5379.OEM
5379.OEM
    MARINCO
    20A 125V 2P 3W OUTLET FLANGED MASTER/50
5379.OEM 数据手册
SPECIFICATION SHEET Web site: www.marinco.com Phone: 800-307-6702 Date: July, 2011 Rev: 03 Flanged Outlet, straight 20A, 125V 2-Pole, 3-Wire Catalog Number: 5379 Item: Flanged Outlet, straight blade Rating: 20 amperes, 125 volts, NEMA Configuration 5-20R Materials: Device body and flange are nylon with CTI greater than 600 volts. Contacts are solid brass. Contacts: One piece, .040" thick brass. Line contacts are triple wipe. Ground contact is double wipe. Terminals: Tempered brass, lug style, Perma-Lock™ design. Terminals visible through clear end cap. Terminal Identification: Terminal screws are color coded. Ground wire entrance hot stamped green and marked "GR." Line wire entrance hot stamped black. Listings: UL listed, File E111198 CSA listed, File LR81290 Dimensions: Dimensions shown in inches
5379.OEM 价格&库存
很抱歉,暂时无法提供与“5379.OEM”相匹配的价格&库存,您可以联系我们找货
