C00200400
C00200400
    NORGREN(诺冠)
    NORGREN - C00200400 - Pneumatic Fitting, Push In Connector, Push-In Straight Adaptor, 10 bar, 4 mm
C00200400 数据手册
Pneufit C & Pneufit M metric Ø 3 ... 16 mm O/D tube Norgren Pneufit® C fittings are ready to use, offering fast assembly with no need for tools providing optimum flow. Pneufit® C offers a broad range of over 1,000 composite push-in pneumatic fittings to complement our established all brass Pneufit® series. Releasable stainless-steel grab-ring to grip nylon or polyurethane tube (85 or 95 durometer). Nickel plated brass components provide corrosion and contamination resistance and an extended life. Pre applied thread sealant on all taper threads and recessed captive O-ring on parallel threads provides optimum rapid sealing. Internal and external hexagons on straight fittings. Immediate quality sealing using silicone free Upacking. Mounting holes on all union fittings. Also introducing Miniature Pneufit® M an ultra compact alternative where space is at a premium. Technical data Operating pressure: 750mm Hg vacuum, up to 10 bar Temperature: 0 to 60°C Medium: compressed air Tube sizes Standard sizes: 4, 6, 8, 10, 12, 16 mm Miniature sizes: 3, 4, and 6 mm Thread sizes Standard sizes: M5, M6, 1/8, 1/4, 3/8 and 1/2 inch ISO G and ISO R Miniature sizes: M3, M5 and 1/8 inch ISO R Tube types Nylon 11 or 12 Polyurethane 85, 95 or 98 durometer Ordering Examples Information 2 Materials Body: PBT Seals: NBR (silicone free) u-packing and O-rings Threaded bodies: nickel plated brass Release sleeve and backing ring: POM Grab-ring: stainless steel Collar: nickel plated brass Thread sealant: threebond 2350B 02/04 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/UK 9.1.001.01 PNEUFIT® C & PNEUFIT® M Method of assembly 2 1 3 1. Ensure that the end tube is cut square and is free from burrs. 5 4 6 2. Push the tube through the release ring button and grab ring into the fitting. 7 3. Push the tube firmly through the 'O' ring until it bottoms on the tube stop, then pull back. 4. To disconnect, push the tube into the fitting, hold down the release button and withdraw the tube. Options selector Series Pneufit C Standard Pneufit M Miniature 1 Impact resistant PBT body in black for Pneufit® C and light gray for Pneufit® M. 2 Release buttons are red for metric, grey for inch, and light grey oval for Pneufit® M. 3 Stainless steel grab ring with special design to retain softer tube and provide easy releasability. 4 Silicon free U-packing provides leak tight tube seal ander side loading. 5 Stem seal provides leak tight 360° swivel connection. 6 Nickel plated brass threads and notches on hex to signify NPT. 7 Pre-applied thread sealant on tapered threads and recessed captive Oring on parallel threads. ˙0˙˙˙˙˙˙˙ Thread size/tube size Substitute C M Thread size/tube size Snape Type Pneufit M Straight Adaptors and Connectors Straight Union M0020 Straight Union (unequal) M0020 Straight Adaptor Straight Adaptor (external + internal hex) (internal hex only) M0225 M022A Straight Adaptor (temale thread) M0226 Page 16 Page 16 Page 16 Page 16 Page 16 Elbow-and Tee connectors and Adaptors Union Elbow M0040 90˚ Swivel Elbow Adaptor Union Tee M0247 M0060 Swivel Tee Adaptor M0267 Swivel Side Tee Adaptor M0268 Page 16 Page 16 Page 17 Page 17 N/UK 9.1.001.02 Page 17 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 02/04 PNEUFIT® C & PNEUFIT® M Pneufit C Straight Adaptors and Connectors Straight Union C0020 Straight Union (unequal) C0020 Straight Adaptor (external + internal hex) C0125 Straight Adaptor Straight Adaptor (external + internal hex) (internal hex only) CO12A C0225 CO22A Page 05 Page 05 Page 05 Page 05 Page 05 Stem Expander (stem/tube) C0023 Bulkhead Union C0029 Straight Adaptor (female bulkhead) C0232 Stem Union (equal + unequal) C0022 Plug C0004 Page 06 Page 06 Page 06 Page 06 Page 07 Straight Adaptor (female thread) C0226 Stem Reducer (stem/tube) C0023 Page 06 Page 06 Cap (female plug) C0012 Page 07 Elbow Connectors and Adaptors Union Elbow C0040 90° Swivel Elbow Adaptor C0147 90° Swivel Elbow Adaptor C0247 Stem Elbow C0043 90° Swivel Elbow Adaptor (extended) CO154 CO254 90° Swivel Elbow Adaptor (female) CO148/C0248 Page 07 Banjo C0A51 Page 07 Banjo with top port C0D51 C0E51 C0F51 C0G51 Page 07 Banjo Flow Control (out) COTAO Page 08 Banjo Flow Control (out) COK51 Page 08 Banjo Flow Control (in) COSAO Page 08 Banjo Flow Control (in) C0L51 In line flow control COOGE Page 9 Page 9 Page 9 Page 9 Page 10 Page 10 Page 10 Tee Connectors and Adaptors Union Tee C0060 Swivel Tee Adaptor C0167 Swivel Tee Adaptor C0267 Swivel Side Tee Adaptor C0168 Swivel Side Tee Adaptor Union Tee C0268 (unequal) C006A Stem Side Tee (unequal) C0063 Page 10 Page 11 Page 11 Page 11 Page 11 Page 12 Stem Tee (unequal) C0064 Swivel Tee Adaptor (female) C016C/C026C Page 12 Page 12 Page 10 Y Connectors Union Y (equal + unequal) C0082 Swivel Y Adaptor C0188 Swivel Y Adaptor C0288 Stem Y (equal + unequal) C0084 Page 13 Page 13 Page 14 Page 14 Cross and Manifolds Union Cross C0090 Manifold Union C00D3 Male Manifold C01D3 Stem Manifold C00J3 Page 14 Page 15 Page 15 Page 15 02/04 