5278DRI.OEM
5278DRI.OEM
    MARINCO
    15A 125V 2P 3W Sb Inlet Front Mount W/Cover Master/50
5278DRI.OEM 数据手册
SPECIFICATION SHEET Web site: www.marinco.com Phone: 800-307-6702 Date: July, 2011 Rev: 01 Flanged Inlet, dust resistant 15A, 125V 2-Pole, 3-Wire Catalog Number: 5278DRI Item: Flanged Inlet, straight blade, dust resistant Rating: 15 amperes, 125 volts, NEMA Configuration 5-15P Materials: Device body and flange are nylon with CTI greater than 600 volts. Sealing cover and rear protective boot are vinyl compound. Blades are solid brass. Terminals: Tempered brass, lug style, Perma-Lock™ design. Terminals visible through clear end cap. Terminal Identification: Terminal screws are color coded. Ground wire entrance hot stamped green and marked "GR." Line wire entrance hot stamped black. Installation: Front mount by three screws; rear mount by 1-1/2" conduit locknut. Listings: UL listed, File E57672 CSA certified, File LR81290 Dimensions:
5278DRI.OEM 价格&库存
很抱歉,暂时无法提供与“5278DRI.OEM”相匹配的价格&库存,您可以联系我们找货
5278DRI.OEM
  • 5+220.818795+28.59997
  • 10+207.7772010+26.91085
  • 25+147.3657025+19.08648
库存:25
