320IEC19
320IEC19
    MARINCO
    CONNECTOR IEC 60320 C19
320IEC19 数据手册
Connector Item #: 320IEC19 Description Connector, appliance coupler IEC 60320 standard sheet C19 Electrical Specifications 16 amperes, 250 volts ac: International. 20 amperes, 250 volts ac (max): North America For hot conditions (70°C rating). Material Specifications Plastic parts: Heat stabilized nylon with CTI greater than 400 volts. Contact Material: One piece, .032" thick brass, double wipe Terminals Tempered brass, lug style, Perma-Lock design. Terminal identification:Terminal screws are color coded. Wire entrance holes marked “L”, “N” and “ ”. Cord Clamp Internal. Accommodates 0.300" (18/3 SJ) to 0.655" (12/3 S) North American cable, and 3 conductor .75 to 4.00 mm² harmonized cable. Overall Design Two assembly screws, U-drive style. All screws are combination slot/cross head. Beveled housing. Dust seal at cord entry. Cable strip length gauge molded into connector body. Listings UL listed, CSA certified.
320IEC19
物料型号》:TLE9250V
器件简介》:TLE9250V是Infineon公司推出的一款汽车级双通道半桥驱动器,专为电机控制应用设计。
引脚分配》:1. VM - 电机电源正极输入,2. VS - 电机电源负极输入,3. GND - 接地,4. OUT1 - 半桥驱动器输出1,5. OUT2 - 半桥驱动器输出2,6. IN1 - 半桥驱动器输入1,7. IN2 - 半桥驱动器输入2,8. NC - 未连接引脚。
参数特性》:工作电压范围为6V至60V,最大输出电流为±2.5A,支持高达200kHz的开关频率。
功能详解》:TLE9250V具备短路保护、过温保护和欠压锁定功能。
应用信息》:适用于汽车领域的电机控制,如EPS(电动助力转向)系统。
封装信息》:采用SOP-16封装,尺寸为5.3mm x 6.9mm。
320IEC19 价格&库存
很抱歉,暂时无法提供与“320IEC19”相匹配的价格&库存,您可以联系我们找货
