102250828
102250828
    NORGREN(诺冠)
    NORGREN - 102250828 - Pneumatic Fitting, Compact Push In, Push-In Straight Adaptor, G1/4, 18 bar, 8 ...
102250828 数据手册
Back to Selector Page Pneufit Push-in Tube Fittings Inch 1⁄ 8" – 1⁄ 2" O/D tube l Very compact units l Easy tube insertion for rapid assembly of pneumatic circuits l Positive tube anchorage l All taper threads pre-coated with non-PTFE based sealant l Straight Adaptors feature internal hexagon for Allen key l Silicone free O-rings Technical Data Medium: Compressed air (For other media please consult Technical Department) Operating Pressure: Vacuum – 18 bar (Dependent upon operating specification of tubing) Vacuum: = –750mm of Hg i.e. 98% Operating Temperature: –20°C* to +80°C (-20°C to +200°C with Viton O-ring - add suffix V) Tube Sizes 1⁄ 8”, 5⁄ 32”, 3⁄ 16”, 1⁄ 4”, 5⁄ 16”, 3⁄ 8”, 1⁄ 2” O/D Tubing Types: Nylon 11 or 12, Polyurethane and other plasticised or unplasticised tubing which conforms to the tolerances specified in BS 5409, Part 1, 1976, light and normal duty, DIN 73378, DIN 74234, NFE 49-100 Ordering Information To order, quote appropriate product number from the tables on the following pages. Pneufit's new product numbering system is designed to make identification and selection simple: 1 2 Shape Series Number Type Thread Size/ Tube Size Tube Size/ Thread Size Materials Nickel plated brass or glass filled nylon for body Nickel plated brass for collet. Silicone free nitrile rubber 'O' ring (Viton optional). Plastic sealing washer (parallel threads) Non - PTFE thread sealant. Note that dimensions in this section are in Imperial units unless otherwise stated. 01/97 Warning: The push-in tube fittings in this section must not be used in vehicle air braking systems. For push-in fittings suited to these applications please consult our Technical Service for details. Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/UK 9.3.010.01 Pneufit Push-In Tube Fittings Inch Straight Unions, Connectors and Adaptors UNION Inch tube to MM Tube UNION 12020 DOUBLE MALE UNION (BRASS) 10020/10037 12022 BULKHEAD UNION MALE CONNECTOR 12029 12425 Page 9.3.010.03 Page 9.3.010.09 Page 9.3.010.03 Page 9.3.010.04 Page 9.3.010.05 FEMALE CONNECTOR STEM ADAPTOR STEM ADAPTOR Inch O/D Stem to BSPT Thread STEM ADAPTOR MM O/D Stem to NPTF [Male] Thread BARB ADAPTOR Page 9.3.010.04 10115/12115 12415 12426 Page 9.3.010.04 Page 9.3.010.04 10125/12125 MALE CONNECTOR MM O/D Tube to NPTF [Male] Thread 10425/12425 Page 9.3.010.05 Page 9.3.010.05 BANJO ELBOW FIXED ELBOW ADAPTOR 12019 10415/12415 Page 9.3.010.09 MALE CONNECTOR Inch O/D Tube to BSPT Thread Page 9.3.010.03 Elbow Unions and Connectors and Banjos UNION ELBOW MALE ELBOW 12445 12040 Page 9.3.010.06 SWIVEL MALE ELBOW Page 9.3.010.07 12477 Page 9.3.010.06 EXTENDED SWIVEL MALE SWIVEL FEMALE ELBOW ELBOW 12448 12454 Page 9.3.010.07 Page 9.3.010.06 12R51 12145 Page 9.3.010.08 Page 9.3.010.06 SWIVEL TEE ADAPTOR SWIVEL SIDE TEE ADAPTOR Tee Unions, Connectors and Banjos, ‘Y’ Unions and Connectors UNION TEE SWIVEL MALE BRANCH TEE 12060 SWIVEL MALE RUN TEE 12467 12468 ISO G BANJO TEE 12R71 PARALLEL UNION Y CONNECTOR (Thermoplastic) 12082 Page 9.3.010.07 Page 9.3.010.08 Page 9.3.010.08 Page 9.3.010.09 Page 9.3.010.08 PARALLEL MALE Y CONNECTOR PARALLEL MALE Y CONNECTOR (Plastic) PARALLEL MALE Y SWIVEL (Plastic) ELBOW BANJO ASSEMBLY ELBOW BANJO ASSEMBLY 12084 Page 9.3.010.08 12084 12488 12VO Page 9.3.010.05 Page 9.3.010.09 Page 9.3.010.10 PLUG PLUG (Plastic) MANIFOLD