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/UK 9.1.001.03 PNEUFIT® C & PNEUFIT® M Speed controllers flowrate for C0K51, C0TA0, C0L51 and C0SA0 banjo types Speed controllers flowrate for C00GE banjo types 3, 4 and 6 mm M5 C00GE0400 80 40 2 3 4 5 6 7 50 8 0 1 2 3 4 5 6 Needle turn 4 5 6 7 8 500 400 300 200 100 04-01 0 9 10 1 2 3 4 5 6 7 8 0 200 1000 800 600 400 200 1 2 3 4 5 6 7 8 9 10 1112 Flow rate (l/min) 400 Pressure (bar) 8 7 5 3 1 600 Flow rate (l/min) Flow rate (l/min) 2 3 4 5 6 7 8 Pressure (bar) 06-02, 04-02 0 1 2 1 1 2 3 4 5 6 7 8 500 400 300 200 100 0 9 10 1 2 3 4 5 6 7 8 Pressure (bar) 3 4 5 6 8 7 5 3 1 250 150 50 0 7 8 Free flow 350 1 2 3 4 5 Pressure (bar) 6 7 8 1000 800 600 400 200 9 10 0 1 2 3 4 5 6 Needle turn 7 8 Pressure (bar) C00GE1000 1000 800 3 600 1 7 9 11 Control flow Flow rate (l/min) 8 7 5 1400 Pressure (bar) Free flow Flow rate (l/min) Control flow 5 Free flow Needle turn 6, 8, 10 and 12 mm 3/8 Flow rate (l/min) 1 Control flow Needle turn 1400 1000 600 200 0 13 15 1 2 3 4 5 6 Needle turn 7 8 Free flow 8 7 5 3 1 700 500 300 100 0 1 2 3 4 5 Pressure (bar) 6 7 8 800 600 400 200 9 10 0 1 2 3 4 5 6 7 8 Needle turn Pressure (bar) C00GE1200 8, 10 and 12 mm 1/2 Free flow 2000 Pressure (bar) Flow rate (l/min) 8 7 5 3 1 1500 1000 500 5 7 9 11 Needle turn N/UK 9.1.001.04 13 Control flow Flow rate (l/min) Control flow Flow rate (l/min) 0 8 7 5 3 Free flow 800 3 9 10 C00GE0800 Control flow 1 8 250 200 150 100 50 Pressure (bar) 4, 6, 8, 10 and 12 mm 1/4 0 7 Pressure (bar) Flow rate (l/min) 3 3 6 Pressure (bar) Flow rate (l/min) 3 1 1 5 Control flow Needle turn 0 4 Needle turn Flow rate (l/min) 200 100 Pressure (bar) 5 Flow rate (l/min) Flow rate (l/min) 8 7 300 0 3 Free flow 400 0 2 125 100 75 50 25 C00GE0600 Control flow 2 1 Pressure (bar) 4, 6 and 8 mm 1/8 1 60 20 0 7 8 8 7 5 3 1 Pressure (bar) Flow rate (l/min) 1 100 140 100 2000 1500 1000 500 0 1 2 3 4 5 6 7 8 Pressure (bar) Free flow 1000 8 7 5 3 1 600 200 0 1 2 3 4 5 6 7 8 9 10 Needle turn Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. Pressure (bar) Flow rate (l/min) 0 150 Free flow Pressure (bar) Flow rate (l/min) 8 7 5 3 1 120 Control flow Flow rate (l/min) 160 Pressure (bar) Free flow Flow rate (l/min) Flow rate (l/min) Control flow 1000 750 500 250 0 1 2 3 4 5 6 7 8 Pressure (bar) 02/04 PNEUFIT® C & PNEUFIT® M C0020 C0225 C C H 4,5 5,5 7,0 8,0 9,5 -* ØK 9,5 12,0 14,0 16,5 19,0 25,0 O 10,5 12,5 14,5 17,5 20,5 -* Typ C00200400 C00200600 C00200800 C00201000 C00201200 C00201600 * no nail hole in 16 mm C G1 øK1 øA øK G ø A1 C0020 Straight Union (Unequal) ØA 6 8 10 12 16 Ø A1 4 6 8 10 12 C 36,5 37,5 41,0 44,0 49,5 G 17,5 18,5 19,5 22,0 24,0 G1 16,5 17,5 18,5 19,5 22,0 C0125 ØK 12,0 14,0 16,5 19,0 25,0 Ø K1 9,5 12,0 14,0 16,5 19,0 Typ C00200604 C00200806 C00201008 C00201210 C00201612 02/04 G 4,0 8,0 6,0 8,0 8,0 5,0 4,0 6,0 8,0 8,0 6,0 8,0 8,0 9,0 6,0 8,0 8,0 9,0 8,0 8,0 9,0 8,0 9,0 ØK 9,5 9,5 9,5 9,5 9,5 12,0 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 25,0 25,0 1 10 10 13 15 17 10 12 15 15 17 15 15 17 21 17 17 17 21 19 19 21 24 24 2 2 3 3 3 2 2 5 5 5 5 6 6 6 5 8 8 8 8 8 8 8 10 Typ C02250405 C02250406 C02250418 C02250428 C02250438 C02250605 C02250606 C02250618 C02250628 C02250638 C02250818 C02250828 C02250838 C02250848 C02251018 C02251028 C02251038 C02251048 C02251228 C02251238 C02251248 C02251638 C02251648 C G1 1 B øA øK øA G1 16,0 16,0 16,0 16,0 16,0 16,5 16,5 17,5 16,5 16,5 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 21,0 21,0 21,0 25,0 25,0 G Straight Adaptor (Internal hex only) (External + internal hex) C 21,5 20,5 22,0 22,0 21,0 22,0 29,5 27,5 25,5 23,0 29,5 28,5 30,5 24,5 29,5 31,5 33,0 30,0 30,0 37,5 40,5 C 22,0 22,0 21,5 23,5 22,0 23,5 23,0 26,5 24,5 25,5 26,5 26,5 25,0 26,0 29,5 30,0 27,0 28,5 32,0 31,5 31,5 36,5 36,5 øK B G Straight Adaptor B R1/8 R1/4 R3/8 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R3/8 R1/2 B M5 M6 G1/8 G1/4 G3/8 M5 M6 G1/8 G1/4 G3/8 G1/8 G1/4 G3/8 G1/2 G1/8 G1/4 G3/8 G1/2 G1/4 G3/8 G1/2 G3/8 G1/2 C012A, C022A C G1 ØA 4 4 4 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 12 16 16 ØA 4 4 4 4 4 6 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 16 16 1 G 16,5 17,5 18,5 19,5 22,0 24,0 øA ØD 3,3 3,3 4,3 4,3 4,3 -* G (External + internal hex) øK C 34,5 37,0 39,5 43,0 48,0 51,0 B øD H øA øK ØA 4 6 8 10 12 16 Straight Adaptor O Straight Union 1 G1 G G 8,0 10,0 11,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 11,0 14,0 G1 16,0 16,0 16,0 16,5 16,5 16,5 16,5 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 21,0 21,0 21,0 21,0 25,0 25,0 ØK 9,5 9,5 9,5 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 19,0 25,0 25,0 1 10 14 17 12 14 17 19 14 14 17 19 17 17 17 19 19 19 19 19 24 24 3 3 3 4 5 5 5 5 6 6 6 5 6 8 8 5 6 8 8 8 10 Typ C01250418 C01250428 C01250438 C01250618 C01250628 C01250638 C01250648 C01250818 C01250828 C01250838 C01250848 C01251018 C01251028 C01251038 C01251048 C01251218 C01251228 C01251238 C01251248 C01251638 C01251648 ØA 4 4 4 4 4 6 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 12 B M5 M6 R1/8 R1/4 R3/8 M5 M6 R1/8 R1/4 R3/8 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 C 22,0 22,0 20,5 20,5 20,5 22,5 22,5 22,0 22,5 22,5 27,0 