CS8369-BT1
CS8369-BT1
    MARINCO
    Conn Power Leads 8 AWG ; Region : ACNA
CS8369-BT1 数据手册
2014EDGE CATALOG The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 10018XL – SPED-24 DLX DUAL TRUMPET RUST-PROOF... SPED-24 DLX DUAL TRUMPET RUST-PROOF... Bates Stage Pin (100A / 125V) Femal... Marinco Electrical Group Marinco Electrical Group SPED-24 DLX DUAL TRUMPET RUST-PROOF; RETAIL Bates Stage Pin (100A / 125V) Female Panel Mount Ring Terminal Blue (D) Part Number Weight Min. Quantity 10018XL N-A N-A Weight Min. Quantity 100FR-D N-A N-A HORN, SGL TRUMPET WITH PLASTIC MOTO... Bates Stage Pin (100A / 125V) Femal... Marinco Electrical Group Marinco Electrical Group HORN; SGL TRUMPET WITH PLASTIC MOTOR COVER Part Number Weight Min. Quantity 10028XLP 28 N-A Bates Stage Pin (100A / 125V) Female Panel Mount Double Set Screw Black Part Number Weight Min. Quantity 100FR-DSS N-A N-A 30A EASY LOCK RING Bates Stage Pin (100A / 125V) Femal... Marinco Electrical Group Marinco Electrical Group 30A EASY LOCK RING 2 Part Number Part Number Weight Min. Quantity 100EL 1 N-A Bates Stage Pin (100A / 125V) Female Panel Mount Double Set Screw Red √جø¬Ω Part Number Weight Min. Quantity 100FR-DSS-C N-A N-A Bates Stage Pin (100A / 125V) Femal... Bates Stage Pin (100A / 125V) Femal... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (100A / 125V) Female Inline Bates Stage Pin (100A / 125V) Female Panel Mount Double Set Screw Blue (D) Part Number Weight Min. Quantity 100F N-A N-A Part Number Weight Min. Quantity 100FR-DSS-D N-A N-A Bates Stage Pin (100A / 125V) Femal... Bates Stage Pin (100A / 125V) Femal... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (100A / 125V) Female Panel Mount Ring Terminal 25/ MASTER Bates Stage Pin (100A / 125V) Female Panel Mount CD80 Part Number Weight Min. Quantity 100FR N-A N-A 860-442-4386 Part Number Weight Min. Quantity 100FR.CD80 N-A N-A the edge group • 2014 103RN – 20A/30A CONN. COVER SHORT W/RING GASKET, W/COVER-15A INLET MARINCO L... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (100A / 125V) Male Inline GASKET; W/COVER-15A INLET MARINCO LOGO Part Number Weight Min. Quantity Part Number Weight Min. Quantity 100M N-A N-A 102405 N-A N-A Bates Stage Pin (100A / 125V) Male ... COVER, BASS BOAT INLET Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (100A / 125V) Male Panel Mount Ring Terminal COVER; BASS BOAT INLET Part Number Weight Min. Quantity Part Number Weight Min. Quantity 100MR N-A N-A 102415A N-A N-A Bates Stage Pin (100A / 125V) Male ... 20A/30A PLUG COVER SHORT Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (100A / 125V) Male Panel Mount Double Set Screw 20A/30A PLUG COVER SHORT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 100MR-DSS N-A N-A 102N 4 N-A 30A THREADED RING 20A/30A CONN. COVER SHORT W/EL RING... Marinco Electrical Group Marinco Electrical Group 30A THREADED RING 20A/30A CONN. COVER SHORT W/EL RING; PARK POWER PKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 100R 1 N-A 103ELRV N-A N-A MINI AIR HORN-WHT DIST 2 20A/30A CONN. COVER SHORT W/RING Marinco Electrical Group Marinco Electrical Group MINI AIR HORN-WHT DIST 2 20A/30A CONN. COVER SHORT W/RING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 10104 50 N-A 103RN 4 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s Bates Stage Pin (100A / 125V) Male ... 3 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 103RN.OEM – 20A/30A CONN. COVER SHORT W/RING BU... 20A/30A CONN. COVER SHORT W/RING BU... Bates Stage Pin (100A / 250V) Femal... Marinco Electrical Group Marinco Electrical Group 20A/30A CONN. COVER SHORT W/RING BULK Bates Stage Pin (100A / 250V) Female Panel Mount Double Set Screw Yellow (H) Part Number Weight Min. Quantity 103RN.OEM N-A N-A Weight Min. Quantity 106FR-DSS-H N-A N-A 20A/30A CONN. COVER SHORT W/ RING, ... Bates Stage Pin (100A / 250V) Femal... Marinco Electrical Group Marinco Electrical Group 20A/30A CONN. COVER SHORT W/ RING; PARK POWER PKG Bates Stage Pin (100A / 250V) Female Panel Mount Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity 103RV N-A N-A 106FR-H N-A N-A ADAPTER, W/LED LIGHT Bates Stage Pin (100A / 250V) Femal... Marinco Electrical Group Marinco Electrical Group ADAPTER; W/LED LIGHT 4 Part Number Bates Stage Pin (100A / 250V) Female Panel Mount Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity 104SPP 25 N-A 106FRAC-H N-A N-A ADAPTER, W/LED LIGHT PARK POWER PAC... Bates Stage Pin (100A / 250V) Male ... Marinco Electrical Group Marinco Electrical Group ADAPTER; W/LED LIGHT PARK POWER PACKAGING Bates Stage Pin (100A / 250V) Male Inline Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity 104SPPRV N-A N-A 106M-H N-A N-A Bates Stage Pin (100A / 250V) Femal... Bates Stage Pin (100A / 250V) Male ... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (100A / 250V) Female Inline Bates Stage Pin (100A / 250V) Male Panel Mount Double Set Screw Yellow (H) Part Number Weight Min. Quantity 106F-H N-A N-A 860-442-4386 Part Number Weight Min. Quantity 106MR-DSS-H N-A N-A the edge group • 2014 117A – 30A PLUG - ADAPTER CONCEALED - COMPACT SINGL FREQUENCY... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (100A / 250V) Male Panel Mount Yellow (H) CONCEALED - COMPACT SINGL FREQUENCY 415 +/- 20 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 106MR-H N-A N-A 11050 N-A N-A SPE-24 DELUXE SNGL TRUMP RUST-PROOF... 30A SEALING COLLAR WITH RING Marinco Electrical Group Marinco Electrical Group SPE-24 DELUXE SNGL TRUMP RUST-PROOF; BULK Bat teries/ Fl a shlights/Charger s Bates Stage Pin (100A / 250V) Male ... 30A SEALING COLLAR WITH RING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 11017XLP N-A N-A 110R 3 N-A SPED-24 DELUXE DUAL TRUMP RUST-PROO... 30A PLUG - ADAPTER Marinco Electrical Group Marinco Electrical Group SPED-24 DELUXE DUAL TRUMP RUST-PROOF; BULK 30A PLUG - ADAPTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity 11018XLP N-A N-A 111A 34 N-A SL BLACK COMPACT SINGLE DROP-IN GRILL, CHROME, SNAP-IN MODE... Marinco Electrical Group Marinco Electrical Group SL BLACK COMPACT SINGLE DROP-IN GRILL; CHROME; SNAP-IN MODEL Part Number Weight Min. Quantity Part Number Weight Min. Quantity 11023 N-A N-A 11225 N-A N-A HORN, SGL TRUMPET 12-VOLT BULK 30A PLUG - ADAPTER Marinco Electrical Group Marinco Electrical Group HORN; SGL TRUMPET 12-VOLT BULK 30A PLUG - ADAPTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity 11028XLP N-A N-A 117A 34 N-A 860-442-4386 5 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 121A – 30A CONNECTOR - ADAPTER 30A CONNECTOR - ADAPTER 12V DUAL OUTLET ADAPTER Marinco Electrical Group Marinco Electrical Group 30A CONNECTOR - ADAPTER 12V DUAL OUTLET ADAPTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity 121A 44 N-A 12VAD 8 N-A ADAPTER, RV 30APLG/50ACON TROLL MTR, PLUG Marinco Electrical Group Marinco Electrical Group ADAPTER; RV 30APLG/50ACON TROLL MTR; PLUG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 124ARV N-A N-A 12VBP 3 N-A ADAPTER, L5-30 PLUG TO 30A RV CONN.... TROLL MTR, PLUG BULK Marinco Electrical Group Marinco Electrical Group ADAPTER; L5-30 PLUG TO 30A RV CONN. YEL AFTRMKT 6 TROLL MTR; PLUG BULK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 125A N-A N-A 12VBP.OEM 0.15 N-A BRACKET, MOUNTING, 12V RECEPT TROLL MTR, PLUG W/SINGLE HOLE Marinco Electrical Group Marinco Electrical Group BRACKET; MOUNTING; 12V RECEPT TROLL MTR; PLUG W/SINGLE HOLE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12BKT 2 N-A 12VBPS 0.162 N-A 12V RECEPTL. MOUNT. PLATE CONNECT PRO, PLUG, 2 WIRE Marinco Electrical Group Marinco Electrical Group 12V RECEPTL. MOUNT. PLATE CONNECT PRO; PLUG; 2 WIRE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12MP.OEM 0.02 N-A 12VBPS2 3 N-A 860-442-4386 the edge group • 2014 12VPK – 12V PLUG & RECEPT COMBO TROLL MTR, PLUG AND RECPT Marinco Electrical Group Marinco Electrical Group CONNECT PRO; PLUG; 2 WIRE TROLL MTR; PLUG AND RECPT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12VBPS2.OEM N-A N-A 12VCP 6 N-A TROLL MTR, RECEPTACLE CONNECT PRO, COMBO 2 WIRE PLUG & CO... Marinco Electrical Group Marinco Electrical Group TROLL MTR; RECEPTACLE Bat teries/ Fl a shlights/Charger s CONNECT PRO, PLUG, 2 WIRE CONNECT PRO; COMBO 2 WIRE PLUG & CONNECTOR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12VBR 1 N-A 12VCPS2 5 N-A TROLL MTR, RECEPTACLE 12V PLUG Marinco Electrical Group Marinco Electrical Group TROLL MTR; RECEPTACLE 12V PLUG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12VBR.OEM 0.09 N-A 12VPG 1 N-A CONNECT PRO, RECEP 2-WIRE 12V PLUG / .OEM PACK Marinco Electrical Group Marinco Electrical Group CONNECT PRO; RECEP 2-WIRE 12V PLUG / .OEM PACK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12VBRS2 1 N-A 12VPG.OEM 0.08 N-A CONNECT PRO, RECEP 2-WIRE 12V PLUG & RECEPT COMBO Marinco Electrical Group Marinco Electrical Group CONNECT PRO; RECEP 2-WIRE 12V PLUG & RECEPT COMBO Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12VBRS2.OEM N-A N-A 12VPK 3 N-A 860-442-4386 7 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 12VRC – 12V RECEPT 12V RECEPT 12V RECEPTACLE SNAP-IN Marinco Electrical Group Marinco Electrical Group 12V RECEPT 12V RECEPTACLE SNAP-IN Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12VRC 2 N-A 12VRCSP.OEM 0.064 N-A 12V RECEPT .OEM PACK 12V RECEPT W/POLARIZED LEADS AND SL... Marinco Electrical Group Marinco Electrical Group 12V RECEPT .OEM PACK 12V RECEPT W/POLARIZED LEADS AND SLIDE LOCK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12VRC.OEM 0.08 N-A 12VRCTT.OEM 0.0784 N-A 12V RECEPTACLE W/GASKET 12V RECEPT. WHITE Marinco Electrical Group Marinco Electrical Group 12V RECEPTACLE W/GASKET 8 12V RECEPT. WHITE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12VRC.PG N-A N-A 12VRCW N-A N-A 12V RECEPT W/OLD LCKG NUT OEM PACK 12V RECEPT. WHITE BULK Marinco Electrical Group Marinco Electrical Group 12V RECEPT W/OLD LCKG NUT OEM PACK 12V RECEPT. WHITE BULK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12VRCO N-A N-A 12VRCW.OEM N-A N-A 12V RECEPTACLE W/PARK PWR PACKAGING 12V RECEPT W/WEEP HOLE ***NO INSTR... Marinco Electrical Group Marinco Electrical Group 12V RECEPTACLE W/PARK PWR PACKAGING 12V RECEPT W/WEEP HOLE ***NO INSTRUCTION SHEET*** Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12VRCRV N-A N-A 12VRCY N-A N-A 860-442-4386 the edge group • 2014 150BBIW.RV – 15A 125V RV INLET WHITE W/PARK POWE... BASS BOAT INLET FRONT MNT 15A 125V Marinco Electrical Group Marinco Electrical Group TERMINAL; BATTERY PKG BASS BOAT INLET FRONT MNT 15A 125V Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12VTR 4 N-A 150BBI.OEM N-A N-A SEALINK RECEPTACLE WITH BATTERY CLI... 15A 125V RV INLET Marinco Electrical Group Marinco Electrical Group SEALINK RECEPTACLE WITH BATTERY CLIPS Bat teries/ Fl a shlights/Charger s TERMINAL, BATTERY PKG 15A 125V RV INLET Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12VXC 10 N-A 150BBI.RV N-A N-A 12V EXTENSION CORD, 6’ BASS BOAT INLET FRONT MNT 15A 125V ... Marinco Electrical Group Marinco Electrical Group 12V EXTENSION CORD; 6’ BASS BOAT INLET FRONT MNT 15A 125V WHITE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 12VXT 9 N-A 150BBIW N-A N-A BASS BOAT INLET FRONT MNT 15A 125V BASS BOAT INLET FRONT MNT 15A 125V ... Marinco Electrical Group Marinco Electrical Group BASS BOAT INLET FRONT MNT 15A 125V BASS BOAT INLET FRONT MNT 15A 125V WHITE BULK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 150BBI 5 N-A 150BBIW.OEM N-A N-A BASS BOAT INLET REAR MNT 15A 125V 15A 125V RV INLET WHITE W/PARK POWE... Marinco Electrical Group Marinco Electrical Group BASS BOAT INLET REAR MNT 15A 125V 15A 125V RV INLET WHITE W/PARK POWER PACKAGING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 150BBI-TM N-A N-A 150BBIW.RV N-A N-A 860-442-4386 9 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 150CC.OEM – CONNECT CHARGE, FRONT MOUNT W/PVC C... CONNECT CHARGE, FRONT MOUNT W/PVC C... CONNECT CHARGE, FRONT MNT W/FLIP LI... Marinco Electrical Group Marinco Electrical Group CONNECT CHARGE; FRONT MOUNT W/PVC COVER CONNECT CHARGE; FRONT MNT W/FLIP LID Part Number Weight Min. Quantity Part Number Weight Min. Quantity 150CC.OEM N-A N-A 150GCA.OEM N-A N-A CONNECT CHARGE, FRNT/REAR MOUNT W/P... CONNECT CHARGE, REAR MNT FOR GEM, B... Marinco Electrical Group Marinco Electrical Group CONNECT CHARGE; FRNT/REAR MOUNT W/PVC COVER Weight Min. Quantity Part Number Weight Min. Quantity 150CCI 4 N-A 150GCTM.BLK N-A N-A CONNECT CHARGE, REAR MNT W/PVC COVE... CONNECT CHARGE, REAR MNT W/FLIP LID Marinco Electrical Group Marinco Electrical Group CONNECT CHARGE; REAR MNT W/PVC COVER 10 CONNECT CHARGE; REAR MNT FOR GEM; BLANK/NO LOGO Part Number CONNECT CHARGE; REAR MNT W/FLIP LID Part Number Weight Min. Quantity Part Number Weight Min. Quantity 150CCTM.OEM N-A N-A 150GCTM.OEM N-A N-A CONNECT CHARGE, REAR MNT BLANK COVE... 50A CONNECTOR - ADAPTER Marinco Electrical Group Marinco Electrical Group CONNECT CHARGE; REAR MNT BLANK COVER 50A CONNECTOR - ADAPTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity 150CCTMB N-A N-A 150SPPRV N-A N-A CONNECT CHARGE, FRONT MNT W/BLANK F... PWR CRD 15A 125V CONN CHG 14/3 SJTW... Marinco Electrical Group Marinco Electrical Group CONNECT CHARGE; FRONT MNT W/BLANK FLIP LID PWR CRD 15A 125V CONN CHG 14/3 SJTW 24 STRIP & R Part Number Weight Min. Quantity Part Number Weight Min. Quantity 150GCA.BLK N-A N-A 152400-01 N-A N-A 860-442-4386 the edge group • 2014 15CLM – CLM Series Inline Single Pin Connec... PWR CRD 15A 125V CONN CHG 14/3 SJTW... Marinco Electrical Group Marinco Electrical Group PWR CRD 15A 125V CONN CHG 14/3 SJTW 24 IEC C15 PWR CRD 15A 125V CONN CHG 14/3 SJTW 72 IEC C15 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 152400-03 N-A N-A 157200-03 N-A N-A Y ADAPTER Y ADAPTER Marinco Electrical Group Marinco Electrical Group Y ADAPTER Y ADAPTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity 153AY 93 N-A 157AY 74 N-A PWR CRD 15A 125V CONN CHG 14/3 SJTW... INTERRUPTER DUPLEX/ RECEPTACLE Marinco Electrical Group Marinco Electrical Group PWR CRD 15A 125V CONN CHG 14/3 SJTW 48 STRIP & R INTERRUPTER DUPLEX/ RECEPTACLE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 154800-01 N-A N-A 1591-FI.WHITE 5 N-A PWR CRD 15A 125V CONN CHG 14/3 SJTW... CLM Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group PWR CRD 15A 125V CONN CHG 14/3 SJTW 48 IEC C15 CLM Series Inline Single Pin Connectors (150A / 600V) Female Extraction Tool Part Number Weight Min. Quantity 154800-03 N-A N-A Part Number Weight Min. Quantity 15CLF N-A N-A PWR CRD 15A 125V CONN CHG 14/3 SJT ... CLM Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group PWR CRD 15A 125V CONN CHG 14/3 SJT 72 STRIP & RET CLM Series Inline Single Pin Connectors (150A / 600V) Male Extraction Tool Part Number Weight Min. Quantity 157200-01 N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s PWR CRD 15A 125V CONN CHG 14/3 SJTW... Part Number Weight Min. Quantity 15CLM N-A N-A 11 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 15RA – 15A RIGHT ANGLE HOUSING 15A RIGHT ANGLE HOUSING Guest ICS On-Board Battery Charger ... Marinco Electrical Group Marinco Electrical Group 15A RIGHT ANGLE HOUSING Guest ICS On-Board Battery Charger 20A (10/10) / 12/24V; 2 Bank; 120V Input Part Number Weight Min. Quantity 15RA 0.068 N-A Weight Min. Quantity 16202 N-A N-A 15A RIGHT ANGLE HOUSING WITH NO LOG... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group 15A RIGHT ANGLE HOUSING WITH NO LOGO Part Number Weight Min. Quantity 15RAB N-A N-A CLS Series Inline Single Pin Connectors (400A / 600V) Female Extraction Tool Part Number Weight Min. Quantity 16CLF N-A N-A Guest ICS On-Board Battery Charger ... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group Guest ICS On-Board Battery Charger 6A / 12V; 1 Bank; 120V Input 12 Part Number Part Number Weight Min. Quantity 16061 N-A N-A CLS Series Inline Single Pin Connectors (400A / 600V) Male Extraction Tool Part Number Weight Min. Quantity 16CLM N-A N-A Guest ICS On-Board Battery Charger ... ADAPTER, 50A/125/250V TO 30A 125V R... Marinco Electrical Group Marinco Electrical Group Guest ICS On-Board Battery Charger 12A (6/6) / 12/24V; 2 Bank; 120V Input ADAPTER; 50A/125/250V TO 30A 125V RV YELLOW Part Number Weight Min. Quantity 16102 N-A N-A Part Number Weight Min. Quantity 173ARV N-A N-A Guest ICS On-Board Battery Charger ... 30A, 25’ CORDSET, LED ERGO GRIP Marinco Electrical Group Marinco Electrical Group Guest ICS On-Board Battery Charger 18A (6/6/6) / 12/24/36V; 3 Bank; 120V Input 30A; 25’ CORDSET; LED ERGO GRIP Part Number Weight Min. Quantity 16153 N-A N-A 860-442-4386 Part Number Weight Min. Quantity 199117 N-A N-A the edge group • 2014 199208 – Cable Tie, 11’’, Natural 25pc Cable Tie, 8’’, Natural, 25pc Marinco Electrical Group Marinco Electrical Group ADAPTER; 30A TO 15A GFCI 30A LKG PLUG TO 15A CONN Cable Tie; 8; Natural; 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199128 N-A N-A 199204 N-A N-A Cable Tie, 4’’, Natural, 25pc Cable Tie, 8’’, Natural, 100pc Marinco Electrical Group Marinco Electrical Group Cable Tie; 4; Natural; 25pc Cable Tie; 8; Natural; 100pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199200 N-A N-A 199205 N-A N-A Cable Tie, 4’’, Natural, 100pc Cable Tie, 8’’, UVB, 25pc Marinco Electrical Group Marinco Electrical Group Cable Tie; 4; Natural; 100pc Bat teries/ Fl a shlights/Charger s ADAPTER, 30A TO 15A GFCI 30A LKG PL... Cable Tie; 8; UVB; 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199201 N-A N-A 199206 N-A N-A Cable tie, 4’’, UVB, 25pc Cable Tie, 8’’, UVB, 100pc Marinco Electrical Group Marinco Electrical Group Cable tie; 4; UVB; 25pc Cable Tie; 8; UVB; 100pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199202 N-A N-A 199207 N-A N-A Cable Tie, 4’’, UVB, 100pc Cable Tie, 11’’, Natural 25pc Marinco Electrical Group Marinco Electrical Group Cable Tie; 4; UVB; 100pc Cable Tie; 11; Natural 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199203 N-A N-A 199208 N-A N-A 860-442-4386 13 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 199209 – Cable Tie, 11’’, Natural 100pc Cable Tie, 11’’, Natural 100pc Cable Tie, 14’’, UVB, 25pc Marinco Electrical Group Marinco Electrical Group Cable Tie; 11; Natural 100pc Cable Tie; 14; UVB; 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199209 N-A N-A 199214 N-A N-A Cable Tie, 11’’, UVB, 25pc Cable Tie, 14’’, UVB, 100pc Marinco Electrical Group Marinco Electrical Group Cable Tie; 11; UVB; 25pc Cable Tie; 14; UVB; 100pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199210 N-A N-A 199215 N-A N-A Cable Tie, 11’’, UVB, 100pc Hvy Dty Cable Tie, 17’’, Natural, 1... Marinco Electrical Group Marinco Electrical Group Cable Tie; 11; UVB; 100pc 14 Hvy Dty Cable Tie; 17; Natural; 10pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199211 N-A N-A 199216 N-A N-A Cable Tie, 14’’, Natural, 25pc Hvy Dty Cable Tie, 17’’, UVB, 10pc Marinco Electrical Group Marinco Electrical Group Cable Tie; 14; Natural; 25pc Hvy Dty Cable Tie; 17; UVB; 10pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199212 N-A N-A 199217 N-A N-A Cable Tie, 14’’, Natural, 100pc Hvy Dty Cable Tie, 24’’, Natural, 1... Marinco Electrical Group Marinco Electrical Group Cable Tie; 14; Natural; 100pc Hvy Dty Cable Tie; 24; Natural; 10pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199213 N-A N-A 199218 N-A N-A 860-442-4386 the edge group • 2014 199228 – Mounting Cable Tie, 8’’, UVB, 25pc Cable Tie, 8’’, Assorted, 24pc Marinco Electrical Group Marinco Electrical Group Hvy Dty Cable Tie; 24; UVB; 10pc Cable Tie; 8; Assorted; 24pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199219 N-A N-A 199224 N-A N-A Hvy Dty Cable Tie, 36’’, Natural, 1... Cable Tie, Assorted, 500pc Marinco Electrical Group Marinco Electrical Group Hvy Dty Cable Tie; 36; Natural; 10pc Cable Tie; Assorted; 500pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199220 N-A N-A 199225 N-A N-A Hvy Dty Cable Tie, 36’’, UVB, 10pc Mounting Cable Tie, 8’’, Natural, ... Marinco Electrical Group Marinco Electrical Group Hvy Dty Cable Tie; 36; UVB; 10pc Bat teries/ Fl a shlights/Charger s Hvy Dty Cable Tie, 24’’, UVB, 10pc Mounting Cable Tie; 8; Natural; 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199221 N-A N-A 199226 N-A N-A Hvy Dty Cable Tie, 48’’, Natural, 1... Mounting Cable Tie, 8’’, Natural, 1... Marinco Electrical Group Marinco Electrical Group Hvy Dty Cable Tie; 48; Natural; 10pc Mounting Cable Tie; 8; Natural; 100pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199222 N-A N-A 199227 N-A N-A Hvy Dty Cable Tie, 48’’, UVB, 10pc Mounting Cable Tie, 8’’, UVB, 25pc Marinco Electrical Group Marinco Electrical Group Hvy Dty Cable Tie; 48; UVB; 10pc Mounting Cable Tie; 8; UVB; 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199223 N-A N-A 199228 N-A N-A 860-442-4386 15 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 199229 – Mounting Cable Tie, 8’’, UVB, 100pc Mounting Cable Tie, 8’’, UVB, 100pc Adhesive Moutning Base, Natural, 25... Marinco Electrical Group Marinco Electrical Group Mounting Cable Tie; 8; UVB; 100pc Adhesive Moutning Base; Natural; 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199229 N-A N-A 199234 N-A N-A Mounting Cable Tie, 14’’, Natural,... Adhesive Mounting Base, UVB, 5pc Marinco Electrical Group Marinco Electrical Group Mounting Cable Tie; 14; Natural; 25pc Adhesive Mounting Base; UVB; 5pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199230 N-A N-A 199235 N-A N-A Cable Tie Mount, #8 Screw, Natural,... Adhesive Mounting Base, UVB, 25pc Marinco Electrical Group Marinco Electrical Group Cable Tie Mount; #8 Screw; Natural; 25pc 16 Adhesive Mounting Base; UVB; 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199231 N-A N-A 199236 N-A N-A Cable Tie Mount, #8 Screw , Natural... ID Cable Tie, 8’’, Natural, 25pc Marinco Electrical Group Marinco Electrical Group Cable Tie Mount; #8 Screw ; Natural; 100pc ID Cable Tie; 8; Natural; 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199232 N-A N-A 199237 N-A N-A Adhesive Mounting Base, Natural, 5p... Stainless Steel Cable Tie, 11’’, 1... Marinco Electrical Group Marinco Electrical Group Adhesive Mounting Base; Natural; 5pc Stainless Steel Cable Tie; 11; 10pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199233 N-A N-A 199238 N-A N-A 860-442-4386 the edge group • 2014 199249 – Cable Tie, 6’’, UVB, 100pc Mounting Cable Tie, 4’’, UVB, 25pc Marinco Electrical Group Marinco Electrical Group Grip Strip; 11; Black; 5pc Mounting Cable Tie; 4; UVB; 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199239 N-A N-A 199245 N-A N-A Releaseable Cable Tie, 8’’, Natural... Cable Tie, 6’’, Natural, 25pc Marinco Electrical Group Marinco Electrical Group Releaseable Cable Tie; 8; Natural; 25pc Cable Tie; 6; Natural; 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199240 N-A N-A 199246 N-A N-A Releaseable Cable Tie, 8’’, UVB, 25... Cable Tie, 6’’, Natural, 100pc Marinco Electrical Group Marinco Electrical Group Releaseable Cable Tie; 8; UVB; 25pc Bat teries/ Fl a shlights/Charger s Grip Strip, 11’’, Black, 5pc Cable Tie; 6; Natural; 100pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199241 N-A N-A 199247 N-A N-A Releaseable Cable Tie, 16’’, UVB, 4... Cable Tie, 6’’, UVB, 25pc Marinco Electrical Group Marinco Electrical Group Releaseable Cable Tie; 16; UVB; 4pc Cable Tie; 6; UVB; 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199242 N-A N-A 199248 N-A N-A Releaseable Cable Tie, 28’’, UVB, 3... Cable Tie, 6’’, UVB, 100pc Marinco Electrical Group Marinco Electrical Group Releaseable Cable Tie; 28; UVB; 3pc Cable Tie; 6; UVB; 100pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199243 N-A N-A 199249 N-A N-A 860-442-4386 17 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 199250 – Mounting Cable Tie, 6’’, Natural, 2... Mounting Cable Tie, 6’’, Natural, 2... Cable Tie, 14’’, UVB, 1000pc Marinco Electrical Group Marinco Electrical Group Mounting Cable Tie; 6; Natural; 25pc Cable Tie; 14; UVB; 1000pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199250 N-A N-A 199256 N-A N-A Mounting Cable Tie, 6’’, Natural, 1... Mounting Cable Tie, 14’’, UVB, 25pc Marinco Electrical Group Marinco Electrical Group Mounting Cable Tie; 6; Natural; 100pc Mounting Cable Tie; 14; UVB; 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199251 N-A N-A 199257 N-A N-A Moutning Cable tie, 6’’, UVB, 25pc Mounting Cable Tie, 14’’, UVB, 100... Marinco Electrical Group Marinco Electrical Group Moutning Cable tie; 6; UVB; 25pc 18 Mounting Cable Tie; 14; UVB; 100pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199252 N-A N-A 199258 N-A N-A Mounting Cable Tie, 6’’, UVB, 100pc Hvy Dty Cable Tie, 15’’, UVB, 25pc Marinco Electrical Group Marinco Electrical Group Mounting Cable Tie; 6; UVB; 100pc Hvy Dty Cable Tie; 15; UVB; 25pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199253 N-A N-A 199259 N-A N-A Cable Tie, 8’’, UVB, 1000pc Hvy Dty Cable Tie, 15’’, UVB, 100pc Marinco Electrical Group Marinco Electrical Group Cable Tie; 8; UVB; 1000pc Hvy Dty Cable Tie; 15; UVB; 100pc Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199254 N-A N-A 199260 N-A N-A 860-442-4386 the edge group • 2014 2014FO – 20A 125/250V FLG OUTLET LKG BASS BOAT INLET FRONT MNT 20A 125V ... Marinco Electrical Group Marinco Electrical Group Cable Tie; 4-8; Nat/UVB; 25pc BASS BOAT INLET FRONT MNT 20A 125V WHITE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199261 N-A N-A 200BBIW.OEM N-A N-A CABLE TIE MOUNT, #10 SCREW, 25 INLET, RV FRONT MNT WHITE 20A 125V Marinco Electrical Group Marinco Electrical Group CABLE TIE MOUNT; #10 SCREW; 25 INLET; RV FRONT MNT WHITE 20A 125V Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199262 N-A N-A 200BBIW.RV N-A N-A CABLE TIE MOUNT, #10 SCREW, 100 20A CONNECTOR, 125/250V LOCKNG Marinco Electrical Group Marinco Electrical Group CABLE TIE MOUNT; #10 SCREW; 100 Bat teries/ Fl a shlights/Charger s Cable Tie, 4-8’’, Nat/UVB, 25pc 20A CONNECTOR; 125/250V LOCKNG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 199263 N-A N-A 2014C 0.27 N-A RECEPT, 15A 250V DUPLEX LEVITON # 4... 20A 125/250V FLANGED INLET LKG Marinco Electrical Group Marinco Electrical Group RECEPT; 15A 250V DUPLEX LEVITON # 4550 BLACK 20A 125/250V FLANGED INLET LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 200183 N-A N-A 2014FI 0.16 N-A INLET, RV FRONT MNT BLACK 20A 125V 20A 125/250V FLG OUTLET LKG Marinco Electrical Group Marinco Electrical Group INLET; RV FRONT MNT BLACK 20A 125V 20A 125/250V FLG OUTLET LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 200BBI.RV N-A N-A 2014FO 0.2 N-A 860-442-4386 19 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 2014P – 20A PLUG, 125/250V LOCKING 20A PLUG, 125/250V LOCKING 20A 250V 3 FLANGED INLET LKG Marinco Electrical Group Marinco Electrical Group 20A PLUG; 125/250V LOCKING 20A 250V 3 FLANGED INLET LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2014P 0.21 N-A 2015FI 0.16 N-A 20A PLUG, 125/250V LOCKING MASTER/5... 20A 250V 3 FLANGED OUTLET LKG Marinco Electrical Group Marinco Electrical Group 20A PLUG; 125/250V LOCKING MASTER/50 20A 250V 3 FLANGED OUTLET LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2014P.OEM 0.21 N-A 2015FO 0.2 N-A 20A 125/250V RECEPTACLE, LOCK 20A 250V 3PH FLANGED OUTLET, SEE NO... Marinco Electrical Group Marinco Electrical Group 20A 125/250V RECEPTACLE; LOCK 20 20A 250V 3PH FLANGED OUTLET; SEE NOTE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2014R 0.22 N-A 2015FO-AM1 N-A N-A 20A 125/250V RECEPTACLE, LOCK MASTE... 20A PLUG, 250V 3 LOCKING Marinco Electrical Group Marinco Electrical Group 20A 125/250V RECEPTACLE; LOCK MASTER/50 20A PLUG; 250V 3 LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2014R.OEM.NMS 0.22 N-A 2015P 0.21 N-A 20A 250V 3 CONNECTOR LOCKING POWER CORD, 6’ 12/4 STO CRIMP TERM,... Marinco Electrical Group Marinco Electrical Group 20A 250V 3 CONNECTOR LOCKING POWER CORD; 6’ 12/4 STO CRIMP TERM; BLUNT CUT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2015C 0.27 N-A 2015P-AK3 N-A N-A 860-442-4386 the edge group • 2014 2016C – 20A CONNECTOR, 480V 3 LOCKING POWER CORD, 6-1/2’ 12/4 STO GRAY, C... Marinco Electrical Group Marinco Electrical Group POWER CORD; 10’ 12/4 SEOW BLACK CRIMP; BLUNT CUT POWER CORD; 6-1/2’ 12/4 STO GRAY; CRIMP Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2015P-AK8 N-A N-A 2015P-DA1 N-A N-A POWER CORD, 5’ 14/4 STO CRIMP TERM,... POWER CORD, 6’5’’ 12/3 STO GRAY, CR... Marinco Electrical Group Marinco Electrical Group POWER CORD; 5’ 14/4 STO CRIMP TERM; BLUNT CUT POWER CORD; 6’5 12/3 STO GRAY; CRIMP Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2015P-AM1 N-A N-A 2015P-DA3 N-A N-A POWER CORD, 14AWG AMPHENOL CONNECTO... 20A 250V 3 RECEPTACLE, LOCK Marinco Electrical Group Marinco Electrical Group POWER CORD; 14AWG AMPHENOL CONNECTOR Bat teries/ Fl a shlights/Charger s POWER CORD, 10’ 12/4 SEOW BLACK CRI... 20A 250V 3 RECEPTACLE; LOCK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2015P-AM11 N-A N-A 2015R 0.22 N-A 20A 250V PLUG W/ 58’’ 14/4 STO GRAY 20A 250V 3PHASE RECEPTACLE LKG Marinco Electrical Group Marinco Electrical Group 20A 250V PLUG W/ 58 14/4 STO GRAY 20A 250V 3PHASE RECEPTACLE LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2015P-AM5 N-A N-A 2015R-AM1 N-A N-A POWER CORD, 58’’ 14/4 STO GRAY 20A CONNECTOR, 480V 3 LOCKING Marinco Electrical Group Marinco Electrical Group POWER CORD; 58 14/4 STO GRAY 20A CONNECTOR; 480V 3 LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2015P-AM6 N-A N-A 2016C 0.27 N-A 860-442-4386 21 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 2016P – 20A PLUG, 480V 3 LOCKING 20A PLUG, 480V 3 LOCKING 20A 120/208V 3 CONNECTOR LKG Marinco Electrical Group Marinco Electrical Group 20A PLUG; 480V 3 LOCKING 20A 120/208V 3 CONNECTOR LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2016P 0.21 N-A 2021C 0.27 N-A 20A 480V 3 RECEPTACLE, LOCK 20A 120/208V 3 CONNECTOR LKG MASTER... Marinco Electrical Group Marinco Electrical Group 20A 480V 3 RECEPTACLE; LOCK 20A 120/208V 3 CONNECTOR LKG MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2016R 0.22 N-A 2021C.OEM 0.27 N-A 12V BASS PLUG 20A 120/208V 3 PLUG LOCKING Marinco Electrical Group Marinco Electrical Group 12V BASS PLUG 22 20A 120/208V 3 PLUG LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2018BP-12.OEM N-A N-A 2021P 0.21 N-A RECEPTACLE, 12/24V BASS BOAT CORDSET, 35’’ 16/5 SEOW BLACK Marinco Electrical Group Marinco Electrical Group RECEPTACLE; 12/24V BASS BOAT CORDSET; 35 16/5 SEOW BLACK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2018BR.OEM N-A N-A 2021P-AM4 N-A N-A BRACKET, MOUNTING, FLIP LID 20A 120/208V 3 Y RECEPT LKG Marinco Electrical Group Marinco Electrical Group BRACKET; MOUNTING; FLIP LID 20A 120/208V 3 Y RECEPT LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2018MB 2 N-A 2021R 0.22 N-A 860-442-4386 the edge group • 2014 205P – 20A 125V PLUG, LOCKING 20A CONN LOCK, COR. REST. SHORT HOU... Marinco Electrical Group Marinco Electrical Group FLIP LID FOR 20/30A RECPT CUSTOM 20A CONN LOCK; COR. REST. SHORT HOUSING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2030FL N-A N-A 205CCRS 0.27 N-A 20A 125V CONN, LOCKING 20A 125V CONN, LOCKING W/NEON BULB Marinco Electrical Group Marinco Electrical Group 20A 125V CONN; LOCKING 20A 125V CONN; LOCKING W/NEON BULB Part Number Weight Min. Quantity Part Number Weight Min. Quantity 205C 0.34 N-A 205CL N-A N-A 20A CONNECTOR, LOCKING MASTER/50 20A 125V FLANGED INLET LOCKING Marinco Electrical Group Marinco Electrical Group 20A CONNECTOR; LOCKING MASTER/50 Bat teries/ Fl a shlights/Charger s FLIP LID FOR 20/30A RECPT CUSTOM 20A 125V FLANGED INLET LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 205C.OEM 0.27 N-A 205FI 0.16 N-A 20A 125V CONN, LOCKING BLACK 20A 125V FLANGED OUTLET LKG Marinco Electrical Group Marinco Electrical Group 20A 125V CONN; LOCKING BLACK 20A 125V FLANGED OUTLET LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 205CBL 0.27 N-A 205FO 0.2 N-A 20A 12V CONN, LOCKING BLACK MASTER/... 