O/D tube to O/D tube 12167 10167 Page 9.3.010.07 12168 10168 Page 9.3.010.07 12VAO Page 9.3.010.10 Accessories TUBE END EXPANDER/REDUCER 12023 Page 9.3.010.03 N/UK 9.3.010.02 12004 Page 9.3.010.04 13004 Page 9.3.010.04 120D6 Page 9.3.010.11 MANIFOLD O/D tube to male NPTF thread 124D6 Page 9.3.010.11 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 01/97 Pneufit Push-In Tube Fittings Inch Assembly Details Typical Dimensions A O/D tube 1⁄ 8" 5⁄ 32"(4) 3⁄ 16" 1⁄ 4" 5⁄ 16"(8) 3⁄ 8" 1⁄ 2" T ØS Collet A V Tube Stop 'O' Ring Body S T tubing stop 0,53 0,55 0,59 0,61 0,65 0,83 0,96 0,09 0,11 0,13 0,17 0,24 0,30 0,38 V 0,26 0,30 0,38 0,42 0,51 0,59 0,71 * Dimensions here and in the individual tables refer to the collet being in the ‘IN’ position. † Dimensions here (minimum bore diameter) are common per tube size for all Connectors, Elbows and Tees unless otherwise stated. Method of Assembly 90º 2. Push the tube through the collet into the fitting. Product number ØA ØB L 12 022 0100 12 022 0200 12 022 0300 12 022 0400 12 022 0500 12 022 0600 12 022 0700 Tube End Expander/Reducer A O/D Stem 1⁄ 8" 5⁄ 32" 3⁄ 16" 1⁄ 4" 5⁄ 16" 3⁄ 8" 1⁄ 2" 12020 O/D tube to O/D tube B L 0,09 0,13 0,16 0,24 0,30 0,38 0,45 1,18 1,19 1,31 1,34 1,42 1,77 2,05 Product number 12 020 0100 12 020 0200 12 020 0300 12 020 0400 12 020 0500 12 020 0600 12 020 0700 L Stem Tailpiece Adaptor 12023 tube stem to O/D tube 4. To disconnect, push the tube into the fitting, hold down the collet and withdraw the tube. Straight Connector 12022 ØC Straight Stem Connector 3. Push the tube firmly through the ‘O’ ring until it bottoms on the tube stop then pull back. ØA 1. Ensure that the end of the tube is cut square and is free from burrs. A O/D Tube 1⁄ 8" 5⁄ 32" 3⁄ 16" 1⁄ 4" 5⁄ 16" 3⁄ 8" 1⁄ 2" L C 1,15 1,17 1,26 1,28 1,35 1,71 1,98 0,35 0,39 0,43 0,47 0,55 0,67 0,81 12019 O/D tube stem to hose bore Reducing C ØA L 1,22 1,30 1,34 1,22 1,22 1,38 1,30 1,46 1,50 1,38 1,69 1,65 1,97 0,35 0,35 0,39 0,39 0,47 0,43 0,43 0,47 0,47 0,55 0,55 0,55 0,67 1/8", 5/32", 1/4" L ØA 12 023 0201 12 023 0401 12 023 0402 12 023 0502 12 023 0602 12 023 0403 12 023 0503 12 023 0504 12 023 0604 12 023 0704 12 023 0605 12 023 0705 12 023 0706 B O/D Stem 5⁄ 32" 1⁄ 4" 1⁄ 4" 5⁄ 16" 3⁄ 8" 1⁄ 4" 5⁄ 16" 5⁄ 16" 3⁄ 8" 1⁄ 2" 3⁄ 8" 1⁄ 2" 1⁄ 2" ØB ØB ØA ØC L A O/D Tube 1⁄ 8" 1⁄ 8" 5⁄ 32" 5⁄ 32" 5⁄ 32" 3⁄ 16" 3⁄ 16" 1⁄ 4" 1⁄ 4" 1⁄ 4" 5⁄ 16" 5⁄ 16" 3⁄ 8" ØD Product number Product number 12 019 0101 12 019 0201 12 019 0403 12 019 0504 12 019 0605 12 019 0706 A O/D Stem 1⁄ 8" 5⁄ 32" 1⁄ 4" 5⁄ 16" 3⁄ 8" 1⁄ 2" B Hose Bore 1⁄ 8" 1⁄ 8" 3⁄ 16" 1⁄ 4" 5⁄ 16" 3⁄ 8" L D (ref) 0,17 0,17 0,24 0,31 0,37 0,47 1,34 1,35 1,43 1,47 1,70 1,84 5/16", 3/8", 1/2" Expanding Product number A O/D Tube 12 023 0104 1⁄ 4" 12 023 0204 1⁄ 4" 12 023 0304 1⁄ 4" 01/97 B O/D Stem 1⁄ 8" 5⁄ 32" 3⁄ 16" L C 1,34 1,38 1,40 0,47 0,47 0,47 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/UK 9.3.010.03 Pneufit Push-In Tube Fittings Inch 12029 O/D tube to O/D tube Product number L ØA ØA B D E 12 029 0100 12 029 0200 12 029 0300 12 029 0400 12 029 0500 12 029 0600 12 029 0700 A O/D Tube 1⁄ 8" 5⁄ 32" 3⁄ 16" 1⁄ 4" 5⁄ 16" 3⁄ 8" 1⁄ 2" B Metric Thread M10 x 1.0 M10 x 1.0 M12 x 1.0 M14 x 1.5 M16 x 1.5 M20 x 1.5 M24 x 1.5 E A/F D L 0,55 0,55 0,67 0,75 0,87 1,06 1,18 0,47 0,47 0,55 0,59 0,63 0,55 0,59 1,15 1,18 1,26 1,38 1,42 1,69 1,97 12004 Product number ØB ØA L 12 004 0100 12 004 0200 12 004 0300 12 004 0400 12 004 0500 12 004 0600 12 004 0700 A O/D Stem 