CL8215
CL8215
    MARINCO
    Conn Power PL 2Power/1Ground POS Solder Lug ST 3 Terminal 1 Port
CL8215 数据手册
Clamp-Lock™ Termination System Clamp-Lock™ Termination System Quick, Strong and Reliable The Clamp-Lock termination system provides a maintenance-free connection. This revolutionary system actually gets stronger as the cable is pulled, which provides peace of mind knowing this durable trouble-free solution can handle heat, shock and vibration. Most important, Clamp-Lock enables wiring termination up to 50% faster than conventional screw termination products resulting in a more cost-effective process. How Does it Work? Use the built-in gauge to measure how much wire insulation should be stripped. Then, to connect the three wires, simply open the color-coded green, white and black cam levers, insert the wires and then close the cam levers—no tools are needed. The cage clamp grips the wire with redundant normal force and doesn’t let go. Slide the housing over the connection and lock it positively in place with two captive screws. Patented Clamp-Lock™ termination system Simply insert wires into funneled terminal entry and close levers for a consistently strong and reliable installation. Removeable inserts for various cable diameters For proper assembly with larger gauge cables, Clamp-Lock is furnished with removable cable clamp inserts. 2 toll free 800.307.6702 Marinco Power Products | marincopowerproducts.com Check out the Video! Find out more about the Clamp-Lock system and see it in use. Selection Chart Amps 15 15 15 20 Poles/ Wires Voltage 2P 3W 2P 3W 2P 3W 2P 3W NEMA Config. 125 5-15R 5-15P 5-15R 5-15P 6-15R 6-15P 5-20R 5-20P 5-15R 5-15P 5-15R 5-15P 125 250 125 Body Housing Plug CL5266 Connector white black black black CL5266BL CL5269BL white black CL5666 CL5669 white black CL5366 CL5369 white black CL8215 CL8219 white clear CL8215T CL8219T CL5266.OEM CL5269 Hospital Grade 15 2P 3W 125 15 2P 3W 125 *OEM packs are 50/pack. Product Specifications Dimensions Agency Listings U.L. Listed File E57672 C.S.A. Certified File LR81290 Dielectric Withstand Voltage >3,000V Heat Rise Maximum 30°C after 100 cycles at 150% of rated current Current Interrupting Yes Plugs A B C D 1.53" 2.09" 1.40" .26" Terminal Accommodation 18/3 SJ through 10/3 S Cable Housing and Body Nylon – Tough and resistant to a wide range of chemicals. U.L. Recognized for 125°C continuous use. U.L. 94V-2 Flammability Index. Cord Clamp Adjustable via nylon inserts Terminal Blades & Contacts Solid brass for excellent connectivity Terminal Cover Clear polycarbonate Cord Accommodation With inserts (0.300"–0.430") Without inserts (0.430"–0.655") toll free 800.307.6702 Connectors A B C D 1.53" 2.79" 1.40" .96" Marinco Power Products | marincopowerproducts.com 3 Check out our NEW Products SeaLink® Dual USB Charger & Receptacle An expansion of the durable SeaLink 12V product line, the combination Dual USB features two ports to charge cell phones, tablets and other devices powered by USB’s, a blue LED to show that power is available, and a cover to prevent water and dirt from entering the ports. These products are ideal for your USB charging needs and designed for longevity in harsh environments. NE NE W E N W W E N W W E N W NE W E N New & Improved Inline Cams Our inline cams are the best in the industry, but we’re always looking for ways to make our devices work better for you. We personally visited a number of our customers to see our inline cams in action and received input on what we could improve. As a result, we updated our 16 & 18 series cams to use a smoother body design that eliminates sharp edges that can get caught during use. This design also provides a perfectly contoured ergonomic grip to give you maximum control during mating and removal. Highly visible alignment arrows guide quicker alignment during mating. Add these improvements to the fact that we've added a wider screw driver slot, wider cut lines and offset internal steps you'll see that our inline cams are now better than ever. Place your order at orderentry@marinco.com or call 800.307.6702 Milwaukee, WI | 800.307.6702 | marincopowerproducts.com | ©2015 Marinco Power Products. All rights reserved. MPP_BRO_001_0415 N
CL8215 价格&库存
很抱歉,暂时无法提供与“CL8215”相匹配的价格&库存,您可以联系我们找货