20A 125V PLUG, LOCKING Marinco Electrical Group Marinco Electrical Group 20A 12V CONN; LOCKING BLACK MASTER/50 20A 125V PLUG; LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 205CBL.OEM 0.27 N-A 205P 0.25 N-A 860-442-4386 23 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 205P.OEM – 20A PLUG, LOCKING MASTER/50 20A PLUG, LOCKING MASTER/50 20A 125V PLUG, LKG W/NEON BULB Marinco Electrical Group Marinco Electrical Group 20A PLUG; LOCKING MASTER/50 20A 125V PLUG; LKG W/NEON BULB Part Number Weight Min. Quantity Part Number Weight Min. Quantity 205P.OEM 0.21 N-A 205PL N-A N-A 20A 125V PLUG, LOCKING NO CORD CLAM... 20A 125V RECEPTACLE, LOCKING Marinco Electrical Group Marinco Electrical Group 20A 125V PLUG; LOCKING NO CORD CLAMP INSERT MASTER/50 Weight Min. Quantity Part Number Weight Min. Quantity 205P.OEM.NI 0.21 N-A 205R 0.22 N-A 20A 125V PLUG, LKG BLACK RECPT, 20A 125V LK N/EARS MASTER/50 Marinco Electrical Group Marinco Electrical Group 20A 125V PLUG; LKG BLACK 24 20A 125V RECEPTACLE; LOCKING Part Number RECPT; 20A 125V LK N/EARS MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 205PBL 0.21 N-A 205R.OEM.NE 0.21 N-A 20A 125V PLUG,LOCKING BLK MASTER/50 20A 125V RECEPTACLE, LOCKING (dis) ... Marinco Electrical Group Marinco Electrical Group 20A 125V PLUG;LOCKING BLK MASTER/50 20A 125V RECEPTACLE; LOCKING (dis) MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 205PBL.OEM 0.21 N-A 205R.OEM.NMS 0.22 N-A 20A PLUG LCK, CORR. REST. SHORT HOU... 20A 125V RECEPTACLE, LOCKING - ISOL... Marinco Electrical Group Marinco Electrical Group 20A PLUG LCK; CORR. REST. SHORT HOUSING 20A 125V RECEPTACLE; LOCKING - ISOLATED GRND Part Number Weight Min. Quantity Part Number Weight Min. Quantity 205PCRS 0.21 N-A 205RIG 0.22 N-A 860-442-4386 the edge group • 2014 206P – 20A PLUG, 250V LOCKING 20A 250V FLANGED INLET LOCKING Marinco Electrical Group Marinco Electrical Group CORDSET; 8’ 12/3 SEOW CRIMPED 20A 250V FLANGED INLET LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 206-AK3 N-A N-A 206FI 0.16 N-A 20A CONNECTOR, 250V LOCKING 20A 250V F. INLET LKG GRY MASTER/50 Marinco Electrical Group Marinco Electrical Group 20A CONNECTOR; 250V LOCKING 20A 250V F. INLET LKG GRY MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 206C 0.27 N-A 206FIGY.OEM 0.16 N-A 20A CONNECTOR, 250V LOCKING MASTER/... 20A 250V FLANGED OUTLET LKG Marinco Electrical Group Marinco Electrical Group 20A CONNECTOR; 250V LOCKING MASTER/50 Bat teries/ Fl a shlights/Charger s CORDSET, 8’ 12/3 SEOW CRIMPED 20A 250V FLANGED OUTLET LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 206C.OEM 0.27 N-A 206FO 0.2 N-A 20A CONN 250V LOCK BLACK 20A 250V FLANGED OUTLET LKG MASTER/... Marinco Electrical Group Marinco Electrical Group 20A CONN 250V LOCK BLACK 20A 250V FLANGED OUTLET LKG MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 206CBL 0.27 N-A 206FO.OEM 0.2 N-A 20A 250V CONN LKG GRAY MASTER/50 20A PLUG, 250V LOCKING Marinco Electrical Group Marinco Electrical Group 20A 250V CONN LKG GRAY MASTER/50 20A PLUG; 250V LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 206CGY.OEM N-A N-A 206P 0.25 N-A 860-442-4386 25 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 206P.OEM – 20A PLUG, 250V LOCKING MASTER/50 20A PLUG, 250V LOCKING MASTER/50 20A 250V RECEPTACLE, LOCKING Marinco Electrical Group Marinco Electrical Group 20A PLUG; 250V LOCKING MASTER/50 20A 250V RECEPTACLE; LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 206P.OEM 0.21 N-A 206R 0.22 N-A 20A PLUG, 250V LOCKING NO INSERT MA... 20A 250V RECEPTACLE, LOCKING MASTER... Marinco Electrical Group Marinco Electrical Group 20A PLUG; 250V LOCKING NO INSERT MASTER/50 20A 250V RECEPTACLE; LOCKING MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 206P.OEM.NI 0.21 N-A 206R.OEM 0.22 N-A PLUG 20A 250V LOCK BLACK 20A 250V RECEPTACLE, LOCKING MASTER... Marinco Electrical Group Marinco Electrical Group PLUG 20A 250V LOCK BLACK 26 20A 250V RECEPTACLE; LOCKING MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 206PBL 0.21 N-A 206R.OEM.NMS 0.22 N-A PLUG 20A 250V LOCK BLACK MASTER/50 20A 250V RECEPTACLE, LOCKING - ISOL... Marinco Electrical Group Marinco Electrical Group PLUG 20A 250V LOCK BLACK MASTER/50 20A 250V RECEPTACLE; LOCKING - ISOLATED GRND Part Number Weight Min. Quantity Part Number Weight Min. Quantity 206PBL.OEM 0.21 N-A 206RIG 0.22 N-A 20A 250V PLUG LKG GRAY NI MASTER/50 PLUG, 20A LOCKING 277V Marinco Electrical Group Marinco Electrical Group 20A 250V PLUG LKG GRAY NI MASTER/50 PLUG; 20A LOCKING 277V Part Number Weight Min. Quantity Part Number Weight Min. Quantity 206PGY.OEM.NI 0.218 N-A 207P 0.21 N-A 860-442-4386 the edge group • 2014 20F-RT – Bates Stage Pin (20A / 125V) Female... Bates Stage Pin (20A / 125V) Female... Marinco Electrical Group Marinco Electrical Group PLUG; 20A LOCKING 277V MASTER/50 Bates Stage Pin (20A / 125V) Female Inline - Blue (D) Cover Part Number Weight Min. Quantity Part Number Weight Min. Quantity 207P.OEM 0.21 N-A 20F-D N-A N-A Bates Stage Pin (20A / 125V) Female... Bates Stage Pin (20A / 125V) Female... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Female Inline Bates Stage Pin (20A / 125V) Female Inline - Green (E) Cover Part Number Weight Min. Quantity Part Number Weight Min. Quantity 20F N-A N-A 20F-E N-A N-A Bates Stage Pin (20A / 125V) Female... Bates Stage Pin (20A / 125V) Female... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Female Inline - All White Bates Stage Pin (20A / 125V) Female Inline - Orange (G) Cover Part Number Weight Min. Quantity Part Number Weight Min. Quantity 20F-AW N-A N-A 20F-G N-A N-A Bates Stage Pin (20A / 125V) Female... Bates Stage Pin (20A / 125V) Female... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Female Inline - White (B) Cover Bates Stage Pin (20A / 125V) Female Inline - Yellow (H) Cover Part Number Weight Min. Quantity Part Number Weight Min. Quantity 20F-B N-A N-A 20F-H N-A N-A Bates Stage Pin (20A / 125V) Female... Bates Stage Pin (20A / 125V) Female... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Female Inline - Red (C ) Cover Bates Stage Pin (20A / 125V) Female Inline Ring Terminal Part Number Weight Min. Quantity Part Number Weight Min. Quantity 20F-C N-A N-A 20F-RT N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s PLUG, 20A LOCKING 277V MASTER/50 27 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 20F-RT.OEM – Bates Stage Pin (20A / 125V) Female... 28 Bates Stage Pin (20A / 125V) Female... Bates Stage Pin (20A / 125V) Female... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Female Inline Ring Terminal OEM Pack 100/MASTER Bates Stage Pin (20A / 125V) Female Panel Mount - White (B) Part Number Weight Min. Quantity 20F-RT.OEM N-A N-A Part Number Weight Min. Quantity 20FR-B N-A N-A Bates Stage Pin (20A / 125V) Female... Bates Stage Pin (20A / 125V) Female... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Female Inline Clear Cover (X) Part Number Weight Min. Quantity 20F-X N-A N-A Bates Stage Pin (20A / 125V) Female Panel Mount - White (B) OEM Pack 100/MASTER Part Number Weight Min. Quantity 20FR-B.OEM N-A N-A Bates Stage Pin (20A / 125V) Female... Bates Stage Pin (20A / 125V) Female... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Female Inline Clear Cover (X) OEM Pack 100/MASTER Bates Stage Pin (20A / 125V) Female Panel Mount - Red (C ) Part Number Weight Min. Quantity 20F-X.OEM N-A N-A Part Number Weight Min. Quantity 20FR-C N-A N-A Bates Stage Pin (20A / 125V) Female... Bates Stage Pin (20A / 125V) Female... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Female Inline OEM Pack 100/MASTER Bates Stage Pin (20A / 125V) Female Panel Mount - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity 20F.OEM N-A N-A 20FR-H N-A N-A Bates Stage Pin (20A / 125V) Female... Bates Stage Pin (20A / 125V) Female... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Female Panel Mount Bates Stage Pin (20A / 125V) Female Panel Mount Ring Terminal Part Number Weight Min. Quantity Part Number Weight Min. Quantity 20FR N-A N-A 20FR-RT N-A N-A 860-442-4386 the edge group • 2014 20M-E – Bates Stage Pin (20A / 125V) Male I... Bates Stage Pin (20A / 125V) Male I... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Female Panel Mount OEM Pack 100/ MASTER Bates Stage Pin (20A / 125V) Male Inline - Red (C ) Cover Part Number Weight Min. Quantity 20FR.OEM N-A N-A Part Number Weight Min. Quantity 20M-C N-A N-A Bates Stage Pin (20A / 125V) Female... Bates Stage Pin (20A / 125V) Male I... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Female Panel Mount OEM Pack No Hardware 100/MASTER Bates Stage Pin (20A / 125V) Male Inline - Blue (D ) Cover Part Number Weight Min. Quantity 20FR.OEMNH N-A N-A Part Number Weight Min. Quantity 20M-D N-A N-A Bates Stage Pin (20A / 125V) Male I... Bates Stage Pin (20A / 125V) Male I... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Male Inline Bat teries/ Fl a shlights/Charger s Bates Stage Pin (20A / 125V) Female... Bates Stage Pin (20A / 125V) Male Inline 2FER Part Number Weight Min. Quantity Part Number Weight Min. Quantity 20M N-A N-A 20M-DB N-A N-A Bates Stage Pin (20A / 125V) Male I... Bates Stage Pin (20A / 125V) Male I... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Male Inline All White Bates Stage Pin (20A / 125V) Male Inline 2FER OEM Pack 100/MASTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity 20M-AW N-A N-A 20M-DB.OEM N-A N-A Bates Stage Pin (20A / 125V) Male I... Bates Stage Pin (20A / 125V) Male I... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Male Inline - White (B) Cover Bates Stage Pin (20A / 125V) Male Inline - Green (E) Cover Part Number Weight Min. Quantity Part Number Weight Min. Quantity 20M-B N-A N-A 20M-E N-A N-A 860-442-4386 29 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 20M-H – Bates Stage Pin (20A / 125V) Male I... Bates Stage Pin (20A / 125V) Male I... Bates Stage Pin (20A / 125V) Male P... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Male Inline - Yellow (H) Cover Bates Stage Pin (20A / 125V) Male Panel Mount Part Number Weight Min. Quantity Part Number Weight Min. Quantity 20M-H N-A N-A 20MR N-A N-A Bates Stage Pin (20A / 125V) Male I... Bates Stage Pin (20A / 125V) Male P... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Male Inline Ring Terminal Part Number Weight Min. Quantity 20M-RT N-A N-A Part Number Weight Min. Quantity 20MR.OEM N-A N-A Bates Stage Pin (20A / 125V) Male I... BATTERY SELECTOR SWITCH Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Male Inline - Clear (X) Cover 30 Bates Stage Pin (20A / 125V) Male Panel Mount OEM Pack 100/ MASTER BATTERY SELECTOR SWITCH Part Number Weight Min. Quantity Part Number Weight Min. Quantity 20M-X N-A N-A 2100 1 N-A Bates Stage Pin (20A / 125V) Male I... BATTERY SELECTOR SWITCH Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Male Inline - Clear (X) Cover OEM Pack 100/MASTER BATTERY SELECTOR SWITCH Part Number Weight Min. Quantity 20M-X.OEM N-A N-A Part Number Weight Min. Quantity 2101 12 N-A Bates Stage Pin (20A / 125V) Male I... 12-10 TO 16-14 STEP DOWN BUTT 25 Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (20A / 125V) Male Inline OEM Pack 100/MASTER 12-10 TO 16-14 STEP DOWN BUTT 25 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 20M.OEM N-A N-A 210165 4 N-A 860-442-4386 the edge group • 2014 220003 – 120 PIECE CONNECTOR KIT BATT. SELECT. SWITCH GREY Marinco Electrical Group Marinco Electrical Group BATTERY ON / OFF SWITCH BATT. SELECT. SWITCH GREY Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2102 5 N-A 2111A 14 N-A BATTERY ON / OFF SWITCH BATT. SELECT. SWITCH RED Marinco Electrical Group Marinco Electrical Group BATTERY ON / OFF SWITCH BATT. SELECT. SWITCH RED Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2102-3-B N-A N-A 2111A-17 N-A N-A BATTERY ON / OFF SWITCH BATT. SELECT. SWITCH BLK Marinco Electrical Group Marinco Electrical Group BATTERY ON / OFF SWITCH Bat teries/ Fl a shlights/Charger s BATTERY ON / OFF SWITCH BATT. SELECT. SWITCH BLK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2102-B N-A N-A 2111A-B N-A N-A DOUBLE MALE FEMALE ADAPTE R 25 BATT. ON/OFF SWITCH GREY Marinco Electrical Group Marinco Electrical Group DOUBLE MALE FEMALE ADAPTE R 25 BATT. ON/OFF SWITCH GREY Part Number Weight Min. Quantity Part Number Weight Min. Quantity 210613 N-A N-A 2112A 12 N-A BATT. SELECT. SWITCH GREY 120 PIECE CONNECTOR KIT Marinco Electrical Group Marinco Electrical Group BATT. SELECT. SWITCH GREY 120 PIECE CONNECTOR KIT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2110A 14 N-A 220003 N-A N-A 860-442-4386 31 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 220007 – COASTAL ELECTRICAL KIT COASTAL ELECTRICAL KIT Connector #6 5/16’’ RING N YLON 1 Marinco Electrical Group Marinco Electrical Group COASTAL ELECTRICAL KIT Connector #6 5/16 RING N YLON 1 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 220007 140 N-A 230245 0.46 N-A HEAVY DUTY BATTERY SLCTR Connector #4 5/16’’ RING N YLON 1 Marinco Electrical Group Marinco Electrical Group HEAVY DUTY BATTERY SLCTR Connector #4 5/16 RING N YLON 1 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2300A 29 N-A 230255 1 N-A HEAVY DUTY BATTERY SLCTR HEAVY DUTY BATTERY ON/OFF Marinco Electrical Group Marinco Electrical Group HEAVY DUTY BATTERY SLCTR 32 HEAVY DUTY BATTERY ON/OFF Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2300A-B N-A N-A 2303A 25 N-A Connector #8 1/4’’ RING NY LON 2 HEAVY DUTY BATTERY ON/OFF Marinco Electrical Group Marinco Electrical Group Connector #8 1/4 RING NY LON 2 HEAVY DUTY BATTERY ON/OFF Part Number Weight Min. Quantity Part Number Weight Min. Quantity 230234 0.48 N-A 2303A-B N-A N-A Connector #6 1/4’’ RING NY LON 1 SWITCH, XTRA HEAVY DUTY Marinco Electrical Group Marinco Electrical Group Connector #6 1/4 RING NY LON 1 SWITCH; XTRA HEAVY DUTY Part Number Weight Min. Quantity Part Number Weight Min. Quantity 230244 0.43 N-A 2304A 30 N-A 860-442-4386 the edge group • 2014 249003 – WATER TIGHT CONN. DOUBLE CONDUCTOR... 2/0 1/2’’ TINNED LUG 10 Marinco Electrical Group Marinco Electrical Group EXTRA HEAVY DUTY DIESEL 2/0 1/2 TINNED LUG 10 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2304A-B N-A N-A 242297 8 N-A Lug #4 1/4’’ TINNED LUG 25 4/0 1/2’’ TINNED LUG 10 Marinco Electrical Group Marinco Electrical Group Lug #4 1/4 TINNED LUG 25 4/0 1/2 TINNED LUG 10 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 242254 8 N-A 242727 14 N-A Lug #4 3/8’’ TINNED LUG 25 2/0 5/16’’ TINNED LUG 100 Marinco Electrical Group Marinco Electrical Group Lug #4 3/8 TINNED LUG 25 Bat teries/ Fl a shlights/Charger s EXTRA HEAVY DUTY DIESEL 2/0 5/16 TINNED LUG 100 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 242256 8 N-A 244295 66 N-A Lug #2 3/8’’ TINNED LUG 25 2/0 3/8’’ TINNED LUG 100 Marinco Electrical Group Marinco Electrical Group Lug #2 3/8 TINNED LUG 25 2/0 3/8 TINNED LUG 100 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 242266 14 N-A 244296 77 N-A 2/0 3/8’’ TINNED LUG 25 WATER TIGHT CONN. DOUBLE CONDUCTOR... Marinco Electrical Group Marinco Electrical Group 2/0 3/8 TINNED LUG 25 WATER TIGHT CONN. DOUBLE CONDUCTOR W/ 14 AWG RED & Part Number Weight Min. Quantity Part Number Weight Min. Quantity 242296 21 N-A 249003 N-A N-A 860-442-4386 33 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 24VRC.OEM – 24V RECEPT. BULK 24V RECEPT. BULK Lug #8 3/8’’ TINNED LUG 2 Marinco Electrical Group Marinco Electrical Group 24V RECEPT. BULK Lug #8 3/8 TINNED LUG 2 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 24VRC.OEM N-A N-A 252236 1 N-A KIT, METAL, NYLON CONNECT ORS, SMAL... Lug #6 #10 TINNED LUG 2 Marinco Electrical Group Marinco Electrical Group KIT; METAL; NYLON CONNECT ORS; SMALL Lug #6 #10 TINNED LUG 2 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 250001 95 N-A 252243 1 N-A Lug #8 #10 TINNED LUG 2 Lug #6 3/8’’ TINNED LUG 2 Marinco Electrical Group Marinco Electrical Group Lug #8 #10 TINNED LUG 2 34 Lug #6 3/8 TINNED LUG 2 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 252233 1 N-A 252246 1 N-A Lug #8 1/4’’ TINNED LUG 2 Lug #4 5/16 & 3/8 TINNED LUG COMBO... Marinco Electrical Group Marinco Electrical Group Lug #8 1/4 TINNED LUG 2 Lug #4 5/16 & 3/8 TINNED LUG COMBO PACK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 252234 1 N-A 252251 0.16 N-A Lug #8 5/16’’ TINNED LUG 2 Lug #4 5/16’’ TINNED LUG 2 Marinco Electrical Group Marinco Electrical Group Lug #8 5/16 TINNED LUG 2 Lug #4 5/16 TINNED LUG 2 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 252235 1 N-A 252255 1 N-A 860-442-4386 the edge group • 2014 25PCMX – 16A 230V CORDSET, 25 FT. 2/0 5/16’’ TINNED LUG 2 Marinco Electrical Group Marinco Electrical Group Lug #2 5/16 & 3/8 TINNED LUG COMBO PACK 2/0 5/16 TINNED LUG 2 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 252261 1 N-A 252295 2 N-A Lug #2 5/16’’ TINNED LUG 2 BAT ISO 1 ALT 2 BAT 120A INPUT Marinco Electrical Group Marinco Electrical Group Lug #2 5/16 TINNED LUG 2 BAT ISO 1 ALT 2 BAT 120A INPUT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 252265 1 N-A 2530 84 N-A Lug #2 3/8’’ TINNED LUG 2 120 AMP BAT ISOLATOR 2 ALT/3 BATT Marinco Electrical Group Marinco Electrical Group Lug #2 3/8 TINNED LUG 2 Bat teries/ Fl a shlights/Charger s Lug #2 5/16 & 3/8 TINNED LUG COMBO... 120 AMP BAT ISOLATOR 2 ALT/3 BATT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 252266 1 N-A 2532 138 N-A 1/0 5/16’’ TINNED LUG 2 30A, 125V 25’ CORDSET SLEEVE PACK Marinco Electrical Group Marinco Electrical Group 1/0 5/16 TINNED LUG 2 30A; 125V 25’ CORDSET SLEEVE PACK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 252285 2 N-A 25PCM2 307 N-A 1/0 3/8’’ TINNED LUG 2 16A 230V CORDSET, 25 FT. Marinco Electrical Group Marinco Electrical Group 1/0 3/8 TINNED LUG 2 16A 230V CORDSET; 25 FT. Part Number Weight Min. Quantity Part Number Weight Min. Quantity 252286 2 N-A 25PCMX N-A N-A 860-442-4386 35 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 25SPP.RV – 30A, POWERCORD PLUS-25FT W/ RV END ... 30A, POWERCORD PLUS-25FT W/ RV END ... Guest Battery Maintainer 3A / 12V; ... Marinco Electrical Group Marinco Electrical Group 30A; POWERCORD PLUS-25FT W/ RV END (MALE) Guest Battery Maintainer 3A / 12V; 1 Bank; 120V Input Part Number Weight Min. Quantity Part Number Weight Min. Quantity 25SPP.RV N-A N-A 2603 24 N-A Guest Battery Maintainer 0.5A / 12V... Guest Battery Maintainer 3A / 12V; ... Marinco Electrical Group Marinco Electrical Group Guest Battery Maintainer 0.5A / 12V; 1 Bank; 120V Input Weight Min. Quantity Part Number Weight Min. Quantity 2602 1 N-A 2603-B N-A N-A Guest Battery Charger 2A / 12V; 1 B... POS/NEG MARINE BAT TERM T IN BR (1/... Marinco Electrical Group Marinco Electrical Group Guest Battery Charger 2A / 12V; 1 Bank; 120V Input 36 Guest Battery Maintainer 3A / 12V; 1 Bank; 120V Input - Bulk Part Number POS/NEG MARINE BAT TERM T IN BR (1/1 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2602A-12 36 N-A 260322 7 N-A Guest Battery Charger 2A / 12V; 1 B... Guest Battery Low Inhibit Charger 5... Marinco Electrical Group Marinco Electrical Group Guest Battery Charger 2A / 12V; 1 Bank; 120V Input - Bulk Guest Battery Low Inhibit Charger 5A / 24V; 1 Bank; 120V Input Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2602A-12-B N-A N-A 2605-24L N-A N-A Guest Battery Charger 2A / 24V; 1 B... ELE110V1010 PRIDE 24V, 5A, POTTED C... Marinco Electrical Group Marinco Electrical Group Guest Battery Charger 2A / 24V; 1 Bank; 120V Input - Bulk ELE110V1010 PRIDE 24V; 5A; POTTED CHARGER Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2602A-24-B N-A N-A 2605A-24 N-A N-A 860-442-4386 the edge group • 2014 2611A-1-B – Guest On-Board Battery Charger 10A ... Guest On-Board Battery Charger 6A /... Marinco Electrical Group Marinco Electrical Group Guest Portable Battery Charger 6A / 12V; 1 Bank; 120V Input Guest On-Board Battery Charger 6A / 12V; 1 Bank; 120V Input; SJTW Cables - Bulk Part Number Weight Min. Quantity 2606A 54 N-A Part Number Weight Min. Quantity 2608A-B-01 N-A N-A Guest On-Board Battery Charger 6A (... Guest On-Board Battery Charger 6A /... Marinco Electrical Group Marinco Electrical Group Guest On-Board Battery Charger 6A (3/3) / 12/24V; 2 Bank; 120V Input Part Number Weight Min. Quantity 2607A 56 N-A Guest On-Board Battery Charger 6A / 12V; 1 Bank; 120V Input; SJTW Cables - Bulk Part Number Weight Min. Quantity 2608CPG-01 N-A N-A Guest On-Board Battery Charger 6A (... Guest On-Board Battery Charger 10A ... Marinco Electrical Group Marinco Electrical Group Guest On-Board Battery Charger 6A (3/3) / 12/24V; 2 Bank; 120V Input - Bulk Guest On-Board Battery Charger 10A (5/5) / 12/24V; 2 Bank; Hardwire; 120V Input Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2607A-B N-A N-A 2610A 82 N-A Guest On-Board Battery Charger 6A /... Guest On-Board Battery Charger 10A ... Marinco Electrical Group Marinco Electrical Group Guest On-Board Battery Charger 6A / 12V; 1 Bank; 120V Input Guest On-Board Battery Charger 10A (5/5) / 12/24V; 2 Bank; 120V Input Part Number Weight Min. Quantity 2608A 52 N-A Part Number Weight Min. Quantity 2611A 100 N-A Guest On-Board Battery Charger 6A /... Guest On-Board Battery Charger 10A ... Marinco Electrical Group Marinco Electrical Group Guest On-Board Battery Charger 6A / 12V; 1 Bank; 120V Input - Bulk Guest On-Board Battery Charger 10A / 12V; 1 Bank; 120V Input - Bulk Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2608A-B N-A N-A 2611A-1-B N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s Guest Portable Battery Charger 6A /... 37 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 2611A-B – Guest On-Board Battery Charger 10A ... 38 Guest On-Board Battery Charger 10A ... Guest Cruising Series Battery Charg... Marinco Electrical Group Marinco Electrical Group Guest On-Board Battery Charger 10A (5/5) / 12/24V; 2 Bank; 120V Input - Bulk Guest Cruising Series Battery Charger 20A (5/5/10) / 12/24/24+12V; 3 Bank; 120V Input Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2611A-B N-A N-A 2621A 264 N-A Guest Portable Battery Charger 10A ... Guest Cruising Series Battery Charg... Marinco Electrical Group Marinco Electrical Group Guest Portable Battery Charger 10A / 12V; 1 Bank; 120V Input Part Number Weight Min. Quantity 2612A 80 N-A Guest Cruising Series Battery Charger 20A (10/10) / 12/12V; 2 Bank; 120V Input Part Number Weight Min. Quantity 2622A 193 N-A Guest On-Board Battery Charger 15A ... Guest Cruising Series Battery Charg... Marinco Electrical Group Marinco Electrical Group Guest On-Board Battery Charger 15A (5/5/5) / 12/24/36V); 3 Bank; 120V Input Guest Cruising Series Battery Charger 20A (10/10) / 12/12V; 2 Bank; 230V Input Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2613A 181 N-A 2622A-230 N-A N-A Guest Cruising Series Battery Charg... Guest On-Board Battery Charger 25A ... Marinco Electrical Group Marinco Electrical Group Guest Cruising Series Battery Charger 15A (5/10) / 12/12V; 2 Bank; 120V Input Guest On-Board Battery Charger 25A (10/10/5) / 12/24/24+12V; 3 Bank; 120V Input Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2614A 193 N-A 2623A 256 N-A Guest On-Board Battery Charger 20A ... Guest On-Board Battery Charger 30A ... Marinco Electrical Group Marinco Electrical Group Guest On-Board Battery Charger 20A (10/10) / 12/24V; 2 Bank; 120V Input Guest On-Board Battery Charger 30A (10/10/10) / 12/24/36V; 3 Bank; 120V Input Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2620A 179 N-A 2631A 251 N-A 860-442-4386 the edge group • 2014 3014C.OEM – CONNECTOR 30A 125/250V MASTER/50 CHARGER, 3 AMP, 24V,HIGH SHIP 2904-... Marinco Electrical Group Marinco Electrical Group Guest Cruising Series Battery Charger 30A (5/5/20) / 12/24/24+12V; 3 Bank; 120V Input CHARGER; 3 AMP; 24V;HIGH SHIP 2904-24 WITHOUT X DO NOT SCRAP Part Number Weight Min. Quantity 2632A 262 N-A Part Number Weight Min. Quantity 2904-24X N-A N-A Guest Cruising Series Battery Charg... AFI500 80 2/12 KIT Marinco Electrical Group Marinco Electrical Group Guest Cruising Series Battery Charger 30A (10/20)/ 12/12V; 2 Bank; 120V Input AFI500 80 2/12 KIT Part Number Weight Min. Quantity 2633A 252 N-A Part Number Weight Min. Quantity 30004 31 N-A Guest On-Board Battery Charger 30A ... COVER, 12V CONN. LONG THR Marinco Electrical Group Marinco Electrical Group Guest On-Board Battery Charger 30A (15/15)/ 12/24V; 2 Bank; 120V Input - Bulk COVER; 12V CONN. LONG THR Part Number Weight Min. Quantity 2730-B N-A N-A Part Number Weight Min. Quantity 300275 N-A N-A 24V, 3A, 1 OUTPUT, POTTED CHARGER 30A 125/250V CONNECTOR LOCKING Marinco Electrical Group Marinco Electrical Group 24V; 3A; 1 OUTPUT; POTTED CHARGER 30A 125/250V CONNECTOR LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2903-1-24 N-A N-A 3014C 0.27 N-A 3A, 230V, LOW INHIBIT, PTDCHR, ELE1... CONNECTOR 30A 125/250V MASTER/50 Marinco Electrical Group Marinco Electrical Group 3A; 230V; LOW INHIBIT; PTDCHR; ELE110V1014 CONNECTOR 30A 125/250V MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 2904-24L-230 N-A N-A 3014C.OEM 0.27 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s Guest Cruising Series Battery Charg... 39 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 3014FI – 30A 125/250V FLANGED INLET LKG 30A 125/250V FLANGED INLET LKG 30A 125/250V RECEPTACLE LKG Marinco Electrical Group Marinco Electrical Group 30A 125/250V FLANGED INLET LKG 30A 125/250V RECEPTACLE LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3014FI 0.16 N-A 3014R 0.22 N-A 30A 125/250V FLANGED INLET LKG MAST... 30A 125/250V RECEPTACLE LOCKING, NO... Marinco Electrical Group Marinco Electrical Group 30A 125/250V FLANGED INLET LKG MASTER/50 30A 125/250V RECEPTACLE LOCKING; NO EARS MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3014FI.OEM 0.16 N-A 3014R.OEM.NE 0.232 N-A 30A 125/250V FLANGED OUTLET 30A 125/250V RECEPTACLE, LOCK MASTE... Marinco Electrical Group Marinco Electrical Group 30A 125/250V FLANGED OUTLET 40 30A 125/250V RECEPTACLE; LOCK MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3014FO 0.2 N-A 3014R.OEM.NMS 0.22 N-A 30A 125/250V PLUG LOCKING CORDSET, 6’ 10/4 STO BLACK CRIMP Marinco Electrical Group Marinco Electrical Group 30A 125/250V PLUG LOCKING CORDSET; 6’ 10/4 STO BLACK CRIMP Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3014P 0.21 N-A 3015-AM4 N-A N-A 30A 125/250V PLUG LOCKING MASTER/50 6’’ SHRINK ASSMT PK 3/16-3 /4 8 PC Marinco Electrical Group Marinco Electrical Group 30A 125/250V PLUG LOCKING MASTER/50 6 SHRINK ASSMT PK 3/16-3 /4 8 PC Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3014P.OEM 0.21 N-A 301506 2 N-A 860-442-4386 the edge group • 2014 3015P-AM11 – POWER CORD, 6.5’ 10/4 STO CRIMP, WI... 30A 250V 3 FLANGED OUTLET LKG Marinco Electrical Group Marinco Electrical Group 30A 250V 3 CONNECTOR LOCKING 30A 250V 3 FLANGED OUTLET LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3015C 0.27 N-A 3015FO 0.2 N-A POWER CORD, 10’ 12/4 SEOW BLACK, CR... FLANGED OUTLET, 77’’ WIRE HARNESS Marinco Electrical Group Marinco Electrical Group POWER CORD; 10’ 12/4 SEOW BLACK; CRIMP FLANGED OUTLET; 77 WIRE HARNESS Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3015C-AM1 N-A N-A 3015FO-AM2 N-A N-A 30A 250V 3 CONNECTOR, NO INSERTS MA... 30A 250V 3 PLUG LOCKING Marinco Electrical Group Marinco Electrical Group 30A 250V 3 CONNECTOR; NO INSERTS MASTER/50 Bat teries/ Fl a shlights/Charger s 30A 250V 3 CONNECTOR LOCKING 30A 250V 3 PLUG LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3015C.OEM.NI 0.344 N-A 3015P 0.21 N-A 30A 250V 3 FLANGED INLET LKG 3015P W/ 10/4 ST YLLW 7’ Marinco Electrical Group Marinco Electrical Group 30A 250V 3 FLANGED INLET LKG 3015P W/ 10/4 ST YLLW 7’ Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3015FI 0.16 N-A 3015P-AK4 N-A N-A 30A 250V FLANGED INLET CRIMP POWER CORD, 6.5’ 10/4 STO CRIMP, WI... Marinco Electrical Group Marinco Electrical Group 30A 250V FLANGED INLET CRIMP POWER CORD; 6.5’ 10/4 STO CRIMP; WITH RING TERM. Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3015FI-AM1 N-A N-A 3015P-AM11 N-A N-A 860-442-4386 41 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 3015P-AM25 – POWER CORD, 16/3 BLK 6’ BLUNT CUT POWER CORD, 16/3 BLK 6’ BLUNT CUT 30A 250V 3PH PLUG LKG MASTER/50 Marinco Electrical Group Marinco Electrical Group POWER CORD; 16/3 BLK 6’ BLUNT CUT 30A 250V 3PH PLUG LKG MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3015P-AM25 N-A N-A 3015P.OEM 0.21 N-A CORDSET, 30A 250V PLUG WITH JAE CON... 30A 250V 3 RECEPTACLE LOCKING Marinco Electrical Group Marinco Electrical Group CORDSET; 30A 250V PLUG WITH JAE CONNECTOR 30A 250V 3 RECEPTACLE LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3015P-AM26 N-A N-A 3015R 0.22 N-A POWER CORD, 30A/250V PLUG 59’’ 30A 250V 3PHASE RECEPTACLE LKG Marinco Electrical Group Marinco Electrical Group POWER CORD; 30A/250V PLUG 59 42 30A 250V 3PHASE RECEPTACLE LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3015P-AM28 N-A N-A 3015R-AM1 N-A N-A POWER CORD, 96’’ CORDSET PAIR, 30A 480V 6’ EACH Marinco Electrical Group Marinco Electrical Group POWER CORD; 96 CORDSET PAIR; 30A 480V 6’ EACH Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3015P-AM30 N-A N-A 3016-AM6 N-A N-A POWER CORD, 30A/250V PLUG 59’’ 30A 480V 3 CONNECTOR LOCKING Marinco Electrical Group Marinco Electrical Group POWER CORD; 30A/250V PLUG 59 30A 480V 3 CONNECTOR LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3015P-AM31 N-A N-A 3016C 0.27 N-A 860-442-4386 the edge group • 2014 301ELRV – 30A INLET EASY LOCK WITH PARK POWER... 30A 125V INLET EASY LOCK Marinco Electrical Group Marinco Electrical Group 30A 480V 3 FLANGED OUTLET LKG 30A 125V INLET EASY LOCK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3016FO 0.2 N-A 301EL-B 16 N-A 30A 480V 3 PLUG LOCKING 30A INLET EASY LOCK Marinco Electrical Group Marinco Electrical Group 30A 480V 3 PLUG LOCKING 30A INLET EASY LOCK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3016P 0.21 N-A 301EL-B.OEM N-A N-A POWER CORD, 8’ 10/4 SEOW BLACK CRIM... 16A INLET EASY LOCK EXP W/WARNING L... Marinco Electrical Group Marinco Electrical Group POWER CORD; 8’ 10/4 SEOW BLACK CRIMP Bat teries/ Fl a shlights/Charger s 30A 480V 3 FLANGED OUTLET LKG 16A INLET EASY LOCK EXP W/WARNING LABEL; 230V Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3016P-AK1 N-A N-A 301EL-BX N-A N-A POWER CORD, 8’ 10/4 SEOW BLACK W/RI... 30A REPLACE. CAP & BEZEL E.L. Marinco Electrical Group Marinco Electrical Group POWER CORD; 8’ 10/4 SEOW BLACK W/RING TERMINALS 30A REPLACE. CAP & BEZEL E.L. Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3016P-AM7 N-A N-A 301ELCB 6 N-A 30A 480V 3 RECEPTACLE LOCKING 30A INLET EASY LOCK WITH PARK POWER... Marinco Electrical Group Marinco Electrical Group 30A 480V 3 RECEPTACLE LOCKING 30A INLET EASY LOCK WITH PARK POWER PACKAGING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3016R 0.22 N-A 301ELRV N-A N-A 860-442-4386 43 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 3021C – 30A 120/208V 3 Y CONNECTOR LKG 30A 120/208V 3 Y CONNECTOR LKG CORDSET, 48’’ 12/5 AWM W/RING TERM. Marinco Electrical Group Marinco Electrical Group 30A 120/208V 3 Y CONNECTOR LKG CORDSET; 48 12/5 AWM W/RING TERM. Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3021C 0.27 N-A 3021P-AM4 N-A N-A 30A 120/208V 3 Y FLG OUTLET LK 30A 120/208V 3 Y PLUG LOCKING MASTE... Marinco Electrical Group Marinco Electrical Group 30A 120/208V 3 Y FLG OUTLET LK 30A 120/208V 3 Y PLUG LOCKING MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3021FO 0.2 N-A 3021P.OEM 0.21 N-A 30A 120/208V 3 Y PLUG LOCKING 30A 120/208V 3 Y RECPT LKG Marinco Electrical Group Marinco Electrical Group 30A 120/208V 3 Y PLUG LOCKING 44 30A 120/208V 3 Y RECPT LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3021P 0.21 N-A 3021R 0.22 N-A POWER CORD, 80’’ 10/3 SEOW 30A 125V EASY LOCK INLET SS, W/ENCL... Marinco Electrical Group Marinco Electrical Group POWER CORD; 80 10/3 SEOW 30A 125V EASY LOCK INLET SS; W/ENCLOSURE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3021P-AM2 N-A N-A 303SSEL-B 21 N-A CORDSET, 48’’ 10/3 SEOW W/RING TERM... 30A 125V EASY LOCK INLET SS, W/ENCL... Marinco Electrical Group Marinco Electrical Group CORDSET; 48 10/3 SEOW W/RING TERM. 30A 125V EASY LOCK INLET SS; W/ENCLOSURE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3021P-AM3 N-A N-A 303SSEL-B.OEM N-A N-A 860-442-4386 the edge group • 2014 305CCRS – 30A CONNECTOR, LOCKING SHORT BODY 1/2’’ X 6’’ BLACK HEAT SHRINK Marinco Electrical Group Marinco Electrical Group 30A EASY LOCK INLET; SS W/ENCL FOR RV 1/2 X 6 BLACK HEAT SHRINK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 303SSEL-BRV N-A N-A 305106 1 N-A 30A 125V OUTLET STAINLESS STEEL Shrink Tube, 1/2’’ Dia., B lack & R... Marinco Electrical Group Marinco Electrical Group 30A 125V OUTLET STAINLESS STEEL Shrink Tube; 1/2 Dia.; B lack & Red 3 Pack Part Number Weight Min. Quantity Part Number Weight Min. Quantity 303SSO 18 N-A 305602 N-A N-A INLET, 30A CONTOURED 30A 125V CONN, LOCKING Marinco Electrical Group Marinco Electrical Group INLET; 30A CONTOURED Bat teries/ Fl a shlights/Charger s 30A EASY LOCK INLET, SS W/ENCL FOR ... 30A 125V CONN; LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 304EL-B.NT 7 N-A 305C 0.34 N-A INLET, 30A CONTOURED W/ CHROME 30A CONNECTOR, LOCKING MASTER/50 Marinco Electrical Group Marinco Electrical Group INLET; 30A CONTOURED W/ CHROME 30A CONNECTOR; LOCKING MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 304EL-BCR 9 N-A 305C.OEM 0.27 N-A ADAPTER, 30M TO 50F, SB TT-30P TO 1... 