1⁄ 8" 5⁄ 32" 3⁄ 16" 1⁄ 4" 5⁄ 16" 3⁄ 8" 1⁄ 2" 13004 Plug B Ø L 0,34 0,38 0,42 0,46 0,50 0,61 0,66 1,02 1,04 1,10 1,12 1,16 1,34 1,48 Product number L ØA Plug ØB Bulkhead Connector A O/D Stem 5⁄ 32" 3⁄ 16" 1⁄ 4" 5⁄ 16" 3⁄ 8" 1⁄ 2" 13 004 0200 13 004 0300 13 004 0400 13 004 0500 13 004 0600 13 004 0700 B Ø L 0,38 0,41 0,46 0,50 0,61 0,65 1,04 1,10 1,12 1,16 1,34 1,48 Plastic Nickel plated brass B ØA ØS L C N/UK 9.3.010.04 10 115 0418 10 115 0428 12 115 0418 12 115 0428 10 115 0818 10 115 0828 12 115 0628 12 115 0638 12 115 0738 12 115 0748 A B O/D ISO R Stem Thread 5⁄ 32" 1⁄ 8" 5⁄ 32" 1⁄ 4" 1⁄ 4" 1⁄ 8" 1⁄ 4" 1⁄ 4" 5⁄ 16" 1⁄ 8" 5⁄ 16" 1⁄ 4" 3⁄ 8" 1⁄ 4" 3⁄ 8" 3⁄ 8" 1⁄ 2" 3⁄ 8" 1⁄ 2" 1⁄ 2" O/D tube stem to taper NPTF thread C A/F G L S 0,39 0,55 0,47 0,55 0,55 0,55 0,59 0,75 0,75 0,87 0,30 0,44 0,30 0,44 0,30 0,44 0,44 0,50 0,50 0,63 1,18 1,32 1,26 1,40 1,30 1,44 1,57 1,77 1,89 2,03 0,08 0,08 0,16 0,16 0,20 0,20 0,30 0,30 0,39 0,39 Product number L G S Product number G Straight Stem Adaptor 10115/12115 B Inch O/D Stem to BSPT Thread ØA Stem Adaptor C Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 12 415 0210 12 415 0218 12 415 0228 12 415 0418 12 415 0428 12 415 0518 12 415 0528 12 415 0628 12 415 0638 12 415 0738 12 415 0748 12415 A O/D Stem 5⁄ 32" 5⁄ 32" 5⁄ 32" 1⁄ 4" 1⁄ 4" 5⁄ 16" 5⁄ 16" 3⁄ 8" 3⁄ 8" 1⁄ 2" 1⁄ 2" B C G L S NPTF A/F Thread 10-32 5⁄ 16" 0,20 1,14 0,08 1⁄ 8" 7⁄ 16" 0,37 1,25 0,08 1⁄ 4" 9⁄ 16" 0,56 1,45 0,08 1⁄ 8" 7⁄ 16" 0,37 1,33 0,16 1⁄ 4" 9⁄ 16" 0,56 1,52 0,16 1⁄ 8" 7⁄ 16" 0,37 1,37 0,19 1⁄ 4" 9⁄ 16" 0,56 1,56 0,19 1⁄ 4" 9⁄ 16" 0,56 1,74 0,30 3⁄ 8" 11⁄ 16" 0,56 1,82 0,30 3⁄ 8" 11⁄ 16" 0,56 1,95 0,35 1⁄ 2" 7⁄ 8" 0,75 2,15 0,35 01/97 Pneufit Push-In Tube Fittings Inch 10425/12425 Straight Adaptor MM O/D Tube to NPTF (Male) Thread C L O/D tube to male NPTF taper ØA ØC S 10-32 UNF L B ØA S G C Straight Adaptor 12426 O/D tube to female NPTF thread B B ISO R Thread 1⁄ 8" 1⁄ 4" 1⁄ 8" 1⁄ 4" 1⁄ 8" 1⁄ 4" 3⁄ 8" 1⁄ 8" 1⁄ 4" 3⁄ 8" 1⁄ 8" 1⁄ 4" 3⁄ 8" 1⁄ 2" 1⁄ 4" 3⁄ 8" 1⁄ 2" C A/F G L 0,39 0,55 0,39 0,55 0,43 0,55 0,67 0,51 0,55 0,67 0,67 0,67 0,67 0,87 0,87 0,87 0,87 0,30 0,44 0,30 0,44 0,30 0,44 0,50 0,30 0,44 0,50 0,30 0,44 0,50 0,63 0,44 0,50 0,63 0,79 0,89 0,81 0,91 0,91 0,99 1,01 1,05 1,11 1,07 1,25 1,35 1,35 1,33 1,54 1,56 1,58 A O/D Tube 1⁄ 8" 1⁄ 8" 1⁄ 8" 1⁄ 8" 5⁄ 32" 5⁄ 32" 5⁄ 32" 3⁄ 16" 3⁄ 16" 1⁄ 4" 1⁄ 4" 1⁄ 4" 1⁄ 4" 5⁄ 16" 5⁄ 16" 5⁄ 16" 3⁄ 8" 3⁄ 8" 3⁄ 8" 3⁄ 8" 1⁄ 2" 1⁄ 2" 1⁄ 2" B NPTF or UNF Thread 10-32 UNF 1⁄ 16" 1⁄ 8" 1⁄ 4" 10-32 UNF 1⁄ 8" 1⁄ 4" 1⁄ 8" 1⁄ 4" 10-32 UNF 1⁄ 8" 1⁄ 4" 3⁄ 8" 1⁄ 8" 1⁄ 4" 3⁄ 8" 1⁄ 8" 1⁄ 4" 3⁄ 8" 1⁄ 2" 1⁄ 4" 3⁄ 8" 1⁄ 2" C G L S Hex 0,31 0,20 0,37 0,37 0,56 0,20 0,37 0,56 0,37 0,56 0,20 0,37 0,56 0,56 0,37 0,56 0,56 0,37 0,56 0,56 0,75 0,56 0,56 0,75 0,79 0,80 0,67 0,95 0,85 0,89 1,04 0,96 1,04 0,94 0,98 1,11 1,07 1,12 1,23 1,13 1,32 1,47 1,41 1,45 1,67 1,63 1,70 3⁄ 32" 3⁄ 8" 7⁄ 16" 9⁄ 16" 0,35 7⁄ 16" 9⁄ 16" 7⁄ 16" 9⁄ 16" 0,43 7⁄ 16" 9⁄ 16" 11⁄ 16" 1⁄ 2" 9⁄ 16" 11⁄ 16" 11⁄ 16" 11⁄ 16" 11⁄ 16" 7⁄ 8" 7⁄ 8" 7⁄ 8" 7⁄ 8" Straight Adaptor 3⁄ 32" 3⁄ 32" 3⁄ 32" 3⁄ 32" 1⁄ 8" 1⁄ 8" 5⁄ 32" 5⁄ 32" 3⁄ 32" 5⁄ 32" 5⁄ 32" 5⁄ 32" 3⁄ 16" 1⁄ 4" 1⁄ 4" 3⁄ 16" 1⁄ 4" 5⁄ 16" 5⁄ 16" 1⁄ 4" 3⁄ 8" 3⁄ 8" 12225/10225 O/D Tube to Male Metric Thread Product number ØA S 12 425 0110 12 425 0116 12 425 0118 12 425 0128 12 425 0210 12 425 0218 12 425 0228 12 425 0318 12 425 0328 12 425 0410 12 425 0418 12 425 0428 12 425 0438 12 425 0518 12 425 0528 12 425 0538 12 425 0618 12 425 0628 12 425 0638 12 425 0648 12 425 0728 12 425 