25,0 25,0 25,0 28,0 29,0 29,0 29,0 35,0 32,5 32,5 32,5 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. G 4,5 4,0 8,0 10,0 11,0 5,0 4,0 8,0 10,0 11,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 G1 16,0 16,0 16,0 16,0 16,0 16,5 16,5 16,5 16,5 16,5 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 21,0 21,0 21,0 21,0 ØK 9,5 9,5 9,5 9,5 9,5 12,0 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 19,0 1 2 2 3 3 3 2 2 4 4 4 4 6 6 6 5 6 6 6 5 6 8 8 Typ C022A0405 C022A0406 C012A0418 C012A0428 C012A0438 C022A0605 C022A0606 C012A0618 C012A0628 C012A0638 C012A0818 C012A0828 C012A0838 C012A0848 C012A1018 C012A1028 C012A1038 C012A1048 C012A1218 C012A1228 C012A1238 C012A1248 N/UK 9.1.001.05 PNEUFIT® C & PNEUFIT® M G øA B B øK G1 øA G C C0029 C øK C0226 Straight Adaptor P (Female thread) ØK 9,5 9,5 9,5 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 Typ C02260418 C02260428 C02260438 C02260618 C02260628 C02260638 C02260818 C02260828 C02260838 C02260848 C02261018 C02261028 C02261038 C02261048 C02261228 C02261238 C02261248 14 17 22 14 17 22 14 17 22 24 17 17 22 24 22 22 24 O Bulkhead Union ØA 4 6 8 10 12 B M12x1 M14x1 M16x1 M20x1 M22x1 C 35,5 40,0 42,0 45,0 50,5 G 16,5 17,5 18,5 19,5 22,0 ØK 9,5 12,0 14,0 16,5 19,0 O 24,5 27,5 29,5 31,5 36,0 P 4 4 5 5 5 C0232 1 P C (Female bulkhead) ø K1 øA ø A1 G F C Stem Reducer (Stem/tube) ØA 6 8 8 10 10 12 12 12 16 Ø A1 4 4 6 6 8 6 8 10 12 C 41,0 42,0 44,5 47,5 49,5 52,0 52,5 56,5 57,5 F 21,5 22,5 23,5 26,5 27,5 29,5 30,5 31,0 33,0 G 13,0 13,0 13,5 13,5 14,0 13,5 14,0 15,0 18,5 Ø K1 9,5 9,5 12,0 12,0 14,0 12,0 14,0 16,5 19,0 C0023 Typ C00230604 C00230804 C00230806 C00231006 C00231008 C00231206 C00231208 C00231210 C00231612 G G1 Straight Adaptor C0023 Typ C00290400 C00290600 C00290800 C00291000 C00291200 14 17 19 24 26 B G1 16,0 16,0 16,0 16,5 16,5 16,5 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 21,0 21,0 21,0 ØA 4 4 4 6 6 6 8 8 8 10 10 10 12 12 12 B B1 G1/8 M12x1 G1/4 M12x1 G3/8 M12x1 G1/8 M14x1 G1/4 M14x1 G3/8 M14x1 G1/8 M16x1 G1/4 M16x1 G3/8 M16x1 G1/4 M20x1 G3/8 M20x1 G1/2 M20x1 G1/4 M22x1 G3/8 M22x1 G1/2 M22x1 C G G1 ØK 26,5 9,0 17,0 9,5 29,0 11,0 17,0 9,5 30,0 12,0 17,0 9,5 28,5 9,0 17,5 12,0 30,5 11,0 17,5 12,0 31,5 12,0 17,5 12,0 29,5 9,0 18,5 14,0 31,5 11,0 18,5 14,0 32,5 12,0 18,5 14,0 32,5 11,0 19,5 16,5 33,5 12,0 19,5 16,5 36,0 14,0 19,5 16,5 38,0 11,0 22,0 19,0 38,0 12,0 22,0 19,0 40,0 14,0 22,0 19,0 P 4 4 4 4 4 4 5 5 5 5 5 5 5 5 5 14 17 17 17 17 17 19 19 19 24 24 24 28 26 26 14 17 19 17 17 22 19 19 22 24 24 24 24 24 24 1 Typ C02320418 C02320428 C02320438 C02320618 C02320628 C02320638 C02320818 C02320828 C02320838 C02321028 C02321038 C02321048 C02321228 C02321238 C02321248 C0022 C G Stem Union øA G 9,0 11,0 12,0 9,0 11,0 12,0 9,0 11,0 12,0 14,0 9,0 11,0 12,0 14,0 11,0 12,0 14,0 ¿A C 26,5 28,5 30,0 27,5 29,5 30,0 28,5 30,5 31,5 34,5 31,5 31,5 32,5 34,5 34,5 34,5 36,5 B1 B G1/8 G1/4 G3/8 G1/8 G1/4 G3/8 G1/8 G1/4 G3/8 G1/2 G1/8 G1/4 G3/8 G1/2 G1/4 G3/8 G1/2 ¿K ØA 4 4 4 6 6 6 8 8 8 8 10 10 10 10 12 12 12 øK øA ø A1 (Unequal) F C Stem Expander (Stem/tube) ØA 6 8 Ø A1 4 6 C 41,0 44,0 N/UK 9.1.001.06 F 24,0 26,5 G 13,5 14,0 ØK 12,0 14,0 ØA 4 6 8 10 12 16 C 37,0 38,0 41,0 44,0 49,0 53,0 Typ C00220400 C00220600 C00220800 C00221000 C00221200 C00221600 Typ C00230406 C00230608 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 02/04 PNEUFIT® C & PNEUFIT® M C0022 E C0147 G C C øA F øA øK ø A1 G1 Stem Union B (Unequal) Ø A1 6 8 10 12 16 C 38,0 41,5 43,5 46,5 52,0 90° Swivel Elbow Adaptor Typ C00220604 C00220806 C00221008 C00221210 C00221612 øA1 C0004 F 18,0 20,5 21,5 22,5 25,0 ØA 4 4 4 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 12 16 16 øA F C Plug Ø A1 4 6 8 10 12 16 C 30,0 34,0 38,0 42,0 46,0 50,0 F 17,5 18,5 21,0 24,0 29,5 30,0 Typ C00040400 C00040600 C00040800 C00041000 C00041200 C00041600 C 24,5 26,5 27,5 26,5 29,5 30,5 33,5 28,0 31,0 32,0 35,0 28,5 31,5 32,5 35,5 32,5 34,5 35,5 38,5 43,0 46,0 øA ø A1 Typ C01470418 C01470428 C01470438 C01470618 C01470628 C01470638 C01470648 C01470818 C01470828 C01470838 C01470848 C01471018 C01471028 C01471038 C01471048 C01471218 C01471228 C01471238 C01471248 C01471638 C01471648 ØK 9,5 12,0 14,0 16,5 19,0 25,0 Typ C00120400 C00120600 C00120800 C00121000 C00121200 C00121600 C G 17,0 17,5 18,5 19,5 22,0 18,0 B 90° Swivel Elbow Adaptor E E G H øA øD G øK 10 14 17 12 14 17 22 14 14 17 22 17 17 17 22 19 19 19 22 24 24 G C 18,0 19,0 21,0 23,0 25,0 25,0 C0040 O øK Union Elbow 02/04 ØK 9,5 9,5 9,5 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 19,0 25,0 25,0 G1 øK Ø A1 10,5 12,5 14,5 17,5 19,5 24,0 ØD 3,3 3,3 4,3 4,3 4,3 4,3 G1 17,0 17,0 17,0 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 19,5 22,0 22,0 22,0 22,0 24,0 24,0 E C0247 (Female plug) ØA 4 6 8 10 12 16 G 8,0 10,0 11,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 11,0 14,0 G Cap ØA 4 6 8 10 12 16 E 18,5 18,5 18,5 20,5 20,5 20,5 20,5 23,0 23,0 23,0 23,0 23,5 23,5 23,5 23,5 27,5 27,5 27,5 27,5 32,5 32,5 C C0012 øK ØA 4 6 8 10 12 16 B R1/8 R1/4 R3/8 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R3/8 R1/2 E 19,0 21,0 22,5 26,0 30,0 34,0 G 15,5 17,5 18,5 20,0 23,0 24,0 H 8,5 7,5 9,0 12,0 13,5 16,0 ØK 9,5 12,0 