30A CONNECTOR, LOCKING SHORT BODY Marinco Electrical Group Marinco Electrical Group ADAPTER; 30M TO 50F; SB TT-30P TO 14-50R 30A CONNECTOR; LOCKING SHORT BODY Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3050ARV N-A N-A 305CCRS 0.27 N-A 860-442-4386 45 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 305CRCN – 30A 125V CONN. COMPACT 30A 125V CONN. COMPACT 30A 125V PLUG AND BOOT VALUE PACK Marinco Electrical Group Marinco Electrical Group 30A 125V CONN. COMPACT 30A 125V PLUG AND BOOT VALUE PACK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 305CRCN 5 N-A 305CRPN.VPK 12 N-A 30A 125V CONN. AND BOOT VALUE PACK 30A 125V RECEPTACLE, LOCKING Marinco Electrical Group Marinco Electrical Group 30A 125V CONN. AND BOOT VALUE PACK 30A 125V RECEPTACLE; LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 305CRCN.VPK 6 N-A 305CRR 5 N-A 16A CONN., COMPACT EXPORT 230V 30A 125V CONN. COMPACT W/PARK POWER... Marinco Electrical Group Marinco Electrical Group 16A CONN.; COMPACT EXPORT 230V 46 30A 125V CONN. COMPACT W/PARK POWER PACKAGING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 305CRCXN N-A N-A 305CRV N-A N-A REPLACE INTERIOR 303 INLET 30A 125V FLANGED INLET LOCKING Marinco Electrical Group Marinco Electrical Group REPLACE INTERIOR 303 INLET 30A 125V FLANGED INLET LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 305CRMB 4 N-A 305FI 0.16 N-A 30A 125V PLUG COMPACT 30A 125V FLANGED INLET LOCKING MAST... Marinco Electrical Group Marinco Electrical Group 30A 125V PLUG COMPACT 30A 125V FLANGED INLET LOCKING MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 305CRPN 1 N-A 305FI.OEM 0.16 N-A 860-442-4386 the edge group • 2014 306648 – 3/4’’ X 48’’ RED HEAT SHRINK RECEPTACLE, 30A 125V NO EARS, LOCKI... Marinco Electrical Group Marinco Electrical Group 30A 125V FLANGED INLET W/4-W MNTG HOLE PATTERN RECEPTACLE; 30A 125V NO EARS; LOCKING MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 305FILD 0.166 N-A 305R.OEM.NE 0.214 N-A 30A 125V FLANGED OUTLET LKG 30A 125V RECEPTACLE, LOCKING MASTER... Marinco Electrical Group Marinco Electrical Group 30A 125V FLANGED OUTLET LKG 30A 125V RECEPTACLE; LOCKING MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 305FO 0.2 N-A 305R.OEM.NMS 0.22 N-A 30A PLUG, LOCKING RECEPTACLE 30A 125V LKG MASTER/50 Marinco Electrical Group Marinco Electrical Group 30A PLUG; LOCKING Bat teries/ Fl a shlights/Charger s 30A 125V FLANGED INLET W/4-W MNTG H... RECEPTACLE 30A 125V LKG MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 305P 0.25 N-A 305RCRS.OEM.NMS 0.22 N-A 30A PLUG, LOCKING MASTER/50 30A 125V RECEPTACLE, LOCKING - ISOL... Marinco Electrical Group Marinco Electrical Group 30A PLUG; LOCKING MASTER/50 30A 125V RECEPTACLE; LOCKING - ISOLATED GRND Part Number Weight Min. Quantity Part Number Weight Min. Quantity 305P.OEM 0.21 N-A 305RIG 0.22 N-A 30A 125V RECEPTACLE, LOCKING 3/4’’ X 48’’ RED HEAT SHRINK Marinco Electrical Group Marinco Electrical Group 30A 125V RECEPTACLE; LOCKING 3/4 X 48 RED HEAT SHRINK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 305R 0.22 N-A 306648 2 N-A 860-442-4386 47 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 306C – 30A CONNECTOR, 250V LOCKING 30A CONNECTOR, 250V LOCKING 30A 250V FLANGED INLET LOCKING Marinco Electrical Group Marinco Electrical Group 30A CONNECTOR; 250V LOCKING 30A 250V FLANGED INLET LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306C 0.27 N-A 306FI 0.16 N-A 30A CONNECTOR, 250V LOCKING MASTER/... 30A 250V FLANGED OUTLET LKG Marinco Electrical Group Marinco Electrical Group 30A CONNECTOR; 250V LOCKING MASTER/50 30A 250V FLANGED OUTLET LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306C.OEM 0.27 N-A 306FO 0.2 N-A 30A CONN, 250V LOCKING NO CLAMP INS... 30A 250V FLANGED OUTLET LKG MASTER/... Marinco Electrical Group Marinco Electrical Group 30A CONN; 250V LOCKING NO CLAMP INSERT MASTER/50 48 30A 250V FLANGED OUTLET LKG MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306C.OEM.NI 0.27 N-A 306FO.OEM 0.2 N-A 30A 250V CONN LKG GRAY NI MASTER/50 30A PLUG, 250V LOCKING Marinco Electrical Group Marinco Electrical Group 30A 250V CONN LKG GRAY NI MASTER/50 30A PLUG; 250V LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306CGY.OEM.NI 0.272 N-A 306P 0.25 N-A 30A, 250V INLET EASY LOCK L6-30 CON... POWER CORD, 5.25’ 12/3STO, WITH RIN... Marinco Electrical Group Marinco Electrical Group 30A; 250V INLET EASY LOCK L6-30 CONFIGURATION MASTER/50 POWER CORD; 5.25’ 12/3STO; WITH RING TERMINALS; GRAY Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306EL-B.OEM N-A N-A 306P-AM3 N-A N-A 860-442-4386 the edge group • 2014 306R.OEM – 30A RECEPTACLE, LOCKING MASTER/50 30A/250V PLG LKG CRMP KIT PACK OF 1... Marinco Electrical Group Marinco Electrical Group POWER CORD; 3.5’ 14/3 STO CRIMPED 30A/250V PLG LKG CRMP KIT PACK OF 100 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306P-AM4 N-A N-A 306PCK N-A N-A POWER CORD, 114’’ 10/3SEOW RING TER... 30A 250V LCKG PLUG GRAY W/NO INSERT... Marinco Electrical Group Marinco Electrical Group POWER CORD; 114 10/3SEOW RING TERMINALS 30A 250V LCKG PLUG GRAY W/NO INSERT MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306P-MT1 N-A N-A 306PGY.OEM.NI 0.212 N-A POWER CORD, 90’’ 10/3 SEOW RING TER... 30A 250V RECEPTACLE, LOCKING Marinco Electrical Group Marinco Electrical Group POWER CORD; 90 10/3 SEOW RING TERMINALS Bat teries/ Fl a shlights/Charger s POWER CORD, 3.5’ 14/3 STO CRIMPED 30A 250V RECEPTACLE; LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306P-MT2 N-A N-A 306R 0.27 N-A 30A PLUG, 250V LOCKING MASTER/50 30A 250V RECEPTACLE LKG Marinco Electrical Group Marinco Electrical Group 30A PLUG; 250V LOCKING MASTER/50 30A 250V RECEPTACLE LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306P.OEM 0.21 N-A 306R-AM1 N-A N-A 30A PLUG, 250V LOCKING MASTER/50 30A RECEPTACLE, LOCKING MASTER/50 Marinco Electrical Group Marinco Electrical Group 30A PLUG; 250V LOCKING MASTER/50 30A RECEPTACLE; LOCKING MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306P.OEM.NI 0.21 N-A 306R.OEM 0.22 N-A 860-442-4386 49 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 306R.OEM.NE – RECPT, 30A 250V LK N/EARS MASTER/50 RECPT, 30A 250V LK N/EARS MASTER/50 22-18 HEATSHRINK BUTT 3 Marinco Electrical Group Marinco Electrical Group RECPT; 30A 250V LK N/EARS MASTER/50 22-18 HEATSHRINK BUTT 3 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306R.OEM.NE 0.22 N-A 309003 0.32 N-A 30A 250V RECEPTACLE LKG MASTER/50 22-18 HEATSHRINK BUTT 25 Marinco Electrical Group Marinco Electrical Group 30A 250V RECEPTACLE LKG MASTER/50 22-18 HEATSHRINK BUTT 25 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306R.OEM.NMS 0.22 N-A 309025 1 N-A RECEPTACLE, 30A LCKG 16-14 HEATSHRINK BUTT 3 Marinco Electrical Group Marinco Electrical Group RECEPTACLE; 30A LCKG 50 16-14 HEATSHRINK BUTT 3 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306RCRS 0.2604 N-A 309103 0.32 N-A 30A 250V RECEPT, LOCKING ISOLATED G... 16-14 HEATSHRINK BUTT 25 Marinco Electrical Group Marinco Electrical Group 30A 250V RECEPT; LOCKING ISOLATED GROUND 16-14 HEATSHRINK BUTT 25 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 306RIG 0.27 N-A 309125 2 N-A 1’’ X 3’’ BLACK HEAT SHRINK 12-10 HEATSHRINK BUTT 3 Marinco Electrical Group Marinco Electrical Group 1 X 3 BLACK HEAT SHRINK 12-10 HEATSHRINK BUTT 3 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 307103 2 N-A 309203 0.48 N-A 860-442-4386 the edge group • 2014 311403 – 16-14 1/4’’ HEATSHRINK RIN G 3 22-18 #8 HEATSHRINK RING 3 Marinco Electrical Group Marinco Electrical Group 12-10 HEATSHRINK BUTT 25 22-18 #8 HEATSHRINK RING 3 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 309225 3 N-A 310203 0.32 N-A PLUG, 30A 125V, SB 22-18 #10 HEATSHRINK RING 3 Marinco Electrical Group Marinco Electrical Group PLUG; 30A 125V; SB 22-18 #10 HEATSHRINK RING 3 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 30MPRV N-A N-A 310303 0.32 N-A HAND OPERATED WINDSHIELD WIPER 16-14 #8 HEATSHRINK RING 3 Marinco Electrical Group Marinco Electrical Group HAND OPERATED WINDSHIELD WIPER Bat teries/ Fl a shlights/Charger s 12-10 HEATSHRINK BUTT 25 16-14 #8 HEATSHRINK RING 3 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 31000 N-A N-A 311203 0.32 N-A 12’’ POLY WIPER BLADE, BLK 16-14 #10 HEATSHRINK RING 3 Marinco Electrical Group Marinco Electrical Group 12 POLY WIPER BLADE; BLK 16-14 #10 HEATSHRINK RING 3 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 31012B 3 N-A 311303 0.32 N-A 14’’ POLY WIPER BLADE BLACK 16-14 1/4’’ HEATSHRINK RIN G 3 Marinco Electrical Group Marinco Electrical Group 14 POLY WIPER BLADE BLACK 16-14 1/4 HEATSHRINK RIN G 3 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 31014B 3 N-A 311403 0.16 N-A 860-442-4386 51 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 312303 – 12-10 #10 HEATSHRINK RING 3 12-10 #10 HEATSHRINK RING 3 16-14 MALE HEATSHRINK DISCONNECT Marinco Electrical Group Marinco Electrical Group 12-10 #10 HEATSHRINK RING 3 16-14 MALE HEATSHRINK DISCONNECT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 312303 0.39 N-A 317903 N-A N-A 12-10 1/4’’ HEATSHRINK RING 3 CONNECTOR IEC 60320 C13 Marinco Electrical Group Marinco Electrical Group 12-10 1/4 HEATSHRINK RING 3 CONNECTOR IEC 60320 C13 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 312403 0.48 N-A 320IEC13 0.138 N-A 12-10 5/16’’ HEATSHRINK RING 3 CONNECTOR IEC 60320 C15 Marinco Electrical Group Marinco Electrical Group 12-10 5/16 HEATSHRINK RING 3 52 CONNECTOR IEC 60320 C15 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 312503 0.48 N-A 320IEC15 0.134 N-A 22-18 FEMALE HEATSHRINK DISCONNECT CONNECTOR IEC 60320 C19 Marinco Electrical Group Marinco Electrical Group 22-18 FEMALE HEATSHRINK DISCONNECT CONNECTOR IEC 60320 C19 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 316803 0.37 N-A 320IEC19 0.128 N-A 16-14 FEMALE HEATSHRINK DISCONNECT 1’’ BLK HEAVY WALL SHRINK 48’’ PCS Marinco Electrical Group Marinco Electrical Group 16-14 FEMALE HEATSHRINK DISCONNECT 1 BLK HEAVY WALL SHRINK 48 PCS Part Number Weight Min. Quantity Part Number Weight Min. Quantity 317803 N-A N-A 327148 1 N-A 860-442-4386 the edge group • 2014 3763N – 50A 250V DC/50A 600V AC PLUG CORDSET, 30A, 125V LED ERGO GRIP, 3... Marinco Electrical Group Marinco Electrical Group 14 CURVED BLADE CORDSET; 30A; 125V LED ERGO GRIP; 35’ YELLOW Part Number Weight Min. Quantity Part Number Weight Min. Quantity 33005 4 N-A 35SPP N-A N-A DLX ARM, 10’’-14’’ ARTICULATING, SI... WIPER KIT, AFI-1000 80D SWEEP,2-1/2... Marinco Electrical Group Marinco Electrical Group DLX ARM; 10-14 ARTICULATING; SILVER WIPER KIT; AFI-1000 80D SWEEP;2-1/2 SHAFT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 33007A 1 N-A 37100 N-A N-A DLX ARM, 14’’-20’’ AFTRMKT ARTICULA... WIPER KIT, AFI-1000 110D SWEP,2-1/2... Marinco Electrical Group Marinco Electrical Group DLX ARM; 14-20 AFTRMKT ARTICULATING; BLACK Bat teries/ Fl a shlights/Charger s 14’’ CURVED BLADE WIPER KIT; AFI-1000 110D SWEP;2-1/2SHAFT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 33014A 9 N-A 37200 N-A N-A 11’’ CURVED BLADE - OEM 50A 250V DC/50A 600V AC CONN. Marinco Electrical Group Marinco Electrical Group 11 CURVED BLADE - OEM 50A 250V DC/50A 600V AC CONN. Part Number Weight Min. Quantity Part Number Weight Min. Quantity 33104 N-A N-A 3762N 1 N-A DLX ARM, 6-3/4’’-10-1/2’’ ARTICULAT... 50A 250V DC/50A 600V AC PLUG Marinco Electrical Group Marinco Electrical Group DLX ARM; 6-3/4-10-1/2 ARTICULATING; SILVER 50A 250V DC/50A 600V AC PLUG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 33106A N-A N-A 3763N 1 N-A 860-442-4386 53 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 3764N – 50A 600V AC/50A 250V DC CONN. 50A 600V AC/50A 250V DC CONN. 50A 250V DC/50A 600V AC INLET Marinco Electrical Group Marinco Electrical Group 50A 600V AC/50A 250V DC CONN. 50A 250V DC/50A 600V AC INLET Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3764N 1 N-A 3777 0.39 N-A 50A 600V AC/50A 250V DC PLUG MRV 110 2 SPEED 2-1/2’’OEM Marinco Electrical Group Marinco Electrical Group 50A 600V AC/50A 250V DC PLUG MRV 110 2 SPEED 2-1/2OEM Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3765N 1 N-A 38010 N-A N-A 50A 250V DC/600V AC RECEPTACLE MRV 60, 1-1/2’’, 24 VOLT, 2 SPEED, ... Marinco Electrical Group Marinco Electrical Group 50A 250V DC/600V AC RECEPTACLE 54 MRV 60; 1-1/2; 24 VOLT; 2 SPEED; OEM Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3769 1 N-A 38261 N-A N-A 50A 250V DC/600V AC RECEPTACLE 1/4’’ NAT CLAMP 25 Marinco Electrical Group Marinco Electrical Group 50A 250V DC/600V AC RECEPTACLE 1/4 NAT CLAMP 25 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3771 0.39 N-A 401252 1 N-A 50A 600V AC/50A 250V DC INLET 5/16’’ NAT CLAMP 25 Marinco Electrical Group Marinco Electrical Group 50A 600V AC/50A 250V DC INLET 5/16 NAT CLAMP 25 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 3775 1 N-A 401312 2 N-A 860-442-4386 the edge group • 2014 403752 – 3/4’’ STAINLESS STEEL CUSH ION CLAM... 3/16’’ STAINLESS STEEL CUS HION CLA... Marinco Electrical Group Marinco Electrical Group 3/8 NAT CLAMP 25 3/16 STAINLESS STEEL CUS HION CLAMP Part Number Weight Min. Quantity Part Number Weight Min. Quantity 401372 1 N-A 403182 3 N-A 1/2’’ NAT CLAMP (25) 3/8’’ STAINLESS STEEL CUSH ION CLAM... Marinco Electrical Group Marinco Electrical Group 1/2 NAT CLAMP (25) 3/8 STAINLESS STEEL CUSH ION CLAMP Part Number Weight Min. Quantity Part Number Weight Min. Quantity 401502 0.16 N-A 403372 4 N-A 5/8’’ NAT CLAMP 25 1/2’’ STAINLESS STEEL CUSH ION CLAM... Marinco Electrical Group Marinco Electrical Group 5/8 NAT CLAMP 25 Bat teries/ Fl a shlights/Charger s 3/8’’ NAT CLAMP 25 1/2 STAINLESS STEEL CUSH ION CLAMP Part Number Weight Min. Quantity Part Number Weight Min. Quantity 401622 2 N-A 403502 4 N-A 3/4’’ NAT CLAMP 25 5/8’’ STAINLESS STEEL CUSH ION CLAM... Marinco Electrical Group Marinco Electrical Group 3/4 NAT CLAMP 25 5/8 STAINLESS STEEL CUSH ION CLAMP Part Number Weight Min. Quantity Part Number Weight Min. Quantity 401752 2 N-A 403622 5 N-A 1’’ NAT CLAMP 25 3/4’’ STAINLESS STEEL CUSH ION CLAM... Marinco Electrical Group Marinco Electrical Group 1 NAT CLAMP 25 3/4 STAINLESS STEEL CUSH ION CLAMP Part Number Weight Min. Quantity Part Number Weight Min. Quantity 401892 3 N-A 403752 6 N-A 860-442-4386 55 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 403892 – 1’’ STAINLESS STEEL CUSHIO N CLAMP 1’’ STAINLESS STEEL CUSHIO N CLAMP Wire Shoe #6 AWG; Qty. 30 Marinco Electrical Group Marinco Electrical Group 1 STAINLESS STEEL CUSHIO N CLAMP Wire Shoe #6 AWG; Qty. 30 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 403892 7 N-A 430129.1 0.0895 N-A 1 1/4 STAINLESS STEEL CUS HION CLAM... Wire Shoe #2 AWG; Qty. 30 Marinco Electrical Group Marinco Electrical Group 1 1/4 STAINLESS STEEL CUS HION CLAMP Wire Shoe #2 AWG; Qty. 30 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 403902 9 N-A 430130.1 0.0685 N-A SCREW, 8-32 X 1/4’’, TERMINAL, BRAS... CL/CLS Copper Shim; Qty. 25 Marinco Electrical Group Marinco Electrical Group SCREW; 8-32 X 1/4; TERMINAL; BRASS; FOR 20A BATES; PACK OF 300 56 CL/CLS Copper Shim; Qty. 25 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 430112.1 N-A N-A 430244.1 0.1705 N-A Stage Pin Wire Shoe (20A); #12 AWG ... CLS Strain Relief Wire; Qty. 100 Marinco Electrical Group Marinco Electrical Group Stage Pin Wire Shoe (20A); #12 AWG Pack of 300 CLS Strain Relief Wire; Qty. 100 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 430117.1 0.099 N-A 430245.1 1 N-A SCREW, 5/16-24 X 3/8’’, SET, HEX, C... CLM Strain Relief Wire; Qty. 100 Marinco Electrical Group Marinco Electrical Group SCREW; 5/16-24 X 3/8; SET; HEX; CLM & BATES 100A; PACK OF 60 CLM Strain Relief Wire; Qty. 100 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 430126.1 0.2835 N-A 430246.1 0.223 N-A 860-442-4386 the edge group • 2014 4570 – 15A 250V PLUG, LOCKING 1/2’’ X 10’ FLAME RETARDAN T SPLIT ... Marinco Electrical Group Marinco Electrical Group 100’ 3/8 SPIRAL WRAP BLACK 1/2 X 10’ FLAME RETARDAN T SPLIT LOOM Part Number Weight Min. Quantity Part Number Weight Min. Quantity 452385 39 N-A 453502 4 N-A 100’ 1/2’’ SPIRAL WRAP BLACK 3/4’’ X 100’ FLAME RETARDA NT SPLIT... Marinco Electrical Group Marinco Electrical Group 100’ 1/2 SPIRAL WRAP BLACK 3/4 X 100’ FLAME RETARDA NT SPLIT LOOM Part Number Weight Min. Quantity Part Number Weight Min. Quantity 452505 59 N-A 453756 72 N-A 10’ 3/4’’ SPIRAL WRAP BLACK RECEPT, 15A 250V DUPLEX Marinco Electrical Group Marinco Electrical Group 10’ 3/4 SPIRAL WRAP BLACK Bat teries/ Fl a shlights/Charger s 100’ 3/8’’ SPIRAL WRAP BLACK RECEPT; 15A 250V DUPLEX Part Number Weight Min. Quantity Part Number Weight Min. Quantity 452751 8 N-A 4550 0.22 N-A GALVANIC ISOLATOR 60A RECEPT, 15A 250V SINGLE Marinco Electrical Group Marinco Electrical Group GALVANIC ISOLATOR 60A RECEPT; 15A 250V SINGLE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4531011 65 N-A 4560 0.16 N-A 3/8’’ X 100’ FLAME RETARDA NT SPLIT... 15A 250V PLUG, LOCKING Marinco Electrical Group Marinco Electrical Group 3/8 X 100’ FLAME RETARDA NT SPLIT LOOM 15A 250V PLUG; LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 453386 120 N-A 4570 0.13 N-A 860-442-4386 57 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 4570-AM1 – CORDSET, IEC320-C13 14/3 SJT 148’’ CORDSET, IEC320-C13 14/3 SJT 148’’ POWER CORD, 11’ 14/3 SJOW CRIMP Marinco Electrical Group Marinco Electrical Group CORDSET; IEC320-C13 14/3 SJT 148 POWER CORD; 11’ 14/3 SJOW CRIMP Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-AM1 N-A N-A 4570-AM20 N-A N-A CORDSET, IEC320-C13 RA 14/3 SJT 72’... CORDSET, IEC320-C13 RA 14/3 SJT 12.... Marinco Electrical Group Marinco Electrical Group CORDSET; IEC320-C13 RA 14/3 SJT 72 CORDSET; IEC320-C13 RA 14/3 SJT 12.5’ Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-AM11 N-A N-A 4570-AM21 N-A N-A CORDSET, IEC320-C13 Y 14/3 SJT 130’... CORDSET, 52’’ 14/3 SJT Y Marinco Electrical Group Marinco Electrical Group CORDSET; IEC320-C13 Y 14/3 SJT 130 58 CORDSET; 52 14/3 SJT Y Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-AM12 N-A N-A 4570-AM23 N-A N-A POWER CORD, 8’ 14/3 SJO CRIMP CORDSET, 320IEC13 14/3 SEO 180’’ Marinco Electrical Group Marinco Electrical Group POWER CORD; 8’ 14/3 SJO CRIMP CORDSET; 320IEC13 14/3 SEO 180 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-AM13 N-A N-A 4570-AM27 N-A N-A CORDSET, IEC320-C13 RA 14/3 SJT 240... CORDSET, 84’’Y 14/3 SJT Marinco Electrical Group Marinco Electrical Group CORDSET; IEC320-C13 RA 14/3 SJT 240 CORDSET; 84Y 14/3 SJT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-AM14 N-A N-A 4570-AM30 N-A N-A 860-442-4386 the edge group • 2014 4570-MT13 – POWER CORD, 148’’, CAGE FAN ASSEMBL... CORD SET, 100’’ 14/3 SJT Y W/ WAGO ... Marinco Electrical Group Marinco Electrical Group POWER CORD; 4’ 14/3 AWM CONTROL CORD SET; 100 14/3 SJT Y W/ WAGO CONNECTORS Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-AM32 N-A N-A 4570-AM45 N-A N-A CORDSET, 320IEC13 14/3 SEOW 40’ CORDSET, 14/3 SJT W/WAGO 7 POLE CON... Marinco Electrical Group Marinco Electrical Group CORDSET; 320IEC13 14/3 SEOW 40’ CORDSET; 14/3 SJT W/WAGO 7 POLE CONN. Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-AM36 N-A N-A 4570-AM46 N-A N-A CORDSET, 14/3 SJT TRIPL Y W/WAGO 7 ... POWER CORD, 4’ 14/3 SJO CRIMP, RING... Marinco Electrical Group Marinco Electrical Group CORDSET; 14/3 SJT TRIPL Y W/WAGO 7 POLE CONN. (2X) POWER CORD; 4’ 14/3 SJO CRIMP; RING TERMINALS Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-AM38 N-A N-A 4570-AM7 N-A N-A CORDSET, IEC320-C13 14/3 SJT 72’’ CORDSET, IEC320-C13 96’’ 14/3 SJT Marinco Electrical Group Marinco Electrical Group CORDSET; IEC320-C13 14/3 SJT 72 CORDSET; IEC320-C13 96 14/3 SJT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-AM4 N-A N-A 4570-MT1 N-A N-A POWER CORD, 100’’ 16/5 W/ AMP CONNE... POWER CORD, 148’’, CAGE FAN ASSEMBL... Marinco Electrical Group Marinco Electrical Group POWER CORD; 100 16/5 W/ AMP CONNECTOR POWER CORD; 148; CAGE FAN ASSEMBLY W/RING TERMINALS Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-AM44 N-A N-A 4570-MT13 N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s POWER CORD, 4’ 14/3 AWM CONTROL 59 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 4570-MT14 – POWER CORD, 172’’, CAGE FAN ASSEMBL... POWER CORD, 172’’, CAGE FAN ASSEMBL... CORDSET, IEC320-C13 180’’ 14/3 SJT Marinco Electrical Group Marinco Electrical Group POWER CORD; 172; CAGE FAN ASSEMBLY W/RING TERMINALS CORDSET; IEC320-C13 180 14/3 SJT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-MT14 N-A N-A 4570-MT5 N-A N-A POWER CORD, 97’’ VOLEX #170638A_10 ... CORDSET, 4579 CONN 174’’ 14/3 SEOW Marinco Electrical Group Marinco Electrical Group POWER CORD; 97 VOLEX #170638A_10 C3 CORDSET; 4579 CONN 174 14/3 SEOW Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-MT15 N-A N-A 4570-MT6 N-A N-A CORDSET, IEC320-C13 120’’ 14/3 SJT CORDSET, IEC 320-C13 192’’ 14/3 SJT Marinco Electrical Group Marinco Electrical Group CORDSET; IEC320-C13 120 14/3 SJT 60 CORDSET; IEC 320-C13 192 14/3 SJT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-MT2 N-A N-A 4570-MT7 N-A N-A CORDSET, IEC320-C13 144’’ 14/3 SJT CORDSET, IEC320-C13 204’’ 14/3 SJT Marinco Electrical Group Marinco Electrical Group CORDSET; IEC320-C13 144 14/3 SJT CORDSET; IEC320-C13 204 14/3 SJT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-MT3 N-A N-A 4570-MT8 N-A N-A CORDSET, IEC320-C13 168’’ 14/3 SJT CORDSET, IEC320-C13 216’’ 14/3 SJT Marinco Electrical Group Marinco Electrical Group CORDSET; IEC320-C13 168 14/3 SJT CORDSET; IEC320-C13 216 14/3 SJT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570-MT4 N-A N-A 4570-MT9 N-A N-A 860-442-4386 the edge group • 2014 4715 – 15A 125V 2P 3W LKG OUTLET FLANGED 15A 250V FLG. INLET, LKG. Marinco Electrical Group Marinco Electrical Group 15A 250V PLUG; LOCKING MASTER/50 15A 250V FLG. INLET; LKG. Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570.OEM 0.118 N-A 4586 0.134 N-A 15A 250V PLUG, LKG GRAY MASTER/50 RIGHT ANGLE HOUSING FOR 4- & 5-WIRE... Marinco Electrical Group Marinco Electrical Group 15A 250V PLUG; LKG GRAY MASTER/50 RIGHT ANGLE HOUSING FOR 4- & 5-WIRE DEVICES MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4570GY.OEM 0.12 N-A 45WRA.OEM N-A N-A 15A 250V CONN, LKG RECEPT, 15A 125V DUPLEX Marinco Electrical Group Marinco Electrical Group 15A 250V CONN; LKG Bat teries/ Fl a shlights/Charger s 15A 250V PLUG, LOCKING MASTER/50 RECEPT; 15A 125V DUPLEX Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4579 0.154 N-A 4700 0.23 N-A 15A 250V CONN, LOCKING, GRAY MASTER... RECEPT, 15A 125V SINGLE Marinco Electrical Group Marinco Electrical Group 15A 250V CONN; LOCKING; GRAY MASTER/50 RECEPT; 15A 125V SINGLE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4579GY.OEM 0.142 N-A 4710 0.16 N-A 15A 250V FLG. OUTLET, LKG 15A 125V 2P 3W LKG OUTLET FLANGED Marinco Electrical Group Marinco Electrical Group 15A 250V FLG. OUTLET; LKG 15A 125V 2P 3W LKG OUTLET FLANGED Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4585 0.13 N-A 4715 0.15 N-A 860-442-4386 61 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 4716 – 15A 125V 2P 3W LKG INLET FLANGED 15A 125V 2P 3W LKG INLET FLANGED CORDSET, IEC320-C13 14/3 SJT 300’’ ... Marinco Electrical Group Marinco Electrical Group 15A 125V 2P 3W LKG INLET FLANGED CORDSET; IEC320-C13 14/3 SJT 300 120V MARKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4716 0.134 N-A 4720-AM3 N-A N-A 15A 125V 2P 3W LKG FLG IN MALE MAST... POWER CORD, 5’ 14/3 SJT WITH RING T... Marinco Electrical Group Marinco Electrical Group 15A 125V 2P 3W LKG FLG IN MALE MASTER/50 POWER CORD; 5’ 14/3 SJT WITH RING TERMINALS Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4716.OEM 0.11 N-A 4720-AM5 N-A N-A 15A 125V PLUG, LOCKING CORDSET, IEC320-C13 14/3 SJT 120’’ ... Marinco Electrical Group Marinco Electrical Group 15A 125V PLUG; LOCKING 62 CORDSET; IEC320-C13 14/3 SJT 120 120V MARKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4720 0.132 N-A 4720-AM6 N-A N-A POWER CORD, 12’ 14/3 SJT WITH RING ... CORDSET, IEC320-C13 14/3 SJT 3.5’,1... Marinco Electrical Group Marinco Electrical Group POWER CORD; 12’ 14/3 SJT WITH RING TERMINALS CORDSET; IEC320-C13 14/3 SJT 3.5’;15A (R)ANGLE HS Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4720-AM10 N-A N-A 4720-AM9 N-A N-A CORDSET, IEC320-C13 14/3 SJT 3.5, 1... 15A 125V PLUG, LOCKING MASTER/50 Marinco Electrical Group Marinco Electrical Group CORDSET; IEC320-C13 14/3 SJT 3.5; 15A (R)ANGLE HSG 15A 125V PLUG; LOCKING MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4720-AM13 N-A N-A 4720.OEM 0.118 N-A 860-442-4386 the edge group • 2014 4729L – 15A 125V CONN. LKG W/NEON BULB 15A 125 CONN, LKG MASTER/50 Marinco Electrical Group Marinco Electrical Group 15A 125V PLUG; LOCK BLACK 15A 125 CONN; LKG MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4720BL 0.13 N-A 4729.OEM 0.14 N-A 15A 125V PLUG LKG GRAY MASTER/50 15A 125V CONN LOCK BLACK Marinco Electrical Group Marinco Electrical Group 15A 125V PLUG LKG GRAY MASTER/50 15A 125V CONN LOCK BLACK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4720GY.OEM 0.12 N-A 4729BL 0.142 N-A 15A 125V PLUG, LKG W/NEON LIGHT AND... 15A 125V CONN LOCK BLACK MASTER/50 Marinco Electrical Group Marinco Electrical Group 15A 125V PLUG; LKG W/NEON LIGHT AND CLEAR HOUSING 15A 125V CONN LOCK BLACK MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4720L 0.141 N-A 4729BL.OEM 0.142 N-A 15A PLUG, LOCKING 15A 125V CONN LKG GRAY MASTER/50 Marinco Electrical Group Marinco Electrical Group 15A PLUG; LOCKING 15A 125V CONN LKG GRAY MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4721CR 2 N-A 4729GY.OEM 0.142 N-A 15A 125V CONN, LKG. 15A 125V CONN. LKG W/NEON BULB Marinco Electrical Group Marinco Electrical Group 15A 125V CONN; LKG. 15A 125V CONN. LKG W/NEON BULB Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4729 0.152 N-A 4729L 0.1635 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s 15A 125V PLUG, LOCK BLACK 63 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 4760 – RECEPT, 15A 277V SGL. RECEPT, 15A 277V SGL. 15A 277V CONN, LKG. Marinco Electrical Group Marinco Electrical Group RECEPT; 15A 277V SGL. 15A 277V CONN; LKG. Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4760 0.16 N-A 4779 0.154 N-A 15A 277V PLUG, LOCKING 15A 277V FLG. OUTLET, LKG Marinco Electrical Group Marinco Electrical Group 15A 277V PLUG; LOCKING 15A 277V FLG. OUTLET; LKG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4770 0.132 N-A 4785 0.13 N-A CORDSET, 84’’ 14/3 SJT Y FLANGED OUTLET, 43’’ WIRE HARNESS 1... Marinco Electrical Group Marinco Electrical Group CORDSET; 84 14/3 SJT Y 64 FLANGED OUTLET; 43 WIRE HARNESS 16 AWG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4770-AM3 N-A N-A 4785-AM2 N-A N-A CORDSET, 17’’ 16/3 SEOW SHIELDED FLANGED OUTLET, 55’’ WIRE HARNESS 1... Marinco Electrical Group Marinco Electrical Group CORDSET; 17 16/3 SEOW SHIELDED FLANGED OUTLET; 55 WIRE HARNESS 16 AWG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4770-AM4 N-A N-A 4785-AM3 N-A N-A CORDSET, 24’’ 16/3 SEOW SHIELDED, W... 15A 277V FLG. INLET, LKG. Marinco Electrical Group Marinco Electrical Group CORDSET; 24 16/3 SEOW SHIELDED; W/AMP PLUG 15A 277V FLG. INLET; LKG. Part Number Weight Min. Quantity Part Number Weight Min. Quantity 4770-AM6 N-A N-A 4786 0.1 N-A 860-442-4386 the edge group • 2014 520217A – HSG 20A INLN TOP ORG ADAPTER, 50M TO 30F, SB 14-50P TO T... Marinco Electrical Group Marinco Electrical Group SCREW; SET; CLS; QTY 50 ADAPTER; 50M TO 30F; SB 14-50P TO TT-30R Part Number Weight Min. Quantity Part Number Weight Min. Quantity 500017PLT.1 1 N-A 5030ARV N-A N-A SCREW, SET, CL, QTY 50 50A SEALING COLLAR WITH RING Marinco Electrical Group Marinco Electrical Group SCREW; SET; CL; QTY 50 50A SEALING COLLAR WITH RING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 500032PLT.1 1 N-A 510R 2 N-A CONTACT, FEMALE SIZING TOOL 400A CL... HSG 20A INLN TOP Marinco Electrical Group Marinco Electrical Group CONTACT; FEMALE SIZING TOOL 400A CL/CLS Bat teries/ Fl a shlights/Charger s SCREW, SET, CLS, QTY 50 HSG 20A INLN TOP Part Number Weight Min. Quantity Part Number Weight Min. Quantity 500072 N-A N-A 520210A N-A N-A CONTACT CLS 18 #2 FEM HSG 20A INLN TOP GRN Marinco Electrical Group Marinco Electrical Group CONTACT CLS 18 #2 FEM HSG 20A INLN TOP GRN Part Number Weight Min. Quantity Part Number Weight Min. Quantity 500104A N-A N-A 520216A N-A N-A 50A THREADED RING HSG 20A INLN TOP ORG Marinco Electrical Group Marinco Electrical Group 50A THREADED RING HSG 20A INLN TOP ORG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 500R 1 N-A 520217A N-A N-A 860-442-4386 65 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 520221A – HSG 20A INLN TOP CLR HSG 20A INLN TOP CLR 15A 125V 2P 3W SB PLUG Marinco Electrical Group Marinco Electrical Group HSG 20A INLN TOP CLR 15A 125V 2P 3W SB PLUG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 520221A N-A N-A 5266 0.126 N-A SCREW, RETAINING, CLS, QTY. 25 15A 125V 2P 3W SB PLUG MASTER/50 Marinco Electrical Group Marinco Electrical Group SCREW; RETAINING; CLS; QTY. 25 15A 125V 2P 3W SB PLUG MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 520710.1 N-A N-A 5266.OEM 0.114 N-A SCREW, RETAINING, CLM, QTY. 25 15A 125V 2P 3W SB PLUG BLACK Marinco Electrical Group Marinco Electrical Group SCREW; RETAINING; CLM; QTY. 25 66 15A 125V 2P 3W SB PLUG BLACK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 520730.1 0.035 N-A 5266BL 0.11 N-A RECEPT, 15A 125V SINGLE 15A 125V 2P 3W SB PLUG BLACK MASTER... Marinco Electrical Group Marinco Electrical Group RECEPT; 15A 125V SINGLE 15A 125V 2P 3W SB PLUG BLACK MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5251 0.16 N-A 5266BL.OEM 0.11 N-A RECEPT, 15A 125V DUPLEX BROWN 15A 125V 2P 3W SB PLUG CR Marinco Electrical Group Marinco Electrical Group RECEPT; 15A 125V DUPLEX BROWN 15A 125V 2P 3W SB PLUG CR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5252 0.22 N-A 5266CRS 0.11 N-A 860-442-4386 the edge group • 2014 5269L – 15A 125V 2P 3W CONNECTOR WITH NEON ... 15A 125V 2P 3W CONNECTOR MASTER/50 Marinco Electrical Group Marinco Electrical Group 15A 125V PLUG SB GRAY MASTER/50 15A 125V 2P 3W CONNECTOR MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5266GY.OEM 0.11 N-A 5269.OEM 0.13 N-A 15A 125V 2P 3W SB PLUG WITH NEON BU... 15A 125V 2P 3W CONNECTOR BLACK Marinco Electrical Group Marinco Electrical Group 15A 125V 2P 3W SB PLUG WITH NEON BULB 15A 125V 2P 3W CONNECTOR BLACK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5266L 0.13 N-A 5269BL 0.13 N-A 15A 125V SB RIGHT ANGLE PLUG 15A 125V 2P 3W CONNECTOR BLACK MAST... Marinco Electrical Group Marinco Electrical Group 15A 125V SB RIGHT ANGLE PLUG Bat teries/ Fl a shlights/Charger s 15A 125V PLUG SB GRAY MASTER/50 15A 125V 2P 3W CONNECTOR BLACK MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5266RA 0.188 N-A 5269BL.OEM 0.13 N-A 15A 125V 2P 3W SB PLUG YEL 15A 125V 2P 3W CONNECTOR Marinco Electrical Group Marinco Electrical Group 15A 125V 2P 3W SB PLUG YEL 15A 125V 2P 3W CONNECTOR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5266YL.OEM 0.11 N-A 5269CR 2 N-A 15A 125V 2P 3W CONNECTOR 15A 125V 2P 3W CONNECTOR WITH NEON ... Marinco Electrical Group Marinco Electrical Group 15A 125V 2P 3W CONNECTOR 15A 125V 2P 3W CONNECTOR WITH NEON BULB Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5269 0.146 N-A 5269L N-A N-A 860-442-4386 67 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 5278 – 15A 125V 2P 3W SB INLET FLANGED 15A 125V 2P 3W SB INLET FLANGED INLET, DUST RESIST REAR MOUNT, 15A ... Marinco Electrical Group Marinco Electrical Group 15A 125V 2P 3W SB INLET FLANGED INLET; DUST RESIST REAR MOUNT; 15A 125V SB MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5278 0.116 N-A 5278DRI-TM.OEM 0.264 N-A 15A 125V 2P 3W SB INLET FLANGED MAS... 15A 125V 2P 3W SB INLET FRONT MOUNT... Marinco Electrical Group Marinco Electrical Group 15A 125V 2P 3W SB INLET FLANGED MASTER/50 15A 125V 2P 3W SB INLET FRONT MOUNT W/COVER MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5278.OEM 0.1 N-A 5278DRI.OEM 0.1 N-A 15A 125V FLANGED INLET SB BLACK 15A 125V 2P 3W OUTLET FLANGED Marinco Electrical Group Marinco Electrical Group 15A 125V FLANGED INLET SB BLACK 68 15A 125V 2P 3W OUTLET FLANGED Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5278BL 0.1 N-A 5279 0.142 N-A 15A 125V FLANGED INLET SB BLACK MAS... 15A 125V FLANGED OUTLET SB BLACK Marinco Electrical Group Marinco Electrical Group 15A 125V FLANGED INLET SB BLACK MASTER/50 15A 125V FLANGED OUTLET SB BLACK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5278BL.OEM 0.1 N-A 5279BL 0.13 N-A 15A 125V 2P 3W SB INLET FRONT MOUNT... 