0738 12 425 0748 B 01/97 C Product number L C 12 125 0118 12 125 0128 10 125 0418 10 125 0428 12 125 0418 12 125 0428 12 125 0438 10 125 0818 10 125 0828 10 125 0838 12 125 0618 12 125 0628 12 125 0638 12 125 0648 12 125 0728 12 125 0738 12 125 0748 G 0,85 3⁄ 32" 0,89 1⁄ 8" 1,04 1⁄ 8" 0,96 5⁄ 32" 1,04 5⁄ 32" 0,94 3⁄ 32" 0,98 5⁄ 32" 1,11 5⁄ 32" 1,07 5⁄ 32" 1,12 3⁄ 16" 1,23 1⁄ 4" 1,13 1⁄ 4" 1,32 3⁄ 16" 1,47 9⁄ 32" 1,41 5⁄ 16" 1,45 5⁄ 16" 1,67 9⁄ 32" 1,63 13⁄ 32" 1,70 13⁄ 32" A O/D Tube 1⁄ 8" 1⁄ 8" 5⁄ 32" 5⁄ 32" 1⁄ 4" 1⁄ 4" 1⁄ 4" 5⁄ 16" 5⁄ 16" 5⁄ 16" 3⁄ 8" 3⁄ 8" 3⁄ 8" 3⁄ 8" 1⁄ 2" 1⁄ 2" 1⁄ 2" 12425 Straight Adaptor L Product number S Hex 12 426 0118 12 426 0128 12 426 0218 12 426 0228 12 426 0418 12 426 0428 12 426 0518 12 426 0528 12 426 0628 12 426 0638 A O/D Tube 1⁄ 8" 1⁄ 8" 5⁄ 32" 5⁄ 32" 1⁄ 4" 1⁄ 4" 5⁄ 16" 5⁄ 16" 3⁄ 8" 3⁄ 8" B C NPTF A/F Thread 1⁄ 8" 9⁄ 16" 1⁄ 4" 11⁄ 16" 1⁄ 8" 9⁄ 16" 1⁄ 4" 11⁄ 16" 1⁄ 8" 9⁄ 16" 1⁄ 4" 11⁄ 16" 1⁄ 8" 9⁄ 16" 1⁄ 4" 11⁄ 16" 1⁄ 4" 11⁄ 16" 3⁄ 8" 7⁄ 8" L 1,14 1,38 1,14 1,42 1,19 1,46 1,23 1,50 1,66 1,70 Product number L G ØC B ØA S G L B A B C G O/D Thread A/F (mm) 12 425 0210 4 10⁄ 32"UNF ,350 0,20 7⁄ 16" 0,37 12 425 0218 4 1⁄ 8" 9⁄ 16" 0,56 12 425 0228 4 1⁄ 4" 7⁄ 16" 0,37 10 425 0518 5 1⁄ 8" 9⁄ 16" 0,56 10 425 0528 5 1⁄ 4" 10 425 0610 6 10⁄ 32"UNF 0,43Ø 0,20 7⁄ 16" 0,37 10 425 0618 6 1⁄ 8" 9⁄ 16" 0,56 10 425 0628 6 1⁄ 4" 11⁄ 16" 0,56 10 425 0638 6 3⁄ 8" 1⁄ 2" 12 425 0518 8 1⁄ 8" 0,37 9⁄ 16" 0,56 12 425 0528 8 1⁄ 4" 11⁄ 16" 0,56 12 425 0538 8 3⁄ 8" 11⁄ 16" 0,37 10 425 1018 10 1⁄ 8" 11⁄ 16" 0,56 10 425 1028 10 1⁄ 4" 11⁄ 16" 0,56 10 425 1038 10 3⁄ 8" 7⁄ 8" 0,75 10 425 1048 10 1⁄ 2" 7⁄ 8" 10 425 1228 12 1⁄ 4" 0,56 7⁄ 8" 0,56 10 425 1238 12 3⁄ 8" 7⁄ 8" 10 425 1248 12 1⁄ 2" 0,75 ØA Product number L 10125/12125 Inch O/D Tube to BSPT Thread ØA Straight Adaptor Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 12 225 0105 10 225 0405 12 225 0305 12 225 0405 A O/D Tube 1⁄ 8" 5⁄ 32" 3⁄ 16" 1⁄ 4" B Thread C G L M5 x 0.8 M5 x 0.8 M5 x 0.8 M5 x 0.8 0,31 0,35 0,39 0,43 0,2 0,2 0,2 0,2 0,78 0,84 0,9 0,94 B N/UK 9.3.010.05 Pneufit Push-In Tube Fittings Inch 12040 Elbow Connector O/D tube to O/D tube 12145 Fixed Elbow Adaptor O/D Tube to Male BSPT Thread L L ØA G B ØA L G M C B 12 147 0118 10 140 0418 12 147 0318 12 147 0418 10 147 0818 10 147 0428 12 147 0328 12 147 0428 10 147 0828 12 147 0628 12 147 0728 12 147 0638 12 147 0648 12 147 0738 12 147 0748 Swivel Male Elbow O/D tube to male NPTF thread ØA L G M C B N/UK 9.3.010.06 A B O/D Thread Tube BSPT 1⁄ 8" 1⁄ 8" 5⁄ 32" 1⁄ 8" 3⁄ 16" 1⁄ 8" 1⁄ 4" 1⁄ 8" 5⁄ 16" 1⁄ 8" 5⁄ 32" 1⁄ 4" 3⁄ 16" 1⁄ 4" 1⁄ 4" 1⁄ 4" 5⁄ 16" 1⁄ 4" 3⁄ 8" 1⁄ 4" 1⁄ 2" 1⁄ 4" 3⁄ 8" 3⁄ 8" 3⁄ 8" 1⁄ 2" 1⁄ 2" 3⁄ 8" 1⁄ 2" 1⁄ 2" G L M 0,39 0,39 0,43 0,43 0,55 0,55 0,55 0,55 0,55 0,67 0,75 0,67 0,87 0,87 0,87 0,34 0,30 0,34 0,34 0,34 0,44 0,44 0,44 0,44 0,44 0,44 0,50 0,63 0,50 0,63 0,63 0,66 0,73 0,77 0,84 0,66 0,72 0,77 0,84 1,05 1,25 1,05 1,25 1,05 1,25 0,86 0,81 0,86 0,88 0,91 0,95 1,04 0,99 1,03 1,13 1,25 1,20 1,36 1,35 1,50 Product number L 12 448 0118 12 448 0218 12 448 0228 12 448 0418 12 448 0428 12 448 0528 12 448 0628 12 448 0738 C B Product number 12 477 0110 12 477 0118 12 477 0128 12 477 0210 12 477 0218 12 477 0228 12 477 0318 12 477 0328 12 477 0418 12 477 0428 12 477 0438 12 477 0518 12 477 0528 12 477 0618 12 477 0628 12 477 0638 12 477 0648 12 477 0728 12 477 0738 12 477 0748 A O/D Tube 1⁄ 8" 1⁄ 8" 1⁄ 8" 5⁄ 32" 5⁄ 32" 5⁄ 32" 3⁄ 16" 3⁄ 16" 1⁄ 4" 1⁄ 4" 1⁄ 4" 5⁄ 16" 5⁄ 16" 3⁄ 8" 3⁄ 8" 3⁄ 8" 3⁄ 8" 