CS8364N
CS8364N
    MARINCO
    THREE PHASE CONNECTOR 50 AMP, 250 VOLT, LOCKING
CS8364N 数据手册
SPECIFICATION SHEET Web site: www.marinco.com Phone: 800-307-6702 Date: December, 2012 Rev: 00 Connector, locking 50A, 250V 3Φ Catalog Number: CS8364N Item: Connector, locking Rating: 50 amperes, 250 volts, three-phase, 3-pole, 4-wire. Materials: All rigid plastic parts are nylon with CTI greater than 600 volts. Color Black housing Terminals: Terminals have 5/16" screws with Perma-Lock™ collar to encapture the wire strands. The terminal screw does not bear down on the wire. Cord Clamp: Internal, self centering Accommodates cable up to 1.2" (6/4 S). Contacts: Line contacts are solid brass, two-piece construction, secured by two solid rivets. Rigid half is 0.10" thick. Spring half is 0.04" thick. Grounding contact is 0.20" thick plate mounted on side of connector body. Overall Design: Two assembly screws Dust seal at cord entry Beveled housing Operating Temp.: -40°C to +75°C (without impact). Listings: UL listed, File E57672 CSA certified, File LR81290 Dimensions: 5.60 2.39 1.98 3.73 4.98
CS8364N 价格&库存
很抱歉,暂时无法提供与“CS8364N”相匹配的价格&库存,您可以联系我们找货
