5278DRI
5278DRI
    MARINCO
    15A 125V 2P 3W SB INLET FRONT MOUNT W/COVER
5278DRI 数据手册
SPECIFICATION SHEET Web site: www.marinco.com Phone: 800-307-6702 Date: July, 2011 Rev: 01 Flanged Inlet, dust resistant 15A, 125V 2-Pole, 3-Wire Catalog Number: 5278DRI Item: Flanged Inlet, straight blade, dust resistant Rating: 15 amperes, 125 volts, NEMA Configuration 5-15P Materials: Device body and flange are nylon with CTI greater than 600 volts. Sealing cover and rear protective boot are vinyl compound. Blades are solid brass. Terminals: Tempered brass, lug style, Perma-Lock™ design. Terminals visible through clear end cap. Terminal Identification: Terminal screws are color coded. Ground wire entrance hot stamped green and marked "GR." Line wire entrance hot stamped black. Installation: Front mount by three screws; rear mount by 1-1/2" conduit locknut. Listings: UL listed, File E57672 CSA certified, File LR81290 Dimensions:
5278DRI 价格&库存
很抱歉,暂时无法提供与“5278DRI”相匹配的价格&库存,您可以联系我们找货