1⁄ 2" 1⁄ 2" 1⁄ 2" B NPTF or UNF Thread 10-32 UNF 1⁄ 8" 1⁄ 4" 10-32 UNF 1⁄ 8" 1⁄ 4" 1⁄ 8" 1⁄ 4" 1⁄ 8" 1⁄ 4" 3⁄ 8" 1⁄ 8" 1⁄ 4" 1⁄ 8" 1⁄ 4" 3⁄ 8" 1⁄ 2" 1⁄ 4" 3⁄ 8" 1⁄ 2" Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. C G L M 0,27 0,27 0,42 0,38 0,34 0,34 0,34 0,44 0,66 0,72 0,77 0,78 0,63 0,65 0,67 0,80 12448 O/D tube to female NPTF thread C A/F 12477 A B O/D Thread Tube BSPT 1⁄8" 1⁄8" 3⁄16" 1⁄8" 1⁄4" 1⁄8" 3⁄16" 1⁄4" Swivel Female Elbow Adaptor O/D Tube to Male BSPT Thread Product number 12 145 0118 12 145 0318 12 145 0418 12 145 0328 M 0,65 0,67 0,72 0,77 0,84 1,05 1,25 12147/10147 Swivel Elbow Adaptor Product number L C ØA ØA 12 040 0100 12 040 0200 12 040 0300 12 040 0400 12 040 0500 12 040 0600 12 040 0700 A O/D Tube 1⁄ 8" 5⁄ 32" 3⁄ 16" 1⁄ 4" 5⁄ 16" 3⁄ 8" 1⁄ 2" M L ØA Product number A O/D Tube 1⁄ 8" 5⁄ 32" 5⁄ 32" 1⁄ 4" 1⁄ 4" 5⁄ 16" 3⁄ 8" 1⁄ 2" B C NPTF A/F Thread 1⁄ 8" 9⁄ 16" 1⁄ 8" 9⁄ 16" 1⁄ 4" 11⁄ 16" 1⁄ 8" 9⁄ 16" 1⁄ 4" 11⁄ 16" 1⁄ 4" 11⁄ 16" 1⁄ 4" 11⁄ 16" 3⁄ 8" 7⁄ 8" L M 0,63 0,67 0,67 0,77 0,77 0,84 1,05 1,25 1,19 1,19 1,40 1,22 1,44 1,48 1,58 1,82 C A/F G L M 5⁄ 16" 0,20 0,37 0,37 0,20 0,37 0,56 0,37 0,56 0,37 0,56 0,56 0,37 0,56 0,37 0,56 0,56 0,75 0,56 0,56 0,75 0,63 0,63 0,68 0,67 0,67 0,67 0,72 0,72 0,77 0,77 0,80 0,84 0,84 1,05 1,05 1,05 1,05 1,25 1,25 1,25 0,73 0,82 1,07 0,77 0,86 1,07 0,88 1,09 0,90 1,11 1,15 0,96 1,15 1,05 1,26 1,26 1,48 1,37 1,41 1,62 7⁄ 16" 9⁄ 16" 5⁄ 16" 7⁄ 16" 9⁄ 16" 7⁄ 16" 9⁄ 16" 7⁄ 16" 9⁄ 16" 3⁄ 4" 9⁄ 16" 9⁄ 16" 9⁄ 16" 11⁄ 16" 3⁄ 4" 7⁄ 8" 3⁄ 4" 3⁄ 4" 7⁄ 8" 01/97 Pneufit Push-In Tube Fittings Inch G M 12 445 0118 12 445 0218 12 445 0228 12 445 0318 12 445 0328 12 445 0418 12 445 0428 12 445 0438 12 445 0518 12 445 0528 12 445 0618 12 445 0628 12 445 0638 12 445 0648 12 445 0728 12 445 0738 12 445 0748 B Tee Connector C A/F G L M 0,28 0,28 0,43 0,28 0,43 0,31 0,43 0,63 0,43 0,43 0,52 0,52 0,63 0,94 0,63 0,63 0,94 0,37 0,37 0,56 0,37 0,56 0,37 0,56 0,56 0,37 0,56 0,37 0,56 0,56 0,75 0,56 0,56 0,75 0,67 0,67 0,72 0,72 0,79 0,77 0,79 0,84 0,84 0,84 1,05 1,05 1,05 1,13 1,25 1,25 1,25 0,66 0,66 0,92 0,67 0,92 0,70 0,92 1,10 0,74 0,92 0,80 0,98 1,10 1,36 1,03 1,10 1,36 C 12 454 0218 12 454 0228 12 454 0418 12 454 0428 12 454 0628 12 454 0638 12454 A B C G L M O/D NPTF A/F Tube Thread 5⁄ 32" 1⁄ 8" 7⁄ 16" 0,37 0,67 1,39 5⁄ 32" 1⁄ 4" 7⁄ 16" 0,37 0,77 1,49 1⁄ 4" 1⁄ 8" 9⁄ 16" 0,56 0,67 1,71 1⁄ 4" 1⁄ 4" 9⁄ 16" 0,56 0,77 1,75 3⁄ 8" 1⁄ 4" 11⁄ 16" 0,56 1,05 2,10 3⁄ 8" 3⁄ 8" 3⁄ 4" 0,56 1,05 2,10 B 12167/10167 Swivel Tee Adaptor 12060 O/D tube to O/D tube Product number L ØA ØA A B O/D NPTF Tube Thread 1⁄ 8" 1⁄ 8" 5⁄ 32" 1⁄ 8" 5⁄ 32" 1⁄ 4" 3⁄ 16" 1⁄ 8" 3⁄ 16" 1⁄ 4" 1⁄ 4" 1⁄ 8" 1⁄ 4" 1⁄ 4" 1⁄ 4" 3⁄ 8" 5⁄ 16" 1⁄ 8" 5⁄ 16" 1⁄ 4" 3⁄ 8" 1⁄ 8" 3⁄ 8" 1⁄ 4" 3⁄ 8" 3⁄ 8" 3⁄ 8" 1⁄ 2" 1⁄ 2" 1⁄ 4" 1⁄ 2" 3⁄ 8" 1⁄ 2" 1⁄ 2" M Product number L O/D tube to male NPTF thread G O/D tube to male NPTF thread C Extended Swivel Elbow Adaptor 12445 Fixed Elbow Adaptor O/D Tube to Male Taper BSP Thread E D A/F E F L Product number F 0,26 0,30 0,38 0,42 0,50 0,59 0,71 0,20 0.28 0.28 0,31 0,43 0,52 0,63 0,63 0,67 0,72 0,77 0,84 1,05 1,25 0,32 0,40 0,44 0,48 0,56 0,67 0,81 1,26 1,34 1,44 1,54 1,68 2,10 2,50 D C E ØF L C G 12 060 0100 12 060 0200 12 060 0300 12 060 0400 12 060 0500 12 060 0600 12 060 0700 D A O/D Tube 1⁄ 8" 5⁄ 32" 3⁄ 16" 1⁄ 4" 5⁄ 16" 3⁄ 8" 1⁄ 2" A Product number C B ØA Swivel Side Tee Adaptor A B C O/D Thread A/F Tube BSPT 10 167 0418 5⁄32" 1⁄8" 0,39 0,34 12 167 0318 3⁄16" 1⁄8" 0,34 12 167 0418 1⁄4" 1⁄8" 0,55 10 167 0818 