14,0 16,5 19,0 25,0 O 10,5 12,5 14,5 18,0 21,0 25,5 Typ C00400400 C00400600 C00400800 C00401000 C00401200 C00401600 øA ØA 4 6 8 10 12 ØA 4 4 4 4 4 6 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 16 16 B M5 M6 G1/8 G1/4 G3/8 M5 M6 G1/8 G1/4 G3/8 G1/8 G1/4 G3/8 G1/2 G1/8 G1/4 G3/8 G1/2 G1/4 G3/8 G1/2 G3/8 G1/2 C 22,0 22,0 22,5 24,5 24,5 24,0 24,0 24,5 26,5 26,5 26,0 28,0 28,0 29,0 26,5 28,5 28,5 29,5 32,5 32,5 32,5 41,0 42,0 E 18,5 18,5 18,5 18,5 18,5 20,5 20,5 20,5 20,5 20,5 23,0 23,0 23,0 23,0 23,5 23,5 23,5 23,5 27,5 27,5 27,5 32,5 32,5 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. G 4,5 4,5 6,0 8,0 8,0 4,5 4,5 6,0 8,0 9,0 8,0 8,0 9,0 10,0 6,0 8,0 9,0 10,0 8,0 9,0 10,0 9,0 10,0 G1 17,0 17,0 17,0 17,0 17,0 17,0 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 19,5 22,0 22,0 22,0 24,0 24,0 ØK 9,5 9,5 9,5 9,5 9,5 12,0 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 25,0 25,0 10 10 14 17 20 12 12 14 17 20 14 21 20 24 17 17 20 24 19 20 24 24 24 Typ C02470405 C02470406 C02470418 C02470428 C02470438 C02470605 C02470606 C02470618 C02470628 C02470638 C02470818 C02470828 C02470838 C02470848 C02471018 C02471028 C02471038 C02471048 C02471228 C02471238 C02471248 C02471638 C02471648 N/UK 9.1.001.07 PNEUFIT® C & PNEUFIT® M C0043 C0148/C0248 E E øK F G C C øA G1 øA øK G1 90° Swivel Elbow Adaptor B (Female) øA1 Stem Elbow ØA 4 6 8 10 12 16 Ø A1 4 6 8 10 12 16 C 28,5 31,5 34,5 38,0 41,0 48,5 E 19,0 20,5 23,0 24,0 28,0 32,0 G1 17,0 17,5 19,0 19,5 22,0 24,0 F 22,0 24,0 26,0 28,0 30,0 35,0 ØK 9,5 12,0 14,0 16,5 19,0 25,0 Typ C00430400 C00430600 C00430800 C00431000 C00431200 C00431600 E C0154, C0254 B M5 M6 R1/8 R1/4 M5 M6 R1/8 R1/4 R3/8 R1/8 R1/4 R3/8 R1/4 R3/8 R1/2 R1/4 R3/8 R1/2 C 21,5 21,5 22,5 24,5 23,5 23,5 24,5 26,5 27,5 26,0 28,0 29,0 28,5 29,5 31,5 31,5 32,5 34,5 E 18,5 18,5 18,5 18,5 20,5 20,5 20,5 20,5 20,5 23,0 23,0 23,0 23,5 23,5 23,5 27,5 27,5 27,5 G 4,5 4,5 9,0 11,0 4,5 4,5 9,0 11,0 12,0 9,0 11,0 12,0 11,0 12,0 14,0 11,0 12,0 14,0 G1 17,0 17,0 17,0 17,0 17,5 17,5 17,5 17,5 17,5 18,5 18,5 18,5 19,5 19,5 19,5 22,0 22,0 22,0 ØK 9,5 9,5 9,5 9,5 12,0 12,0 12,0 12,0 12,0 14,0 14,0 14,0 16,5 16,5 16,5 19,0 19,0 19,0 10 10 14 17 12 12 14 17 21 14 17 22 17 22 24 19 22 24 Typ C02480405 C02480406 C01480418 C01480428 C02480605 C02480606 C01480618 C01480628 C01480638 C01480818 C01480828 C01480838 C01481028 C01481038 C01481048 C01481228 C01481238 C01481248 G C øA øK G1 ØA 4 4 4 4 6 6 6 6 6 8 8 8 10 10 10 12 12 12 B 90° Swivel Elbow Adaptor (Extended) ØA 4 4 4 4 4 6 6 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 12 16 16 B M5 M6 R1/8 R1/4 R3/8 M5 M6 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R3/8 R1/2 C 33,5 33,0 35,5 37,5 38,5 38,0 37,5 40,0 42,0 43,0 46,0 44,0 46,0 47,0 50,0 47,5 49,5 50,5 53,5 54,0 56,0 57,0 60,0 69,0 72,0 E 18,5 18,5 18,5 18,5 18,5 20,5 20,5 20,5 20,5 20,5 20,5 23,0 23,0 23,0 23,0 23,5 23,5 23,5 23,5 27,5 27,5 27,5 27,5 32,5 32,5 N/UK 9.1.001.08 G 4,6 4,6 8,0 10,0 11,0 4,5 4,5 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 11,0 14,0 G1 17,0 17,0 17,0 17,0 17,0 17,5 17,5 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 19,5 22,0 22,0 22,0 22,0 24,0 24,0 ØK 9,5 9,5 9,5 9,5 9,5 12,0 12,0 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 19,0 25,0 25,0 10 10 10 14 17 12 12 12 14 17 22 14 14 17 22 17 17 17 22 19 19 19 22 24 24 Typ C02540405 C02540406 C01540418 C01540428 C01540438 C02540605 C02540606 C01540618 C01540628 C01540638 C01540648 C01540818 C01540828 C01540838 C01540848 C01541018 C01541028 C01541038 C01541048 C01541218 C01541228 C01541238 C01541248 C01541638 C01541648 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 02/04 PNEUFIT® C & PNEUFIT® M C0A51 C0TA0 C G1 C G1 øK 1 G G E E 2 øA C1 2 øK C1 øA 1 B B Banjo Flow Control Banjo (out) ØA 4 4 4 6 6 6 6 8 8 8 8 10 10 10 12 12 B M5 G1/8 G1/4 M5 G1/8 G1/4 G3/8 G1/8 G1/4 G3/8 G1/2 G1/4 G3/8 G1/2 G3/8 G1/2 C 25,0 30,5 34,5 18,0 31,0 35,0 38,5 33,0 37,0 40,0 46,0 39,0 42,0 47,5 46,0 50,0 C1 18,0 25,0 29,0 28,0 25,0 29,0 32,5 25,0 29,0 32,5 39,5 29,0 32,5 39,5 32,5 39,5 E 10,0 14,5 16,5 11,0 14,5 16,5 20,5 13,5 16,0 20,5 23,0 15,5 19,5 23,0 18,5 21,5 G 3,5 11,0 10,0 3,5 8,0 10,0 11,0 8,0 10,0 11,0 14,0 10,0 11,0 14,0 11,0 14,0 G1 16,5 16,5 16,5 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 22,0 22,0 ØK 9,5 9,5 9,5 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 19,0 19,0 Typ C0A510405 C0A510418 C0A510428 C0A510605 C0A510618 C0A510628 C0A510638 C0A510818 C0A510828 C0A510838 C0A510848 C0A511028 C0A511038 C0A511048 C0A511238 C0A511248 8 8 15 8 11 15 19 11 15 19 24 15 19 24 19 24 ØA 4 4 6 6 6 8 8 8 8 10 10 10 12 12 12 B C R1/8 R1/4 R1/8 R1/4 R3/8 R1/8 R1/4 R3/8 R1/2 R1/4 R3/8 R1/2 R1/4 R3/8 R1/2 30,5 34,5 31,0 35,0 38,5 33,0 37,0 40,0 46,0 39,0 42,0 47,5 41,0 46,0 50,0 C1 min. max. 35,0 40,0 35,0 40,0 46,5 35,0 40,0 46,5 53,0 40,0 46,5 53,0 40,0 46,5 53,0 40,0 45,5 31,0 45,5 55,0 40,0 45,5 55,0 60,0 45,5 55,0 60,0 45,5 55,0 60,0 E G G1 ØK 14,5 18,0 14,5 18,0 21,0 15,5 19,0 21,0 25,0 20,0 22,5 25,0 22,0 23,0 27,0 8,0 10,0 8,0 10,0 11,0 8,0 10,0 11,0 14,0 10,0 11,0 14,0 10,0 11,0 14,0 16,5 16,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 22,0 22,0 22,0 9,5 9,5 