150234828
150234828
    NORGREN(诺冠)
    NORGREN - 150234828 - Pneumatic Fitting, BSP, Reducer, G1/4, R1/2, 18 bar, Brass, 15
150234828 数据手册
Nickel Plated BSP & Hose Fittings M3, M5, 1⁄8" – 11⁄2" BSP ● Suitable for use in most general industrial applications ● Bright nickel plated brass ● Compact design ● Reliable and corrosion resistant ● Washers included where necessary Technical Data Medium: Compressed air or any fluids compatible with the materials listed below Operating Pressure and Temperature: Generally limited by tubing specification except where plastic sealing washers are used (Banjo bolts M3 & M5 units). In these cases temperature limited to +70°C, pressure limited to 18 bar. Suitable for vacuum applications. Ordering Information To order, quote appropriate product number from the tables on the following pages. M3, M5, 1⁄8", 1⁄4", 3⁄8", 1⁄2", 3⁄4", 1", 11⁄4", 11⁄2" BSP threads Flow regulating banjos are limited to 1-10 bar operating range Materials Bar parts brass to BS 2874: 1986 (CZ121), bright nickel plated. Stamped parts brass to BS 2872: 1969 (CZ122), bright nickel plated. Copper sealing washers (nylon for M3 & M5 units and banjo assemblies). 05/98 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/AL 9.8.001.01 Nickel Plated BSP & Hose Fittings Straight Adaptors and Connectors BULKHEAD CONNECTOR SLEEVE ADAPTOR female BSPP 16029 Page 9.8.001.03 NIPPLE ADAPTOR male BSPP 16022 Page 9.8.001.03 HEXAGON NIPPLE GAUGE ADAPTOR female BSPP to male NPTF male NPTF to male BSPT 17223 NIPPLE ADAPTOR male BSPT 15020 16020 15423 Page 9.8.001.03 Page 9.8.001.03 Page 9.8.001.04 BSP CONNECTOR reducer - male BSPT x female BSPP BSP CONNECTOR expander - male BSPT x female BSPP PLUG male BSPP PLUG male BSPT HOSE ADAPTOR metric I/D hose bore x male BSPT 15023 15023 Page 9.8.001.04 Page 9.8.001.04 HOSE ADAPTOR imperial I/D hose bore x male BSPT HOSE ADAPTOR metric I/D hose bore x male BSPP SWIVEL HOSE ADAPTOR HOSE CONNECTOR imperial I/D x female BSPP imperial Page 9.8.001.04 30218 29217 Page 9.8.001.06 16023 16023 ADAPTOR female NPTF to male BSPT Page 9.8.001.03 Page 9.8.001.04 Page 9.8.001.06 BSP CONNECTOR expander male x female Page 9.8.001.03 15420 30117 BSP CONNECTOR reducer male x female Page 9.8.001.06 16005 Page 9.8.001.05 15005 Page 9.8.001.05 29117 Page 9.8.001.06 30014 Page 9.8.001.07 Elbow Connectors and Adaptors ELBOW 2 x female BSPP ELBOW ELBOW male BSPT x female BSPP 2 x male BSPT 16042 Page 9.8.001.04 15043 Page 9.8.001.04 ELBOW BANJO ASSEMBLY ELBOW BANJO ASSEMBLY non regulating bolt regulating out 16A51 15040 Page 9.8.001.05 Page 9.8.001.07 16K51 Page 9.8.001.07 Tee Connectors and Adaptors TEE 3 x female BSPP TEE 3 x male BSPT 16062 Page 