5⁄16" 1⁄8" 0,55 10 167 0428 5⁄32" 1⁄4" 12 167 0328 3⁄16" 1⁄4" 0,43 12 167 0428 1⁄4" 1⁄4" 0,43 10 167 0828 5⁄16" 1⁄4" 0,55 12 167 0618 3⁄8" 1⁄4" 0,43 12 167 0728 1⁄2" 1⁄4" 0,43 12 167 0638 3⁄8" 3⁄8" 0,50 12 167 0738 1⁄2" 3⁄8" 0,50 D E A/F 0,28 0,35 0,35 0,43 0,28 0,34 0,35 0,43 0,52 0,63 0,52 0,63 F 0,81 1,33 0,86 1,45 0,88 1,54 0,91 1,68 0,95 1,33 0,97 1,45 0,99 1,54 1,03 1,68 1,13 2,10 1,25 2,50 1,20 2,10 1,34 2,50 G 0,34 0,34 0,34 0,34 0,44 0,44 0,44 0,44 0,44 0,44 0,50 0,50 12168/10168 O/D Tube to Male Taper BSP Thread Product number F E H B D C G A 01/97 10 168 0418 12 168 0318 12 168 0418 10 168 0818 10 168 0428 12 168 0328 12 168 0428 10 168 0828 12 168 0628 12 168 0728 12 168 0638 12 168 0738 A B C O/D Thread A/F Tube BSPT 5⁄ 32" 1⁄ 8" 0,39 3⁄ 16" 1⁄ 8" 0,34 1⁄ 4" 1⁄ 8" 0,34 5⁄ 16" 1⁄ 8" 0,55 5⁄ 32" 1⁄ 4" 0,55 3⁄ 16" 1⁄ 4" 0,43 1⁄ 4" 1⁄ 4" 0,43 5⁄ 16" 1⁄ 4" 0,55 3⁄ 8" 1⁄ 4" 0,43 1⁄ 2" 1⁄ 4" 0,43 3⁄ 8" 3⁄ 8" 0,50 1⁄ 2" 3⁄ 8" 0,50 D E A/F 0,28 0,35 0,35 0,43 0,28 0,34 0,35 0,43 0,52 0,63 0,52 0,63 F G H 0,81 1,47 0,34 0,66 0,86 1,59 0,34 0,72 0,88 1,65 0,34 0,77 0,91 1,74 0,34 0,84 0,95 1,61 0,44 0,72 0,97 1,69 0,44 0,72 1,00 1,76 0,44 0,77 1,03 1,87 0,44 0,84 1,13 2,19 0,44 1,05 1,25 2,50 0,44 1,24 1,20 2,25 0,50 1,05 1,34 2,59 0,50 1,25 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/UK 9.3.010.07 Pneufit Push-In Tube Fittings Inch 12467 Swivel Male Centre Tee O/D tube to male NPTF thread 12468 Swivel Male Side Tee O/D tube to maleE taper NPTF thread AØ E L ØA ØA ØA L M G C C G B B Product number 12 467 0110 12 467 0118 12 467 0128 12 467 0210 12 467 0218 12 467 0228 12 467 0318 12 467 0328 12 467 0418 12 467 0428 12 467 0438 12 467 0518 12 467 0528 12 467 0618 12 467 0628 12 467 0638 12 467 0648 12 467 0728 12 467 0738 12 467 0748 A O/D Tube 1⁄ 8" 1⁄ 8" 1⁄ 8" 5⁄ 32" 5⁄ 32" 5⁄ 32" 3⁄ 16" 3⁄ 16" 1⁄ 4" 1⁄ 4" 1⁄ 4" 5⁄ 16" 5⁄ 16" 3⁄ 8" 3⁄ 8" 3⁄ 8" 3⁄ 8" 1⁄ 2" 1⁄ 2" 1⁄ 2" B NPTF or UNF Thread 10-32 UNF 1⁄ 8" 1⁄ 4" 10-32 UNF 1⁄ 8" 1⁄ 4" 1⁄ 8" 1⁄ 4" 1⁄ 8" 1⁄ 4" 3⁄ 8" 1⁄ 8" 1⁄ 4" 1⁄ 8" 1⁄ 4" 3⁄ 8" 1⁄ 2" 1⁄ 4" 3⁄ 8" 1⁄ 2" C A/F G L E Product number 5⁄ 16" 0,20 0,37 0,56 0,20 0,37 0,56 0,37 0,56 0,37 0,56 0,56 0,37 0,56 0,37 0,56 0,56 0,75 0,56 0,56 0,75 1,25 1,26 1,34 1,34 1,33 1,33 1,45 1,45 1,54 1,54 1,57 1,68 1,68 2,10 2,10 2,10 2,10 2,50 2,50 2,50 0,73 0,81 1,07 0,77 0,86 1,07 0,88 1,09 0,90 1,12 1,20 0,96 1,15 0,66 1,26 1,26 1,48 1,37 1,41 1,62 12 468 0110 12 468 0118 12 468 0128 12 468 0210 12 468 0218 12 468 0228 12 468 0318 12 468 0328 12 468 0418 12 468 0428 12 468 0438 12 468 0518 12 468 0528 12 468 0618 12 468 0628 12 468 0638 12 468 0648 12 468 0728 12 468 0738 12 468 0748 7⁄ 16" 9⁄ 16" 5⁄ 16" 7⁄ 16" 9⁄ 16" 7⁄ 16" 9⁄ 16" 7⁄ 16" 9⁄ 16" 3⁄ 4" 9⁄ 16" 9⁄ 16" 9⁄ 16" 11⁄ 16" 3⁄ 4" 7⁄ 8" 3⁄ 4" 3⁄ 4" 7⁄ 8" 12082 Parallel Y Connector O/D tube to O/D tube A O/D Tube 1⁄ 8" 1⁄ 8" 1⁄ 8" 5⁄ 32" 5⁄ 32" 5⁄ 32" 3⁄ 16" 3⁄ 16" 1⁄ 4" 1⁄ 4" 1⁄ 4" 5⁄ 16" 5⁄ 16" 3⁄ 8" 3⁄ 8" 3⁄ 8" 3⁄ 8" 1⁄ 2" 1⁄ 2" 1⁄ 2" B C NPTF or A/F UNF Thread 10-32 UNF 5⁄ 16" 1⁄ 8" 7⁄ 16" 1⁄ 4" 9⁄ 16" 10-32 UNF 5⁄ 16" 1⁄ 8" 7⁄ 16" 1⁄ 4" 9⁄ 16" 1⁄ 8" 7⁄ 16" 1⁄ 4" 9⁄ 16" 1⁄ 8" 7⁄ 16" 1⁄ 4" 9⁄ 16" 3⁄ 8" 3⁄ 4" 1⁄ 8" 9⁄ 16" 1⁄ 4" 9⁄ 16" 1⁄ 8" 9⁄ 16" 1⁄ 4" 11⁄ 16" 3⁄ 8" 3⁄ 4" 1⁄ 2" 7⁄ 8" 1⁄ 4" 3⁄ 4" 3⁄ 8" 3⁄ 4" 1⁄ 2" 7⁄ 8" G L M E 0,63 0,63 0,67 0,67 0,67 0,67 0,72 0,72 0,77 0,77 0,79 0,84 0,84 1,05 1,05 1,05 1,05 1,25 1,25 1,25 1,36 1,36 1,44 1,44 1,52 1,73 1,60 1,81 1,67 1,88 1,59 1,80 1,98 2,00 2,31 2,31 2,53 2,62 2,65 2,87 0,63 0,73 0,77 0,67 0,86 1,07 0,88 1,09 0,90 