8215T.OEM
8215T.OEM
    MARINCO
    15A 125V Plug Hospital Grade Clear Master/50
8215T.OEM 数据手册
SPECIFICATION SHEET Web site: www.marinco.com Phone: 800-307-6702 Date: December, 2011 Rev: 00 Hospital Grade Plug, straight 15A, 125V NEMA 5-15P Catalog Number: 8215, 8215T Item: Hospital Grade Plug, straight blade Rating: 15 amperes, 125 volts, NEMA Configuration 5-15P Materials: Body and cord clamp are nylon with CTI greater than 600 volts. Rear housing is black (8215) or clear (8215T) polycarbonate (UL listed for 130° C and 94HB flammability index). Blades are solid brass. Terminals: Tempered brass, lug style, Perma-Lock™ design. Terminals visible through clear end cap. Terminal Identification: Terminal screws are color coded. Ground wire entrance hot stamped green and marked "GR." Line wire entrance hot stamped black. Cord Clamp: Internal. Accommodates 18/3 SJ through 12/3 S cable. Overall Design: Two assembly and cord clamp screws. All screws are combination slot/cross head. Beveled housing. Dust seal at cord entry. Cable strip length gauge molded into plug body. Listings: UL listed, File E57672 CSA certified, File LR81290 Dimensions: Dimensions shown in inches
8215T.OEM 价格&库存
很抱歉,暂时无法提供与“8215T.OEM”相匹配的价格&库存,您可以联系我们找货
