CS6375.OEM
CS6375.OEM
    MARINCO
    50A 125/250V FLANGED INLET MASTER/50
CS6375.OEM 数据手册
product specifications for: 50A Wiring Devices Item #: CS6375FL Description Flanged inlet, locking. Electrical Specifications 50 amperes, 125/250 volts, 3-pole, 4-wire Material Specifications Flange Material: Nylon Contact Material: Brass Cover: Molded flexible vinyl Terminals Brass, Perma-Lock design. Terminal Marking: Terminal lugs are color coded. Ground wier enterance hot stamped green and maked "G" Neutral wire enterance hot stamped white and marked "W" Phase wire enterances colored red and black and marked "X" and "Y" Listings UL listed, File E57672 CSA certified, File LR81290 Dimensions: Dimensions shown in inches
CS6375.OEM 价格&库存
很抱歉,暂时无法提供与“CS6375.OEM”相匹配的价格&库存,您可以联系我们找货