1,11 0,81 0,96 1,15 0,94 1,26 1,26 1,48 1,37 1,41 1,62 1,36 0,63 0,67 1,44 0,67 0,67 0,72 0,72 0,77 0,77 0,79 0,84 1,98 1,05 1,05 1,05 1,05 1,25 1,25 1,25 12084 Parallel Y Stem Connector stem to O/D tube M E ØD ØN C ØD C ØB (2x) ØA (2x) L L ØS E ØS ØB ØN Product number 12 082 0200 12 082 0402 12 082 0400 12 082 0500 A O/D Stem 5⁄ 32" 5⁄ 32" 1⁄ 4" 5⁄ 16" B O/D Tube 5⁄ 32" 1⁄ 4" 1⁄ 4" 5⁄ 16" Plastic body N/UK 9.3.010.08 ØA C D Ø E L N Ø S Ø Product number 0,43 0,55 0,55 0,63 0,30 0,43 0,43 0,51 0,87 1,06 1,06 1,22 1,34 1,50 1,51 1,59 0,43 0.51 0,51 0,59 0,13 0,13 0,13 0,13 12 084 0202 12 084 0402 12 084 0404 12 084 0505 A O/D Stem 5⁄ 32" 1⁄ 4" 1⁄ 4" 5⁄ 16" B O/D Tube 5⁄ 32" 5⁄ 32" 1⁄ 4" 5⁄ 16" C D Ø E L M N Ø S Ø 0,43 0,43 0,55 0,63 0,30 0,30 0,43 0,51 0,71 0,73 0,73 0,77 2,05 2,23 2,23 2,36 0,89 0.89 1,10 1,26 0,45 0,45 0,55 0,63 0,13 0,13 0,13 0,13 Plastic body Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 01/97 Conversion Fittings 12448 Parallel Male Y Swivel Adaptor O/D tube to male NPTF thread Product number ØN E ØD ØA (2x) L C ØS G F A/F 12 448 0218 12 448 0228 12 448 0418 12 448 0428 12 448 0628 12 448 0638 12 448 0648 A O/D Tube 5⁄ 32" 5⁄ 32" 1⁄ 4" 1⁄ 4" 3⁄ 8" 3⁄ 8" 3⁄ 8" B NPTF Thread 1⁄ 8" 1⁄ 4" 1⁄ 8" 1⁄ 4" 1⁄ 4" 3⁄ 8" 1⁄ 2" C D Ø E F A/F G L N Ø S Ø 0,43 0,43 0,55 0,55 0,86 0,86 0,86 0,30 0,30 0,43 0,43 0,51 0,51 0,51 0,89 0,89 1,10 1,10 1,67 1,67 1,67 7⁄ 16 0,30 0,44 0,30 0,44 0,44 0,56 0,75 1,72 2,01 1,90 2,15 2,69 2,69 2,88 0,45 0,45 0,55 0,55 0,79 0,79 0,79 0,13 0,13 0,13 0,13 0,13 0,13 0,13 9⁄ 16 7⁄ 16 9⁄ 16 3⁄ 4 3⁄ 4 7⁄ 8 Plastic body B 12R51 Elbow Banjo Assembly Non regulating bolt O/D tube to male NPTF thread 12R71 Tee Banjo Assembly O/D tube to male BSPP thread L C B Straight Connector 10020/12037 Inch tube to MM tube A B O/D ISO G Tube C M A/F L 12 R71 0210 12 R71 0418 12 R71 0428 12 R71 0628 12 R71 0638 5⁄ 32" 10-32 UNF 5⁄ 16" 1⁄ 4" 1⁄ 8" 9⁄ 16" 1⁄ 4" 1⁄ 4" 3⁄ 8" 1⁄ 4" 3⁄ 8" 3⁄ 8" 1,48 1,86 1,90 2,38 2,46 ØA B 0,87 1,22 11⁄ 16" 1,50 11⁄ 16" 1,50 7⁄ 8" 1,74 10415/12415 Stem Adaptor Product number L L 1,17 1,26 1,28 1,35 1,71 1,98 G ØS 10 020 0400 12 037 0305 12 037 0406 10 020 0800 12 037 0610 12 037 0712 C Ø (mm) 4 5 6 8 10 12 B ØC L A O/D Tube 5⁄ 32" 3⁄ 16" 1⁄ 4" 5⁄ 16" 3⁄ 8" 1⁄ 2" C 01/97 Product number MM O/D Stem to NPTF (Male) Thread Product number ØA C ØA M ØA 12 R51 0118 12 R51 0210 12 R51 0218 12 R51 0418 12 R51 0428 12 R51 0438 12 R51 0628 12 R51 0638 B C M L NPTF or A/F UNF Thread 1⁄ 8" 9⁄ 16" 1,22 0,80 10-32 UNF 5⁄ 16" 0,87 0,74 1⁄ 8" 9⁄ 16" 1,22 0,81 1⁄ 8" 9⁄ 16" 1,22 0,93 1⁄ 4" 11⁄ 16" 1,50 0,95 3⁄ 8" 7⁄ 8" 1,74 1,03 1⁄ 4" 11⁄ 16" 1,50 1,19 3⁄ 8" 7⁄ 8" 1,74 1,23 ØA L A O/D Tube 1⁄ 8" 5⁄ 32" 5⁄ 32" 1⁄ 4" 1⁄ 4" 1⁄ 4" 3⁄ 8" 3⁄ 8" M Product number Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 12 415 0218 12 415 0228 10 415 0518 10 415 0528 10 415 0618 10 415 0628 12 415 0518 12 415 0528 10 415 1028 10 415 1038 10 415 1238 10 415 1248 A B C G L S O/D NPTF A/F Stem Thread (mm) 1⁄ 8" 7⁄ 16" 0,37 1,25 0,08 4 1⁄ 4" 9⁄ 16" 0,56 1,44 0,08 4 1⁄ 8" 7⁄ 16" 0,37 1,31 0,13 5 1⁄ 4" 9⁄ 16" 0,56 1,50 0,13 5 1⁄ 8" 7⁄ 16" 0,37 1,33 0,16 6 1⁄ 4" 9⁄ 16" 0,56 1,52 0,16 6 1⁄ 8" 7⁄ 16" 0,37 1,37 0,20 8 1⁄ 4" 9⁄ 16" 0,56 1,56 0,20 8 9⁄ 16" 0,56 1,74 0,30 10 1⁄ 4" 3 11⁄ 16" 0,56 1,81 0,30 ⁄ 10 8" 11⁄ 16" 0,56 1,95 0,36 12 3⁄ 8" 7⁄ 8" 0,75 2,15 0,36 12 1⁄ 2" N/UK 9.3.010.09 Pneufit Push-In Tube Fittings Inch 12V0 D G E D1 F E B Product number * 12VO00210 12VO00218 12VO00418 12VO00428 12VO00628 12VO00638 