12VPG.OEM
12VPG.OEM
    MARINCO
    12V PLUG BULK PACK 50/MASTER
12VPG.OEM 数据手册
product specifications for: DC connectors Item #: 12VPG Description Sealink plug, 12 volt Electrical Specifications 12V, 10A Material Specifications Housing Material: Nylon; Contact Material: Brass Terminals Accommodates 16 AWG wire. Strain Relief Internal, clamp style, for 16/2 wire. Indicator Light Red LED, Provided. Mechanical Specification Overall Design: Provided with weather resistant cord seal. Also has sealing ring to provide with weather resistant seal when mated with Marinco Sealink receptacle (cat. no. 12VRC). Plug locks into receptacle to prevent inadvertent disconnection; disengages when plug is rotated 30°. Fuse 10 Amp AGC (1-1/4" X 1/4") provided inside unit. CAUTION: A 10 amp fuse is provided. If your wiring is smaller than 16 gauge or if the equipment manufacturer recommends a different size fuse, install the appropriate size fuse before using the plug. Do not use a fuse larger than 15 amps. Reversing positive and negative wires may damage equipment. Dimensions shown in inches.
12VPG.OEM 价格&库存
很抱歉,暂时无法提供与“12VPG.OEM”相匹配的价格&库存,您可以联系我们找货