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 19,0 19,0 19,0 Typ 11 15 11 15 19 11 15 19 24 15 19 24 15 19 24 C0TAO0418 C0TAO0428 C0TAO0618 C0TAO0628 C0TAO0638 C0TAO0818 C0TAO0828 C0TAO0838 C0TAO0848 C0TAO1028 C0TAO1038 C0TAO1048 C0TAO1228 C0TAO1238 C0TAO1248 Control flow, see Page 4 C0D51 C0E51 C0F51 C0G51 C C C0K51 G1 G1 G2 B1 øA 2 øK øK C1 2 1 G G E E C1 øA 1 B B Banjo with Top Port ØA 4 4 4 6 6 6 6 8 8 8 10 10 12 B/B1 M5 R1/8 R1/4 M5 R1/8 R1/4 R3/8 R1/8 R1/4 R3/8 R1/4 R3/8 R3/8 02/04 C 25,0 30,5 34,5 28,0 31,0 35,0 38,5 33,0 38,0 40,0 39,0 42,0 46,0 C1 20,0 30,0 35,5 20,0 30,0 35,5 41,0 30,0 35,5 41,0 35,5 41,0 41,0 E G 10,0 3,5 14,5 9,0 18,0 11,0 11,0 3,5 14,5 9,0 18,0 11,0 21,0 12,0 15,5 9,0 19,0 11,0 21,0 12,0 20,0 11,0 22,5 12,0 23,0 12,0 G1 16,5 16,5 16,5 17,5 17,5 17,5 17,5 18,5 18,5 18,5 19,5 19,5 22,0 G2 6,0 8,0 10,0 6,0 8,0 10,0 11,0 8,0 10,0 11,0 10,0 11,0 11,0 ØK 9,5 9,5 9,5 12,0 12,0 12,0 12,0 14,0 14,0 14,0 16,5 16,5 19,0 8 17 17 8 14 17 21 14 17 21 17 21 21 Typ C0D510405 C0E510418 C0F510428 C0D510605 C0E510618 C0F510628 C0G510638 C0E510818 C0F510828 C0G510838 C0F511028 C0G511038 C0G511238 Banjo Flow Control (out) ØA B C 3 M5 21,5 4 M5 25,0 4 G1/8 30,5 4 G1/4 34,5 6 M5 28,0 6 G1/8 31,0 6 G1/4 35,0 6 G3/8 38,5 8 G1/8 33,0 8 G1/4 37,0 8 G3/8 40,0 8 G1/2 46,0 10 G1/4 39,0 10 G3/8 42,0 10 G1/2 47,5 12 G1/4 41,0 12 G3/8 46,0 12 G1/2 50,0 Control flow, see Page 4 C1 min. max. 27,0 27,0 35,0 40,0 27,0 35,0 40,0 46,5 35,0 40,0 46,5 53,0 40,0 46,5 53,0 40,0 46,5 53,0 30,0 30,0 40,0 45,5 30,0 40,0 45,5 55,0 40,0 45,5 55,0 60,0 45,5 55,0 60,0 45,5 55,0 60,0 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. E G G1 9,5 10,0 15,0 17,0 11,0 15,0 17,0 21,0 14,0 16,0 21,0 22,5 18,0 19,5 22,5 20,0 19,0 21,0 3,5 3,5 6,0 8,0 3,5 6,0 8,0 8,0 6,0 8,0 8,0 9,0 8,0 8,0 9,0 8,0 8,0 9,0 11,0 16,5 16,5 16,5 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 22,0 22,0 22,0 ØK 7,5 9,5 9,5 9,5 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 19,0 19,0 19,0 Typ 8 15 8 12 8 8 12 14 8 12 14 19 12 14 19 12 14 19 COK510305 COK510405 COK510418 COK510428 COK510605 COK510618 COK510628 COK510638 COK510818 COK510828 COK510838 COK510848 COK511028 COK511038 COK511048 COK511228 COK511238 COK511248 N/UK 9.1.001.09 PNEUFIT® C & PNEUFIT® M C C0SA0 C C00GE G1 E D 1 1 2 N øK øK C1 2 E 1 øA C1 2 øA 1 G 2 G B Banjo Flow Control In-Line Flow Control (in) G1 ØK Typ ØA C C1 min. max. 4 R1/8 30,5 35,0 40,0 14,5 4 R1/4 34,5 40,0 45,5 18,0 6 R1/8 31,0 35,0 40,0 14,5 6 R1/4 35,0 40,0 45,5 18,0 6 R3/8 39,0 46,5 55,0 21,0 8 R1/8 33,0 35,0 40,0 15,5 8 R1/4 37,0 40,0 45,5 19,0 8 R3/8 40,0 46,5 55,0 21,0 8 R1/2 46,0 53,0 60,0 25,0 10 R1/4 39,0 40,0 45,5 20,0 10 R3/8 42,0 46,5 55,0 22,5 10 R1/2 47,5 53,0 60,0 25,0 12 R1/4 41,0 40,0 45,5 22,0 12 R3/8 46,0 46,5 55,0 23,0 12 R1/2 50,0 53,0 60,0 27,0 Please see Speed Controllers Flowrate on page 4 8,0 10,0 8,0 10,0 11,0 8,0 10,0 11,0 14,0 10,0 11,0 14,0 10,0 11,0 14,0 16,5 16,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 22 22 22 9,5 9,5 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 19,0 19,0 19,0 11 15 11 15 19 11 15 19 24 15 19 24 15 19 24 C0SA00418 C0SA00428 C0SA00618 C0SA00628 C0SA00638 C0SA00818 C0SA00828 C0SA00838 C0SA00848 C0SA01028 C0SA01038 C0SA01048 C0SA01228 C0SA01238 C0SA01248 D E G ØK N Typ 16,5 17,5 18,5 19,5 22,0 9,5 12,0 14,0 16,5 19,0 13,5 17,5 20,0 23,0 25,5 CO0GE0400 CO0GE0600 CO0GE0800 CO0GE1000 CO0GE1200 max. 4 45,0 30,0 33,0 3,3 15,0 6 50,0 35,0 39,5 4,4 20,5 8 55,5 37,5 42,0 4,4 23,0 10 61,0 44,0 49,0 4,4 28,0 12 70,0 47,5 53,5 4,4 32,0 Please see Speed Controllers Flowrate on page 4 C C0060 G øD G H E G1 C1 min. øK C øA B C1 ØA O øA øK C0L51 C øA 1 E ØA C C1 ØD E G G1 H ØK O Typ 4 6 8 10 12 16 19,0 21,5 23,5 25,5 29,5 34,5 3,3 3,3 4,3 4,3 4,3 4,3 6,5 7,5 9,0 10,0 13,0 16,0 16,5 17,5 18,5 20,0 22,0 24,0 12,5 13,5 15,0 15,5 16,5 18,0 8,5 7,5 9,0 11,0 12,5 16,0 9,5 12,0 14,0 16,5 19,0 25,0 10,5 12,5 14,5 17,5 20,5 25,5 C00600400 C00600600 C00600800 C00601000 C00601200 C00601600 36,5 42,0 45,0 48,0 57,0 68,0 E 2 øK C1 G1 1 E Union Tee G 2 B C006A Banjo Flow Control C G (in) 3 M5 21,5 27,0 30,0 9,5 4 M5 25,0 27,0 30,0 10,0 4 G1/8 30,5 35,0 40,0 15,0 4 G1/4 34,5 40,0 45,5 17,0 6 M5 28,0 27,0 30,0 11,0 6 G1/8 31,0 35,0 40,0 15,0 6 G1/4 35,0 40,0 45,5 17,0 6 G3/8 39,0 46,5 55,0 21,0 8 G1/8 33,0 35,0 40,0 14,0 8 G1/4 37,0 40,0 45,5 16,0 8 G3/8 40,0 46,5 55,0 21,0 8 G1/2 46,0 53,0 60,0 22,5 10 G1/4 39,0 40,0 45,5 18,0 10 G3/8 42,0 46,5 55,0 19,5 10 G1/2 47,5 53,0 60,0 22,5 12 G1/4 41,0 40,0 45,5 20,0 12 G3/8 46,0 46,5 55,0 19,0 12 G1/2 50,0 53,0 60,0 21,0 Please see Speed Controllers Flowrate on page 4 N/UK 9.1.001.010 G1 ØK 3,5 3,5 6,0 8,0 3,5 6,0 8,0 8,0 6,0 8,0 8,0 9,0 8,0 8,0 9,0 8,0 8,0 9,0 11,0 16,0 16,0 16,0 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 22,0 22,0 22,0 7,5 9,5 9,5 9,5 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 19,0 19,0 19,0 Typ 8 15 8 12 8 8 12 14 8 12 14 19 12 14 19 12 14 19 COL510305 COL510405 COL510418 COL510428 COL510605 COL510618 COL510628 COL510638 COL510818 COL510828 COL510838 COL510848 COL511028 COL511038 COL511048 COL511228 COL511238 COL511248 øD G H E max. G1 C1 min. øA C øK B C1 ØA O