CLS40MRB-F
CLS40MRB-F
    MARINCO
    CLS Series Panel Mount (400A / 600V) 2/0 - 4/0 Double Set Screw Male - Brown (F)
CLS40MRB-F 数据手册
CLS 40 Panel Mounts Item #: CLS40MRB Description CAM CLS 40 Double Set Screw Male Panel Mount Electrical Specifications Max. Amperage: 400A Max. Voltage: 600V AC/DC Short Circuit Rating (SCCR): 35kA (UL 508) Tested at rated voltage with no circuit protection Material Specifications Housing Material: Santoprene TPV Contact Material: Brass Temperature Rating: -40°C to 105°C Mechanical Specification Gender: Male Connection Type: Double Set Screw (Torque to 150 in.-lbs., do not over tighten) Cable Range: 2/0 – 4/0 AWG Mounting: Brass eyelet for #10-32 bolt (Bolts Not Provided) Optional drilled out version (X) for #10-32 nut and bolt
CLS40MRB-F 价格&库存
很抱歉,暂时无法提供与“CLS40MRB-F”相匹配的价格&库存,您可以联系我们找货