15A 125V FLANGED OUTLET SB BLACK MA... Marinco Electrical Group Marinco Electrical Group 15A 125V 2P 3W SB INLET FRONT MOUNT W/COVER 15A 125V FLANGED OUTLET SB BLACK MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5278DRI 0.1 N-A 5279BL.OEM 0.13 N-A 860-442-4386 the edge group • 2014 5369CR – 20A 125V 2P 3W CONNECTOR CR RECEPT, 20A 125V DUPLEX Marinco Electrical Group Marinco Electrical Group 15A 125V 2P 3W SB DUST RESISTANT OUTLET RECEPT; 20A 125V DUPLEX Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5279DRO N-A N-A 5352 0.22 N-A BULB D C INDEX, 24V, 1.04 A, 25.0W,... 20A 125V 2P 3W SB PLUG Marinco Electrical Group Marinco Electrical Group BULB D C INDEX; 24V; 1.04 A; 25.0W; 24CP 1 20A 125V 2P 3W SB PLUG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 529341 0.16 N-A 5366 0.118 N-A LED, FESTOON, 8 LED, 12V, 10 X 44 M... 20A 125V 2P 3W SB PLUG MASTER/50 Marinco Electrical Group Marinco Electrical Group LED; FESTOON; 8 LED; 12V; 10 X 44 MM Bat teries/ Fl a shlights/Charger s 15A 125V 2P 3W SB DUST RESISTANT OU... 20A 125V 2P 3W SB PLUG MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 529417 0.48 N-A 5366.OEM 0.11 N-A BULB STANDARD BASE, 24V, 50W 2 20A 125V 2P 3W CONNECTOR Marinco Electrical Group Marinco Electrical Group BULB STANDARD BASE; 24V; 50W 2 20A 125V 2P 3W CONNECTOR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 532050 N-A N-A 5369 0.148 N-A RECEPT, 20A 125V SINGLE 20A 125V 2P 3W CONNECTOR CR Marinco Electrical Group Marinco Electrical Group RECEPT; 20A 125V SINGLE 20A 125V 2P 3W CONNECTOR CR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5351 0.16 N-A 5369CR N-A N-A 860-442-4386 69 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 5378 – 20A 125V 2P 3W SB INLET FLANGED 20A 125V 2P 3W SB INLET FLANGED RECEPT, 20A 250V DUPLEX Marinco Electrical Group Marinco Electrical Group 20A 125V 2P 3W SB INLET FLANGED RECEPT; 20A 250V DUPLEX Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5378 0.118 N-A 5462 0.23 N-A 20A 125V 2P 3W OUTLET FLANGED 20A 250V 2P 3W SB PLUG Marinco Electrical Group Marinco Electrical Group 20A 125V 2P 3W OUTLET FLANGED 20A 250V 2P 3W SB PLUG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5379 0.13 N-A 5466 0.124 N-A 20A 125V 2P 3W OUTLET FLANGED MASTE... 20A 250V 2P 3W CONNECTOR Marinco Electrical Group Marinco Electrical Group 20A 125V 2P 3W OUTLET FLANGED MASTER/50 70 20A 250V 2P 3W CONNECTOR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5379.OEM 0.13 N-A 5469 0.146 N-A 20A 125V 2P 3W SB DUST RESISTANT OU... 20A 250V 2P 3W SB INLET FLANGED Marinco Electrical Group Marinco Electrical Group 20A 125V 2P 3W SB DUST RESISTANT OUTLET 20A 250V 2P 3W SB INLET FLANGED Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5379DRO N-A N-A 5478 0.1 N-A RECEPT, 20A 250V SINGLE 20A 250V 2P 3W OUTLET FLANGED Marinco Electrical Group Marinco Electrical Group RECEPT; 20A 250V SINGLE 20A 250V 2P 3W OUTLET FLANGED Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5461 0.16 N-A 5479 0.142 N-A 860-442-4386 the edge group • 2014 5669 – 15A 250V 2P 3W CONNECTOR 15A 250V 2P 3W SB PLUG Marinco Electrical Group Marinco Electrical Group Circuit Breaker; Standard Black Toggle; Single Pol 15A 250V 2P 3W SB PLUG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 551510 3 N-A 5666 0.124 N-A Circuit Breaker, Standard White Tog... POWER CORD,14-3 SEOW 5’W/ AMPHENOL ... Marinco Electrical Group Marinco Electrical Group Circuit Breaker; Standard White Toggle; Double Pol POWER CORD;14-3 SEOW 5’W/ AMPHENOL CONNECTOR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 552830 6 N-A 5666-AM3 N-A N-A 4 GANG 26A 380V PIN TRML BLOCK POWER CORD, 14/3 SJT IEC320-C13 Marinco Electrical Group Marinco Electrical Group 4 GANG 26A 380V PIN TRML BLOCK Bat teries/ Fl a shlights/Charger s Circuit Breaker, Standard Black Tog... POWER CORD; 14/3 SJT IEC320-C13 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 553091 N-A N-A 5666-AM5 N-A N-A 12 GANG 26A 380V PIN TRML BLOCK POWER CORD, 14/3 SJT W/RA IEC320-C1... Marinco Electrical Group Marinco Electrical Group 12 GANG 26A 380V PIN TRML BLOCK POWER CORD; 14/3 SJT W/RA IEC320-C13 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 553095 N-A N-A 5666-AM6 N-A N-A WATERPROOF TOGGLE BOOTS B LACK 5 15A 250V 2P 3W CONNECTOR Marinco Electrical Group Marinco Electrical Group WATERPROOF TOGGLE BOOTS B LACK 5 15A 250V 2P 3W CONNECTOR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 555105 N-A N-A 5669 0.148 N-A 860-442-4386 71 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 5678 – 15A 250V 2P 3W SB INLET FLANGED 15A 250V 2P 3W SB INLET FLANGED CLS SERIES RED (C) FEM BOOT W/SCREW Marinco Electrical Group Marinco Electrical Group 15A 250V 2P 3W SB INLET FLANGED CLS SERIES RED (C) FEM BOOT W/SCREW Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5678 0.122 N-A 600097-C N-A N-A 15A 250V 2P 3W SB INLET FRONT MOUNT... CLS SERIES BLUE (D) FEM BOOT W/SCRE... Marinco Electrical Group Marinco Electrical Group 15A 250V 2P 3W SB INLET FRONT MOUNT W/COVER Weight Min. Quantity Part Number Weight Min. Quantity 5678DRI 0.1 N-A 600097-D N-A N-A 15A 250V 2P 3W OUTLET FLANGED CLS SERIES GREEN (E) FEM BOOT W/SCR... Marinco Electrical Group Marinco Electrical Group 15A 250V 2P 3W OUTLET FLANGED 72 CLS SERIES BLUE (D) FEM BOOT W/SCREW Part Number CLS SERIES GREEN (E) FEM BOOT W/SCREW Part Number Weight Min. Quantity Part Number Weight Min. Quantity 5679 0.15 N-A 600097-E N-A N-A CLS SERIES BLACK (A) FEM BOOT W/SCR... CLS SERIES BROWN (F) FEM BOOT W/SCR... Marinco Electrical Group Marinco Electrical Group CLS SERIES BLACK (A) FEM BOOT W/SCREW CLS SERIES BROWN (F) FEM BOOT W/SCREW Part Number Weight Min. Quantity Part Number Weight Min. Quantity 600097-A N-A N-A 600097-F N-A N-A CLS SERIES WHITE (B) FEM BOOT W/SCR... CLS SERIES ORANGE (G) FEM BOOT W/SC... Marinco Electrical Group Marinco Electrical Group CLS SERIES WHITE (B) FEM BOOT W/SCREW CLS SERIES ORANGE (G) FEM BOOT W/SCREW Part Number Weight Min. Quantity Part Number Weight Min. Quantity 600097-B N-A N-A 600097-G N-A N-A 860-442-4386 the edge group • 2014 600098-H – CLS SERIES YELLOW (H) MALE BOOT W/S... CLS SERIES BLUE (D) MALE BOOT W/SCR... Marinco Electrical Group Marinco Electrical Group CLS SERIES YELLOW (H) FEM BOOT W/SCREW CLS SERIES BLUE (D) MALE BOOT W/SCREW Part Number Weight Min. Quantity Part Number Weight Min. Quantity 600097-H N-A N-A 600098-D N-A N-A CLS SERIES GRAY (J) FEM BOOT W/SCRE... CLS SERIES GREEN (E) MALE BOOT W/SC... Marinco Electrical Group Marinco Electrical Group CLS SERIES GRAY (J) FEM BOOT W/SCREW CLS SERIES GREEN (E) MALE BOOT W/SCREW Part Number Weight Min. Quantity Part Number Weight Min. Quantity 600097-J N-A N-A 600098-E N-A N-A CLS SERIES BLACK (A) MALE BOOT W/SC... CLS SERIES BROWN (F) MALE BOOT W/SC... Marinco Electrical Group Marinco Electrical Group CLS SERIES BLACK (A) MALE BOOT W/SCREW Bat teries/ Fl a shlights/Charger s CLS SERIES YELLOW (H) FEM BOOT W/SC... CLS SERIES BROWN (F) MALE BOOT W/SCREW Part Number Weight Min. Quantity Part Number Weight Min. Quantity 600098-A N-A N-A 600098-F N-A N-A CLS SERIES WHITE (B) MALE BOOT W/SC... CLS SERIES ORANGE (G) MALE BOOT W/S... Marinco Electrical Group Marinco Electrical Group CLS SERIES WHITE (B) MALE BOOT W/SCREW CLS SERIES ORANGE (G) MALE BOOT W/SCREW Part Number Weight Min. Quantity Part Number Weight Min. Quantity 600098-B N-A N-A 600098-G N-A N-A CLS SERIES RED (C) MALE BOOT W/SCRE... CLS SERIES YELLOW (H) MALE BOOT W/S... Marinco Electrical Group Marinco Electrical Group CLS SERIES RED (C) MALE BOOT W/SCREW CLS SERIES YELLOW (H) MALE BOOT W/SCREW Part Number Weight Min. Quantity Part Number Weight Min. Quantity 600098-C N-A N-A 600098-H N-A N-A 860-442-4386 73 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 600098-J – CLS SERIES GRAY (J) MALE BOOT W/SCR... CLS SERIES GRAY (J) MALE BOOT W/SCR... CLS SERIES #2 - 2/0 AWG MALE CONTAC... Marinco Electrical Group Marinco Electrical Group CLS SERIES GRAY (J) MALE BOOT W/SCREW CLS SERIES #2 - 2/0 AWG MALE CONTACT W/HARDWARE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 600098-J N-A N-A 600100-20 N-A N-A CLS SERIES #6 - #2 AWG FEMALE CONTA... CLS SERIES 2/0 - 4/0 AWG MALE CONTA... Marinco Electrical Group Marinco Electrical Group CLS SERIES #6 - #2 AWG FEMALE CONTACT W/HARDWARE Weight Min. Quantity Part Number Weight Min. Quantity 600099-2 N-A N-A 600100-40 N-A N-A CLS SERIES #2 - 2/0 AWG FEMALE CONT... CLM SERIES #2 AWG FEMALE CONTACT W/... Marinco Electrical Group Marinco Electrical Group CLS SERIES #2 - 2/0 AWG FEMALE CONTACT W/HARDWARE 74 CLS SERIES 2/0 - 4/0 AWG MALE CONTACT W/HARDWARE Part Number CLM SERIES #2 AWG FEMALE CONTACT W/HARDWARE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 600099-20 N-A N-A 600112-2 N-A N-A CLS SERIES 2/0 - 4/0 AWG FEMALE CON... CLM SERIES #2 AWG MALE CONTACT W/HA... Marinco Electrical Group Marinco Electrical Group CLS SERIES 2/0 - 4/0 AWG FEMALE CONTACT W/HARDWARE CLM SERIES #2 AWG MALE CONTACT W/HARDWARE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 600099-40 N-A N-A 600113-2 N-A N-A CLS SERIES #6 - #2 AWG MALE CONTACT... 5 AMP AGC FUSE 5 Marinco Electrical Group Marinco Electrical Group CLS SERIES #6 - #2 AWG MALE CONTACT W/HARDWARE 5 AMP AGC FUSE 5 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 600100-2 N-A N-A 601050 1 N-A 860-442-4386 the edge group • 2014 607122 – ATO/ATC 6 CIRCUIT FUSE PANEL AGC PANEL MOUNT FUSE HOLDER Marinco Electrical Group Marinco Electrical Group MARINE FUSE ASSORTMENT PA CK 5 AGC PANEL MOUNT FUSE HOLDER Part Number Weight Min. Quantity Part Number Weight Min. Quantity 601112 1 N-A 607010 1 N-A ATC FUSE ASSORTMENT PACK 6 CRIMPABLE FUSE HOLDER 30 AMP RATED Marinco Electrical Group Marinco Electrical Group ATC FUSE ASSORTMENT PACK 6 CRIMPABLE FUSE HOLDER 30 AMP RATED Part Number Weight Min. Quantity Part Number Weight Min. Quantity 601114 1 N-A 607012 0.4 N-A 15 AMP AGC FUSE 5 AGC WATERPROOF FUSE HOLDE R RATED 3... Marinco Electrical Group Marinco Electrical Group 15 AMP AGC FUSE 5 Bat teries/ Fl a shlights/Charger s MARINE FUSE ASSORTMENT PA CK 5 AGC WATERPROOF FUSE HOLDE R RATED 30 AMPS 12-18 WIR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 601150 1 N-A 607013 1 N-A PLUG BOOT, 15/20A SB BLACK RUBBER WATERPROOF ATO/ATC FUSE HOLDER Marinco Electrical Group Marinco Electrical Group PLUG BOOT; 15/20A SB BLACK RUBBER WATERPROOF ATO/ATC FUSE HOLDER Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6017 0.1702 N-A 607019 2 N-A CONNECTOR BOOT, 15/20A SB BLACK RUB... ATO/ATC 6 CIRCUIT FUSE PANEL Marinco Electrical Group Marinco Electrical Group CONNECTOR BOOT; 15/20A SB BLACK RUBBER ATO/ATC 6 CIRCUIT FUSE PANEL Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6018 0.222 N-A 607122 0.37 N-A 860-442-4386 75 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 6080 – FS BOX BLACK FS BOX BLACK Bates Stage Pin (60A / 125V) Female... Marinco Electrical Group Marinco Electrical Group FS BOX BLACK Bates Stage Pin (60A / 125V) Female Panel Mount Double Set Screw Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6080 1 N-A 60FR-DSS N-A N-A FS BOX, BLACK CHALLANGER - #FSC-34 Bates Stage Pin (60A / 125V) Male I... Marinco Electrical Group Marinco Electrical Group FS BOX; BLACK CHALLANGER - #FSC-34 Bates Stage Pin (60A / 125V) Male Inline Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6080.OEM N-A N-A 60M N-A N-A FD BOX, W/TWO 3/4 K.O. HOLES YELLOW Bates Stage Pin (60A / 125V) Male P... Marinco Electrical Group Marinco Electrical Group FD BOX; W/TWO 3/4 K.O. HOLES YELLOW 76 Bates Stage Pin (60A / 125V) Male Panel Mount Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6083CR 14 N-A 60MR N-A N-A Bates Stage Pin (60A / 125V) Female... Bates Stage Pin (60A / 125V) Male P... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (60A / 125V) Female Inline Bates Stage Pin (60A / 125V) Male Panel Mount Double Set Screw Part Number Weight Min. Quantity Part Number Weight Min. Quantity 60F N-A N-A 60MR-DSS N-A N-A Bates Stage Pin (60A / 125V) Female... 50A 125/250V CORDSET, 50’ MOLDED, W... Marinco Electrical Group Marinco Electrical Group Bates Stage Pin (60A / 125V) Female Panel Mount 50A 125/250V CORDSET; 50’ MOLDED; W/LED Part Number Weight Min. Quantity Part Number Weight Min. Quantity 60FR N-A N-A 6152SPP 701 N-A 860-442-4386 the edge group • 2014 6353EL – 50A 125/250V EASY LOCK INLET 50A 125V CORDSET, 50’ MOLDED Marinco Electrical Group Marinco Electrical Group 50A 125/250V CORDSET; 12’ MOLDED; W/SEALING COLLAR 50A 125V CORDSET; 50’ MOLDED Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6152SPP-12SC 210 N-A 6153SPP 563 N-A 50A 125/250V CORDSET, 25’ MOLDED 32A 230V CORDSET, 50’ MOLDED, FOR E... Marinco Electrical Group Marinco Electrical Group 50A 125/250V CORDSET; 25’ MOLDED 32A 230V CORDSET; 50’ MOLDED; FOR EXPORT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6152SPP-25 375 N-A 6153SPPX N-A N-A 50A 125/250V CORDSET, 25’ MOLDED, R... INLET, 50A 125/250V CNTRD W/SS TRIM... Marinco Electrical Group Marinco Electrical Group 50A 125/250V CORDSET; 25’ MOLDED; RV Bat teries/ Fl a shlights/Charger s 50A 125/250V CORDSET, 12’ MOLDED, W... INLET; 50A 125/250V CNTRD W/SS TRIM ENCL FOR RV Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6152SPPRV-25 N-A N-A 6344EL-BRV N-A N-A 50A 125/250V CORDSET, 40’ 32A 220 EZ LK INLET W/ENC EXPORT Marinco Electrical Group Marinco Electrical Group 50A 125/250V CORDSET; 40’ 32A 220 EZ LK INLET W/ENC EXPORT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6152SPPRV-40 N-A N-A 6351EL-BX N-A N-A 50A 125/250V CORDSET, 50’ MOLDED, R... 50A 125/250V EASY LOCK INLET Marinco Electrical Group Marinco Electrical Group 50A 125/250V CORDSET; 50’ MOLDED; RV 50A 125/250V EASY LOCK INLET Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6152SPPRV-50 N-A N-A 6353EL 47 N-A 860-442-4386 77 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 6353EL-B – 50A 125/250V EL INLET W/ENCLOSURE 50A 125/250V EL INLET W/ENCLOSURE 50A 125V PLUG, LOCKING Marinco Electrical Group Marinco Electrical Group 50A 125/250V EL INLET W/ENCLOSURE 50A 125V PLUG; LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6353EL-B 16 N-A 6361CRN 10 N-A 50A 125/250V EL INLET W/ENCL 50A 125/250V CONNECTOR LOCKING Marinco Electrical Group Marinco Electrical Group 50A 125/250V EL INLET W/ENCL 50A 125/250V CONNECTOR LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6353EL-B.OEM N-A N-A 6364CRN 1 N-A REPLACEMENT CAP & BEZEL 50A 125/250... 50A 125/250V CONNECTOR, LOCKING Marinco Electrical Group Marinco Electrical Group REPLACEMENT CAP & BEZEL 50A 125/250V EL 78 50A 125/250V CONNECTOR; LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6353ELCB N-A N-A 6364CRN.OEM N-A N-A 50A 125/250V EL INLET W/PARK POWER ... CONN., 50A 125/250V BOXED W/LABEL F... Marinco Electrical Group Marinco Electrical Group 50A 125/250V EL INLET W/PARK POWER PACKAGING CONN.; 50A 125/250V BOXED W/LABEL FOR SWD Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6353ELRV N-A N-A 6364CRNS 1 N-A 50A 125V CONNECTOR, LOCKING CONN. 50A 125/250V LOCKNG W/PARK PO... Marinco Electrical Group Marinco Electrical Group 50A 125V CONNECTOR; LOCKING CONN. 50A 125/250V LOCKNG W/PARK POWER PACKAGING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6360CRN 10 N-A 6364CRV N-A N-A 860-442-4386 the edge group • 2014 6373EL-B.OEM – 50A 125/250V EL INLET SS W/ENCL 50A 125V RECEPTACLE Marinco Electrical Group Marinco Electrical Group 50A 125/250V PLUG LOCKING 50A 125V RECEPTACLE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6365CRN 12 N-A 6370CR N-A N-A 50A 125/250V PLUG LKG BLK HOUSING &... 50A 125V EL INLET SS W/ENCLOSURE Marinco Electrical Group Marinco Electrical Group 50A 125/250V PLUG LKG BLK HOUSING & BLK SLEEVE 50A 125V EL INLET SS W/ENCLOSURE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6365CRN.01 N-A N-A 6371EL-B 98 N-A 50A 125/250V RECEPTACLE 50A 125/250V EL INLET SS Marinco Electrical Group Marinco Electrical Group 50A 125/250V RECEPTACLE Bat teries/ Fl a shlights/Charger s 50A 125/250V PLUG LOCKING 50A 125/250V EL INLET SS Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6369CR 8 N-A 6373EL 21 N-A 50A 125 / 250V RECEPTACLE LOCKING 50A 125/250V EL INLET SS (REPLACES ... Marinco Electrical Group Marinco Electrical Group 50A 125 / 250V RECEPTACLE LOCKING 50A 125/250V EL INLET SS (REPLACES 6373CR &6374CR) Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6369CRS 1 N-A 6373EL-B 25 N-A RECEPTACLE, 50A 125/250V MASTER/50 50A 125/250V EL INLET SS W/ENCL Marinco Electrical Group Marinco Electrical Group RECEPTACLE; 50A 125/250V MASTER/50 50A 125/250V EL INLET SS W/ENCL Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6369CRS.OEM.NMS 0.45 N-A 6373EL-B.OEM N-A N-A 860-442-4386 79 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 6373EL-BRV – 50A 125/250V EL INLET SS FOR RV 50A 125/250V EL INLET SS FOR RV PANEL MOUNT BATTERY SWITCH Marinco Electrical Group Marinco Electrical Group 50A 125/250V EL INLET SS FOR RV PANEL MOUNT BATTERY SWITCH Part Number Weight Min. Quantity Part Number Weight Min. Quantity 6373EL-BRV N-A N-A 701-PM 6 N-A PLASTIC WIRE BATTERY TERM INAL CLEA... SS CUT/STRIP/CRIMP TOOL Marinco Electrical Group Marinco Electrical Group PLASTIC WIRE BATTERY TERM INAL CLEANER SS CUT/STRIP/CRIMP TOOL Part Number Weight Min. Quantity Part Number Weight Min. Quantity 700103 N-A N-A 701009 N-A N-A DIELECTRIC SILICO COMPOUND, 1/3 OZ.... DOUBLE CRIMP TOOL 22-10 AWG Marinco Electrical Group Marinco Electrical Group DIELECTRIC SILICO COMPOUND; 1/3 OZ.;1/CARD; 5/MASTER 80 DOUBLE CRIMP TOOL 22-10 AWG Part Number Weight Min. Quantity Part Number Weight Min. Quantity 700115 N-A N-A 701030 N-A N-A MINI BATTERY DISCONNECT SWITCH - 27... BATTERY DISCONNECT SWITCH - 275A CO... Marinco Electrical Group Marinco Electrical Group MINI BATTERY DISCONNECT SWITCH - 275A CONTINUOUS BATTERY DISCONNECT SWITCH - 275A CONTINUOUS; BULK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 701 6 N-A 701B N-A N-A REPLACEMENT KEY FOR 701 MINI SELECTOR SWITCH, PANEL MOUNT Marinco Electrical Group Marinco Electrical Group REPLACEMENT KEY FOR 701 MINI SELECTOR SWITCH; PANEL MOUNT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 701-KEY N-A N-A 701S-PM N-A N-A 860-442-4386 the edge group • 2014 7413C – CONN, 20A 120/208V HEAVY-DUTY BATTERY SELECTOR SWITCH ... Marinco Electrical Group Marinco Electrical Group DISTRIBUTION STUD MODULE - DUAL; 2 X 3/8 HEAVY-DUTY BATTERY SELECTOR SWITCH - FOUR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 702-2S 7 N-A 721 23 N-A AUTOMATIC STRIPPER AND CR IMPER FOR... RECEPT, 20A 125/250V Marinco Electrical Group Marinco Electrical Group AUTOMATIC STRIPPER AND CR IMPER FOR 10-26 AWG RECEPT; 20A 125/250V Part Number Weight Min. Quantity Part Number Weight Min. Quantity 702033 N-A N-A 7310B 0.22 N-A HEAVY DUTY BUS BAR, 300A, BULK CONN, 20A 125/250V Marinco Electrical Group Marinco Electrical Group HEAVY DUTY BUS BAR; 300A; BULK Bat teries/ Fl a shlights/Charger s DISTRIBUTION STUD MODULE - DUAL, 2 ... CONN; 20A 125/250V Part Number Weight Min. Quantity Part Number Weight Min. Quantity 703-300A_B N-A N-A 7314C 0.4 N-A BATTERY DISTRIBUTION CLUSTER, SQUAR... PLUG, 20A 120/208V 3 Y Marinco Electrical Group Marinco Electrical Group BATTERY DISTRIBUTION CLUSTER; SQUARE; 100A PLUG; 20A 120/208V 3 Y Part Number Weight Min. Quantity Part Number Weight Min. Quantity 716-SQ-100A N-A N-A 7411C 0.3 N-A HEAVY DUTY BATTERY DISCONNECT SWITC... CONN, 20A 120/208V Marinco Electrical Group Marinco Electrical Group HEAVY DUTY BATTERY DISCONNECT SWITCH; DOUBLE CONN; 20A 120/208V Part Number Weight Min. Quantity Part Number Weight Min. Quantity 720-DP_B N-A N-A 7413C 0.4 N-A 860-442-4386 81 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 7420CR – WEATHERPROOF COVER W/LIFT LID WEATHERPROOF COVER W/LIFT LID 50A COVER WITH RING CONNECTOR Marinco Electrical Group Marinco Electrical Group WEATHERPROOF COVER W/LIFT LID 50A COVER WITH RING CONNECTOR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 7420CR 3 N-A 7715CRN 5 N-A WEATHERPROOF COVER W/LIFT LID 50A COVER WITH RING CONNECTOR Marinco Electrical Group Marinco Electrical Group WEATHERPROOF COVER W/LIFT LID 50A COVER WITH RING CONNECTOR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 7420CR.OEM N-A N-A 7715CRN.OEM N-A N-A WEATHERPROOF COVER W/LIFT LID 32A COVER WITH RING, OEM FOR CONNEC... Marinco Electrical Group Marinco Electrical Group WEATHERPROOF COVER W/LIFT LID 82 32A COVER WITH RING; OEM FOR CONNECTOR; EXPORT Part Number Weight Min. Quantity Part Number Weight Min. Quantity 7420CRS 0.25 N-A 7715CRNX N-A N-A WEATHERPROOF COVER, GRAY WITHOUT MO... 50A COVER WITH RING CONN. W/ PARK P... Marinco Electrical Group Marinco Electrical Group WEATHERPROOF COVER; GRAY WITHOUT MOUNTING SCREWS 50A COVER WITH RING CONN. W/ PARK POWER PACKAGING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 7420GY.NMS 0.19 N-A 7715CRV N-A N-A 45 PIECE ASSORTED GROMMET KIT 50A COVER W/EASY LOCK RING Marinco Electrical Group Marinco Electrical Group 45 PIECE ASSORTED GROMMET KIT 50A COVER W/EASY LOCK RING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 750000 0.16 N-A 7715ELN 6 N-A 860-442-4386 the edge group • 2014 7879CR-FI – COVER, RECEPTACLE SS FOR GFCI (WP-2... WEATHERPROOF COVER W/LIFT LID Marinco Electrical Group Marinco Electrical Group 50A COVER PLUG WEATHERPROOF COVER W/LIFT LID Part Number Weight Min. Quantity Part Number Weight Min. Quantity 7717N 4 N-A 7788CRS 0.4 N-A 50A COVER PLUG WEATHERPROOF COVER W/LIFT LID WHITE Marinco Electrical Group Marinco Electrical Group 50A COVER PLUG WEATHERPROOF COVER W/LIFT LID WHITE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 7717N.OEM N-A N-A 7788CRW 0.25 N-A 50A 600V AC/50A 250V DC CONN. WEATHERPROOF COVER, GRAY WITHOUT MO... Marinco Electrical Group Marinco Electrical Group 50A 600V AC/50A 250V DC CONN. Bat teries/ Fl a shlights/Charger s 50A COVER PLUG WEATHERPROOF COVER; GRAY WITHOUT MOUNTING SCREWS Part Number Weight Min. Quantity Part Number Weight Min. Quantity 7764N 1 N-A 7788GY.NMS N-A N-A 50A 600V AC/50A 250V DC PLUG COVER, RECEPTACLE SS (WP-8) Marinco Electrical Group Marinco Electrical Group 50A 600V AC/50A 250V DC PLUG COVER; RECEPTACLE SS (WP-8) Part Number Weight Min. Quantity Part Number Weight Min. Quantity 7765N 1 N-A 7879CR 3 N-A WEATHERPROOF COVER BLK MASTER/50 COVER, RECEPTACLE SS FOR GFCI (WP-2... Marinco Electrical Group Marinco Electrical Group WEATHERPROOF COVER BLK MASTER/50 COVER; RECEPTACLE SS FOR GFCI (WP-26) Part Number Weight Min. Quantity Part Number Weight Min. Quantity 7788BL.OEM 0.25 N-A 7879CR-FI 6 N-A 860-442-4386 83 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s 7958 – 50A 600V AC/50A 250V DC INLET 50A 600V AC/50A 250V DC INLET 15A 125V PLUG, HOSPITAL GRADE, CLEA... Marinco Electrical Group Marinco Electrical Group 50A 600V AC/50A 250V DC INLET 15A 125V PLUG; HOSPITAL GRADE; CLEAR MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity 7958 1 N-A 8215T.OEM 0.11 N-A ADAPTER, 30A TO 20A 15A 125V PLUG, W/NEON BULB, HG CLEA... Marinco Electrical Group Marinco Electrical Group ADAPTER; 30A TO 20A 15A 125V PLUG; W/NEON BULB; HG CLEAR HOUSING Part Number Weight Min. Quantity Part Number Weight Min. Quantity 81A 6 N-A 8215TL 0.13 N-A 15A 125V PLUG, HOSPITAL GRADE 15A 125V PLUG, RIGHT ANGL CLEAR Marinco Electrical Group Marinco Electrical Group 15A 125V PLUG; HOSPITAL GRADE 84 15A 125V PLUG; RIGHT ANGL CLEAR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 8215 0.126 N-A 8215TRA N-A N-A 15A 125V PLUG, HOSPITAL GRADE MASTE... 15A 125V CONN, HOSPITAL GRADE Marinco Electrical Group Marinco Electrical Group 15A 125V PLUG; HOSPITAL GRADE MASTER/50 15A 125V CONN; HOSPITAL GRADE Part Number Weight Min. Quantity Part Number Weight Min. Quantity 8215.OEM 0.11 N-A 8219 0.15 N-A 15A 125V PLUG, HOSPITAL GRADE, CLEA... 15A 125V CONN, HOSPITAL GRADE, CLEA... Marinco Electrical Group Marinco Electrical Group 15A 125V PLUG; HOSPITAL GRADE; CLEAR 15A 125V CONN; HOSPITAL GRADE; CLEAR Part Number Weight Min. Quantity Part Number Weight Min. Quantity 8215T 0.11 N-A 8219T 0.13 N-A 860-442-4386 the edge group • 2014 BBC-24WR – BUSS BAR COVER - 24 WAY - POSITIVE ... BUSS BAR - 6 WAY - 100A W/ 2 INPUT ... Marinco Electrical Group Marinco Electrical Group ADAPTER BUSS BAR - 6 WAY - 100A W/ 2 INPUT STUDS Part Number Weight Min. Quantity Part Number Weight Min. Quantity 83A 6 N-A BB-6W-2S N-A N-A PLUG, 20A 125/250V BUSS BAR COVER - 12 WAY - NEGATIVE ... Marinco Electrical Group Marinco Electrical Group PLUG; 20A 125/250V BUSS BAR COVER - 12 WAY - NEGATIVE - BLACK Part Number Weight Min. Quantity Part Number Weight Min. Quantity 9965C 0.3 N-A BBC-12WBK 1 N-A FUSE HOLDER, 6 WAY, SCREW TERMINAL ... BUSS BAR COVER - 12 WAY - POSITIVE ... Marinco Electrical Group Marinco Electrical Group FUSE HOLDER; 6 WAY; SCREW TERMINAL C/W COVER BUSS BAR COVER - 12 WAY - POSITIVE - RED Part Number Weight Min. Quantity Part Number Weight Min. Quantity ATC-6W N-A N-A BBC-12WR 8 N-A BUSS BAR - 12 WAY/100A W/ 2 INPUT S... BUSS BAR COVER - 24 WAY - NEGATIVE ... Marinco Electrical Group Marinco Electrical Group BUSS BAR - 12 WAY/100A W/ 2 INPUT STUDS BUSS BAR COVER - 24 WAY - NEGATIVE - BLACK Part Number Weight Min. Quantity Part Number Weight Min. Quantity BB-12W-2S N-A N-A BBC-24WBK 1 N-A BUSS BAR - 24 WAY/150A W/ 2 INPUT S... BUSS BAR COVER - 24 WAY - POSITIVE ... Marinco Electrical Group Marinco Electrical Group BUSS BAR - 24 WAY/150A W/ 2 INPUT STUDS BUSS BAR COVER - 24 WAY - POSITIVE - RED Part Number Weight Min. Quantity Part Number Weight Min. Quantity BB-24W-2S N-A N-A BBC-24WR 1 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s ADAPTER 85 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s BBC-6WBK – BUSS BAR COVER ‚Äì 6 WAY ‚Äì NEGATIVE ‚Äì... BUSS BAR COVER ‚Äì 6 WAY ‚Äì NEGATIVE ‚Äì... CLS 18 Series Ballnose Hard 3Fer (... Marinco Electrical Group Marinco Electrical Group BUSS BAR COVER √جø¬Ω 6 WAY √جø¬Ω NEGATIVE √جø¬ΩBLACK CLS 18 Series Ballnose Hard 3Fer (M-F-F-F) - Blue (D) Part Number Weight Min. Quantity BBC-6WBK 0.16 N-A Weight Min. Quantity CA318F-D N-A N-A BUSS BAR COVER - 6 WAY - POSITIVE -... CLS 18 Series Ballnose Hard 3Fer (... Marinco Electrical Group Marinco Electrical Group BUSS BAR COVER - 6 WAY - POSITIVE - RED CLS 18 Series Ballnose Hard 3Fer (M-F-F-F) - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity BBC-6WR 0.16 N-A CA318F-E N-A N-A CLS 18 Series Ballnose Hard 3Fer (... CL/CLS/CLM Hard 3Fer Adapter (M-F-F... Marinco Electrical Group Marinco Electrical Group CLS 18 Series Ballnose Hard 3Fer (M-F-F-F) - Black (A) 86 Part Number CL/CLS/CLM Hard 3Fer Adapter (M-F-F-F) - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CA318F-A N-A N-A CA3F-A 3 N-A CLS 18 Series Ballnose Hard 3Fer (... CL/CLS/CLM Hard 3Fer Adapter (M-F-F... Marinco Electrical Group Marinco Electrical Group CLS 18 Series Ballnose Hard 3Fer (M-F-F-F) - White (B) CL/CLS/CLM Hard 3Fer Adapter (M-F-F-F) - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CA318F-B N-A N-A CA3F-B 3 N-A CLS 18 Series Ballnose Hard 3Fer (... CL/CLS/CLM Hard 3Fer Adapter (M-F-F... Marinco Electrical Group Marinco Electrical Group CLS 18 Series Ballnose Hard 3Fer (M-F-F-F) - Red (C ) CL/CLS/CLM Hard 3Fer Adapter (M-F-F-F) - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CA318F-C N-A N-A CA3F-C 3 N-A 860-442-4386 the edge group • 2014 CA3MST-E – CLS Assembled Adapters Reverse Soft... CLS Assembled Adapters Soft 3Fer (M... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Hard 3Fer Adapter (M-F-F-F) - Blue (D) CLS Assembled Adapters Soft 3Fer (M-F-F-F) - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CA3F-D 3 N-A CA3FST-D N-A N-A CL/CLS/CLM Hard 3Fer Adapter (M-F-F... CLS Assembled Adapters Soft 3Fer (M... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Hard 3Fer Adapter (M-F-F-F) - Green (E) CLS Assembled Adapters Soft 3Fer (M-F-F-F) - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CA3F-E 3 N-A CA3FST-E N-A N-A CLS Assembled Adapters Soft 3Fer (M... CL/CLS/CLM Reverse Hard 3Fer Adapte... Marinco Electrical Group Marinco Electrical Group CLS Assembled Adapters Soft 3Fer (M-F-F-F) - Black (A) CL/CLS/CLM Reverse Hard 3Fer Adapter (F-M-M-M) - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CA3FST-A N-A N-A CA3M-B N-A N-A CLS Assembled Adapters Soft 3Fer (M... CL/CLS/CLM Reverse Hard 3Fer Adapte... Marinco Electrical Group Marinco Electrical Group CLS Assembled Adapters Soft 3Fer (M-F-F-F) - White (B) CL/CLS/CLM Reverse Hard 3Fer Adapter (F-M-M-M) - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CA3FST-B N-A N-A CA3M-E 3 N-A CLS Assembled Adapters Soft 3Fer (M... CLS Assembled Adapters Reverse Soft... Marinco Electrical Group Marinco Electrical Group CLS Assembled Adapters Soft 3Fer (M-F-F-F) - Red (C ) CLS Assembled Adapters Reverse Soft 3Fer (F-M-M-M) - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CA3FST-C N-A N-A CA3MST-E N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CL/CLS/CLM Hard 3Fer Adapter (M-F-F... 87 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CD1816MF-A – Ballnose Male and Tapernose Female ... Ballnose Male and Tapernose Female ... CLS 18 Series Ballnose Tapping T Ad... Marinco Electrical Group Marinco Electrical Group Ballnose Male and Tapernose Female Adapter (M-F) - Black (A) CLS 18 Series Ballnose Tapping T Adapter (M-F-F) - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CD1816MF-A 1 N-A CD18TT-A 1 N-A Ballnose Male and Tapernose Female ... CLS 18 Series Ballnose Tapping T Ad... Marinco Electrical Group Marinco Electrical Group Ballnose Male and Tapernose Female Adapter (M-F) - White (B) Weight Min. Quantity Part Number Weight Min. Quantity CD1816MF-B N-A N-A CD18TT-B N-A N-A Ballnose Male and Tapernose Female ... CLS 18 Series Ballnose Tapping T Ad... Marinco Electrical Group Marinco Electrical Group Ballnose Male and Tapernose Female Adapter (M-F) - Red (C ) 88 CLS 18 Series Ballnose Tapping T Adapter (M-F-F) - White (B) Part Number CLS 18 Series Ballnose Tapping T Adapter (M-F-F) - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CD1816MF-C N-A N-A CD18TT-C N-A N-A Ballnose Male and Tapernose Female ... CLS 18 Series Ballnose Tapping T Ad... Marinco Electrical Group Marinco Electrical Group Ballnose Male and Tapernose Female Adapter (M-F) - Blue (D) CLS 18 Series Ballnose Tapping T Adapter (M-F-F) - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CD1816MF-D N-A N-A CD18TT-D N-A N-A Ballnose Male and Tapernose Female ... CLS 18 Series Ballnose Tapping T Ad... Marinco Electrical Group Marinco Electrical Group Ballnose Male and Tapernose Female Adapter (M-F) - Green (E) CLS 18 Series Ballnose Tapping T Adapter (M-F-F) - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CD1816MF-E N-A N-A CD18TT-E N-A N-A 860-442-4386 the edge group • 2014 CDMM-B – CL/CLS/CLM Male to Male Coupler (M-... CL/CLS/CLM Female to Female Coupler... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Female to Female Coupler (F-F) - Black (A) CL/CLS/CLM Female to Female Coupler (F-F) - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CDFF-A N-A N-A CDFF-F N-A N-A CL/CLS/CLM Female to Female Coupler... CL/CLS/CLM Female to Female Coupler... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Female to Female Coupler (F-F) - White (B) CL/CLS/CLM Female to Female Coupler (F-F) - Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CDFF-B N-A N-A CDFF-G N-A N-A CL/CLS/CLM Female to Female Coupler... CL/CLS/CLM Female to Female Coupler... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Female to Female Coupler (F-F) - Red (C ) CL/CLS/CLM Female to Female Coupler (F-F) - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CDFF-C N-A N-A CDFF-H N-A N-A CL/CLS/CLM Female to Female Coupler... CL/CLS/CLM Male to Male Coupler (M-... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Female to Female Coupler (F-F) - Blue (D) CL/CLS/CLM Male to Male Coupler (M-M) - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CDFF-D N-A N-A CDMM-A 1 N-A CL/CLS/CLM Female to Female Coupler... CL/CLS/CLM Male to Male Coupler (M-... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Female to Female Coupler (F-F) - Green (E) CL/CLS/CLM Male to Male Coupler (M-M) - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CDFF-E N-A N-A CDMM-B 1 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CL/CLS/CLM Female to Female Coupler... 89 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CDMM-C – CL/CLS/CLM Male to Male Coupler (M-... CL/CLS/CLM Male to Male Coupler (M-... CL/CLS/CLM Male to Male Coupler (M-... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Male to Male Coupler (M-M) - Red (C ) CL/CLS/CLM Male to Male Coupler (M-M) - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CDMM-C 1 N-A CDMM-H 1 N-A CL/CLS/CLM Male to Male Coupler (M-... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Male to Male Coupler (M-M) - Blue (D) Part Number Weight Min. Quantity CDMM-D 1 N-A Part Number Weight Min. Quantity CL20FB-A N-A N-A CL/CLS/CLM Male to Male Coupler (M-... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Male to Male Coupler (M-M) - Green (E) 90 CL Series Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female Black (A) Part Number Weight Min. Quantity CDMM-E 1 N-A CL Series Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female White (B) Part Number Weight Min. Quantity CL20FB-B N-A N-A CL/CLS/CLM Male to Male Coupler (M-... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Male to Male Coupler (M-M) - Brown (F) CL Series Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female - Red (C ) Part Number Weight Min. Quantity CDMM-F 1 N-A Part Number Weight Min. Quantity CL20FB-C N-A N-A CL/CLS/CLM Male to Male Coupler (M-... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Male to Male Coupler (M-M) - Orange (G) CL Series Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female - Blue (D) Part Number Weight Min. Quantity CDMM-G 1 N-A 860-442-4386 Part Number Weight Min. Quantity CL20FB-D N-A N-A the edge group • 2014 CL20FRB-E – CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female Green (E) CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL20FB-E N-A N-A CL20FRB-C N-A N-A CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Black (A) CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Red (C ) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL20FRB-A N-A N-A CL20FRB-CX N-A N-A CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Black (A) Drill Out CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL20FRB-AX N-A N-A CL20FRB-D N-A N-A CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - White (B) CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Blue (D) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL20FRB-B N-A N-A CL20FRB-DX N-A N-A CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - White (B) Drill Out CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL20FRB-BX N-A N-A CL20FRB-E N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CL Series Single Pin Connector (400... 91 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CL20FRB-EX – CL Series Panel Mount (400A / 600V)... 92 CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Green (E) Drill Out CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL20FRB-EX N-A N-A CL20FRB-H 1 N-A CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Brown (F) CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Yellow (H) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL20FRB-F 1 N-A CL20FRB-HX 1 N-A CL Series Panel Mount (400A / 600V)... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Brown (F) Drill Out CL Series Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL20FRB-FX 1 N-A CL20MB-A N-A N-A CL Series Panel Mount (400A / 600V)... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Orange (G) CL Series Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL20FRB-G 1 N-A CL20MB-B N-A N-A CL Series Panel Mount (400A / 600V)... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screw; Female - Orange (G) Drill Out CL Series Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL20FRB-GX 1 N-A CL20MB-C N-A N-A 860-442-4386 the edge group • 2014 CL20MRB-DX – CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male - Blue (D) CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - White (B) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL20MB-D N-A N-A CL20MRB-BX 1 N-A CL Series Single Pin Connector (400... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male Green (E) CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Red (C ) Part Number Weight Min. Quantity CL20MB-E N-A N-A Part Number Weight Min. Quantity CL20MRB-C 1 N-A CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Black (A) Part Number Weight Min. Quantity CL20MRB-A 1 N-A CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Red (C ) Drill Out Part Number Weight Min. Quantity CL20MRB-CX 1 N-A CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Black (A) Drill Out CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Blue (D) Part Number Weight Min. Quantity CL20MRB-AX 1 N-A Part Number Weight Min. Quantity CL20MRB-D 1 N-A CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - White (B) CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Blue (D) Drill Out Part Number Weight Min. Quantity CL20MRB-B 1 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CL Series Single Pin Connector (400... Part Number Weight Min. Quantity CL20MRB-DX 1 N-A 93 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CL20MRB-E – CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Green (E) CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Orange (G) Drill Out Part Number Weight Min. Quantity CL20MRB-E 1 N-A Weight Min. Quantity CL20MRB-GX 1 N-A CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Green (E) Drill Out CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Yellow (H) Part Number Weight Min. Quantity CL20MRB-EX 1 N-A Part Number Weight Min. Quantity CL20MRB-H 1 N-A CL Series Panel Mount (400A / 600V)... CL Series Panel Mount (400A / 600V)... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Brown (F) 94 Part Number Part Number Weight Min. Quantity CL20MRB-F 1 N-A CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Yellow (H) Drill Out Part Number Weight Min. Quantity CL20MRB-HX 1 N-A CL Series Panel Mount (400A / 600V)... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Brown (F) Drill Out CL Series Single Pin Connector (400A / 600V) #6 - #2 AWG Female Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL20MRB-FX 1 N-A CL2FB-A N-A N-A CL Series Panel Mount (400A / 600V)... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount (400A / 600V) #2 - 2/0 AWG Male - Orange (G) CL Series Single Pin Connector (400A / 600V) #6 - #2 AWG Female White (B) Part Number Weight Min. Quantity CL20MRB-G 1 N-A 860-442-4386 Part Number Weight Min. Quantity CL2FB-B N-A N-A the edge group • 2014 CL40FB-B – CL Series Single Pin Connector (400... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connector (400A / 600V) #6 - #2 AWG Female Red (C ) CL Series Single Pin Connector (400A / 600V) #6 - #2 AWG Male - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL2FB-C N-A N-A CL2MB-C N-A N-A CL Series Single Pin Connector (400... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connector (400A / 600V) #6 - #2 AWG Female Blue (D) CL Series Single Pin Connector (400A / 600V) #6 - #2 AWG Male - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL2FB-D N-A N-A CL2MB-D N-A N-A CL Series Single Pin Connector (400... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connector (400A / 600V) #6 - #2 AWG Female Green (E) CL Series Single Pin Connector (400A / 600V) #6 - #2 AWG Male Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL2FB-E N-A N-A CL2MB-E N-A N-A CL Series Single Pin Connector (400... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connector (400A / 600V) #6 - #2 AWG Male - Black (A) CL Series Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL2MB-A N-A N-A CL40FB-A N-A N-A CL Series Single Pin Connector (400... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connector (400A / 600V) #6 - #2 AWG Male White (B) CL Series Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL2MB-B N-A N-A CL40FB-B N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CL Series Single Pin Connector (400... 95 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CL40FB-C – CL Series Single Pin Connector (400... 96 CL Series Single Pin Connector (400... CL Series Single Pin Connector (400... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Red (C ) CL Series Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FB-C N-A N-A CL40FB-H N-A N-A CL Series Single Pin Connector (400... CL, CLS Series Protective Cap for F... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Blue (D) CL; CLS Series Protective Cap for Female Connections 20 Lanyard Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FB-D N-A N-A CL40FC-A N-A N-A CL Series Single Pin Connector (400... CL, CLS Series Protective Cap for F... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Green (E) CL; CLS Series Protective Cap for Female Connections 20 Lanyard White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FB-E N-A N-A CL40FC-B N-A N-A CL Series Single Pin Connector (400... CL, CLS Series Protective Cap for F... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Brown (F) CL; CLS Series Protective Cap for Female Connections 20 Lanyard Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FB-F N-A N-A CL40FC-C N-A N-A CL Series Single Pin Connector (400... CL, CLS Series Protective Cap for F... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Orange (G) CL; CLS Series Protective Cap for Female Connections 20 Lanyard Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FB-G N-A N-A CL40FC-D N-A N-A 860-442-4386 the edge group • 2014 CL40FR-ANGLE-F – CL, CLS Series Bus Bar Mount Recept... CL, CLS Series Bus Bar Mount Recept... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Protective Cap for Female Connections 20 Lanyard Green (E) CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Angled 30Deg - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FC-E N-A N-A CL40FR-ANGLE-B N-A N-A CL, CLS Series Protective Cap for F... CL, CLS Series Bus Bar Mount Recept... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Protective Cap for Female Connections 20 Lanyard Brown (F) CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Angled 30Deg - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FC-F 0.085 N-A CL40FR-ANGLE-C N-A N-A CL, CLS Series Protective Cap for F... CL, CLS Series Bus Bar Mount Recept... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Protective Cap for Female Connections 20 Lanyard Orange (G) CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Angled 30Deg - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FC-G N-A N-A CL40FR-ANGLE-D N-A N-A CL, CLS Series Protective Cap for F... CL, CLS Series Bus Bar Mount Recept... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Protective Cap for Female Connections 20 Lanyard Yellow (H) CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Angled 30Deg - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FC-H N-A N-A CL40FR-ANGLE-E N-A N-A CL, CLS Series Bus Bar Mount Recept... CL, CLS Series Bus Bar Mount Recept... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Angled 30Deg - Black (A) CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Angled 30Deg - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FR-ANGLE-A N-A N-A CL40FR-ANGLE-F N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CL, CLS Series Protective Cap for F... 97 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CL40FR-ANGLE-G – CL, CLS Series Bus Bar Mount Recept... 98 CL, CLS Series Bus Bar Mount Recept... CL, CLS Series Bus Bar Mount Recept... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) FemaleAngled 30Deg - Orange (G) CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Offset - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FR-ANGLE-G N-A N-A CL40FR-OFFSET-D N-A N-A CL, CLS Series Bus Bar Mount Recept... CL, CLS Series Bus Bar Mount Recept... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Angled 30Deg - Yellow (H) CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Offset - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FR-ANGLE-H N-A N-A CL40FR-OFFSET-E N-A N-A CL, CLS Series Bus Bar Mount Recept... CL, CLS Series Bus Bar Mount Recept... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Offset - Black (A) CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Offset - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FR-OFFSET-A N-A N-A CL40FR-OFFSET-F N-A N-A CL, CLS Series Bus Bar Mount Recept... CL, CLS Series Bus Bar Mount Recept... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Offset - White (B) CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Offset - Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FR-OFFSET-B N-A N-A CL40FR-OFFSET-G N-A N-A CL, CLS Series Bus Bar Mount Recept... CL, CLS Series Bus Bar Mount Recept... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Offset - Red (C ) CL; CLS Series Bus Bar Mount Receptacle (400A / 600V) Female Offset - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FR-OFFSET-C N-A N-A CL40FR-OFFSET-H N-A N-A 860-442-4386 the edge group • 2014 CL40FRB-C – CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Black (A) CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female Bus Bar - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRB-A 1 N-A CL40FRB-BB-C N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Black (A) Drill Out No Screws CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female Bus Bar - Blue (D ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRB-AX N-A N-A CL40FRB-BB-D N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - White (B) CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female Bus Bar - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRB-B 1 N-A CL40FRB-BB-E N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female Bus Bar - Black (A) CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - White (B) Drill Out No Screws Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRB-BB-A N-A N-A CL40FRB-BX N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female Bus Bar - White (B) CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Red (C ) Part Number Weight Min. Quantity CL40FRB-BB-B N-A N-A 860-442-4386 Part Number Weight Min. Quantity CL40FRB-C 1 N-A Bat teries/ Fl a shlights/Charger s CL Series Panel Mounts (400A / 600V... 99 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CL40FRB-CX – CL Series Panel Mounts (400A / 600V... 100 CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Red (C ) Drill Out No Screws CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRB-CX N-A N-A CL40FRB-F 1 N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Blue (D) Part Number Weight Min. Quantity CL40FRB-D 1 N-A CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Brown (F) Drill Out No Screws Part Number Weight Min. Quantity CL40FRB-FX N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Blue (D) Drill Out No Screws CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRB-DX N-A N-A CL40FRB-G 1 N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Green (E) CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Orange (G) Drill Out No Screws Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRB-E 1 N-A CL40FRB-GX N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Green (E) Drill Out No Screws CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRB-EX N-A N-A CL40FRB-H 1 N-A 860-442-4386 the edge group • 2014 CL40FRSB-E – CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2/0 - 4/0 AWG Female - Yellow (H) Drill Out No Screws CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRB-HX N-A N-A CL40FRSB-C 1 N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Black (A) CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Red (C ) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB-A 1 N-A CL40FRSB-CX N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Black (A) Drill Out CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB-AX N-A N-A CL40FRSB-D 1 N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female White (B) CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Blue (D) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB-B 1 N-A CL40FRSB-DX N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female White (B) Drill Out CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB-BX N-A N-A CL40FRSB-E 1 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CL Series Panel Mounts (400A / 600V... 101 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CL40FRSB-EX – CL Series Panel Mounts (400A / 600V... 102 CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Green (E) Drill Out CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB-EX N-A N-A CL40FRSB-H 1 N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Brown (F) CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Yellow (H) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB-F 1 N-A CL40FRSB-HX N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Brown (F) Drill Out CL Series Panel Mounts (400A / 600V) 2 Threaded Stud Female - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB-FX N-A N-A CL40FRSB2-A N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Orange (G) CL Series Panel Mounts (400A / 600V) 2 Threaded Stud Female White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB-G 1 N-A CL40FRSB2-B N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 1.25 Threaded Stud Female Orange (G) Drill Out CL Series Panel Mounts (400A / 600V) 2 Threaded Stud Female - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB-GX N-A N-A CL40FRSB2-C N-A N-A 860-442-4386 the edge group • 2014 CL40FRSBML-E – CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2 Threaded Stud Female - Blue (D) CL Series Panel Mounts (400A / 600V) Threaded Stud Female - Black (A) Extended Shoulder Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB2-D N-A N-A CL40FRSBML-A N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2 Threaded Stud Female Green (E) CL Series Panel Mounts (400A / 600V) Threaded Stud Female - White (B) Extended Shoulder Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB2-E N-A N-A CL40FRSBML-B N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2 Threaded Stud Female Brown (F) CL Series Panel Mounts (400A / 600V) Threaded Stud Female - Red (C ) Extended Shoulder Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB2-F N-A N-A CL40FRSBML-C N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2 Threaded Stud Female Orange (G) CL Series Panel Mounts (400A / 600V) Threaded Stud Female - Blue (D) Extended Shoulder Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB2-G N-A N-A CL40FRSBML-D N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Panel Mounts (400A / 600V... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) 2 Threaded Stud Female - Yellow (H) CL Series Panel Mounts (400A / 600V) Threaded Stud Female - Green (E) Extended Shoulder Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSB2-H N-A N-A CL40FRSBML-E N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CL Series Panel Mounts (400A / 600V... 103 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CL40FRSBML-F – CL Series Panel Mounts (400A / 600V... 104 CL Series Panel Mounts (400A / 600V... CL Series Single Pin Connectors (40... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) Threaded Stud Female - Brown (F) Extended Shoulder CL Series Single Pin Connectors (400A / 600V) 2/0 - 4/0 AWG Male Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSBML-F N-A N-A CL40MB-C N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Single Pin Connectors (40... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) Threaded Stud Female - Orange (G) Extended Shoulder CL Series Single Pin Connectors (400A / 600V) 2/0 - 4/0 AWG Male Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSBML-G N-A N-A CL40MB-D N-A N-A CL Series Panel Mounts (400A / 600V... CL Series Single Pin Connectors (40... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts (400A / 600V) Threaded Stud Female - Yellow (H) Extended Shoulder CL Series Single Pin Connectors (400A / 600V) 2/0 - 4/0 AWG Male Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40FRSBML-H N-A N-A CL40MB-E N-A N-A CL Series Single Pin Connectors (40... CL Series Single Pin Connectors (40... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connectors (400A / 600V) 2/0 - 4/0 AWG Male Black (A) CL Series Single Pin Connectors (400A / 600V) 2/0 - 4/0 AWG Male Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MB-A N-A N-A CL40MB-F N-A N-A CL Series Single Pin Connectors (40... CL Series Single Pin Connectors (40... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connectors (400A / 600V) 2/0 - 4/0 AWG Male White (B) CL Series Single Pin Connectors (400A / 600V) 2/0 - 4/0 AWG Male Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MB-B N-A N-A CL40MB-G N-A N-A 860-442-4386 the edge group • 2014 CL40MR-ANGLE-A – CL, CLS Series Bus Bar Mount Inlet ... CL, CLS Series Protective Cap for M... Marinco Electrical Group Marinco Electrical Group CL Series Single Pin Connectors (400A / 600V) 2/0 - 4/0 AWG Male Yellow (H) CL; CLS Series Protective Cap for Male Connections 20 Lanyard - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MB-H N-A N-A CL40MC-E 0.123 N-A CL, CLS Series Protective Cap for M... CL, CLS Series Protective Cap for M... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Protective Cap for Male Connections 20 Lanyard - Black (A) CL; CLS Series Protective Cap for Male Connections 20 Lanyard Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MC-A 0.123 N-A CL40MC-F 0.123 N-A CL, CLS Series Protective Cap for M... CL, CLS Series Protective Cap for M... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Protective Cap for Male Connections 20 Lanyard - White (B) CL; CLS Series Protective Cap for Male Connections 20 Lanyard Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MC-B 0.123 N-A CL40MC-G 0.123 N-A CL, CLS Series Protective Cap for M... CL, CLS Series Protective Cap for M... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Protective Cap for Male Connections 20 Lanyard - Red √جø¬Ω CL; CLS Series Protective Cap for Male Connections 20 Lanyard - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MC-C 0.123 N-A CL40MC-H 0.123 N-A CL, CLS Series Protective Cap for M... CL, CLS Series Bus Bar Mount Inlet ... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Protective Cap for Male Connections 20 Lanyard - Blue (D) CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Angled 30Deg - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MC-D 0.123 N-A CL40MR-ANGLE-A N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CL Series Single Pin Connectors (40... 105 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CL40MR-ANGLE-B – CL, CLS Series Bus Bar Mount Inlet ... 106 CL, CLS Series Bus Bar Mount Inlet ... CL, CLS Series Bus Bar Mount Inlet ... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Angled 30Deg - White (B) CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Angled 30Deg - Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MR-ANGLE-B N-A N-A CL40MR-ANGLE-G N-A N-A CL, CLS Series Bus Bar Mount Inlet ... CL, CLS Series Bus Bar Mount Inlet ... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Angled 30Deg - Red C CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Angled 30Deg - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MR-ANGLE-C N-A N-A CL40MR-ANGLE-H N-A N-A CL, CLS Series Bus Bar Mount Inlet ... CL, CLS Series Bus Bar Mount Inlet ... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Angled 30Deg - Blue (D) CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Offset - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MR-ANGLE-D N-A N-A CL40MR-OFFSET-A 1 N-A CL, CLS Series Bus Bar Mount Inlet ... CL, CLS Series Bus Bar Mount Inlet ... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Angled 30Deg - Green (E) CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Offset - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MR-ANGLE-E N-A N-A CL40MR-OFFSET-B 1 N-A CL, CLS Series Bus Bar Mount Inlet ... CL, CLS Series Bus Bar Mount Inlet ... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Angled 30Deg - Brown (F) CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Offset - Red (C ) Part Number Weight Min. Quantity CL40MR-ANGLE-F N-A N-A 860-442-4386 Part Number Weight Min. Quantity CL40MR-OFFSET-C 1 N-A the edge group • 2014 CL40MRB-BB-B – CL Series Panel Mounts Inlet (400A ... CL Series Panel Mounts Inlet (400A ... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Offset - Blue (D) CL Series Panel Mounts Inlet (400A / 600V) Male - Black (A) Part Number Weight Min. Quantity CL40MR-OFFSET-D 1 N-A Part Number Weight Min. Quantity CL40MRB-A 1 N-A CL, CLS Series Bus Bar Mount Inlet ... CL Series Panel Mounts Inlet (400A ... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Offset - Green (E) CL Series Panel Mounts Inlet (400A / 600V) Male - Black (A) Drill Out No Screws Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MR-OFFSET-E 1 N-A CL40MRB-AX N-A N-A CL, CLS Series Bus Bar Mount Inlet ... CL Series Panel Mounts Inlet (400A ... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Offset - Brown (F) CL Series Panel Mounts Inlet (400A / 600V) Male - White (B) Part Number Weight Min. Quantity CL40MR-OFFSET-F 1 N-A Part Number Weight Min. Quantity CL40MRB-B 1 N-A CL, CLS Series Bus Bar Mount Inlet ... CL Series Panel Mounts Inlet (400A ... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Offset - Orange (G) CL Series Panel Mounts Inlet (400A / 600V) Male Bus Bar - Black (A) Part Number Weight Min. Quantity CL40MR-OFFSET-G 1 N-A Part Number Weight Min. Quantity CL40MRB-BB-A N-A N-A CL, CLS Series Bus Bar Mount Inlet ... CL Series Panel Mounts Inlet (400A ... Marinco Electrical Group Marinco Electrical Group CL; CLS Series Bus Bar Mount Inlet (400A / 600V) Male Offset - Yellow (H) CL Series Panel Mounts Inlet (400A / 600V) Male Bus Bar - White (B) Part Number Weight Min. Quantity CL40MR-OFFSET-H 1 N-A 860-442-4386 Part Number Weight Min. Quantity CL40MRB-BB-B N-A N-A Bat teries/ Fl a shlights/Charger s CL, CLS Series Bus Bar Mount Inlet ... 107 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CL40MRB-BB-C – CL Series Panel Mounts Inlet (400A ... CL Series Panel Mounts Inlet (400A ... CL Series Panel Mounts Inlet (400A ... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts Inlet (400A / 600V) Male Bus Bar - Red √جø¬Ω CL Series Panel Mounts Inlet (400A / 600V) Male - Red (C ) Drill Out Part Number Weight Min. Quantity CL40MRB-BB-C N-A N-A Weight Min. Quantity CL40MRB-CX N-A N-A CL Series Panel Mounts Inlet (400A ... CL Series Panel Mounts Inlet (400A ... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts Inlet (400A / 600V) Male Bus Bar - Blue (D) CL Series Panel Mounts Inlet (400A / 600V) Male - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRB-BB-D N-A N-A CL40MRB-D 1 N-A CL Series Panel Mounts Inlet (400A ... CL Series Panel Mounts Inlet (400A ... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts Inlet (400A / 600V) Male Bus Bar - Green (E) 108 Part Number CL Series Panel Mounts Inlet (400A / 600V) Male - Blue (D) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRB-BB-E N-A N-A CL40MRB-DX N-A N-A CL Series Panel Mounts Inlet (400A ... CL Series Panel Mounts Inlet (400A ... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts Inlet (400A / 600V) Male - White (B) Drill Out CL Series Panel Mounts Inlet (400A / 600V) Male - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRB-BX N-A N-A CL40MRB-E 1 N-A CL Series Panel Mounts Inlet (400A ... CL Series Panel Mounts Inlet (400A ... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts Inlet (400A / 600V) Male - Red (C ) CL Series Panel Mounts Inlet (400A / 600V) Male - Green (E) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRB-C 1 N-A CL40MRB-EX N-A N-A 860-442-4386 the edge group • 2014 CL40MRSB-BX – CL Series Panel Mount Inlet (400A /... CL Series Panel Mounts Inlet (400A ... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts Inlet (400A / 600V) Male - Brown (F) CL Series Panel Mounts Inlet (400A / 600V) Male - Yellow (H) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRB-F 1 N-A CL40MRB-HX N-A N-A CL Series Panel Mounts Inlet (400A ... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts Inlet (400A / 600V) Male - Brown (F) Drill Out Part Number Weight Min. Quantity CL40MRB-FX N-A N-A CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male - Black (A) Part Number Weight Min. Quantity CL40MRSB-A 1 N-A CL Series Panel Mounts Inlet (400A ... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts Inlet (400A / 600V) Male - Orange (G) Part Number Weight Min. Quantity CL40MRB-G 1 N-A CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male Black (A) Drill Out Part Number Weight Min. Quantity CL40MRSB-AX N-A N-A CL Series Panel Mounts Inlet (400A ... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts Inlet (400A / 600V) Male - Orange (G) Drill Out CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male - White (B) Part Number Weight Min. Quantity CL40MRB-GX N-A N-A Part Number Weight Min. Quantity CL40MRSB-B 1 N-A CL Series Panel Mounts Inlet (400A ... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mounts Inlet (400A / 600V) Male - Yellow (H) CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male White (B) Drill Out Part Number Weight Min. Quantity CL40MRB-H 1 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CL Series Panel Mounts Inlet (400A ... Part Number Weight Min. Quantity CL40MRSB-BX N-A N-A 109 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CL40MRSB-C – CL Series Panel Mount Inlet (400A /... 110 CL Series Panel Mount Inlet (400A /... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male - Red (C ) CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male Green (E) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRSB-C 1 N-A CL40MRSB-EX N-A N-A CL Series Panel Mount Inlet (400A /... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male Red (C ) Drill Out CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRSB-CX N-A N-A CL40MRSB-F 1 N-A CL Series Panel Mount Inlet (400A /... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male - Blue (D) CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male Brown (F) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRSB-D 1 N-A CL40MRSB-FX 1 N-A CL Series Panel Mount Inlet (400A /... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male Blue (D) Drill Out CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male - Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRSB-DX N-A N-A CL40MRSB-G 1 N-A CL Series Panel Mount Inlet (400A /... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male - Green (E) CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male Orange (G) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRSB-E 1 N-A CL40MRSB-GX 1 N-A 860-442-4386 the edge group • 2014 CL40MRSB2-H – CL Series Panel Mount Inlet (400A /... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male - Yellow (H) CL Series Panel Mount Inlet (400A / 600V) 2 Threaded Stud Male Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRSB-H 1 N-A CL40MRSB2-D N-A N-A CL Series Panel Mount Inlet (400A /... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) 1.25 Threaded Stud Male Yellow (H) Drill Out CL Series Panel Mount Inlet (400A / 600V) 2 Threaded Stud Male Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRSB-HX 1 N-A CL40MRSB2-E N-A N-A CL Series Panel Mount Inlet (400A /... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) 2 Threaded Stud Male Black (A) CL Series Panel Mount Inlet (400A / 600V) 2 Threaded Stud Male Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRSB2-A N-A N-A CL40MRSB2-F N-A N-A CL Series Panel Mount Inlet (400A /... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) 2 Threaded Stud Male White (B) CL Series Panel Mount Inlet (400A / 600V) 2 Threaded Stud Male Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRSB2-B N-A N-A CL40MRSB2-G N-A N-A CL Series Panel Mount Inlet (400A /... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) 2 Threaded Stud Male - Red (C ) CL Series Panel Mount Inlet (400A / 600V) 2 Threaded Stud Male Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRSB2-C N-A N-A CL40MRSB2-H N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CL Series Panel Mount Inlet (400A /... 111 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CL40MRSBML-A – CL Series Panel Mount Inlet (400A /... 112 CL Series Panel Mount Inlet (400A /... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) Threaded Stud Male - Black (A) Extended Shoulder CL Series Panel Mount Inlet (400A / 600V) Threaded Stud Male Brown (F) Extended Shoulder Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRSBML-A N-A N-A CL40MRSBML-F N-A N-A CL Series Panel Mount Inlet (400A /... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) Threaded Stud Male White (B) Extended Shoulder CL Series Panel Mount Inlet (400A / 600V) Threaded Stud Male Orange (G) Extended Shoulder Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRSBML-B N-A N-A CL40MRSBML-G N-A N-A CL Series Panel Mount Inlet (400A /... CL Series Panel Mount Inlet (400A /... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) Threaded Stud Male - Red (C) Extended Shoulder CL Series Panel Mount Inlet (400A / 600V) Threaded Stud Male - Yellow (H) Extended Shoulder Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40MRSBML-C N-A N-A CL40MRSBML-H N-A N-A CL Series Panel Mount Inlet (400A /... Snap Back Cam Cover Through Mount (... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) Threaded Stud Male - Blue (D) Extended Shoulder Snap Back Cam Cover Through Mount (.370 - .400) - Black (A) Part Number Weight Min. Quantity CL40MRSBML-D N-A N-A Part Number Weight Min. Quantity CL40WTC-L-062-A 0.145 N-A CL Series Panel Mount Inlet (400A /... Snap Back Cam Cover Through Mount (... Marinco Electrical Group Marinco Electrical Group CL Series Panel Mount Inlet (400A / 600V) Threaded Stud Male Green (E) Extended Shoulder Snap Back Cam Cover Through Mount (.370 - .400) - White (B) Part Number Weight Min. Quantity CL40MRSBML-E N-A N-A 860-442-4386 Part Number Weight Min. Quantity CL40WTC-L-062-B 0.145 N-A the edge group • 2014 CL40WTC-L-125-D – Snap Back Cam Cover Surface Mount -... Snap Back Cam Cover Through Mount (... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through Mount (.370 - .400) - Red √جø¬Ω Snap Back Cam Cover Through Mount (.370 - .400) - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-L-062-C 0.145 N-A CL40WTC-L-062-H 0.145 N-A Snap Back Cam Cover Through Mount (... Snap Back Cam Cover Surface Mount -... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through Mount (.370 - .400) - Blue (D) Snap Back Cam Cover Surface Mount - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-L-062-D 0.145 N-A CL40WTC-L-125-A N-A N-A Snap Back Cam Cover Through Mount (... Snap Back Cam Cover Surface Mount -... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through Mount (.370 - .400) - Green (E) Snap Back Cam Cover Surface Mount - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-L-062-E 0.145 N-A CL40WTC-L-125-B N-A N-A Snap Back Cam Cover Through Mount (... Snap Back Cam Cover Surface Mount -... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through Mount (.370 - .400) - Brown (F) Snap Back Cam Cover Surface Mount - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-L-062-F 0.145 N-A CL40WTC-L-125-C N-A N-A Snap Back Cam Cover Through Mount (... Snap Back Cam Cover Surface Mount -... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through Mount (.370 - .400) - Orange (G) Snap Back Cam Cover Surface Mount - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-L-062-G 0.145 N-A CL40WTC-L-125-D N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s Snap Back Cam Cover Through Mount (... 113 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CL40WTC-L-125-E – Snap Back Cam Cover Surface Mount -... Snap Back Cam Cover Surface Mount -... Snap Back Cam Cover Through-Mount (... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Surface Mount - Green (E) Snap Back Cam Cover Through-Mount (.070 - .090) - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-L-125-E N-A N-A CL40WTC-L-187-A N-A N-A Snap Back Cam Cover Surface Mount -... Snap Back Cam Cover Through-Mount (... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Surface Mount - Brown (F) Snap Back Cam Cover Through-Mount (.070 - .090) - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-L-125-F N-A N-A CL40WTC-L-187-B N-A N-A Snap Back Cam Cover Surface Mount -... Snap Back Cam Cover Through-Mount (... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Surface Mount - Orange (G) 114 Snap Back Cam Cover Through-Mount (.070 - .090) - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-L-125-G N-A N-A CL40WTC-L-187-C N-A N-A Snap Back Cam Cover Surface Mount -... Snap Back Cam Cover Through-Mount (... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Surface Mount - Yellow (H) Snap Back Cam Cover Through-Mount (.070 - .090) - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-L-125-H N-A N-A CL40WTC-L-187-D N-A N-A Snap Back Cam Cover Surface Mount -... Snap Back Cam Cover Through-Mount (... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Surface Mount - Grey (J) Snap Back Cam Cover Through-Mount (.070 - .090) - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-L-125-J 0.1405 N-A CL40WTC-L-187-E N-A N-A 860-442-4386 the edge group • 2014 CL40WTC-S-062-D – Snap Back Cam Cover Through-Mount (... Snap Back Cam Cover Through-Mount (... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through-Mount (.070 - .090) - Brown (F) Snap Back Cam Cover Through-Mount (.070 - .090) - Green (E) Stamp G Part Number Weight Min. Quantity CL40WTC-L-187-F N-A N-A Part Number Weight Min. Quantity CL40WTC-L187EG N-A N-A Snap Back Cam Cover Through-Mount (... Snap Back Cam Cover Through-Mount (... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through-Mount (.070 - .090) - Orange (G) Snap Back Cam Cover Through-Mount (.370 - .400) - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-L-187-G N-A N-A CL40WTC-S-062-A N-A N-A Snap Back Cam Cover Through-Mount (... Snap Back Cam Cover Through-Mount (... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through-Mount (.070 - .090) - Yellow (H) Snap Back Cam Cover Through-Mount (.370 - .400) - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-L-187-H N-A N-A CL40WTC-S-062-B N-A N-A Snap Back Cam Cover Through-Mount (... Snap Back Cam Cover Through-Mount (... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through-Mount (.070 - .090) - Black (A) Stamp L1 Snap Back Cam Cover Through-Mount (.370 - .400) - Red (C ) Part Number Weight Min. Quantity CL40WTC-L187A1 N-A N-A Part Number Weight Min. Quantity CL40WTC-S-062-C N-A N-A Snap Back Cam Cover Through-Mount (... Snap Back Cam Cover Through-Mount (... Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through-Mount (.070 - .090) - Red (C ) Stamp L2 Snap Back Cam Cover Through-Mount (.370 - .400) - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-L187C2 N-A N-A CL40WTC-S-062-D N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s Snap Back Cam Cover Through-Mount (... 115 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CL40WTC-S-062-E – Snap Back Cam Cover Through-Mount (... Snap Back Cam Cover Through-Mount (... PLUG, 5-15 CLAMP LOCK Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through-Mount (.370 - .400) - Green (E) PLUG; 5-15 CLAMP LOCK Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-S-062-E N-A N-A CL5266 0.1345 N-A Snap Back Cam Cover Through-Mount (... PLUG, 5-15 CLAMP LOCK MASTER/50 Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through-Mount (.370 - .400) - Brown (F) Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-S-062-F N-A N-A CL5266.OEM 0.1225 N-A Snap Back Cam Cover Through-Mount (... PLUG, 5-15 CLAMP LOCK BLK BODY Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through-Mount (.370 - .400) - Orange (G) 116 PLUG; 5-15 CLAMP LOCK MASTER/50 Part Number PLUG; 5-15 CLAMP LOCK BLK BODY Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-S-062-G N-A N-A CL5266BL 0.1225 N-A Snap Back Cam Cover Through-Mount (... CONN, 5-15 CLAMP LOCK Marinco Electrical Group Marinco Electrical Group Snap Back Cam Cover Through-Mount (.370 - .400) - Yellow (H) CONN; 5-15 CLAMP LOCK Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL40WTC-S-062-H N-A N-A CL5269 0.1565 N-A Snap Back Cam Metal Cover Through M... CONN, 5-15 CLAMP LOCK MASTER/50 Marinco Electrical Group Marinco Electrical Group Snap Back Cam Metal Cover Through Mount (.070 - .090) Anodized AL - Clear CONN; 5-15 CLAMP LOCK MASTER/50 Part Number Weight Min. Quantity CL40ZFLC-161 N-A N-A 860-442-4386 Part Number Weight Min. Quantity CL5269.OEM 0.145 N-A the edge group • 2014 CLIP – CLIP,SHORE CORD HLDR,6 PC CONN, 6-15 CLAMP LOCK Marinco Electrical Group Marinco Electrical Group CONN; 5-15 CLAMP LOCK BLK BODY CONN; 6-15 CLAMP LOCK Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL5269BL 0.145 N-A CL5669 0.1442 N-A PLUG, 5-20 CLAMP LOCK BULK PLUG, 5-15 CLAMP LOCK HG Marinco Electrical Group Marinco Electrical Group PLUG; 5-20 CLAMP LOCK BULK PLUG; 5-15 CLAMP LOCK HG Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL5366.OEM N-A N-A CL8215 0.1225 N-A CONN, 5-20 CLAMP LOCK PLUG, 5-15 CLAMP LOCK HG TRANSPAREN... Marinco Electrical Group Marinco Electrical Group CONN; 5-20 CLAMP LOCK Bat teries/ Fl a shlights/Charger s CONN, 5-15 CLAMP LOCK BLK BODY PLUG; 5-15 CLAMP LOCK HG TRANSPARENT HOUSING Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL5369 0.1442 N-A CL8215T 0.1225 N-A CONN, 5-20 CLAMP LOCK BULK CONN, 5-15 CLAMP LOCK HG Marinco Electrical Group Marinco Electrical Group CONN; 5-20 CLAMP LOCK BULK CONN; 5-15 CLAMP LOCK HG Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL5369.OEM N-A N-A CL8219 0.1442 N-A PLUG, 6-15 CLAMP LOCK CLIP,SHORE CORD HLDR,6 PC Marinco Electrical Group Marinco Electrical Group PLUG; 6-15 CLAMP LOCK CLIP;SHORE CORD HLDR;6 PC Part Number Weight Min. Quantity Part Number Weight Min. Quantity CL5666 0.1225 N-A CLIP 1 N-A 860-442-4386 117 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLL3R-A – Cam NEMA 3R Enclosure (400A) - Blac... Cam NEMA 3R Enclosure (400A) - Blac... Cam NEMA 3R Enclosure (400A) - Brow... Marinco Electrical Group Marinco Electrical Group Cam NEMA 3R Enclosure (400A) - Black (A) Cam NEMA 3R Enclosure (400A) - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLL3R-A N-A N-A CLL3R-F N-A N-A Cam NEMA 3R Enclosure (400A) - Whit... Cam NEMA 3R Enclosure (400A) - Oran... Marinco Electrical Group Marinco Electrical Group Cam NEMA 3R Enclosure (400A) - White (B) Cam NEMA 3R Enclosure (400A) - Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLL3R-B N-A N-A CLL3R-G N-A N-A Cam NEMA 3R Enclosure (400A) - Red ... Cam NEMA 3R Enclosure (400A) - Yell... Marinco Electrical Group Marinco Electrical Group Cam NEMA 3R Enclosure (400A) - Red (C ) 118 Cam NEMA 3R Enclosure (400A) - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLL3R-C N-A N-A CLL3R-H N-A N-A Cam NEMA 3R Enclosure (400A) - Blue... CLM Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group Cam NEMA 3R Enclosure (400A) - Blue (D) CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Female - Black (A) Part Number Weight Min. Quantity CLL3R-D N-A N-A Part Number Weight Min. Quantity CLM2F-A 0.181 N-A Cam NEMA 3R Enclosure (400A) - Gree... CLM Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group Cam NEMA 3R Enclosure (400A) - Green (E) CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Female - White (B) Part Number Weight Min. Quantity CLL3R-E N-A N-A 860-442-4386 Part Number Weight Min. Quantity CLM2F-B N-A N-A the edge group • 2014 CLM2M-D – CLM Series Inline Single Pin Connec... CLM Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Female - Red (C ) CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Female - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLM2F-C N-A N-A CLM2F-H N-A N-A CLM Series Inline Single Pin Connec... CLM Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Female - Blue (D) CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Male - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLM2F-D N-A N-A CLM2M-A N-A N-A CLM Series Inline Single Pin Connec... CLM Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Female - Green (E) CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Male - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLM2F-E N-A N-A CLM2M-B N-A N-A CLM Series Inline Single Pin Connec... CLM Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Female - Brown (F) CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Male - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLM2F-F N-A N-A CLM2M-C N-A N-A CLM Series Inline Single Pin Connec... CLM Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Female - Orange (G) CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Male - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLM2F-G N-A N-A CLM2M-D N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLM Series Inline Single Pin Connec... 119 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLM2M-E – CLM Series Inline Single Pin Connec... 120 CLM Series Inline Single Pin Connec... Mini Cam NEMA 3R Enclosure (150A) -... Marinco Electrical Group Marinco Electrical Group CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Male - Green (E) Mini Cam NEMA 3R Enclosure (150A) - White (B) Part Number Weight Min. Quantity CLM2M-E N-A N-A Part Number Weight Min. Quantity CLM3R-B N-A N-A CLM Series Inline Single Pin Connec... Mini Cam NEMA 3R Enclosure (150A) -... Marinco Electrical Group Marinco Electrical Group CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Male - Brown (F) Mini Cam NEMA 3R Enclosure (150A) - Red (C ) Part Number Weight Min. Quantity CLM2M-F N-A N-A Part Number Weight Min. Quantity CLM3R-C N-A N-A CLM Series Inline Single Pin Connec... Mini Cam NEMA 3R Enclosure (150A) -... Marinco Electrical Group Marinco Electrical Group CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Male - Orange (G) Mini Cam NEMA 3R Enclosure (150A) - Blue (D) Part Number Weight Min. Quantity CLM2M-G N-A N-A Part Number Weight Min. Quantity CLM3R-D N-A N-A CLM Series Inline Single Pin Connec... Mini Cam NEMA 3R Enclosure (150A) -... Marinco Electrical Group Marinco Electrical Group CLM Series Inline Single Pin Connectors (150A / 600V) #8 - #2 AWG Male - Yellow (H) Mini Cam NEMA 3R Enclosure (150A) - Green (E) Part Number Weight Min. Quantity CLM2M-H N-A N-A Part Number Weight Min. Quantity CLM3R-E N-A N-A Mini Cam NEMA 3R Enclosure (150A) -... Mini Cam NEMA 3R Enclosure (150A) -... Marinco Electrical Group Marinco Electrical Group Mini Cam NEMA 3R Enclosure (150A) - Black (A) Mini Cam NEMA 3R Enclosure (150A) - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLM3R-A N-A N-A CLM3R-F N-A N-A 860-442-4386 the edge group • 2014 CLMAD3FST-C – CLM Cam Reducer (400A / 600V) Male ... CLM Cam Reducer (400A / 600V) Male ... Marinco Electrical Group Marinco Electrical Group Mini Cam NEMA 3R Enclosure (150A) - Orange (G) CLM Cam Reducer (400A / 600V) Male to Three (150A / 600V) Female 3FER - Blue (D) Part Number Weight Min. Quantity CLM3R-G N-A N-A Part Number Weight Min. Quantity CLMAD3F-D N-A N-A Mini Cam NEMA 3R Enclosure (150A) -... CLM Cam Reducer (400A / 600V) Male ... Marinco Electrical Group Marinco Electrical Group Mini Cam NEMA 3R Enclosure (150A) - Yellow (H) Part Number Weight Min. Quantity CLM3R-H N-A N-A CLM Cam Reducer (400A / 600V) Male to Three (150A / 600V) Female 3FER - Green (E) Part Number Weight Min. Quantity CLMAD3F-E N-A N-A CLM Cam Reducer (400A / 600V) Male ... CLM Cam Reducer (400A / 600V) Male ... Marinco Electrical Group Marinco Electrical Group CLM Cam Reducer (400A / 600V) Male to Three (150A / 600V) Female 3FER - Black (A) CLM Cam Reducer (400A / 600V) Male to Three (150A / 600V) Female Soft 3FER - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMAD3F-A N-A N-A CLMAD3FST-A N-A N-A CLM Cam Reducer (400A / 600V) Male ... CLM Cam Reducer (400A / 600V) Male ... Marinco Electrical Group Marinco Electrical Group CLM Cam Reducer (400A / 600V) Male to Three (150A / 600V) Female 3FER - White (B) CLM Cam Reducer (400A / 600V) Male to Three (150A / 600V) Female Soft 3FER - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMAD3F-B N-A N-A CLMAD3FST-B N-A N-A CLM Cam Reducer (400A / 600V) Male ... CLM Cam Reducer (400A / 600V) Male ... Marinco Electrical Group Marinco Electrical Group CLM Cam Reducer (400A / 600V) Male to Three (150A / 600V) Female 3FER - Red (C ) CLM Cam Reducer (400A / 600V) Male to Three (150A / 600V) Female Soft 3FER - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMAD3F-C N-A N-A CLMAD3FST-C N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s Mini Cam NEMA 3R Enclosure (150A) -... 121 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLMAD3FST-D – CLM Cam Reducer (400A / 600V) Male ... CLM Cam Reducer (400A / 600V) Male ... CLM Cam Inline Reducer 400A to 150A... Marinco Electrical Group Marinco Electrical Group CLM Cam Reducer (400A / 600V) Male to Three (150A / 600V) Female Soft 3FER - Blue (D) CLM Cam Inline Reducer 400A to 150A (F-M) - Red (C ) Part Number Weight Min. Quantity CLMAD3FST-D N-A N-A Weight Min. Quantity CLMADFM-C N-A N-A CLM Cam Reducer (400A / 600V) Male ... CLM Cam Inline Reducer 400A to 150A... Marinco Electrical Group Marinco Electrical Group CLM Cam Reducer (400A / 600V) Male to Three (150A / 600V) Female Soft 3FER - Green (E) CLM Cam Inline Reducer 400A to 150A (F-M) - Blue (D) Part Number Weight Min. Quantity CLMAD3FST-E N-A N-A Part Number Weight Min. Quantity CLMADFM-D N-A N-A CLM Cam Inline Reducer 400A to 150A... CLM Cam Inline Reducer 400A to 150A... Marinco Electrical Group Marinco Electrical Group CLM Cam Inline Reducer 400A to 150A (F-F) - Black (A) 122 Part Number CLM Cam Inline Reducer 400A to 150A (F-M) - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMADFF-A N-A N-A CLMADFM-E N-A N-A CLM Cam Inline Reducer 400A to 150A... CLM Cam Inline Reducer 400A to 150A... Marinco Electrical Group Marinco Electrical Group CLM Cam Inline Reducer 400A to 150A (F-M) - Black (A) CLM Cam Inline Reducer 400A to 150A (M-F) - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMADFM-A N-A N-A CLMADMF-A N-A N-A CLM Cam Inline Reducer 400A to 150A... CLM Cam Inline Reducer 400A to 150A... Marinco Electrical Group Marinco Electrical Group CLM Cam Inline Reducer 400A to 150A (F-M) - White (B) CLM Cam Inline Reducer 400A to 150A (M-F) - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMADFM-B N-A N-A CLMADMF-B N-A N-A 860-442-4386 the edge group • 2014 CLMFC-E – CLM Mini female protective cap w/ l... CLM Mini female protective cap w/ l... Marinco Electrical Group Marinco Electrical Group CLM Cam Inline Reducer 400A to 150A (M-F) - Red (C ) CLM Mini female protective cap w/ lanyard - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMADMF-C N-A N-A CLMFC-A N-A N-A CLM Cam Inline Reducer 400A to 150A... CLM Mini female protective cap w/ l... Marinco Electrical Group Marinco Electrical Group CLM Cam Inline Reducer 400A to 150A (M-F) - Blue (D) CLM Mini female protective cap w/ lanyard - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMADMF-D N-A N-A CLMFC-B 0.05 N-A CLM Cam Inline Reducer 400A to 150A... CLM Mini female protective cap w/ l... Marinco Electrical Group Marinco Electrical Group CLM Cam Inline Reducer 400A to 150A (M-F) - Green (E) CLM Mini female protective cap w/ lanyard - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMADMF-E N-A N-A CLMFC-C 0.05 N-A CLM Cam Inline Reducer 400A to 150A... CLM Mini female protective cap w/ l... Marinco Electrical Group Marinco Electrical Group CLM Cam Inline Reducer 400A to 150A (M-M) - Black (A) CLM Mini female protective cap w/ lanyard - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMADMM-A N-A N-A CLMFC-D 0.05 N-A CLM Cam Inline Reducer 400A to 150A... CLM Mini female protective cap w/ l... Marinco Electrical Group Marinco Electrical Group CLM Cam Inline Reducer 400A to 150A (M-M) - Red (C ) CLM Mini female protective cap w/ lanyard - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMADMM-C N-A N-A CLMFC-E 0.05 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLM Cam Inline Reducer 400A to 150A... 123 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLMFC-F – CLM Mini female protective cap w/ l... CLM Mini female protective cap w/ l... CLM Turnaround (150A / 600V) (F-F) ... Marinco Electrical Group Marinco Electrical Group CLM Mini female protective cap w/ lanyard - Brown (F) CLM Turnaround (150A / 600V) (F-F) - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFC-F 0.048 N-A CLMFF-C 0.206 N-A CLM Mini female protective cap w/ l... CLM Turnaround (150A / 600V) (F-F) ... Marinco Electrical Group Marinco Electrical Group CLM Mini female protective cap w/ lanyard - Orange (G) Weight Min. Quantity Part Number Weight Min. Quantity CLMFC-G 0.48 N-A CLMFF-D 0.206 N-A CLM Mini female protective cap w/ l... CLM Turnaround (150A / 600V) (F-F) ... Marinco Electrical Group Marinco Electrical Group CLM Mini female protective cap w/ lanyard - Yellow (H) 124 CLM Turnaround (150A / 600V) (F-F) - Blue (D) Part Number CLM Turnaround (150A / 600V) (F-F) - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFC-H 0.48 N-A CLMFF-E 0.206 N-A CLM Turnaround (150A / 600V) (F-F) ... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Turnaround (150A / 600V) (F-F) - Black (A) CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw - Black (A) Part Number Weight Min. Quantity CLMFF-A 0.206 N-A Part Number Weight Min. Quantity CLMFR2-A N-A N-A CLM Turnaround (150A / 600V) (F-F) ... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Turnaround (150A / 600V) (F-F) - White (B) CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw - Black (A) Drill Out Part Number Weight Min. Quantity CLMFF-B 0.206 N-A 860-442-4386 Part Number Weight Min. Quantity CLMFR2-AX N-A N-A the edge group • 2014 CLMFR2-G – CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw - White (B) CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw - Blue (D) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFR2-B N-A N-A CLMFR2-DX N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw - White (B)Drill Out CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFR2-BX N-A N-A CLMFR2-E N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw - Red (C ) CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw - Green (E) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFR2-C N-A N-A CLMFR2-EX N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw - Red (C ) Drill Out CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFR2-CX N-A N-A CLMFR2-F N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw - Blue (D) CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw - Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFR2-D N-A N-A CLMFR2-G N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLM Series Panel Mounts (150A / 600... 125 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLMFR2-H – CLM Series Panel Mounts (150A / 600... 126 CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw - Yellow (H) CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Female - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFR2-H N-A N-A CLMFRS-C N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Female - Black (A) CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Female - Red (C ) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFRS-A N-A N-A CLMFRS-CX N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Female - Black (A) Drill Out CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Female - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFRS-AX N-A N-A CLMFRS-D N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Female - White (B) CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Female - Blue (D) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFRS-B N-A N-A CLMFRS-DX N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Female - White (B) Drill Out CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Female - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFRS-BX N-A N-A CLMFRS-E N-A N-A 860-442-4386 the edge group • 2014 CLMMC-C – CLM Series Mini Protective Cap w/ L... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Female - Green (E) Drill Out CLM Series Panel Mounts (150A / 600V) 1 - 8 Threaded Stud; Female - White (B) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFRS-EX N-A N-A CLMFRS1-BX N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Mini Protective Cap w/ L... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Female - Brown (F) CLM Series Mini Protective Cap w/ Lanyard Male - Black (A) Part Number Weight Min. Quantity CLMFRS-F N-A N-A Part Number Weight Min. Quantity CLMMC N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Mini Protective Cap w/ L... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Female - Orange (G) CLM Series Mini Protective Cap w/ Lanyard Male - Black (A) Part Number Weight Min. Quantity CLMFRS-G N-A N-A Part Number Weight Min. Quantity CLMMC-A N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Mini Protective Cap w/ L... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Female - Yellow (H) CLM Series Mini Protective Cap w/ Lanyard Male - White (B) Part Number Weight Min. Quantity CLMFRS-H N-A N-A Part Number Weight Min. Quantity CLMMC-B 0.05 N-A Receptacle CLM MINI PanelMount Whit... CLM Series Mini Protective Cap w/ L... Marinco Electrical Group Marinco Electrical Group Receptacle CLM MINI PanelMount White 1 Stud NO Drill Out CLM Series Mini Protective Cap w/ Lanyard Male - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMFRS1-B N-A N-A CLMMC-C 0.05 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLM Series Panel Mounts (150A / 600... 127 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLMMC-D – CLM Series Mini Protective Cap w/ L... CLM Series Mini Protective Cap w/ L... CL Series Turnaround (150A / 600V) ... Marinco Electrical Group Marinco Electrical Group CLM Series Mini Protective Cap w/ Lanyard Male - Blue (D) CL Series Turnaround (150A / 600V) (M-M) - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMC-D 0.05 N-A CLMMM-A N-A N-A CLM Series Mini Protective Cap w/ L... CL Series Turnaround (150A / 600V) ... Marinco Electrical Group Marinco Electrical Group CLM Series Mini Protective Cap w/ Lanyard Male - Green (E) Weight Min. Quantity Part Number Weight Min. Quantity CLMMC-E 0.05 N-A CLMMM-B N-A N-A CLM MAL CAP BRN W/20’’LAN- YARD CL Series Turnaround (150A / 600V) ... Marinco Electrical Group Marinco Electrical Group CLM MAL CAP BRN W/20LAN- YARD 128 CL Series Turnaround (150A / 600V) (M-M) - White (B) Part Number CL Series Turnaround (150A / 600V) (M-M) - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMC-F 0.05 N-A CLMMM-C N-A N-A CLM MAL CAP ORG W/20’’LAN- YARD CL Series Turnaround (150A / 600V) ... Marinco Electrical Group Marinco Electrical Group CLM MAL CAP ORG W/20LAN- YARD CL Series Turnaround (150A / 600V) (M-M) - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMC-G 0.05 N-A CLMMM-D N-A N-A CLM MAL CAP YEL W/20’’LAN- YARD CL Series Turnaround (150A / 600V) ... Marinco Electrical Group Marinco Electrical Group CLM MAL CAP YEL W/20LAN- YARD CL Series Turnaround (150A / 600V) (M-M) - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMC-H 0.05 N-A CLMMM-E N-A N-A 860-442-4386 the edge group • 2014 CLMMR2-EX – CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw Male - Black (A) CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw Male - Red (C ) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMR2-A N-A N-A CLMMR2-CX N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw Male - Black (A) Drill Out CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw Male - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMR2-AX N-A N-A CLMMR2-D N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw Male - White (B) CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw Male - Blue (D) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMR2-B N-A N-A CLMMR2-DX N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw Male - White (B) Drill Out CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw Male - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMR2-BX N-A N-A CLMMR2-E N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw Male - Red (C ) CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw Male - Green (E) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMR2-C N-A N-A CLMMR2-EX N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLM Series Panel Mounts (150A / 600... 129 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLMMR2-F – CLM Series Panel Mounts (150A / 600... 130 CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw Male - Brown (F) CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Male - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMR2-F N-A N-A CLMMRS-B N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw Male - Orange (G) CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Male White (B) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMR2-G N-A N-A CLMMRS-BX N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) #8 - #2 AWG; Double Set Screw Male - Yellow (H) CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Male - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMR2-H N-A N-A CLMMRS-C N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Male - Black (A) CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Male - Red (C ) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMRS-A N-A N-A CLMMRS-CX N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Male Black (A) Drill Out CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Male - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMRS-AX N-A N-A CLMMRS-D N-A N-A 860-442-4386 the edge group • 2014 CLMPT-D – CLM Series Parallelling T Connector... CLM Series Panel Mounts (150A / 600... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Male - Blue (D) Drill Out CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Male - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMMRS-DX N-A N-A CLMMRS-H N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Parallelling T Connector... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Male - Green (E) CLM Series Parallelling T Connector (150A / 600V) (M-M-F) - Black (A) Part Number Weight Min. Quantity CLMMRS-E N-A N-A Part Number Weight Min. Quantity CLMPT-A N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Parallelling T Connector... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Male Green (E) Drill Out CLM Series Parallelling T Connector (150A / 600V) (M-M-F) - White (B) Part Number Weight Min. Quantity CLMMRS-EX N-A N-A Part Number Weight Min. Quantity CLMPT-B N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Parallelling T Connector... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Male - Brown (F) CLM Series Parallelling T Connector (150A / 600V) (M-M-F) - Red (C ) Part Number Weight Min. Quantity CLMMRS-F N-A N-A Part Number Weight Min. Quantity CLMPT-C N-A N-A CLM Series Panel Mounts (150A / 600... CLM Series Parallelling T Connector... Marinco Electrical Group Marinco Electrical Group CLM Series Panel Mounts (150A / 600V) 3/4 - 8 Threaded Stud; Male - Orange (G) CLM Series Parallelling T Connector (150A / 600V) (M-M-F) - Blue (D) Part Number Weight Min. Quantity CLMMRS-G N-A N-A 860-442-4386 Part Number Weight Min. Quantity CLMPT-D N-A N-A Bat teries/ Fl a shlights/Charger s CLM Series Panel Mounts (150A / 600... 131 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLMPT-E – CLM Series Parallelling T Connector... CLM Series Parallelling T Connector... CLM Series Parallelling T Connector... Marinco Electrical Group Marinco Electrical Group CLM Series Parallelling T Connector (150A / 600V) (M-M-F) - Green (E) CLM Series Parallelling T Connector (150A / 600V) (M-F-F) - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLMPT-E N-A N-A CLMTT-E N-A N-A CLM Series Parallelling T Connector... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLM Series Parallelling T Connector (150A / 600V) (M-F-F) - Black (A) Part Number Weight Min. Quantity CLMTT-A N-A N-A Part Number Weight Min. Quantity CLS1820FB-A 1 N-A CLM Series Parallelling T Connector... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLM Series Parallelling T Connector (150A / 600V) (M-F-F) - White (B) 132 CLS Series Inline Ballnose (400A / 600V) #2 - 2/0 AWG Female - Black (A) Part Number Weight Min. Quantity CLMTT-B N-A N-A CLS Series Inline Ballnose (400A / 600V) #2 - 2/0 AWG Female - White (B) Part Number Weight Min. Quantity CLS1820FB-B 1 N-A CLM Series Parallelling T Connector... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLM Series Parallelling T Connector (150A / 600V) (M-F-F) - Red (C ) CLS Series Inline Ballnose (400A / 600V) #2 - 2/0 AWG Female - Red (C ) Part Number Weight Min. Quantity CLMTT-C N-A N-A Part Number Weight Min. Quantity CLS1820FB-C 1 N-A CLM Series Parallelling T Connector... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLM Series Parallelling T Connector (150A / 600V) (M-F-F) - Blue (D) CLS Series Inline Ballnose (400A / 600V) #2 - 2/0 AWG Female - Blue (D) Part Number Weight Min. Quantity CLMTT-D N-A N-A 860-442-4386 Part Number Weight Min. Quantity CLS1820FB-D 1 N-A the edge group • 2014 CLS182FB-D – CLS Series Inline Ballnose (400A / ... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) #2 - 2/0 AWG Female - Green (E) CLS Series Inline Ballnose (400A / 600V) #2 - 2/0 AWG Male - Green (E) Part Number Weight Min. Quantity CLS1820FB-E 1 N-A Part Number Weight Min. Quantity CLS1820MB-E 1 N-A CLS Series Inline Ballnose (400A / ... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) #2 - 2/0 AWG Male - Black (A) Part Number Weight Min. Quantity CLS1820MB-A 1 N-A CLS Series Inline Ballnose (400A / 600V) #6 - #2 AWG Female - Black (A) Part Number Weight Min. Quantity CLS182FB-A 1 N-A CLS Series Inline Ballnose (400A / ... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) #2 - 2/0 AWG Male - White (B) CLS Series Inline Ballnose (400A / 600V) #6 - #2 AWG Female - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS1820MB-B 1 N-A CLS182FB-B 1 N-A CLS Series Inline Ballnose (400A / ... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) #2 - 2/0 AWG Male - Red (C ) CLS Series Inline Ballnose (400A / 600V) #6 - #2 AWG Female - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS1820MB-C 1 N-A CLS182FB-C 1 N-A CLS Series Inline Ballnose (400A / ... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) #2 - 2/0 AWG Male - Blue (D) CLS Series Inline Ballnose (400A / 600V) #6 - #2 AWG Female - Blue (D) Part Number Weight Min. Quantity CLS1820MB-D 1 N-A 860-442-4386 Part Number Weight Min. Quantity CLS182FB-D 1 N-A Bat teries/ Fl a shlights/Charger s CLS Series Inline Ballnose (400A / ... 133 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLS182FB-E – CLS Series Inline Ballnose (400A / ... CLS Series Inline Ballnose (400A / ... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) #6 - #2 AWG Female - Green (E) CLS Series Inline Ballnose (400A / 600V) #6 - #2 AWG Male - Green (E) Part Number Weight Min. Quantity CLS182FB-E 1 N-A Weight Min. Quantity CLS182MB-E 1 N-A CLS Series Inline Ballnose (400A / ... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) #6 - #2 AWG Male - Black (A) Part Number Weight Min. Quantity CLS182MB-A 1 N-A CLS Series Inline Ballnose (400A / 600V) 2/0 - 4/0 AWG Female - Black (A) Part Number Weight Min. Quantity CLS1840FB-A 1 N-A CLS Series Inline Ballnose (400A / ... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) #6 - #2 AWG Male - White (B) 134 Part Number Part Number Weight Min. Quantity CLS182MB-B 1 N-A CLS Series Inline Ballnose (400A / 600V) 2/0 - 4/0 AWG Female White (B) Part Number Weight Min. Quantity CLS1840FB-B 1 N-A CLS Series Inline Ballnose (400A / ... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) #6 - #2 AWG Male - Red (C ) CLS Series Inline Ballnose (400A / 600V) 2/0 - 4/0 AWG Female - Red (C ) Part Number Weight Min. Quantity CLS182MB-C 1 N-A Part Number Weight Min. Quantity CLS1840FB-C 1 N-A CLS Series Inline Ballnose (400A / ... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) #6 - #2 AWG Male - Blue (D) CLS Series Inline Ballnose (400A / 600V) 2/0 - 4/0 AWG Female - Blue (D) Part Number Weight Min. Quantity CLS182MB-D 1 N-A 860-442-4386 Part Number Weight Min. Quantity CLS1840FB-D 1 N-A the edge group • 2014 CLS20FB-C – CLS Series Inline Single Pin Connec... CLS Series Inline Ballnose (400A / ... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) 2/0 - 4/0 AWG Female Green (E) CLS Series Inline Ballnose (400A / 600V) 2/0 - 4/0 AWG Male - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS1840FB-E 1 N-A CLS1840MB-E 1 N-A CLS Series Inline Ballnose (400A / ... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) 2/0 - 4/0 AWG Male - Black (A) CLS Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS1840MB-A 1 N-A CLS20FB-A 1 N-A CLS Series Inline Ballnose (400A / ... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) 2/0 - 4/0 AWG Male - White (B) CLS Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female - Black (A) OEM Pack 10/MASTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS1840MB-B 1 N-A CLS20FB-A.OEM N-A N-A CLS Series Inline Ballnose (400A / ... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) 2/0 - 4/0 AWG Male - Red (C ) CLS Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female - White (B) Part Number Weight Min. Quantity CLS1840MB-C 1 N-A Part Number Weight Min. Quantity CLS20FB-B 1 N-A CLS Series Inline Ballnose (400A / ... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Ballnose (400A / 600V) 2/0 - 4/0 AWG Male - Blue (D) CLS Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female - Red (C ) Part Number Weight Min. Quantity CLS1840MB-D 1 N-A 860-442-4386 Part Number Weight Min. Quantity CLS20FB-C 1 N-A Bat teries/ Fl a shlights/Charger s CLS Series Inline Ballnose (400A / ... 135 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLS20FB-D – CLS Series Inline Single Pin Connec... 136 CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female - Blue (D) CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG Set Screw Female - Black (A) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20FB-D 1 N-A CLS20FRB-AX N-A N-A CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female - Green (E) CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG Set Screw Female - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20FB-E 1 N-A CLS20FRB-B N-A N-A CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female - Brown (F) CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG Set Screw Female - White (B) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20FB-F 1 N-A CLS20FRB-BX N-A N-A CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female - Orange (G) CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG Set Screw Female - Red (C ) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20FB-G 1 N-A CLS20FRB-CX N-A N-A CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Female - Yellow (H) CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG Set Screw Female - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20FB-H 1 N-A CLS20FRB-D N-A N-A 860-442-4386 the edge group • 2014 CLS20MB-E – CL Series Inline Single Pin Connect... CL Series Inline Single Pin Connect... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG Set Screw Female - Blue (D) Drill Out CL Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male - Black (A) OEM Pack 10/MASTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20FRB-DX N-A N-A CLS20MB-A.OEM N-A N-A CLS Series Panel Mount (400A / 600V... CL Series Inline Single Pin Connect... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG Set Screw Female - Green (E) CL Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20FRB-E N-A N-A CLS20MB-B 1 N-A CLS Series Panel Mount (400A / 600V... CL Series Inline Single Pin Connect... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG Set Screw Female - Green (E) Drill Out CL Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20FRB-EX N-A N-A CLS20MB-C 1 N-A RECPT 200A CLS PNL BRN DS CL Series Inline Single Pin Connect... Marinco Electrical Group Marinco Electrical Group RECPT 200A CLS PNL BRN DS CL Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male - Blue (D) Part Number Weight Min. Quantity CLS20FRB-F N-A N-A Part Number Weight Min. Quantity CLS20MB-D 1 N-A CL Series Inline Single Pin Connect... CL Series Inline Single Pin Connect... Marinco Electrical Group Marinco Electrical Group CL Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male - Black (A) CL Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20MB-A 1 N-A CLS20MB-E 1 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLS Series Panel Mount (400A / 600V... 137 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLS20MB-F – CL Series Inline Single Pin Connect... 138 CL Series Inline Single Pin Connect... CLS Series Panel Mount (400A / 600... Marinco Electrical Group Marinco Electrical Group CL Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male - Brown (F) CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screws Male - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20MB-F 1 N-A CLS20MRB-B N-A N-A CL Series Inline Single Pin Connect... CLS Series Panel Mount (400A / 600... Marinco Electrical Group Marinco Electrical Group CL Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male - Orange (G) CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screws Male - White (B) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20MB-G 1 N-A CLS20MRB-BX N-A N-A CL Series Inline Single Pin Connect... CLS Series Panel Mount (400A / 600... Marinco Electrical Group Marinco Electrical Group CL Series Inline Single Pin Connector (400A / 600V) #2 - 2/0 AWG Male - Yellow (H) CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screws Male - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20MB-H 1 N-A CLS20MRB-C N-A N-A CLS Series Panel Mount (400A / 600... CLS Series Panel Mount (400A / 600... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screws Male - Black (A) CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screws Male - Red (C ) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20MRB-A N-A N-A CLS20MRB-CX N-A N-A CLS Series Panel Mount (400A / 600... CLS Series Panel Mount (400A / 600... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screws Male - Black (A) Drill Out CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screws Male - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20MRB-AX N-A N-A CLS20MRB-D N-A N-A 860-442-4386 the edge group • 2014 CLS2FB-D – CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screws Male - Blue (D) Drill Out CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screws Male - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20MRB-DX N-A N-A CLS20MRB-H N-A N-A CLS Series Panel Mount (400A / 600... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screws Male - Green (E) CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Female - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20MRB-E N-A N-A CLS2FB-A 1 N-A CLS Series Panel Mount (400A / 600... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screws Male - Green (E) Drill Out CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Female - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20MRB-EX N-A N-A CLS2FB-B 1 N-A CLS Series Panel Mount (400A / 600... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screws Male - Brown (F) CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Female - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20MRB-F N-A N-A CLS2FB-C 1 N-A CLS Series Panel Mount (400A / 600... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) #2 - 2/0 AWG; Double Set Screws Male - Orange (G) CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Female - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS20MRB-G N-A N-A CLS2FB-D 1 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLS Series Panel Mount (400A / 600... 139 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLS2FB-E – CLS Series Inline Single Pin Connec... 140 CLS Series Inline Single Pin Connec... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Female - Green (E) CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Male - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS2FB-E 1 N-A CLS2MB-B N-A N-A CLS Series Inline Single Pin Connec... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Female - Brown (F) CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Male - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS2FB-F 1 N-A CLS2MB-C N-A N-A CLS Series Inline Single Pin Connec... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Female - Orange (G) CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Male - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS2FB-G 1 N-A CLS2MB-D N-A N-A CLS Series Inline Single Pin Connec... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Female - Yellow (H) CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Male - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS2FB-H 1 N-A CLS2MB-E N-A N-A CLS Series Inline Single Pin Connec... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Male - Black (A) CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Male - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS2MB-A N-A N-A CLS2MB-F 1 N-A 860-442-4386 the edge group • 2014 CLS40FB-D.OEM – CLS Series Inline Single Pin Connec... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Male - Orange (G) CLS Series Inline Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - White (B) OEM Pack 10/MASTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS2MB-G 1 N-A CLS40FB-B.OEM N-A N-A CLS Series Inline Single Pin Connec... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) #6 - #2 AWG Male - Yellow (H) CLS Series Inline Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS2MB-H N-A N-A CLS40FB-C 1 N-A CLS Series Inline Single Pin Connec... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Black (A) CLS Series Inline Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Red (C ) OEM Pack 10/MASTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FB-A 1 N-A CLS40FB-C.OEM N-A N-A CLS Series Inline Single Pin Connec... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Black (A) OEM Pack 10/MASTER CLS Series Inline Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FB-A.OEM N-A N-A CLS40FB-D 1 N-A CLS Series Inline Single Pin Connec... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - White (B) CLS Series Inline Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Blue (D) OEM Pack 10/MASTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FB-B 1 N-A CLS40FB-D.OEM N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLS Series Inline Single Pin Connec... 141 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLS40FB-E – CLS Series Inline Single Pin Connec... 142 CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Green (E) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FB-E 1 N-A CLS40FRB-A N-A N-A CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Green (E) OEM Pack 10/MASTER CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Black (A) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FB-E.OEM N-A N-A CLS40FRB-AX N-A N-A CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Brown (F) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FB-F 1 N-A CLS40FRB-B N-A N-A CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Orange (G) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Female Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FB-G 1 N-A CLS40FRB-BB-A N-A N-A CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector (400A / 600V) 2/0 - 4/0 AWG Female - Yellow (H) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Female White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FB-H 1 N-A CLS40FRB-BB-B N-A N-A 860-442-4386 the edge group • 2014 CLS40FRB-BB2-D – CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Female - Red (C ) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Female Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-BB-C N-A N-A CLS40FRB-BB-H N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Female - Blue (D) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole Female - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-BB-D N-A N-A CLS40FRB-BB2-A N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Female Green (E) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole 2 Hole Female - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-BB-E N-A N-A CLS40FRB-BB2-B N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Female Brown (F) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole 2 Hole Female - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-BB-F N-A N-A CLS40FRB-BB2-C N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Female Orange (G) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole 2 Hole Female - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-BB-G N-A N-A CLS40FRB-BB2-D N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLS Series Panel Mount (400A / 600V... 143 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLS40FRB-BB2-E – CLS Series Panel Mount (400A / 600V... 144 CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole 2 Hole Female - Green (E) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Red (C ) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-BB2-E N-A N-A CLS40FRB-CX N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole Female - Brown (F) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-BB2-F N-A N-A CLS40FRB-D N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole Female - Orange (G) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Blue (D) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-BB2-G N-A N-A CLS40FRB-DX N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole Female - Yellow (H) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-BB2-H N-A N-A CLS40FRB-E N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Red (C ) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Green (E) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-C N-A N-A CLS40FRB-EX N-A N-A 860-442-4386 the edge group • 2014 CLS40FRSB-D – CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Brown (F) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Yellow (H) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-F N-A N-A CLS40FRB-HX N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Brown (F) Drill Out CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Female - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-FX N-A N-A CLS40FRSB-A N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Orange (G) CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Female - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-G N-A N-A CLS40FRSB-B N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Orange (G) Drill Out CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Female - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-GX N-A N-A CLS40FRSB-C N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Female - Yellow (H) CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Female - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRB-H N-A N-A CLS40FRSB-D N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLS Series Panel Mount (400A / 600V... 145 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLS40FRSB-E – CLS Series Panel Mount (400A / 600V... 146 CLS Series Panel Mount (400A / 600V... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Female - Green (E) CLS Series Inline Single Pin Connector(400A / 600V) 2/0 - 4/0 AWG Male - Black (A) OEM Pack 10/MASTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRSB-E N-A N-A CLS40MB-A.OEM N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Female - Brown (F) CLS Series Inline Single Pin Connector(400A / 600V) 2/0 - 4/0 AWG Male - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRSB-F N-A N-A CLS40MB-B 1 N-A CLS Series Panel Mount (400A / 600V... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Female - Orange (G) CLS Series Inline Single Pin Connector(400A / 600V) 2/0 - 4/0 AWG Male - White (B) OEM Pack 10/MASTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRSB-G N-A N-A CLS40MB-B.OEM N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Female - Yellow (H) CLS Series Inline Single Pin Connector(400A / 600V) 2/0 - 4/0 AWG Male - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40FRSB-H N-A N-A CLS40MB-C 1 N-A CLS Series Inline Single Pin Connec... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector(400A / 600V) 2/0 - 4/0 AWG Male - Black (A) CLS Series Inline Single Pin Connector(400A / 600V) 2/0 - 4/0 AWG Male - Red (C ) OEM Pack 10/MASTER Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MB-A 1 N-A CLS40MB-C.OEM N-A N-A 860-442-4386 the edge group • 2014 CLS40MRB-BB-A – CLS Series Panel Mount (400A / 600V... CLS Series Inline Single Pin Connec... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector(400A / 600V) 2/0 - 4/0 AWG Male - Blue (D) CLS Series Inline Single Pin Connector(400A / 600V) 2/0 - 4/0 AWG Male - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MB-D 1 N-A CLS40MB-H 1 N-A CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector(400A / 600V) 2/0 - 4/0 AWG Male - Green (E) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MB-E 1 N-A CLS40MRB-A N-A N-A CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector(400A / 600V) 2/0 - 4/0 AWG Male - Green (E) OEM Pack10/MASTER CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Black (A) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MB-E.OEM N-A N-A CLS40MRB-AX N-A N-A CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector(400A / 600V) 2/0 - 4/0 AWG Male - Brown (F) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MB-F 1 N-A CLS40MRB-B N-A N-A CLS Series Inline Single Pin Connec... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Inline Single Pin Connector(400A / 600V) 2/0 - 4/0 AWG Male - Orange (G) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Male - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MB-G 1 N-A CLS40MRB-BB-A N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLS Series Inline Single Pin Connec... 147 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLS40MRB-BB-B – CLS Series Panel Mount (400A / 600V... 148 CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Male - White (B) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Male - Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-BB-B N-A N-A CLS40MRB-BB-G N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Male - Red (C ) Part Number Weight Min. Quantity CLS40MRB-BB-C N-A N-A CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Male - Yellow (H) Part Number Weight Min. Quantity CLS40MRB-BB-H N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Male - Blue (D) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole Male - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-BB-D N-A N-A CLS40MRB-BB2-A N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Male - Green (E) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole Male - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-BB-E N-A N-A CLS40MRB-BB2-B N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar Male - Brown (F) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole Male - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-BB-F N-A N-A CLS40MRB-BB2-C N-A N-A 860-442-4386 the edge group • 2014 CLS40MRB-DX – CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole Male - Blue (D) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - White (B) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-BB2-D N-A N-A CLS40MRB-BX N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole Male - Green (E) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-BB2-E N-A N-A CLS40MRB-C N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole Male - Brown (F) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Red (C ) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-BB2-F N-A N-A CLS40MRB-CX N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole Male - Orange (G) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-BB2-G N-A N-A CLS40MRB-D N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Bus Bar 2 Hole Male - Yellow (H) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Blue (D) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-BB2-H N-A N-A CLS40MRB-DX N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLS Series Panel Mount (400A / 600V... 149 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLS40MRB-E – CLS Series Panel Mount (400A / 600V... 150 CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Green (E) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Orange (G) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-E N-A N-A CLS40MRB-GX N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Green (E) Drill Out CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-EX N-A N-A CLS40MRB-H N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Brown (F) CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Yellow (H) Drill Out Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-F N-A N-A CLS40MRB-HX N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Brown (F) Drill Out CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Male Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-FX N-A N-A CLS40MRSB-A N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw; Male - Orange (G) CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Male White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRB-G N-A N-A CLS40MRSB-B N-A N-A 860-442-4386 the edge group • 2014 CLS45FR2SB-B – CLS 45 Degree Receptacle Panel Moun... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Male White (B) Drill Out CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Male Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRSB-BX N-A N-A CLS40MRSB-F N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Male Red (C ) CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Male Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRSB-C N-A N-A CLS40MRSB-G N-A N-A CLS Series Panel Mount (400A / 600V... CLS Series Panel Mount (400A / 600V... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Male Blue (D) CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Male Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRSB-D N-A N-A CLS40MRSB-H N-A N-A CLS Series Panel Mount (400A / 600V... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Male Green (E) CLS 45 Degree Receptacle Panel Mount (400A / 600V) 2 Threaded Stud; Female - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRSB-E N-A N-A CLS45FR2SB-A N-A N-A CLS Series Panel Mount (400A / 600V... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS Series Panel Mount (400A / 600V) 1-1/4 Threaded Stud; Male Green (E) Drill Out CLS 45 Degree Receptacle Panel Mount (400A / 600V) 2 Threaded Stud; Female - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS40MRSB-EX N-A N-A CLS45FR2SB-B N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLS Series Panel Mount (400A / 600V... 151 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLS45FR2SB-C – CLS 45 Degree Receptacle Panel Moun... 152 CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) 2 Threaded Stud; Female - Red (C) CLS 45 Degree Receptacle Panel Mount (400A / 600V) 2 Threaded Stud; Female - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FR2SB-C N-A N-A CLS45FR2SB-H N-A N-A CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) 2 Threaded Stud; Female - Blue (D) CLS 45 Degree Receptacle Panel Mount (400A / 600V) Double Set Screw; Female - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FR2SB-D N-A N-A CLS45FRB-A N-A N-A CLS 45 Degree Receptacle Panel Moun... CLS 45 DEGREE RECEPTACLE PANEL MOUN... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) 2 Threaded Stud; Female - Green (E) CLS 45 DEGREE RECEPTACLE PANEL MOUNT(400A/600V) DOUBLE SET SCREW; FEMALE-WHITE (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FR2SB-E N-A N-A CLS45FRB-B N-A N-A CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) 2 Threaded Stud; Female - Brown (F) CLS 45 Degree Receptacle Panel Mount (400A / 600V) Bus Bar; Female - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FR2SB-F N-A N-A CLS45FRB-BB-A N-A N-A CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) 2 Threaded Stud; Female - Orange (G) CLS 45 Degree Receptacle Panel Mount (400A / 600V) Bus Bar; Female - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FR2SB-G N-A N-A CLS45FRB-BB-B N-A N-A 860-442-4386 the edge group • 2014 CLS45FRB-F – CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) Bus Bar; Female - Red (C) CLS 45 Degree Receptacle Panel Mount (400A / 600V) Bus Bar; Female - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FRB-BB-C N-A N-A CLS45FRB-BB-H N-A N-A CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) Bus Bar; Female - Blue (D) CLS 45 Degree Receptacle Panel Mount (400A / 600V) Double Set Screw; Female - Red (C) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FRB-BB-D N-A N-A CLS45FRB-C N-A N-A CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) Bus Bar; Female - Green (E) CLS 45 Degree Receptacle Panel Mount (400A / 600V) Double Set Screw; Female - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FRB-BB-E N-A N-A CLS45FRB-D N-A N-A CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) Bus Bar; Female - Brown (F) CLS 45 Degree Receptacle Panel Mount (400A / 600V) Double Set Screw; Female - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FRB-BB-F N-A N-A CLS45FRB-E N-A N-A CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) Bus Bar; Female - Orange (G) CLS 45 Degree Receptacle Panel Mount (400A / 600V) Double Set Screw; Female - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FRB-BB-G N-A N-A CLS45FRB-F N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLS 45 Degree Receptacle Panel Moun... 153 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLS45FRB-G – CLS 45 Degree Receptacle Panel Moun... 154 CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) Double Set Screw; Female - Orange (G) CLS 45 Degree Receptacle Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Female - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FRB-G N-A N-A CLS45FRSB-D N-A N-A CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) Double Set Screw; Female - Yellow (H) CLS 45 Degree Receptacle Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Female - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FRB-H N-A N-A CLS45FRSB-E N-A N-A CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Female - Black (A) CLS 45 Degree Receptacle Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Female - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FRSB-A N-A N-A CLS45FRSB-F N-A N-A CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Female - White (B) CLS 45 Degree Receptacle Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Female - Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FRSB-B N-A N-A CLS45FRSB-G N-A N-A CLS 45 Degree Receptacle Panel Moun... CLS 45 Degree Receptacle Panel Moun... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Receptacle Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Female - Red (C) CLS 45 Degree Receptacle Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Female - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45FRSB-C N-A N-A CLS45FRSB-H N-A N-A 860-442-4386 the edge group • 2014 CLS45MRB-B – CLS 45 Degree Inlet Panel Mount (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) 2 Threaded Stud; Male - Black (A) CLS 45 Degree Inlet Panel Mount (400A / 600V) 2 Threaded Stud; Male - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MR2SB-A N-A N-A CLS45MR2SB-F N-A N-A CLS 45 Degree Inlet Panel Mount (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) 2 Threaded Stud; Male - White (B) CLS 45 Degree Inlet Panel Mount (400A / 600V) 2 Threaded Stud; Male - Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MR2SB-B N-A N-A CLS45MR2SB-G N-A N-A CLS 45 Degree Inlet Panel Mount (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) 2 Threaded Stud; Male - Red (C) CLS 45 Degree Inlet Panel Mount (400A / 600V) 2 Threaded Stud; Male - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MR2SB-C N-A N-A CLS45MR2SB-H N-A N-A CLS 45 Degree Inlet Panel Mount (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) 2 Threaded Stud; Male - Blue (D) CLS 45 Degree Inlet Panel Mount (400A / 600V) Double Set Screw; Male - Black (A) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MR2SB-D N-A N-A CLS45MRB-A N-A N-A CLS 45 Degree Inlet Panel Mount (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) 2 Threaded Stud; Male - Green (E) CLS 45 Degree Inlet Panel Mount (400A / 600V) Double Set Screw; Male - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MR2SB-E N-A N-A CLS45MRB-B N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLS 45 Degree Inlet Panel Mount (40... 155 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLS45MRB-BB-A – CLS 45 Degree Inlet Panel Mount (40... 