CS6369.OEM.NMS
CS6369.OEM.NMS
    MARINCO
    50A 125/250V RECEPTACLE MASTER/50
CS6369.OEM.NMS 数据手册
SPECIFICATION SHEET Web site: www.marinco.com Phone: 800-307-6702 Date: March, 2011 Rev: 01 Receptacle 50A, 125/250V 3-Pole, 4-Wire Catalog Number: CS6369 Item: Receptacle, locking Rating: 50 amperes, 125/250 volts, 3-pole, 4-wire. Materials: All plastic parts are glass-filled, heat resistant nylon with a UL flammability rating of 94V-0. Terminals: Terminals have 5/16" screws with Perma-Lock™ collar to encapture the wire strands. The terminal screw does not bear down on the wire. Contacts: Solid brass, two-piece construction, secured by two solid rivets. Rigid half is 0.10" thick. Spring half is 0.04" thick. Listings: UL listed, File E111198 CSA certified, File LR81290 Dimensions: Dimensions shown in inches
CS6369.OEM.NMS 价格&库存
很抱歉,暂时无法提供与“CS6369.OEM.NMS”相匹配的价格&库存,您可以联系我们找货