ø A1 ø K1 E E Union Tee (Unequal) ØA Ø A1 C C1 ØD E G G1 H ØK Ø K1 O 6 8 10 10 12 12 16 16 4 6 6 8 8 10 10 12 41,5 45,0 49,0 49,0 56,0 56,0 61,0 63,5 19,0 22,0 23,0 25,0 25,5 27,5 30,5 33,0 3,3 4,3 4,3 4,3 4,3 4,3 4,3 4,3 7,0 8,5 8,5 9,5 9,5 11,0 11,5 13,0 17,5 18,5 19,5 19,5 22,0 22,0 24,0 24,0 12,5 13,5 13,5 15,0 15,0 15,5 15,5 16,5 8,0 9,5 11,0 11,0 12,5 12,5 16,0 16,0 12,0 14,0 16,5 16,5 19,0 19,0 25,0 25,0 9,5 12,0 12,0 14,0 14,0 16,5 16,5 19,0 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. Typ 12,5 C006A0604 15,0 C006A0806 17,5 C006A1006 17,5 C006A1008 20,5 C006A1208 20,5 C006A1210 25,5 C006A1610 25,5 C006A1612 02/04 PNEUFIT® C & PNEUFIT® M C C C0168 G1 C1 øK øA G G C1 øK G1 øA C0167 B B Swivel Tee Adaptor ØA 4 4 4 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 12 16 16 B R1/8 R1/4 R3/8 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R3/8 R1/2 C 37,5 37,5 37,5 41,0 41,0 41,0 41,0 44,0 44,0 44,0 44,0 47,0 47,0 47,0 47,0 55,0 55,0 55,0 55,0 64,5 64,5 Swivel Side Tee Adaptor C1 24,5 26,5 27,5 26,5 29,5 30,5 33,5 28,0 31,0 32,0 35,0 28,5 32,0 32,5 35,5 32,5 34,5 35,5 38,5 43,0 46,0 G 8,0 10,0 11,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 11,0 14,0 G1 17,0 17,0 17,0 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 19,5 22,0 22,0 22,0 22,0 24,0 24,0 ØK 9,5 9,5 9,5 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 19,0 25,0 25,0 10 14 17 12 14 17 22 14 14 17 22 17 17 17 22 19 19 19 22 24 24 Typ C01670418 C01670428 C01670438 C01670618 C01670628 C01670638 C01670648 C01670818 C01670828 C01670838 C01670848 C01671018 C01671028 C01671038 C01671048 C01671218 C01671228 C01671238 C01671248 C01671638 C01671648 ØA 4 4 4 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 12 B R1/8 R1/4 R3/8 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 C 20,0 20,0 20,0 21,5 21,5 21,5 21,5 23,5 23,5 23,5 23,5 25,5 25,5 25,5 25,5 30,0 30,0 30,0 30,0 C1 45,0 48,0 49,0 48,5 51,0 52,0 55,0 52,0 55,0 56,0 59,0 55,5 58,5 59,5 62,5 63,0 65,0 66,0 69,0 G 8,0 10,0 11,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 G1 17,0 17,0 17,0 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 19,5 22,0 22,0 22,0 22,0 ØK 9,5 9,5 9,5 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 19,0 10 14 17 12 14 17 22 14 14 17 22 17 17 17 22 19 19 19 22 Typ C01680418 C01680428 C01680438 C01680618 C01680628 C01680638 C01680648 C01680818 C01680828 C01680838 C01680848 C01681018 C01681028 C01681038 C01681048 C01681218 C01681228 C01681238 C01681248 C A C G1 C1 øK øA øA G1 C0268 G G C1 øK C0267 B B Swivel Side Tee Adaptor Swivel Tee Adaptor ØA 4 4 4 4 4 6 6 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 16 16 02/04 B M5 M6 G1/8 G1/4 G3/8 M5 M6 G1/8 G1/4 G3/8 G1/2 G1/8 G1/4 G3/8 G1/2 G1/8 G1/4 G3/8 G1/2 G1/4 G3/8 G1/2 G3/8 G1/2 C 37,5 37,5 37,5 37,5 37,5 41,0 41,0 41,0 41,0 41,0 41,0 44,5 44,5 44,5 44,5 47,0 47,0 47,0 47,0 55,0 55,0 55,0 64,5 64,5 C1 22,0 22,0 22,0 24,0 24,0 24,0 24,0 24,5 26,5 27,5 28,5 26,0 28,0 29,0 30,0 26,5 28,5 29,5 30,5 31,5 32,5 33,5 40,0 41,0 G 4,5 4,5 6,0 8,0 8,0 4,5 4,5 6,0 8,0 9,0 9,0 6,0 8,0 9,0 10,0 6,0 8,0 9,0 10,0 8,0 9,0 10,0 9,0 10,0 G1 17,0 17,0 17,0 17,0 17,0 17,5 17,5 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 19,5 22,0 22,0 22,0 24,0 24,0 ØK 9,5 9,5 9,5 9,5 9,5 12,0 12,0 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 25,0 25,0 10 10 14 17 20 12 12 14 17 20 24 14 17 20 24 17 17 20 24 19 20 24 24 24 Typ C02670405 C02670406 C02670418 C02670428 C02670438 C02670605 C02670606 C02670618 C02670628 C02670638 C02670648 C02670818 C02670828 C02670838 C02670848 C02671018 C02671028 C02671038 C02671048 C02671228 C02671238 C02671248 C02671638 C02671648 ØA B C C1 G G1 ØK 4 4 4 4 4 6 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 M5 M6 G1/8 G1/4 G3/8 M5 M6 G1/8 G1/4 G3/8 G1/8 G1/4 G3/8 G1/2 G1/8 G1/4 G3/8 G1/2 G1/4 G3/8 G1/2 20,0 20,0 20,0 20,0 20,0 21,5 21,5 21,5 21,5 21,5 23,5 23,5 23,5 23,5 25,5 25,5 25,5 25,5 30,0 30,0 30,0 42,0 42,0 43,0 45,0 45,0 46,0 46,0 47,0 49,0 50,0 50,0 52,0 56,0 54,0 54,0 56,0 57,0 58,0 62,0 63,0 64,0 4,5 4,5 6,0 8,0 8,0 4,5 4,5 6,0 8,0 9,0 6,0 8,0 9,0 10,0 6,0 8,0 9,0 10,0 8,0 9,0 10,0 17,0 17,0 17,0 17,0 17,0 17,5 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 19,5 22,0 22,0 22,0 9,5 9,5 9,5 9,5 9,5 12,0 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. Typ 10 10 14 17 20 12 12 14 17 20 14 17 20 24 17 17 20 24 19 20 24 C02680405 C02680406 C02680418 C02680428 C02680438 C02680605 C02680606 C02680618 C02680628 C02680638 C02680818 C02680828 C02680838 C02680848 C02681018 C02681028 C02681038 C02681048 C02681228 C02681238 C02681248 N/UK 9.1.001.011 PNEUFIT® C & PNEUFIT® M C0063 C016C/C026C C C G1 øK F G C1 C1 øA øA øK G Swivel Tee Adaptor B (Female) øA1 Stem Side Tee ØA (Equal) ØA Ø A1 C C1 F G ØK Typ 4 6 8 10 12 4 6 8 10 12 37,5 41,0 44,5 47,0 55,0 32,5 34,5 36,0 37,5 39,0 24,0 25,0 26,0 28,0 30,0 16,5 18,0 16,5 19,5 22,0 9,5 12,0 14,0 16,5 19,0 C00630400 C00630600 C00630800 C00631000 C00631200 (Unequal) ØA Ø A1 C C1 F G ØK Typ 4 6 8 10 6 8 10 12 37,5 41,0 44,5 47,0 33,5 35,5 38,5 39,5 25,0 28,0 28,0 30,0 17,0 17,5 18,5 19,5 9,5 12,0 14,0 16,5 C00630604 C00630806 C00631008 C00631210 C0064 B C G G1 M5 M6 