156 CLS 45 Degree Inlet Panel Mount (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) Bus Bar; Male - Black (A) CLS 45 Degree Inlet Panel Mount (400A / 600V) Bus Bar; Male - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MRB-BB-A N-A N-A CLS45MRB-BB-F N-A N-A CLS 45 Degree Inlet Panel Mount (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) Bus Bar; Male - White (B) CLS 45 Degree Inlet Panel Mount (400A / 600V) Bus Bar; Male Orange (G) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MRB-BB-B N-A N-A CLS45MRB-BB-G N-A N-A CLS 45 Degree Inlet Panel Mount (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) Bus Bar; Male - Red (C) CLS 45 Degree Inlet Panel Mount (400A / 600V) Bus Bar; Male - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MRB-BB-C N-A N-A CLS45MRB-BB-H N-A N-A CLS 45 Degree Inlet Panel Mount (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) Bus Bar; Male - Blue (D) CLS 45 Degree Inlet Panel Mount (400A / 600V) Double Set Screw; Male - Red (C) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MRB-BB-D N-A N-A CLS45MRB-C N-A N-A CLS 45 Degree Inlet Panel Mount (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) Bus Bar; Male - Green (E) CLS 45 Degree Inlet Panel Mount (400A / 600V) Double Set Screw; Male - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MRB-BB-E N-A N-A CLS45MRB-D N-A N-A 860-442-4386 the edge group • 2014 CLS45MRSB-F – CLS 45 Degree Inlet Panel Mount (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) Double Set Screw; Male - Green (E) CLS 45 Degree Inlet Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Male - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MRB-E N-A N-A CLS45MRSB-B N-A N-A CLS 45 DEGREE INLET PANEL MOUNT (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 DEGREE INLET PANEL MOUNT (400A/600V) DOUBLE SET SCREW; MALE - BROWN(F) CLS 45 Degree Inlet Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Male - Red (C) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MRB-F N-A N-A CLS45MRSB-C N-A N-A CLS 45 DEGREE INLET PANEL MOUNT (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 DEGREE INLET PANEL MOUNT (400A/600V) DOUBLE SET SCREW; MALE - ORANGE (G) CLS 45 Degree Inlet Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Male - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MRB-G N-A N-A CLS45MRSB-D N-A N-A CLS 45 DEGREE INLET PANEL MOUNT (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 DEGREE INLET PANEL MOUNT (400A/600V) DOUBLE SET SCREW; MALE - YELLOW (H) CLS 45 Degree Inlet Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Male - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MRB-H N-A N-A CLS45MRSB-E N-A N-A CLS 45 Degree Inlet Panel Mount (40... CLS 45 Degree Inlet Panel Mount (40... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Male - Black (A) CLS 45 Degree Inlet Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Male - Brown (F) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MRSB-A N-A N-A CLS45MRSB-F N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLS 45 Degree Inlet Panel Mount (40... 157 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLS45MRSB-G – CLS 45 Degree Inlet Panel Mount (40... 158 CLS 45 Degree Inlet Panel Mount (40... CLSM Series Panel Mount ( 150A / 60... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Male - Orange (G) CLSM Series Panel Mount ( 150A / 600V) #8 - #2 AWG Double Set Screw; Female - Blue (D) MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MRSB-G N-A N-A CLSMFR2-D 0.165 N-A CLS 45 Degree Inlet Panel Mount (40... CLSM Series Panel Mount ( 150A / 60... Marinco Electrical Group Marinco Electrical Group CLS 45 Degree Inlet Panel Mount (400A / 600V) 1-1/8 Threaded Stud; Male - Yellow (H) CLSM Series Panel Mount ( 150A / 600V) #8 - #2 AWG Double Set Screw; Female - Green (E) MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLS45MRSB-H N-A N-A CLSMFR2-E 0.165 N-A CLSM Series Panel Mount ( 150A / 60... CLSM Series Panel Mount ( 150A / 60... Marinco Electrical Group Marinco Electrical Group CLSM Series Panel Mount ( 150A / 600V) #8 - #2 AWG Double Set Screw; Female - Black (A) MASTER/ 50 CLSM Series Panel Mount ( 150A / 600V) #8 - #2 AWG Double Set Screw; Female - Brown (F) MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLSMFR2-A 0.165 N-A CLSMFR2-F 0.165 N-A CLSM Series Panel Mount ( 150A / 60... CLSM Series Panel Mount ( 150A / 60... Marinco Electrical Group Marinco Electrical Group CLSM Series Panel Mount ( 150A / 600V) #8 - #2 AWG Double Set Screw; Female - White (B) MASTER/50 CLSM Series Panel Mount ( 150A / 600V) #8 - #2 AWG Double Set Screw; Female - Orange (G) MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLSMFR2-B 0.165 N-A CLSMFR2-G 0.165 N-A CLSM Series Panel Mount ( 150A / 60... CLSM Series Panel Mount ( 150A / 60... Marinco Electrical Group Marinco Electrical Group CLSM Series Panel Mount ( 150A / 600V) #8 - #2 AWG Double Set Screw; Female - Red (C ) MASTER/50 CLSM Series Panel Mount ( 150A / 600V) #8 - #2 AWG Double Set Screw; Female - Yellow (H) MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLSMFR2-C 0.165 N-A CLSMFR2-H 0.165 N-A 860-442-4386 the edge group • 2014 CLSMMR2-E – CLSM Series Panel Mount (150A / 600... CLSM Series Panel Mount (150A / 600... Marinco Electrical Group Marinco Electrical Group CLSM Series Panel Mount (150A / 600V) 3/4 - 8 Threaded Stud; Female - Black (A) MASTER/50 CLSM Series Panel Mount (150A / 600V) #8 - #2 AWG Double Set Screw; Male - Black (A) MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLSMFRS-A N-A N-A CLSMMR2-A 0.165 N-A CLSM Series Panel Mount (150A / 600... CLSM Series Panel Mount (150A / 600... Marinco Electrical Group Marinco Electrical Group CLSM Series Panel Mount (150A / 600V) 3/4 - 8 Threaded Stud; Female - White (B) MASTER/50 CLSM Series Panel Mount (150A / 600V) #8 - #2 AWG Double Set Screw; Male - White (B) MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLSMFRS-B N-A N-A CLSMMR2-B 0.165 N-A CLSM Series Panel Mount (150A / 600... CLSM Series Panel Mount (150A / 600... Marinco Electrical Group Marinco Electrical Group CLSM Series Panel Mount (150A / 600V) 3/4 - 8 Threaded Stud; Female - Red (C ) MASTER/50 CLSM Series Panel Mount (150A / 600V) #8 - #2 AWG Double Set Screw; Male - Red (C ) MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLSMFRS-C N-A N-A CLSMMR2-C 0.165 N-A CLSM Series Panel Mount (150A / 600... CLSM Series Panel Mount (150A / 600... Marinco Electrical Group Marinco Electrical Group CLSM Series Panel Mount (150A / 600V) 3/4 - 8 Threaded Stud; Female - Blue (D) MASTER/50 CLSM Series Panel Mount (150A / 600V) #8 - #2 AWG Double Set Screw; Male - Blue (D) MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLSMFRS-D N-A N-A CLSMMR2-D 0.165 N-A CLSM Series Panel Mount (150A / 600... CLSM Series Panel Mount (150A / 600... Marinco Electrical Group Marinco Electrical Group CLSM Series Panel Mount (150A / 600V) 3/4 - 8 Threaded Stud; Female - Green (E) MASTER/50 CLSM Series Panel Mount (150A / 600V) #8 - #2 AWG Double Set Screw; Male - Green (E) MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CLSMFRS-E N-A N-A CLSMMR2-E 0.165 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CLSM Series Panel Mount (150A / 600... 159 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CLSMMRS-A – CLSM Series Panel Mount (150A / 600... 160 CLSM Series Panel Mount (150A / 600... CLS Inline Assembly Press Tool Marinco Electrical Group Marinco Electrical Group CLSM Series Panel Mount (150A / 600V) 3/4 - 8 Threaded Stud; Male Black (A) MASTER/50 CLS Inline Assembly Press Tool Part Number Weight Min. Quantity CLSMMRS-A N-A N-A Part Number Weight Min. Quantity CLSPRESS 14 N-A CLSM Series Panel Mount (150A / 600... Cam Cover Standoff for AC Power S-C... Marinco Electrical Group Marinco Electrical Group CLSM Series Panel Mount (150A / 600V) 3/4 - 8 Threaded Stud; Male White (B) MASTER/50 Cam Cover Standoff for AC Power S-CFM16 Part Number Weight Min. Quantity CLSMMRS-B N-A N-A Part Number Weight Min. Quantity CLSTNDOFF N-A N-A CLSM Series Panel Mount (150A / 600... CL/CLS/CLM Paralleling T Adapter (M... Marinco Electrical Group Marinco Electrical Group CLSM Series Panel Mount (150A / 600V) 3/4 - 8 Threaded Stud; Male Red (C )MASTER/50 CL/CLS/CLM Paralleling T Adapter (M-M-F) - Black (A) Part Number Weight Min. Quantity CLSMMRS-C N-A N-A Part Number Weight Min. Quantity CPT-A 1 N-A CLSM Series Panel Mount (150A / 600... CL/CLS/CLM Paralleling T Adapter (M... Marinco Electrical Group Marinco Electrical Group CLSM Series Panel Mount (150A / 600V) 3/4 - 8 Threaded Stud; Male Blue (D) MASTER/50 CL/CLS/CLM Paralleling T Adapter (M-M-F) - White (B) Part Number Weight Min. Quantity CLSMMRS-D N-A N-A Part Number Weight Min. Quantity CPT-B 1 N-A CLSM Series Panel Mount (150A / 600... CL/CLS/CLM Paralleling T Adapter (M... Marinco Electrical Group Marinco Electrical Group CLSM Series Panel Mount (150A / 600V) 3/4 - 8 Threaded Stud; Male Green (E) MASTER/50 CL/CLS/CLM Paralleling T Adapter (M-M-F) - Red (C ) Part Number Weight Min. Quantity CLSMMRS-E N-A N-A 860-442-4386 Part Number Weight Min. Quantity CPT-C 1 N-A the edge group • 2014 CS6365N.OEM – 50A 125/250V PLUG LOCKING MASTER/50 50A 125V PLUG, LOCKING Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Paralleling T Adapter (M-M-F) - Blue (D) 50A 125V PLUG; LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity CPT-D 1 N-A CS6361N 1 N-A CL/CLS/CLM Paralleling T Adapter (M... 50A 125/250V CONNECTOR Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Paralleling T Adapter (M-M-F) - Green (E) 50A 125/250V CONNECTOR Part Number Weight Min. Quantity Part Number Weight Min. Quantity CPT-E 1 N-A CS6364N 1 N-A CLS Soft Paralleling T Adapter (M-M... 50A 125/250V CONNECTOR LOCKING MAST... Marinco Electrical Group Marinco Electrical Group CLS Soft Paralleling T Adapter (M-M-F) - White (B) 50A 125/250V CONNECTOR LOCKING MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CPTFST-B N-A N-A CS6364N.OEM 1 N-A CLS Soft Paralleling T Adapter (M-M... 50A 125/250V PLUG LOCKING Marinco Electrical Group Marinco Electrical Group CLS Soft Paralleling T Adapter (M-M-F) - Green (E) 50A 125/250V PLUG LOCKING Part Number Weight Min. Quantity Part Number Weight Min. Quantity CPTFST-E N-A N-A CS6365N 1 N-A 50A 125V CONNECTOR ***NO BRASS PLAT... 50A 125/250V PLUG LOCKING MASTER/50 Marinco Electrical Group Marinco Electrical Group 50A 125V CONNECTOR ***NO BRASS PLATE*** 50A 125/250V PLUG LOCKING MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS6360N 1 N-A CS6365N.OEM 1 N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s CL/CLS/CLM Paralleling T Adapter (M... 161 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CS6369 – 50A 125/250V RECEPTACLE 50A 125/250V RECEPTACLE 50A 125/250V FLANGED INLET MASTER/5... Marinco Electrical Group Marinco Electrical Group 50A 125/250V RECEPTACLE 50A 125/250V FLANGED INLET MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS6369 1 N-A CS6375.OEM 0.31 N-A 50A 125/250V RECEPTACLE MASTER/50 50A 125/250V FLANGED INLT W/INTEGRA... Marinco Electrical Group Marinco Electrical Group 50A 125/250V RECEPTACLE MASTER/50 50A 125/250V FLANGED INLT W/INTEGRAL SPRING LID Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS6369.OEM 0.46 N-A CS6375FL 0.43 N-A 50A 125/250V RECEPTACLE MASTER/50 50A 125/250V FLANGED INLT W/INTEGRA... Marinco Electrical Group Marinco Electrical Group 50A 125/250V RECEPTACLE MASTER/50 162 50A 125/250V FLANGED INLT W/INTEGRAL SPRING LID MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS6369.OEM.NMS 0.46 N-A CS6375FL.OEM 0.36 N-A 50A 125V RECEPTACLE 50A 125/250V FLG INLET W/ 3 MOUNTIN... Marinco Electrical Group Marinco Electrical Group 50A 125V RECEPTACLE 50A 125/250V FLG INLET W/ 3 MOUNTING HOLES MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS6370 1 N-A CS6375SD.OEM 0.295 N-A 50A 125/250V FLANGED INLET 50A 125V FLANGED INLET Marinco Electrical Group Marinco Electrical Group 50A 125/250V FLANGED INLET 50A 125V FLANGED INLET Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS6375 0.4 N-A CS6377 0.39 N-A 860-442-4386 the edge group • 2014 CS8264N – 50A 250V CONNECTOR ***NO BRASS PLAT... 50A 3PH 480V A.C. PLUG MASTER/50 Marinco Electrical Group Marinco Electrical Group 50A 125V FLG INLET W/3 MOUNTING HOLES 50A 3PH 480V A.C. PLUG MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS6377SD 0.1332 N-A CS8165N.OEM 1 N-A 50A 3PH 480V A.C. CONNECTOR 50A 3 480V A.C.RECEPTACLE Marinco Electrical Group Marinco Electrical Group 50A 3PH 480V A.C. CONNECTOR 50A 3 480V A.C.RECEPTACLE Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8164N 1 N-A CS8169 1 N-A 50A 3PH 480V A.C. CONNECTOR MASTER/... CS8169 CRIMP STYLE W/6’ LEADS Marinco Electrical Group Marinco Electrical Group 50A 3PH 480V A.C. CONNECTOR MASTER/50 Bat teries/ Fl a shlights/Charger s 50A 125V FLG INLET W/3 MOUNTING HOL... CS8169 CRIMP STYLE W/6’ LEADS Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8164N.OEM 1 N-A CS8169-AK1 N-A N-A 50A 3PH 480V A.C. PLUG 50A 3 480V AC FLANGED INLET Marinco Electrical Group Marinco Electrical Group 50A 3PH 480V A.C. PLUG 50A 3 480V AC FLANGED INLET Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8165N 1 N-A CS8175 0.4 N-A POWER CORD, 11’ 6/4 SEOW CRIMP 50A 250V CONNECTOR ***NO BRASS PLAT... Marinco Electrical Group Marinco Electrical Group POWER CORD; 11’ 6/4 SEOW CRIMP 50A 250V CONNECTOR ***NO BRASS PLATE*** Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8165N-AK1 N-A N-A CS8264N 1 N-A 860-442-4386 163 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CS8265N – 50A 250V PLUG 50A 250V PLUG 50A 3PH 250V A.C. CONNECTOR MASTER/... Marinco Electrical Group Marinco Electrical Group 50A 250V PLUG 50A 3PH 250V A.C. CONNECTOR MASTER/50 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8265N 1 N-A CS8364N.OEM 1 N-A 50A 250V PLUG MASTER/50 CS8365N W/6/4 SO-6FT. Marinco Electrical Group Marinco Electrical Group 50A 250V PLUG MASTER/50 CS8365N W/6/4 SO-6FT. Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8265N.OEM 1 N-A CS8365-AM1 N-A N-A 50A 250V RECEPTACLE POWER CORD, 5’ 8/4HI TEMP CRIMP, CO... Marinco Electrical Group Marinco Electrical Group 50A 250V RECEPTACLE 164 POWER CORD; 5’ 8/4HI TEMP CRIMP; CORD GRIP; RINGS Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8269 1 N-A CS8365-AM3 N-A N-A 50A 250V FLANGED INLET POWER CORD, 25’’, 8/4 SO CRIMP, RIN... Marinco Electrical Group Marinco Electrical Group 50A 250V FLANGED INLET POWER CORD; 25; 8/4 SO CRIMP; RING TERMINALS Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8275 0.36 N-A CS8365-AM6 N-A N-A 50A 250V 3PH A.C. CONNECTOR POWER CORD, 72’’, 8/4 SO CRIMP, RIN... Marinco Electrical Group Marinco Electrical Group 50A 250V 3PH A.C. CONNECTOR POWER CORD; 72; 8/4 SO CRIMP; RING TERMINALS Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8364N 1 N-A CS8365-AM7 N-A N-A 860-442-4386 the edge group • 2014 CS8465N – 50A 480V PLUG RECPT, 50A CRIMP STYLE,8’ Marinco Electrical Group Marinco Electrical Group POWER CORD; 108; 8/4 SO CRIMP; RING TERMINALS RECPT; 50A CRIMP STYLE;8’ Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8365-AM9 N-A N-A CS8369-AM6 N-A N-A 50A 250V 3PH A.C. PLUG CS8369 W/8AWG THHN LEADS 9’-3/4’’ Marinco Electrical Group Marinco Electrical Group 50A 250V 3PH A.C. PLUG CS8369 W/8AWG THHN LEADS 9’-3/4 Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8365N 1 N-A CS8369-BT1 N-A N-A 50A 3PH 250V A.C. PLUG MASTER/50 50A 3 250V AC FLANGED INLET Marinco Electrical Group Marinco Electrical Group 50A 3PH 250V A.C. PLUG MASTER/50 Bat teries/ Fl a shlights/Charger s POWER CORD, 108’’, 8/4 SO CRIMP, RI... 50A 3 250V AC FLANGED INLET Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8365N.OEM 1 N-A CS8375 0.39 N-A 50A 3 250V A.C. RECEPTACLE 50A 480V CONNECTOR ***NO BRASS PLAT... Marinco Electrical Group Marinco Electrical Group 50A 3 250V A.C. RECEPTACLE 50A 480V CONNECTOR ***NO BRASS PLATE*** Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8369 1 N-A CS8464N 1 N-A RECEPTACLE, 6’ LEADS 50A 480V PLUG Marinco Electrical Group Marinco Electrical Group RECEPTACLE; 6’ LEADS 50A 480V PLUG Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8369-AM5 N-A N-A CS8465N 1 N-A 860-442-4386 165 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CS8469 – 50A 480V RECEPTACLE 50A 480V RECEPTACLE CL/CLS/CLM Tapping T Adapter (M-F-F... Marinco Electrical Group Marinco Electrical Group 50A 480V RECEPTACLE CL/CLS/CLM Tapping T Adapter (M-F-F) - Green (E) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CS8469 1 N-A CTT-E 1 N-A CL/CLS/CLM Tapping T Adapter (M-F-F... CLS Soft Tapping T Adapter (M-F-F) ... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Tapping T Adapter (M-F-F) - Black (A) Weight Min. Quantity Part Number Weight Min. Quantity CTT-A 1 N-A CTTFST-A N-A N-A CL/CLS/CLM Tapping T Adapter (M-F-F... CLS Soft Tapping T Adapter (M-F-F) ... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Tapping T Adapter (M-F-F) - White (B) 166 CLS Soft Tapping T Adapter (M-F-F) - Black (A) Part Number CLS Soft Tapping T Adapter (M-F-F) - White (B) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CTT-B 1 N-A CTTFST-B N-A N-A CL/CLS/CLM Tapping T Adapter (M-F-F... CLS Soft Tapping T Adapter (M-F-F) ... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Tapping T Adapter (M-F-F) - Red (C ) CLS Soft Tapping T Adapter (M-F-F) - Red (C ) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CTT-C 1 N-A CTTFST-C N-A N-A CL/CLS/CLM Tapping T Adapter (M-F-F... CLS Soft Tapping T Adapter (M-F-F) ... Marinco Electrical Group Marinco Electrical Group CL/CLS/CLM Tapping T Adapter (M-F-F) - Blue (D) CLS Soft Tapping T Adapter (M-F-F) - Blue (D) Part Number Weight Min. Quantity Part Number Weight Min. Quantity CTT-D 1 N-A CTTFST-D N-A N-A 860-442-4386 the edge group • 2014 CW-T2R – Cable Wraptor, Medium, Black/Red; 7... SMALL WRAPTOR GRAVITY FEED Marinco Electrical Group Marinco Electrical Group CLS Soft Tapping T Adapter (M-F-F) - Green (E) SMALL WRAPTOR GRAVITY FEED Part Number Weight Min. Quantity Part Number Weight Min. Quantity CTTFST-E N-A N-A CW-T1M50 N-A N-A CLS Soft Tapping T Adapter (M-F-M) ... Cable Wraptor, small, black/red, re... Marinco Electrical Group Marinco Electrical Group CLS Soft Tapping T Adapter (M-F-M) - Black (A) Cable Wraptor; small; black/red; register display Part Number Weight Min. Quantity Part Number Weight Min. Quantity CTTMST-A N-A N-A CW-T1RR50 N-A N-A CLS Soft Tapping T Adapter (M-F-M) ... Cable Wraptor Desktop Display, Medi... Marinco Electrical Group Marinco Electrical Group CLS Soft Tapping T Adapter (M-F-M) - White (B) Bat teries/ Fl a shlights/Charger s CLS Soft Tapping T Adapter (M-F-F) ... Cable Wraptor Desktop Display; Medium; Black/Red; 25/Display Part Number Weight Min. Quantity Part Number Weight Min. Quantity CTTMST-B N-A N-A CW-T2M25 42 N-A CLS Soft Tapping T Adapter (M-F-M) ... Cable Wraptor Gravity Feed Display,... Marinco Electrical Group Marinco Electrical Group CLS Soft Tapping T Adapter (M-F-M) - Green (E) Cable Wraptor Gravity Feed Display; 75 Medium; Black/Red Part Number Weight Min. Quantity Part Number Weight Min. Quantity CTTMST-E N-A N-A CW-T2M75 80 N-A Cable Wraptor Stackout Display, 100... Cable Wraptor, Medium, Black/Red; 7... Marinco Electrical Group Marinco Electrical Group Cable Wraptor Stackout Display; 100/Medium; 150/Large; 40/XL Cable Wraptor; Medium; Black/Red; 75/Master Part Number Weight Min. Quantity Part Number Weight Min. Quantity CW-290 N-A N-A CW-T2R 1 N-A 860-442-4386 167 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s CW-T2R2 – Cable Wraptor, 2 Medium, Black/Red;... Cable Wraptor, 2 Medium, Black/Red;... Cable Wraptor, Large, Black/Red; 25... Marinco Electrical Group Marinco Electrical Group Cable Wraptor; 2 Medium; Black/Red; 2/Card; 5 Cards/Master Cable Wraptor; Large; Black/Red; 25/Cutcase Part Number Weight Min. Quantity Part Number Weight Min. Quantity CW-T2R2 2 N-A CW-T3RR25 2 N-A Cable Wraptor, Medium, Black/Red; 2... Cable Wraptor XL Gravity Sidekick D... Marinco Electrical Group Marinco Electrical Group Cable Wraptor; Medium; Black/Red; 25/Cutcase Cable Wraptor XL Gravity Sidekick Display; 20 XL Wraptors/Display Part Number Weight Min. Quantity Part Number Weight Min. Quantity CW-T2RR25 1 N-A CW-T4M20 N-A N-A Cable Wraptor Desktop Display, Larg... Cable Wraptor, extra Large, black/r... Marinco Electrical Group Marinco Electrical Group Cable Wraptor Desktop Display; Large; Black/Red; 25/Display 168 Cable Wraptor; extra Large; black/red; register display Part Number Weight Min. Quantity Part Number Weight Min. Quantity CW-T3M25 68 N-A CW-T4RR20 2 N-A cable Wraptor Gravity Feed Display,... POWER CORD, 112’’ 14/3 SJO CRIMP, R... Marinco Electrical Group Marinco Electrical Group cable Wraptor Gravity Feed Display; 50 Large; Black/Red POWER CORD; 112 14/3 SJO CRIMP; RING TERM & STRN Part Number Weight Min. Quantity Part Number Weight Min. Quantity CW-T3M50 139 N-A FC4720-AM1 N-A N-A Cable Wraptor, Large, Black/Red; 50... Group5¬Æ Inline Stage Pin (100A / 12... Marinco Electrical Group Marinco Electrical Group Cable Wraptor; Large; Black/Red; 50/Master Group5√جø¬Ω Inline Stage Pin (100A / 125V) Female Part Number Weight Min. Quantity Part Number Weight Min. Quantity CW-T3R 2 N-A G100F N-A N-A 860-442-4386 the edge group • 2014 G106F-H – Group5¬Æ Inline Stage Pin (100A / 25... Group5¬Æ Inline Stage Pin (100A / 12... Marinco Electrical Group Marinco Electrical Group Group5√جø¬Ω Inline Stage Pin (100A / 125V) 2Fer; Female Group5√جø¬Ω Inline Stage Pin (100A / 125V) Fused; Male Part Number Weight Min. Quantity Part Number Weight Min. Quantity G100F-DB N-A N-A G100M-FU N-A N-A Group5¬Æ Inline Stage Pin (100A / 12... Group5¬Æ Inline Stage Pin (100A / 12... Marinco Electrical Group Marinco Electrical Group Group5√جø¬Ω Inline Stage Pin (100A / 125V) Fused; Female Group5√جø¬Ω Inline Stage Pin (100A / 125V) Ring Terminal; Male Part Number Weight Min. Quantity Part Number Weight Min. Quantity G100F-FU N-A N-A G100M-RT N-A N-A Group5¬Æ Stage Pin Panel Mount (100A... Group5¬Æ Stage Pin Panel Mount (100A... Marinco Electrical Group Marinco Electrical Group Group5√جø¬Ω Stage Pin Panel Mount (100A / 125V) Female Special Group5√جø¬Ω Stage Pin Panel Mount (100A / 125V) Male Special Part Number Weight Min. Quantity Part Number Weight Min. Quantity G100FR1-R5 N-A N-A G100MR1-R5 N-A N-A Group5¬Æ Inline Stage Pin (100A / 12... G5 100A 250V FEM YEL Marinco Electrical Group Marinco Electrical Group Group5√جø¬Ω Inline Stage Pin (100A / 125V) Male G5 100A 250V FEM YEL Part Number Weight Min. Quantity Part Number Weight Min. Quantity G100M N-A N-A G106F-FU-H N-A N-A Group5¬Æ Inline Stage Pin (100A / 12... Group5¬Æ Inline Stage Pin (100A / 25... Marinco Electrical Group Marinco Electrical Group Group5√جø¬Ω Inline Stage Pin (100A / 125V) 2Fer; Male Group5√جø¬Ω Inline Stage Pin (100A / 250V) Female - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity G100M-DB N-A N-A G106F-H N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s Group5¬Æ Inline Stage Pin (100A / 12... 169 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s G106F-RT-H – Group5¬Æ Inline Stage Pin (100A / 25... 170 Group5¬Æ Inline Stage Pin (100A / 25... Group5¬Æ Stage Pin Panel Mount (100A... Marinco Electrical Group Marinco Electrical Group Group5√جø¬Ω Inline Stage Pin (100A / 250V) Ring Terminal; Female - Yellow (H) Group5√جø¬Ω Stage Pin Panel Mount (100A / 250V) Male Flush Mount - Yellow (H) Part Number Weight Min. Quantity Part Number Weight Min. Quantity G106F-RT-H N-A N-A G106MR1-R5-H N-A N-A Group5¬Æ Stage Pin Panel Mount (100A... Group5¬Æ Inline Stage Pin (20A / 125... Marinco Electrical Group Marinco Electrical Group Group5√جø¬Ω Stage Pin Panel Mount (100A / 250V) Flush Mount Female Special - Yellow (H) Group5√جø¬Ω Inline Stage Pin (20A / 125V) Female Part Number Weight Min. Quantity G106FR1-R5-H N-A N-A Part Number Weight Min. Quantity G20F N-A N-A Group5¬Æ Inline Stage Pin (100A / 25... Group5¬Æ Inline Stage Pin (20A / 125... Marinco Electrical Group Marinco Electrical Group Group5√جø¬Ω Inline Stage Pin (100A / 250V) 2Fer; Male - Yellow (H) Group5√جø¬Ω Inline Stage Pin (20A / 125V) Fused; Female Part Number Weight Min. Quantity G106M-DB-H N-A N-A Part Number Weight Min. Quantity G20F-FU N-A N-A Group5¬Æ Inline Stage Pin (100A / 25... Group5¬Æ Inline Stage Pin (20A / 125... Marinco Electrical Group Marinco Electrical Group Group5√جø¬Ω Inline Stage Pin (100A / 250V) Male - Yellow (H) Group5√جø¬Ω Inline Stage Pin (20A / 125V) Male Part Number Weight Min. Quantity Part Number Weight Min. Quantity G106M-H N-A N-A G20M N-A N-A Group5¬Æ Inline Stage Pin (100A / 25... Group5¬Æ Inline Stage Pin (20A / 125... Marinco Electrical Group Marinco Electrical Group Group5√جø¬Ω Inline Stage Pin (100A / 250V) Ring Terminal; Male - Yellow (H) Group5√جø¬Ω Inline Stage Pin (20A / 125V) Fused; Male Part Number Weight Min. Quantity G106M-RT-H N-A N-A 860-442-4386 Part Number Weight Min. Quantity G20M-FU N-A N-A the edge group • 2014 IS-10MM-1 – INSULATED DISTRIBUTION STUD, SINGLE... Group5¬Æ Inline Stage Pin (60A / 125... Marinco Electrical Group Marinco Electrical Group Group5√جø¬Ω Inline Stage Pin (60A / 125V) Female Group5√جø¬Ω Inline Stage Pin (60A / 125V) 2Fer; Male Part Number Weight Min. Quantity Part Number Weight Min. Quantity G60F N-A N-A G60M-DB N-A N-A G5 60A FEM Group5¬Æ Inline Stage Pin (60A / 125... Marinco Electrical Group Marinco Electrical Group G5 60A FEM Group5√جø¬Ω Inline Stage Pin (60A / 125V) Fused; Male Part Number Weight Min. Quantity Part Number Weight Min. Quantity G60F-DB N-A N-A G60M-FU N-A N-A Group5¬Æ Inline Stage Pin (60A / 125... Group5¬Æ Inline Stage Pin (60A / 125... Marinco Electrical Group Marinco Electrical Group Group5√جø¬Ω Inline Stage Pin (60A / 125V) Fused; Female Group5√جø¬Ω Inline Stage Pin (60A / 125V) Ring Terminal; Male Part Number Weight Min. Quantity Part Number Weight Min. Quantity G60F-FU N-A N-A G60M-RT N-A N-A Group 5 60A / 125V Phenolic Front L... MAXI FUSE HOLDER, IN-LINE Marinco Electrical Group Marinco Electrical Group Group 5 60A / 125V Phenolic Front Load Panel Mount Through Hole MAXI FUSE HOLDER; IN-LINE Part Number Weight Min. Quantity Part Number Weight Min. Quantity G60FR-TH N-A N-A HDBFH N-A N-A Group5¬Æ Inline Stage Pin (60A / 125... INSULATED DISTRIBUTION STUD, SINGLE... Marinco Electrical Group Marinco Electrical Group Group5√جø¬Ω Inline Stage Pin (60A / 125V) Male INSULATED DISTRIBUTION STUD; SINGLE 3/8 - Part Number Weight Min. Quantity Part Number Weight Min. Quantity G60M N-A N-A IS-10MM-1 N-A N-A 860-442-4386 Bat teries/ Fl a shlights/Charger s Group5¬Æ Inline Stage Pin (60A / 125... 171 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s IS-10MM-1R – INSULATED DISTRIBUTION STUD, SINGLE... INSULATED DISTRIBUTION STUD, SINGLE... DOUBLE INSULATED STUD COVER - NEGAT... Marinco Electrical Group Marinco Electrical Group INSULATED DISTRIBUTION STUD; SINGLE 3/8 - DOUBLE INSULATED STUD COVER - NEGATIVE - BLACK; Part Number Weight Min. Quantity Part Number Weight Min. Quantity IS-10MM-1R N-A N-A ISC-6-2 N-A N-A INSULATED STUD MODULE, DUAL 3/8’’ (... 100A 125/250V CONN. FOR INLET,MFG-#... Marinco Electrical Group Marinco Electrical Group INSULATED STUD MODULE; DUAL 3/8 (BLACK); BULK Weight Min. Quantity Part Number Weight Min. Quantity IS-10MM-2 N-A N-A M4100C12R 1 N-A INSULATED DISTRIBUTION STUD, DUAL 1... 100A 125/250V PLUG MFG-#ME4100P12M Marinco Electrical Group Marinco Electrical Group INSULATED DISTRIBUTION STUD; DUAL 1/4 (BLACK); 172 100A 125/250V CONN. FOR INLET;MFG-#ME4100C12RM Part Number 100A 125/250V PLUG MFG-#ME4100P12M Part Number Weight Min. Quantity Part Number Weight Min. Quantity IS-6MM-2 N-A N-A M4100P12 47 N-A INSULATED STUD COVER - NEGATIVE - B... 100A 125/250V RECEPTACLE MFG-#ME410... Marinco Electrical Group Marinco Electrical Group INSULATED STUD COVER - NEGATIVE - BLACK; BULK 100A 125/250V RECEPTACLE MFG-#ME4100R12M Part Number Weight Min. Quantity Part Number Weight Min. Quantity ISC-10BK N-A N-A M4100R12 45 N-A INSULATED STUD COVER - POSITIVE - R... 100A 120/208V INLET Marinco Electrical Group Marinco Electrical Group INSULATED STUD COVER - POSITIVE - RED; BULK 100A 120/208V INLET Part Number Weight Min. Quantity Part Number Weight Min. Quantity ISC-10R N-A N-A M5100B9R 46 N-A 860-442-4386 the edge group • 2014 MRL3016 – RECEPT. 30A 480V LKG SNGL W/ REMOVE... RECEPT. 15A 250V LKG DPLX W/ REMOVE... Marinco Electrical Group Marinco Electrical Group 100A 120/208V CONN. FOR INLET RECEPT. 15A 250V LKG DPLX W/ REMOVEABLE TERM. SCREW Part Number Weight Min. Quantity Part Number Weight Min. Quantity M5100C9R 1 N-A MRL156D N-A N-A 100A 120/208V PLUG MENEKES # M5100P... RECEPT. 20A 250V LKG SNGL W/ REMOVE... Marinco Electrical Group Marinco Electrical Group 100A 120/208V PLUG MENEKES # M5100P9M RECEPT. 20A 250V LKG SNGL W/ REMOVEABLE TERM. SCREW Part Number Weight Min. Quantity Part Number Weight Min. Quantity M5100P9 52 N-A MRL2015 N-A N-A 100A 120/208V RECEPTACLE RECEPT. 20A 250V LKG SNGL W/ REMOVE... Marinco Electrical Group Marinco Electrical Group 100A 120/208V RECEPTACLE Bat teries/ Fl a shlights/Charger s 100A 120/208V CONN. FOR INLET RECEPT. 20A 250V LKG SNGL W/ REMOVEABLE TERM. SCREW Part Number Weight Min. Quantity Part Number Weight Min. Quantity M5100R9 50 N-A MRL206 N-A N-A RECEPT. 15A 125V LKG DPLX W/ REMOVE... RECEPT. 30A 250V LKG SNGL W/ REMOVE... Marinco Electrical Group Marinco Electrical Group RECEPT. 15A 125V LKG DPLX W/ REMOVEABLE TERM. SCREW RECEPT. 30A 250V LKG SNGL W/ REMOVEABLE TERM. SCREW Part Number Weight Min. Quantity Part Number Weight Min. Quantity MRL155D N-A N-A MRL3015 N-A N-A RECEPT. 15A 250V LKG SNGL W/ REMOVE... RECEPT. 30A 480V LKG SNGL W/ REMOVE... Marinco Electrical Group Marinco Electrical Group RECEPT. 15A 250V LKG SNGL W/ REMOVEABLE TERM. SCREW ***NO INSTRUCTION SHEET*** RECEPT. 30A 480V LKG SNGL W/ REMOVEABLE TERM. SCREW Part Number Weight Min. Quantity MRL156 N-A N-A 860-442-4386 Part Number Weight Min. Quantity MRL3016 N-A N-A 173 The Edge group • 2014 Bat teries/ Fl a shlights/Charger s MRL306 – RECEPT. 30A 250V LKG SNGL W/ REMOVE... RECEPT. 30A 250V LKG SNGL W/ REMOVE... MARINA & RV PARK OUTLET Marinco Electrical Group Marinco Electrical Group RECEPT. 30A 250V LKG SNGL W/ REMOVEABLE TERM. SCREW MARINA & RV PARK OUTLET Part Number Weight Min. Quantity Part Number Weight Min. Quantity MRL306 N-A N-A PH6597 2 N-A RECEPT. 15A 125V SB DPLX W/ REMOVEA... TELEPHONE/TV OUTLET Marinco Electrical Group Marinco Electrical Group RECEPT. 15A 125V SB DPLX W/ REMOVEABLE TERM. SCREW Weight Min. Quantity Part Number Weight Min. Quantity MRS155D N-A N-A PH6597TV 3 N-A RECEPT. 15A 125V GFI DPLX W/ REMOVE... TELEPHONE/TV OUTLET Marinco Electrical Group Marinco Electrical Group RECEPT. 15A 125V GFI DPLX W/ REMOVEABLE TERM. SCREW 174 TELEPHONE/TV OUTLET Part Number TELEPHONE/TV OUTLET Part Number Weight Min. Quantity Part Number Weight Min. Quantity MRS155DGW N-A N-A PH6597TV.OEM N-A N-A RECEPT. 15A 125V SB DPLX W/ REMOVEA... PHONE CORDSET, 50 FT. YELLOW Marinco Electrical Group Marinco Electrical Group RECEPT. 15A 125V SB DPLX W/ REMOVEABLE TERM. SCREW PHONE CORDSET; 50 FT. YELLOW Part Number Weight Min. Quantity Part Number Weight Min. Quantity MRS155DW N-A N-A PH6599 66 N-A PHONE/TV EZ LOCK INLET, SS PHONE ADAPTER PLUG Marinco Electrical Group Marinco Electrical Group PHONE/TV EZ LOCK INLET; SS PHONE ADAPTER PLUG Part Number Weight Min. Quantity Part Number Weight Min. Quantity PH6592TV-SS 18 N-A PH6600 2 N-A 860-442-4386 the edge group • 2014 Y-AM2 – CORDSET, 14/3 SJT TRIPL Y W/WAGO 7 ... WEATHERPROOF COVER W/LID BLACK 15A Marinco Electrical Group Marinco Electrical Group PHONE ADAPTER CONN WEATHERPROOF COVER W/LID BLACK 15A Part Number Weight Min. Quantity Part Number Weight Min. Quantity PH6601 2 N-A WP1 0.225 N-A TELEPHONE CONNECTOR AND COVER CORDSET, 14/3 SJT TRIPL Y W/WAGO 7 ... Marinco Electrical Group Marinco Electrical Group TELEPHONE CONNECTOR AND COVER CORDSET; 14/3 SJT TRIPL Y W/WAGO 7 POLE CONN. (2X) Part Number Weight Min. Quantity Part Number Weight Min. Quantity PH6629 2 N-A Y-AM1 N-A N-A TV/TELEPHONE CORDSET, 50 FT. CORDSET, 14/3 SJT TRIPL Y W/WAGO 7 ... Marinco Electrical Group Marinco Electrical Group TV/TELEPHONE CORDSET; 50 FT. Bat teries/ Fl a shlights/Charger s PHONE ADAPTER CONN CORDSET; 14/3 SJT TRIPL Y W/WAGO 7 POLE CONN. (2X) Part Number Weight Min. Quantity Part Number Weight Min. Quantity PHTV6599 142 N-A Y-AM2 N-A N-A Bates Stage Pin Splitters (20A / 12... Marinco Electrical Group Bates Stage Pin Splitters (20A / 125V) Male Female Combo Part Number Weight Min. Quantity TRIXFER N-A N-A Bates Stage Pin Splitters (20A / 12... Marinco Electrical Group Bates Stage Pin Splitters (20A / 125V) Female Female Tap Part Number Weight Min. Quantity TRIXFER.FF N-A N-A 860-442-4386 175
CS8369-BT1 价格&库存
很抱歉,暂时无法提供与“CS8369-BT1”相匹配的价格&库存,您可以联系我们找货