9.8.001.05 TEE 2 x female BSPT x male BSPP leg 15060 Page 9.8.001.05 CROSS 4 x female BSPP 16092 15069 Page 9.8.001.05 Page 9.8.001.05 BANJO BOLT non regulating double stacking 20B00 BANJO BOLT regulating single stacking BSP parallel 20K00 Banjo Bodies and Bolts ELBOW BANJO BODY BANJO BOLT non regulating single stacking 16051 20A00 Page 9.8.001.07 Page 9.8.001.07 Page 9.8.001.07 Page 9.8.001.07 MANIFOLD single sided LOCKNUT metric LOCKNUT inch FLAT UNION 34050 Page 9.8.001.08 N/AL 9.8.001.02 36054 Page 9.8.001.08 34022 Page 9.8.001.08 TAPER PLUG with internal hexagon 15033 Page 9.8.001.08 4 WAY BLOCK CONNECTOR 25013 Page 9.8.001.08 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. Page 9.8.001.08 05/98 Nickel Plated BSP & Hose Fittings Bulkhead Connector A BSPP B metric D female male thread thread B A 160290005 M5x0,8 M10x1,0 14,0 G F E A/F F G max. 14 3,5 7,0 160290018 1⁄8" M16x1,5 18,0 22 4,0 10,0 160290028 1⁄4" M20x1,5 25,0 27 4,0 16,0 160290038 3⁄8" M26x1,5 26,0 32 5,0 15,0 160290048 1⁄2" M28x1,5 33,0 36 6,0 160290068 3⁄4" M33x1,5 36,5 41 160290088 1" M42x1,5 41,5 1602900A8 11⁄4" M48x1,5 50,0 E Product number D G A BSPP B BSPP D male male thread thread M5x0,8 11,0 8 - 13,0 14 7,4 160221818 1⁄8" 1⁄8" 15,0 14 - 160222818 1⁄4" 1⁄8" 19,0 17 9,5 21,0 160222828 1⁄4" 1⁄4" 22,0 17 - 6,0 22,5 160223818 3⁄8" 1⁄8" 20,0 22 10,5 46 8,0 24,5 160223828 3⁄8" 1⁄4" 23,0 22 10,5 55 8,0 29,5 160223838 3⁄8" 3⁄8" 24,0 22 - 160224818 1⁄2" 1⁄8" 24,0 24 13,0 160224828 1⁄2" 1⁄4" 25,0 24 13,0 160224838 1⁄2" 3⁄8" 27,5 24 13,0 160224848 1⁄2" 1⁄2" 30,0 26 - 160226848 3⁄4" 1⁄2" 30,0 30 14,5 160226868 3⁄4" 3⁄4" 32,0 32 - 160228868 1" 3⁄4" 41,0 40 17 160228888 1" 1" 45,5 41 - G E G1 A/F G ∅S D Product number E B A E G1 A/F G ∅S min. 19,5 12 7,5 7,5 5,5 1⁄8" 23,5 14 11,0 7,5 5,5 150202828 1⁄4" 1⁄4" 27,6 14 11,0 11,0 6,35 150203818 3⁄8" 1⁄8" 24,0 17 11,5 7,5 150203828 3⁄8" 1⁄4" 27,5 17 11,5 11,0 8,0 8,0 150203838 3⁄8" 3⁄8" 28,0 17 11,5 11,5 11,0 11,0 150204818 1⁄2" 1⁄8" 27,0 22 14,0 7,5 8,0 150204828 1⁄2" 1⁄4" 30,5 22 14,0 11,0 8,0 11,0 150204838 1⁄2" 3⁄8" 31,0 22 14,0 11,5 11,0 10,0 10,0 15,0 150204848 1⁄2" 1⁄2" 33,5 22 14,0 14,0 15,0 12,0 10,0 15,0 150206828 3⁄4" 1⁄4" 37,2 27 19,0 11,1 6,35 53,0 32 14,7 14,7 18,0 150206838 3⁄4" 3⁄8" 38,8 27 19,0 12,7 9,0 1⁄2" 56,7 41 17,5 13,4 14,0 150206848 3⁄4" 1⁄2" 37,5 27 16,0 14,0 15,0 160208868 1" 3⁄4" 58,0 41 17,5 14,7 18,0 150206868 3⁄4" 3⁄4" 40,0 27 16,5 16,5 19,0 160208888 1" 1" 60,8 41 17,5 17,5 25,0 150208838 1" 3⁄8" 42,8 36 22,1 12,7 9,0 150208848 1" 1⁄2" 46,0 36 22,1 15,9 12,7 150208868 1" 3⁄4" 43,0 34 19,0 16,5 19,0 150208888 1" 1" 45,5 34 19,0 19,0 23,0 2,0 6,0 4,0 2,0 160201818 1⁄8" 1⁄8" 16,5 14 6,0 6,0 5,5 160202818 1⁄4" 1⁄8" 