12VRC.OEM
12VRC.OEM
    MARINCO
    12V RECEPT .OEM PACK
12VRC.OEM 数据手册
SPECIFICATION SHEET Web site: www.marinco.com Phone: 800-307-6702 Date: February, 2014 Rev: 00 Receptacle, 12V "Cigarette lighter" style Catalog Number: 12VRC.OEM Item: SeaLink® receptacle, 12 volt Rating: 12V, 15A Materials: Plastic parts are high-temperature, glass-filled nylon. Metal current carrying parts are .032" copper alloy for maximum conductivity and nickel plated for maximum corrosion protection. Terminals: NEMA .250" quick connect tabs. Mounting: Rear mount—provided with non-metallic, Slide-Lok™ 1-1/8x16 UN locknut for fast assembly.. Construction: Provided with pvc cap to seal receptacle when not in use. Sealing ring on Marinco Sealink plug (cat. no. 12VPG) provides weather seal while in use. Receptacle provided with recesses to lock Marinco Sealink plug to prevent inadvertent disconnection; disengages when plug is rotated 30. Dimensions: MOUNTING HOLE 1.150 +-.010 1.050 +-.010 1.31 1.13 1.03 1.43 .35 1.86 1.74
12VRC.OEM 价格&库存
很抱歉,暂时无法提供与“12VRC.OEM”相匹配的价格&库存,您可以联系我们找货
