2021FO
2021FO
    MARINCO
    FLANGED OUTLET, LOCKING 20 AMPERES, 120/208 VOLTS
2021FO 数据手册
SPECIFICATION SHEET Web site: www.marinco.com Phone: 800-307-6702 Date: July, 2011 Rev: 02 Flanged Outlet, Locking 20A, 120/208V 3-phase 4-Pole, 5-Wire Catalog Number: 2021FO Item: Flanged outlet, locking. Rating: 20 amperes, 120/208 volts, 3-phase, 4-pole, 5-wire. Configuration: NEMA L21-20R Materials: Flange is nylon. Connector body is nylon with a CTI greater than 600volts. End cap is clear polycarbonate. Terminals: Line terminals are clamp-type, with color coded, 10-32, slot/cross head brass terminal screws. Grounding terminal is set-screw type. Contacts: Line contacts are one-piece construction, 0.040" thick brass. Grounding contact is machined brass sleeve. Certifications: Underwriters Laboratories, Inc. File E111198 Canadian Standards Association File LR81290 Dimensions: Dimensions shown in inches
2021FO 价格&库存
很抱歉,暂时无法提供与“2021FO”相匹配的价格&库存,您可以联系我们找货
