&库存,您可以联系我们找货
5266.OEM
  • 10+76.6359310+9.94389
  • 25+68.6193925+8.90371
库存:35