R1/8 R1/4 M5 M6 R1/8 R1/4 R3/8 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/4 R3/8 R1/2 37,5 37,5 38,0 38,0 41,0 41,0 41,0 41,0 41,0 44,5 44,5 44,5 44,5 47,0 47,0 47,0 47,0 55,0 55,0 55,0 16,5 16,5 17,5 19,5 17,5 17,5 18,5 20,5 21,5 21,0 21,0 22,0 24,0 20,0 20,0 21,0 23,0 21,0 22,0 24,0 8,0 8,0 9,0 11,0 8,0 8,0 9,0 11,0 12,0 9,0 11,0 12,0 14,0 9,0 11,0 12,0 14,0 11,0 12,0 14,0 C1 ØK 17,0 17,0 17,0 17,0 17,5 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 19,5 22,0 22,0 22,0 9,5 9,5 9,5 9,5 12,0 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 Typ 10 10 14 17 12 12 14 17 21 14 17 22 24 17 17 22 24 19 22 24 C026C0405 C026C0406 C016C0418 C016C0428 C026C0605 C026C0606 C016C0618 C016C0628 C016C0638 C016C0818 C016C0828 C016C0838 C016C0848 C016C1018 C016C1028 C016C1038 C016C1048 C016C1228 C016C1238 C016C1248 F C1 øA øK G C 4 4 4 4 6 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 øA1 Stem Tee (Equal) ØA Ø A1 C C1 F G ØK Typ 4 6 8 10 12 4 6 8 10 12 20,5 21,5 23,5 25,5 30,0 58,0 52,5 67,0 73,0 82,0 17,0 17,5 18,5 19,5 22,0 24,0 25,0 26,0 28,0 30,0 9,5 12,0 14,0 16,5 19,5 C00640400 C00640600 C00640800 C00641000 C00641200 (Unequal) ØA Ø A1 C C1 F G ØK Typ 4 6 8 10 6 8 10 12 20,0 21,5 23,5 25,5 59,0 63,5 69,5 75,0 17,0 17,5 18,5 19,5 25,0 26,0 28,0 30,0 9,5 12,0 14,0 16,5 C00640604 C00640806 C00641008 C00641210 N/UK 9.1.001.012 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 02/04 PNEUFIT® C & PNEUFIT® M C0082 C0188 N N L L øK øK øA C D G1 G2 øA G C O G øA øK Union Y B Swivel Y Adaptor (Equal) ØA C D G G2 ØK L N O Typ ØA B C G G1 4 6 8 10 12 37,0 40,0 43,0 47,5 53,0 3,3 3,3 4,3 4,3 4,3 17,0 17,5 18,5 19,5 22,0 15 16 17 18,5 21,5 9,5 12,0 14,0 16,5 19,0 10,5 12,5 14,5 17,5 20,5 21,0 25,0 29,0 35,0 41,0 10,5 12,5 14,5 17,5 20,5 C00820400 C00820600 C00820800 C00821000 C00821200 4 4 4 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 12 R1/8 R1/4 R3/8 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 41,5 42,5 43,5 44,0 47,0 48,0 51,0 45,5 48,5 48,5 52,5 49,0 52,0 53,0 56,2 52,5 54,5 55,5 58,5 8,0 10,0 11,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 8,0 10,0 11,0 14,0 3,0 8,0 11,0 14,0 17,0 17,0 17,0 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 19,5 22,0 22,0 22,0 22,0 C0082 N L øK C D G2 øA 9,5 9,5 9,5 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 19,0 L N 10,5 10,5 10,5 12,5 12,5 12,5 12,5 14,5 14,5 14,5 14,5 17,5 17,5 17,5 17,5 20,5 20,5 20,5 20,5 21,0 21,0 21,0 25,0 25,0 25,0 25,0 29,0 29,0 29,0 29,0 35,0 35,0 35,0 35,0 41,0 41,0 41,0 41,0 Typ 10 14 17 12 14 17 22 14 14 17 22 17 17 17 22 19 19 19 22 C01880418 C01880428 C01880438 C01880618 C01880628 C01880638 C01880648 C01880818 C01880828 C01880838 C01880848 C01881018 C01881028 C01881038 C01881048 C01881218 C01881228 C01881238 C01881248 G O ØK øA1 øK1 Union Y (Unequal) Ø A Ø A1 4 6 8 10 6 8 10 12 02/04 C D G G2 ØK Ø K1 L N O Type 38,0 41,0 43,0 46,5 3,3 4,3 4,3 4,3 17,5 18,5 19,5 22,0 15,0 16,0 17,0 18,5 10,5 12,5 14,5 17,5 12,5 14,5 17,5 20,5 21,0 25,0 29,0 35,0 10,5 13,0 15,0 18,0 C00820604 C00820806 C00821008 C00821210 10,5 12,5 14,5 17,5 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/UK 9.1.001.013 PNEUFIT® C & PNEUFIT® M N C0288 N C0084 L L øK øA øA G F C C G G1 øK B øA1 Stem Y Swivel Y Adaptor (Unequal) ØK L N 4 4 4 4 4 6 6 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 M5 M6 G1/8 G1/4 G3/8 M5 M6 G1/8 G1/4 G3/8 G1/2 G1/8 G1/4 G3/8 G1/2 G1/8 G1/4 G3/8 G1/2 G1/4 G3/8 G1/2 35,0 35,0 41,0 43,0 43,0 41,5 41,5 42,5 44,5 45,5 46,5 43,5 45,5 46,5 47,5 49,5 51,5 52,5 53,5 55,0 56,0 57,0 4,5 4,5 6,0 8,0 8,0 4,5 4,5 6,0 8,0 9,0 10,0 6,0 8,0 9,0 10,0, 6,0 8,0 9,0 10,0 8,0 9,0 10,0 17,0 17,0 17,0 17,0 17,0 17,5 17,5 17,5 17,5 17,5 17,5 18,5 18,5 18,5 18,5 19,5 19,5 19,5 19,5 22,0 22,0 22,0 9,5 9,5 9,5 9,5 9,5 12,0 12,0 12,0 12,0 12,0 12,0 14,0 14,0 14,0 14,0 16,5 16,5 16,5 16,5 19,0 19,0 19,0 10,5 10,5 10,5 10,5 10,5 12,5 12,5 12,5 12,5 12,5 12,5 14,5 14,5 14,5 14,5 17,5 17,5 17,5 17,5 20,5 20,5 20,5 21,0 21,0 21,0 21,0 21,0 25,0 25,0 25,0 25,0 25,0 25,0 29,0 29,0 29,0 29,0 35,0 35,0 35,0 35,0 41,0 41,0 41,0 10 10 14 17 20 12 12 14 17 20 24 14 17 20 24 17 17 20 24 19 20 24 Typ ØA Ø A1 C F G C02880405 C02880406 C02880418 C02880428 C02880438 C02880605 C02880606 C02880618 C02880628 C02880638 C02880648 C02880818 C02880828 C02880838 C02880848 C02881018 C02881028 C02881038 C02881048 C02881228 C02881238 C02881248 4 6 8 10 6 8 10 12 51,5 56,5 62,0 68,0 24,0 26,0 28,0 30,0 17,5 18,5 20,0 22,0 ØK 9,5 12,0 14,0 16,5 L N Typ 10,5 12,5 14,5 17,5 21,0 25,0 29,0 35,0 C00840604 C00840806 C00841008 C00841210 C0090 C G øD G1 H G øA C C1 B øK ØA O E E Union Cross C0084 N ØA 4 6 8 10 12 L øK C1 38,0 42,5 47,0 50,5 57,0 ØD 3,3 4,3 4,3 4,3 4,3 E 6,5 7,5 9,0 10,0 12,0 G 17,0 17,5 18,5 19,5 22,0 H 6,5 7,5 9,0 10,0 12,0 ØK 9,5 12,0 14,0 16,5 19,0 Typ C00900400 C00900600 C00900800 C00901000 C00901200 F C G øA C 36,5 42,0 45,0 48,0 55,0 øA Stem Y (Equal) ØA ØA C F G ØK L N Typ 4 6 8 10 12 4 6 8 10 12 49,5 54,5 60,0 66,0 71,5 22,0 24,0 26,0 28,0 30,0 17,0 17,5 18,5 20,0 22,0 9,5 12,0 14,0 16,5 19,0 10,5 12,5 14,5 17,5 20,5 21,0 25,0 29,0 35,0 41,0 C00840400 C00840600 C00840800 C00841000 C00841200 N/UK 9.1.001.014 