19,0 17 8,0 6,0 5,5 160202828 1⁄4" 1⁄4" 21,0 17 8,0 8,0 8,0 160203828 3⁄8" 1⁄4" 22,0 19 9,0 8,0 160203838 3⁄8" 3⁄8" 23,0 19 9,0 9,0 160204828 1⁄2" 1⁄4" 23,5 24 10,0 8,0 160204838 1⁄2" 3⁄8" 24,5 24 10,0 9,0 160204848 1⁄2" 1⁄2" 25,5 24 160206848 3⁄4" 1⁄2" 27,5 30 160206868 3⁄4" 3⁄4" A 4,0 4,0 14,5 14 ØS B 1⁄8" 150202818 1⁄4" 11,5 8 M5x0,8 BSP – Connector Reducer – Male BSPP x Female BSPP G A BSPT B BSPT D male male thread thread 150201818 1⁄8" M5x0,8 160201805 1⁄8" G1 G Supplied with sealing washers 5,5 5,5 Expander– Male BSPP x Female BSPP A BSPP B BSPP D male female thread thread E A/F G max. 160231805 1⁄8" M5x0,8 10,5 14 6,0 160232805 1⁄4" M5x0,8 13,3 17 7,3 160232818 1⁄4" 1⁄8" 13,0 17 8,0 160233818 3⁄8" 1⁄8" 14,0 19 9,0 160233828 3⁄8" 1⁄4" 14,0 19 9,0 160234818 1⁄2" 1⁄8" 15,5 24 160234828 1⁄2" 1⁄4" 15,5 160234838 1⁄2" 3⁄8" 160236828 3⁄4" 160236838 3⁄4" 160236848 3⁄4" D E ØS Product number Product number A BSPP B BSPP D male female thread thread E G1 A/F ∅S G min. 14,5 14 4,0 2,0 160231828 1⁄8" 1⁄4" 19,5 17 6,0 5,5 9,5 160231838 1⁄8" 3⁄8" 21,0 22 6,0 5,5 10,5 160232838 1⁄4" 3⁄8" 22,5 22 8,0 8,0 10,5 160232848 1⁄4" 1⁄2" 26,0 26 8,0 8,0 13,0 10,0 160232868 1⁄4" 3⁄4" 32,8 32 7,3 6,5 16,3 24 10,0 160233848 3⁄8" 1⁄2" 27,0 26 9,0 11 13,0 15,5 24 10,0 160233868 3⁄8" 3⁄4" 34,2 32 8,7 9,5 16,3 1⁄4" 23,0 32 14,2 160234868 1⁄2" 3⁄4" 37,8 32 11,75 13,6 16,3 3⁄8" 17,5 30 12,0 1⁄2" 17,5 30 12,0 B 160230518 M5x0,8 1⁄8" A E G M5x0,8 160200505 M5x0,8 160208848 1" D E A/F Nipple – Male BSPT Product number B ØS A G1 D 1⁄8" Nipple – Male BSPP E B BSPP female thread 160221805 Supplied complete with locknut D A BSPP female thread 160220505 M5x0,8 B Product number E A D Sleeve - Female BSPP G1 G 7,4 Supplied with sealing washers Supplied with sealing washers 05/98 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/AL 9.8.001.03 Nickel Plated BSP & Hose Fittings Adaptor- Female NPTF to Male BSPT Product number D B G A H ∅D E A B BSPT C NPTF thread thread ∅G H A/F F Product number C E F ∅D A B NPTF C BSPP thread thread E ∅G H A/F F 154231818 1⁄8" 1⁄8" 27,5 4,75 9,50 2,0 10,7 15,0 172232828 1⁄4" 1⁄4" 33,5 7,60 14,3 2,0 17,7 19,O 154232828 1⁄4" 1⁄4" 36,0 7,60 11,10 2,0 13,7 19,0 172233838 3⁄8" 3⁄8" 33,5 9,60 14,3 2,0 16,7 24,0 154233838 3⁄8" 3⁄8" 38,0 9,60 12,70 2,0 16,7 22,0 172234848 1⁄2" 1⁄2" 44,0 12,70 19,0 2,0 21,7 27,0 154234848 1⁄2" 1⁄2" 47,0 12,70 15,90 2,0 21,7 27,0 154236868 3⁄4" 3⁄4" 50,0 17,45 19,05 2,0 26,7 36,0 D B G E F A C Gauge Adaptor Female BSPP to Male NPTF H Hexagon Nipple - Male NPTF to Male BSPT C H B G D A ∅G A NPTF thread B BSPT thread C 154201818 1⁄8" 1⁄8" 154202828 1⁄4" 1⁄4" 154203838 3⁄8" 3⁄8" 154204848 1⁄2" 1⁄2" 46,5 12,70 19,0 15,90 21,7 2,0 