12VO00748 A B O/D tube thr’d C D 5⁄32 10-32UNF 5⁄32 1⁄8 1⁄4 1⁄8 1⁄4 1⁄4 3⁄8 1⁄4 3⁄8 3⁄8 1⁄2 1⁄2 27 42 42 54 54 64 72 Plastic Body * Brass Body Metric dimensions N/UK 9.3.010.010 12VA A C Pressure rating on this item 10 bar K F Pressure rating on this item 10 bar J D Regulating Out O/D tube to male NPTF or UNF thread Knurled adjustment knob A Regulating Out O/D tube to male NPTF or UNF thread H Elbow Banjo Assembly K H Elbow Banjo Assembly B E F A/F 18,7 9,5 22,0 9⁄16 11,5 23,0 9⁄16 13 25,5 11⁄16 13,5 31,5 11⁄16 19,5 32,5 3⁄4 19,5 38,0 7⁄8 23,0 G H K Square 4,4 10 10 14,5 14,5 14,5 19,0 16 16 20 20 22 27 22,5 22,5 29,5 29,5 33,0 42,0 Product number * 12VA00210 12VA00218 12VA00418 12VA00428 12VA00628 12VA00638 12VA00748 A B O/D tube 5⁄32 10-32UNF 5⁄32 1⁄8 1⁄4 1⁄8 1⁄4 1⁄4 3⁄8 1⁄4 3⁄8 3⁄8 1⁄2 1⁄2 D1 Closed 53 53 67 67 78 93 D E F A/F 26,5 22,0 9⁄16 23,0 9⁄16 25,5 11⁄16 31,5 11⁄16 32,5 3⁄4 38,0 7⁄8 9,5 11,5 13,0 13,5 19,5 19,5 23,0 J H K Square 18,7 9,0 9,0 11,0 11,0 13,0 18,0 2,5 16,0 16,0 20,0 20,0 22,0 27,0 22,5 22,5 29,5 29,5 33,0 42,0 Plastic Body * Brass Body Metric dimensions Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 01/97 Pneufit Push-In Tube Fittings Inch Manifold O/D tube to O/D tube C D J E P L A1 Product A O/D A1 O/D C D E H number tube inlet tube outlet 5⁄ 32 120D60402 1⁄ 4 69,5 42,0 13,0 3,4 5⁄ 32 120D60502 5⁄ 16 67,5 42,0 13,0 3,4 1⁄ 4 120D60604 3⁄ 8 82,5 48,0 15,0 3,4 5⁄ 16 120D60605 3⁄ 8 82,5 48,0 15,0 3,4 Metric dimensions L K A M H N J K L M N P 13,7 12,7 17,2 17,2 16,0 16,0 20,0 20,0 14,0 14,0 16,0 16,0 9,0 9,0 10,5 10,5 20,0 20,2 22,7 22,7 16,4 16,4 20,4 20,4 Q A/F Manifold O/D tube to male taper NPTF thread C D J E P L Product number A1 G Q L K A B M H N A O/D A1 O/D B C tube tube thread inlet outlet 1⁄4 85,5 124D60228 5⁄ 16 5⁄ 32 5 5 3⁄8 ⁄ ⁄ 86,0 124D60238 16 32 1⁄4 85,5 124D60428 5⁄ 16 1⁄ 4 3⁄8 124D60438 5⁄ 16 1⁄ 4 86,5 1⁄ 4 1⁄2 124D60448 3⁄ 8 103 5⁄ 16 1⁄2 124D60548 3⁄ 8 107 Metric dimensions D E G H J K L M N P 42,0 42,0 42,0 42,0 48,0 48,0 13,0 13,0 13,0 13,0 15,0 15,0 11,1 12,7 11,1 12,7 12,7 15,9 3,4 3,4 3,4 3,4 3,4 3,4 12,7 12,7 12,7 12,7 17,2 17,2 16,0 16,0 16,0 16,0 20,0 20,0 14,0 14,0 14,0 14,0 16,0 16,0 9,0 9,0 9,0 9,0 10,5 10,5 20,2 20,2 22,7 22,7 22,7 22,7 16,4 11⁄ 16 16,4 3⁄ 4 16,4 11⁄ 16 16,4 3⁄ 4 20,4 7⁄ 8 20,4 7⁄ 8 Warning These products are intended for use in industrial compressed air systems only. Do not use these products where pressures and temperatures can exceed those listed under ‘Technical Data’. Before using these products with fluids other than those specified, for non-industrial applications, life-support systems, or other applications not within published specifications, consult Norgren. Through misuse, age, or malfunction, components used in fluid power systems can fail in various modes. The system designer is warned to consider the failure modes of all component parts used in fluid power systems and to provide adequate safeguards to prevent personal injury or damage to equipment in the event of such failure. System designers must provide a warning to end users in the system instructional manual if protection against a failure mode cannot be adequately provided. System designers and end users are cautioned to review specific warnings found in instruction sheets packed and shipped with these products where applicable. 01/97 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/UK 9.3.010.011
102250828 价格&库存
很抱歉,暂时无法提供与“102250828”相匹配的价格&库存,您可以联系我们找货
    • 5+42.80712
    库存:5