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 02/04 PNEUFIT® C & PNEUFIT® M C C00D3 øD C1 H øA1 ø K1 G O øA L E N Manifold Union ØA Ø A1 C C1 D E G H 4 4 6 6 8 6 8 8 10 10 63,5 65,5 71,5 78,0 83,5 18,0 21,5 22,5 23,5 26,0 3,3 4,3 4,3 4,3 4,3 34,0 35,0 41,0 42,0 47,0 17,5 18,5 18,5 19,5 19,5 7,5 9,0 9,5 9,5 9,5 Ø K1 L N O Typ 10,5 10,5 12,5 12,5 14,5 14,5 15,5 15,0 18,5 18,5 12,5 14,5 14,5 17,5 17,5 C00D30604 C00D30804 C00D30806 C00D31006 C00D31008 12,0 14,0 14,0 16,5 16,5 C01D3 C G1 H C1 øB øK øD øA1 G O øA L N E Male Manifold ØA Ø A1 B C C1 ØD E G G1 4 4 6 8 6 8 8 10 R1/8 R1/8 R1/4 R3/8 72,0 74,0 82,5 95,0 24,0 28,5 34,0 34,5 3,3 4,3 4,3 4,3 34,0 35,0 41,0 47,0 8,0 8,0 10,0 10,0 17,5 18,5 18,5 19,5 H 7,5 9,0 9,5 9,5 Ø K1 L N O 12,0 14,0 14,0 16,5 10,5 10,5 12,5 14,5 23,5 23,5 26,5 30,0 12,5 14,5 14,5 17,5 Typ 12 14 14 17 C01D30418 C01D30428 C01D30628 C01D30838 C00J3 C F øD C1 H øK øA øA2 G O øA1 L E N Stem Manifold ØA Ø A1 Ø A2 C C1 ØD E F G H ØK L N O Typ 6 8 8 10 4 4 6 8 6 8 8 10 84,5 89,5 95,5 109,5 24,0 28,5 34,0 34,5 3,3 4,3 4,3 4,3 34,0 35,0 41,0 47,0 25,0 28,5 28,5 31,0 17,5 18,5 18,5 19,5 7,5 9,0 9,5 9,5 12,0 14,0 14,0 16,5 10,5 10,5 12,5 14,5 35,5 39,5 39,5 44,5 12,5 14,5 14,5 17,5 C00J30604 C00J30804 C00J30806 C00J31008 N/UK 9.1.001.015 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 02/04 PNEUFIT® C & PNEUFIT® M M0126, M0226 M0020 øA (Female thread) G 11,5 13,0 13,0 G1 11,0 11,0 11,5 ØK 8 10 10 Ø K1 7 7 8 Typ M00200403 M00200603 M00200604 C B M3 M5 M6 M3 M5 M6 R1/8 M5 M6 R1/8 Straight Union G 4,0 6,0 6,0 4,0 6,0 6,0 8,5 6,0 6,0 8,5 G1 11,0 11,0 11,0 11,5 11,5 11,5 11,5 13,0 13,0 13,0 ØK 7,0 7,0 7,0 8,0 8,0 8,0 8,0 10,0 10,0 10,0 Typ M02260303 M02260305 M02260306 M02260403 M02260405 M02260406 M01260418 M02260605 M02260606 M01260618 8 8 8 8 8 8 12 10 10 12 ØK 7 8 10 M0040 Typ M00200300 M00200400 M00200600 E G øA G 11,0 11,5 13,0 M0125, M0225 H øK C 23,5 26,0 26,5 C 17,5 19,0 19,0 18,0 19,5 19,5 23,0 21,5 21,5 25,5 øA øK G ØA 3 3 3 4 4 4 4 6 6 6 øD C 24,0 24,0 26,5 M0020 ØA 3 4 6 øK B ø K1 øK Straight Adaptor (Unequal) Ø A1 3 3 4 G1 ø A1 G1 G øA G Straight Union ØA 4 6 6 C C G E C O G1 øA B øK øK Union Elbow ØA 3 4 6 G Straight Adaptor (External + internal hex) G1 11,0 11,0 11,0 11,5 11,5 11,5 11,5 13,0 13,0 13,0 ØK 7,0 7,0 7,0 8,0 8,0 8,0 8,0 10,0 10,0 10,0 Type M02250303 M02250305 M02250306 M02250403 M02250405 M02250406 M01250418 M02250605 M02250606 M01250618 7 8 8 8 8 8 12 10 10 12 M0147, M0247 H 5,5 6,0 7,0 ØK O 7,0 7,5 8,0 8,5 10,0 10,5 Typ M00400300 M00400400 M00400600 E G1 C G 4,0 4,5 5,0 4,0 4,5 5,0 6,0 4,5 5,0 8,0 G 11,0 11,5 13,0 G C 17,0 17,5 18,0 17,5 18,0 19,0 19,0 19,5 20,0 19,5 øA B M3 M5 M6 M3 M5 M6 R1/8 M5 M6 R1/8 E 13,5 14,5 16,5 øK ØA 3 3 3 4 4 4 4 6 6 6 ØD 3,2 3,2 3,2 B M012A, M022A øA B øK 1 90˚ Swivel Elbow Adaptor G1 G C Straight Adaptor (Internal hex only) ØA 3 3 3 4 4 4 4 6 6 6 02/04 B M3 M5 M6 M3 M5 M6 R1/8 M5 M6 R1/8 C 17,0 17,5 18,0 17,5 19,0 19,0 17,5 19,5 20,0 19,5 G 4,0 4,5 5,0 4,0 4,5 5,0 8,0 4,5 5,0 8,0 G1 11,0 11,0 11,0 11,5 11,5 11,5 11,5 13,0 13,0 13,0 ØK 7,0 7,0 8,0 8,0 8,0 8,0 8,0 10,0 10,0 10,0 1 1,5 2,0 2,0 1,5 2,5 3,0 3,0 2,5 3,0 2,5 Typ M022A0303 M022A0305 M022A0306 M022A0403 M022A0405 M022A0406 M012A0418 M022A0605 M022A0606 M012A0618 ØA 3 3 3 4 4 4 4 6 6 6 B M3 M5 M6 M3 M5 M6 R1/8 M5 M6 R1/8 C 16,0 17,0 17,0 16,0 17,0 17,0 18,0 17,0 17,0 18,0 E 13,5 13,5 13,5 14,5 14,5 14,5 14,5 15,5 15,5 15,5 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. G 3,0 4,0 4,0 3,0 4,0 4,0 6,0 3,5 4,0 5,0 G1 11,0 11,0 11,0 11,5 11,5 11,5 11,5 13,0 13,0 12,0 ØK 7,0 7,0 7,0 8,0 8,0 8,0 8,0 10,0 10,0 10,0 8 8 8 8 8 8 14 8 8 14 Typ M02470303 M02470305 M02470306 M02470403 M02470405 M02470406 M01470418 M02470605 M02470606 M01470618 N/UK 9.1.001.016 PNEUFIT® C & PNEUFIT® M M0060 C øD H øA C1 øK G O øA øK E E Union Tee ØA 3 4 6 C 26,5 28,5 33,0 C1 13,5 14,5 16,5 ØD 3,2 3,2 3,2 E 5,5 6,0 7,0 G 11,0 12,0 13,0 H 5,5 6,0 7,0 ØK 7,0 8,0 10,0 O 7,5 8,5 10,5 Typ M00600300 M00600400 M00600600 C M0167, M0267 G C1 øK øA G1 B Swivel Tee Adaptor ØA B C C1 G G1 ØK 3 3 3 4 4 4 4 6 6 6 M3 M5 M6 M3 M5 M6 R1/8 M5 M6 R1/8 25,5 29,0 27,0 28,5 28,5 29,0 29,0 31,0 31,0 31,0 16,0 17,0 17,0 16,0 17,0 17,0 18,0 17,0 17,0 18,0 3,0 4,0 4,0 3,0 3,5 4,0 6,0 3,5 4,0 6,0 11,0 11,0 11,0 11,5 11,5 11,5 11,5 13,0 13,0 13,0 7,0 7,0 7,0 8,0 8,0 8,0 8,0 10,0 10,0 10,0 M0168, M0268 Typ 8 8 8 8 8 8 14 8 8 14 M02670303 M02670305 M02670306 M02670403 M02670405 M02670406 M01670418 M02670605 M02670606 M01670618 8 8 8 8 8 8 14 8 8 14 Typ M02680303 M02680305 M02680306 M02680403 M02680405 M02680406 M01680418 M02680605 M02680606 M01680618 C G øA øK C1 G1 øA B Swivel Side Tee Adaptor ØA 3 3 3 4 4 4 4 6 6 6 B M3 M5 M6 M3 M5 M6 R1/8 M5 M6 R1/8 C 13,5 13,5 13,5 14,0 14,0 14,0 14,0 16,5 16,5 16,5 C1 29,5 30,0 30,5 30,5 31,0 31,5 31,5 33,5 34,0 33,5 N/UK 9.1.001.017 G 3,0 4,0 4,0 3,0 3,5 4,0 6,0 3,5 4,0 6,0 G1 11,0 11,0 11,0 11,5 11,5 12,0 11,5 13,0 13,0 13,0 ØK 7,0 7,0 7,0 8,0 8,0 8,0 8,0 10,0 10,0 10,0 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 02/04
C00200400 价格&库存
很抱歉,暂时无法提供与“C00200400”相匹配的价格&库存,您可以联系我们找货
C00200400
    • 1+290.06702
    • 5+281.37147
    • 10+272.92585
    库存:60