22,0 154206868 3⁄4" 3⁄4" 47,5 17,45 19,0 19,05 26,7 2,0 27,0 F E ∅D Product number E F H J 27,0 4,75 9,5 9,50 10,7 2,0 3,50 7,60 14,3 11,10 13,7 2,0 14,0 37,0 9,60 14,3 12,70 16,7 2,0 17,0 11,0 J Adaptor Fittings - Allow connection between components and system using BSP or NPT threads BSP Connector Reducer – Male BSPT x Female BSPP 1⁄8" 1⁄4" 22,0 17 7,5 5 9,5 150231838 1⁄8" 3⁄8" 22,5 22 7,5 5 10,5 11,0 5,5 7,4 150232828 1⁄4" 1⁄4" 26,0 17 11,0 8,0 9,5 150231848 1⁄8" 1⁄2" 31,0 27 8,6 5 15,0 150233818 3⁄8" 1⁄8" 16,5 17 11,5 5,5 7,4 150232838 1⁄4" 3⁄8" 27,0 22 11,0 8 10,5 150233828 3⁄8" 1⁄4" 16,5 17 11,5 8,0 9,5 150232848 1⁄4" 1⁄2" 30,0 26 11,0 8 13,0 3⁄8" 3⁄8" 27,5 22 11,5 11,0 10,5 150232868 1⁄4" 3⁄4" 37,3 32 11,1 7 16,3 150234818 1⁄2" 1⁄8" 19,5 22 14,0 5,5 7,4 150233848 3⁄8" 1⁄2" 30,5 26 11,5 11 13,0 150234828 1⁄2" 1⁄4" 19,5 22 14,0 8,0 9,5 150233868 3⁄8" 3⁄4" 38,3 32 12,7 11 16,3 150234838 1⁄2" 3⁄8" 19,5 22 14,0 11,0 10,5 150234868 1⁄2" 3⁄4" 35,0 32 14,0 15 14,5 1⁄2" 1⁄2" 33,0 26 14,0 15,0 13,0 150236888 3⁄4" 1" 47,5 41 19,05 18 19,0 150236828 3⁄4" 1⁄4" 29,5 27 19,05 11,5 11,0 150236838 3⁄4" 3⁄8" 23,5 27 16,5 11,0 10,5 150236848 3⁄4" 1⁄2" 23,5 27 16,5 15,0 13,0 150238838 1" 3⁄8" 34,5 35 22,1 15,0 11,4 150238848 1" 1⁄2" 26,5 34 19,0 15,0 13,0 150238868 1" 3⁄4" 26,5 34 19,0 19,0 16,5 Product number A BSPT B BSPP E G1 G J1 J male female A/F min. thread thread ∅S 150430018 1⁄8" 1⁄8" 12 8 7,0 21 18,5 5,5 150430028 1⁄4" 1⁄4" 13 11 9,5 25,5 24 150430038 3⁄8" 3⁄8" 16 11,5 11,5 28 27 150430048 1⁄2" 1⁄2" 20 14 150430068 3⁄4" 3⁄4" 27 14,5 14,5 36,5 32 5,5 7,4 G min. J ∅S 7,0 21 5,5 13 9,5 25,5 8 160420048 1⁄2" 160420068 3⁄4" 20 27 11,5 15,0 14,5 28 32 36,5 E B 12 160420028 1⁄4" 16 J1 G 160420018 1⁄8" 160420038 G G1 Elbow – Male BSPT x Female BSPP A BSPP E female A/F thread 3⁄8" B 7,5 A 20,0 14 11 15 G1 ØS 150231828 16,0 14 Product number A A BSPT B BSPP D male female thread thread 1⁄8" Elbow – 2 x Female BSPP G E G1 ∅S G A/F min. min. Product number 1⁄8" 150234848 J E 1⁄4" 150233838 E D J G E G1 ∅S G A/F min. min. A BSPT B BSPP D male female thread thread 150231818 1⁄8" 150232818 B A ØS E ØS Product number D G1 Expander – Male BSPT x Female BSPP 19 A 8 11 13,0 32 29,5 15 19 ØS N/AL 9.8.001.04 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 05/98 Nickel Plated BSP & Hose Fittings Tee – 3 x Female BSPP Elbow – 2 x Male BSPT D ∅S Product number A BSPT male thread E A/F G J 150400018 1⁄8" 12 7,5 18,5 6 150400028 1⁄4" 13 11 24 8 150400038 3⁄8" 16 12 27 11 150400048 1⁄2" 20 14 29,5 15 E A ØS J J G J E G A Product number A BSPP D female thread E A/F G min. J ∅S 160620018 1⁄8" 39 12 7,4 19,5 6 160620028 1⁄4" 49 13 9,5 24,5 8 160620038 3⁄8" 54 16 10,5 27 11 