CLS45MRB-F
CLS45MRB-F
    MARINCO
    CLS 45 DEGREE INLET PANEL MOUNT (400A/600V) DOUBLE SET SCREW, MALE
CLS45MRB-F 数据手册
CLS 45 Degree Panel Mounts Item #: CLS45MRB Description CAM CLS 45 Double Set Screw Male Panel Mount Electrical Specifications Max. Amperage: 400A Max. Voltage: 600V AC/DC Short Circuit Rating (SCCR): 35kA (UL 508) Tested at rated voltage with no circuit protection Material Specifications Housing Material: Santoprene TPV Contact Material: One piece solid Brass Temperature Rating: -40°C to 105°C Mechanical Specification Gender: Male Connection Type: Double Set Screw (Torque to 150 in.-lbs., do not over tighten) Cable Range: 2/0 – 4/0 AWG Mounting: Brass eyelet for #10-32 through bolt (Bolts Not Provided) Example: CLS45MRB + = CLS45MRB-A
CLS45MRB-F 价格&库存
很抱歉,暂时无法提供与“CLS45MRB-F”相匹配的价格&库存,您可以联系我们找货
