12VBRS3.OEM
12VBRS3.OEM
    MARINCO
    70A Trolling Motor Receptacle - OEM
12VBRS3.OEM 数据手册
product specifications for: 70A Trolling Motor Receptacle Item #: 12VBRS3 Description 70A Trolling Motor Receptacle Electrical Specifications Max. Amperage: 70A (12V and 24V) 60A (36V and 48V) Voltage: 12V, 24V, 12/24V, 36V, 24/36V, & 48V Wire: Two or Three Wire Mechanical Specifications Gender: Female Mating Part: 12VBPS3 Terminals: Double Set Screw w/ferrule Wire Size: 8AWG and 6AWG. 4AWG can be used with 4AWG Ferulles (not provided) Mounting Hole Size: 1.75" Mounting Thickness: 1" Max Material Specifications Receptacle Body: Nylon Contacts: Nickel Plated Brass Mounting Screws: Stainless Steel with Black Oxide Coating Terminal Screws: Nickel Plated Steel Weather Resistant Sealing Cap Dimensions in inches
12VBRS3.OEM 价格&库存
很抱歉,暂时无法提供与“12VBRS3.OEM”相匹配的价格&库存,您可以联系我们找货