160620048 1⁄2" 64 20 13,0 29 15 160620068 3⁄4" 73 27 14,5 36,5 19 ØS Tee – 3 x Male BSPT Product number A BSPT D male thread E A/F G J ∅S 150600028 1⁄4" 13 11 23 8 D E 46 Product number D E J G J1 G1 J A A ØS ØS J Tee – 2 x Female BSPP x Male BSPT Leg G A BSPP B BSPT D E G1 G J1 female male A/F min. thread thread J ∅S 150690018 1⁄8" 1⁄8" 39 12 8 8,5 17,5 19,5 6 150690028 1⁄4" 1⁄4" 49 13 11 11 23 150690038 3⁄8" 3⁄8" 54 16 11,5 12 25,5 27 11 150690048 1⁄2" 1⁄2" 64 20 14 15 29 32 15 3⁄4" 3⁄4" 73 27 14,5 16,5 32 36,5 19 150690068 24,5 8 B Cross – 4 x Female BSPP Product number A BSPP female thread D G J ∅S 160920018 1⁄8" 39 8,5 19,5 6 160920028 1⁄4" 50 11 25 8 160920038 3⁄8" 56 12 28 11 160920048 1⁄2" 64 15 32 15 Product number A G D C A ØS J Plug – Male BSPP E D B A B C BSPP D male thread A/F E 160050005 8,0 4,5 M5 8 - 160050018 10,0 6,5 1⁄8" 14 13,4 160050028 13,0 9 1⁄4" 17 17,6 160050038 13,5 9,5 3⁄8" 19 20,9 160050048 14,5 10 1⁄2" 24 26,4 160050068 16 11 3⁄4" 30 32,4 160050088 17 12 1" 40 38,9 Ø Supplied with sealing washer Plug – Male BSPT A D G 05/98 E Product number A BSPT male thread D E G 150050018 1⁄8" 14,5 10 9,5 150050028 1⁄4" 16,5 14 11,1 150050038 3⁄8" 19 17 12,7 150050048 1⁄2" 22,5 22 15,9 150050068 3⁄4" 27 27 19,05 150050088 1" 30 36 22,1 A/F Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/AL 9.8.001.05 Nickel Plated BSP & Hose Fittings Hose Adaptor Metric I/D Hose Bore x Male BSPT ∅S min. 19,5 3,2 D ØA ØS L ∅S min. Product number A B BSPT D hose male bore thread E G A/F L 301170318 3⁄16" 1⁄8" 36 10 8,3 22,5 4,2 301170328 3⁄16" 1⁄4" 41 14 12,3 22,5 4,2 301170418 1⁄4" 1⁄8" 36 10 8,3 22,5 5,35 14 12,3 22,5 5,35 1⁄8" 291170618 6 1⁄8" 32,0 12 7,5 19,5 3,2 291170628 6 1⁄4" 35,5 14 11,0 19,5 3,2 291170638 6 3⁄8" 42,5 17 14,3 22,5 5,0 301170428 1⁄4" 1⁄4" 41 291170718 7 1⁄8" 32,0 12 7,5 19,5 5,0 301170438 1⁄4" 3⁄8" 42,5 17 14,25 22,5 5,35 291170728 7 1⁄4" 35,5 14 11,0 19,5 6,0 301170448 1⁄4" 1⁄2" 45,5 22 16,8 22,5 5,35 291170738 7 3⁄8" 36,0 17 11,5 19,5 6,0 301170518 5⁄16" 1⁄8" 36 12 8,3 22,5 5 291170828 8 1⁄4" 35,5 14 11,0 19,5 7,5 301170528 5⁄16" 1⁄4" 41 14 12,3 22,5 7 291170838 8 3⁄8" 36,0 17 11,5 19,5 7,5 301170618 3⁄8" 1⁄8" 36 12 8,3 22,5 5 291170918 9 1⁄8" 36,0 13 8,3 22,5 5,0 301170628 3⁄8" 1⁄4" 41 14 12,3 22,5 7 291170928 9 1⁄4" 41,0 14 12,3 22,5 7,6 301170638 3⁄8" 3⁄8" 42,5 17 14,25 22,5 8,33 291170938 9 3⁄8" 42,5 17 14,25 22,5 7,6 301170648 3⁄8" 1⁄2" 45,5 22 16,8 22,5 8,33 291170948 9 1⁄2" 45,5 22 16,8 22,5 7,6 301170728 1⁄2" 1⁄4" 48,5 17 12,3 29,5 7 291171018 10 1⁄8" 36,0 13 8,3 22,5 8,8 301170738 1⁄2" 3⁄8" 49,5 17 14,25 29,5 10,7 291171028 10 1⁄4" 35,5 14 11,0 19,5 7,5 301170748 1⁄2" 1⁄2" 52,5 22 16,8 29,5 10,7 291171038 10 3⁄8" 36,0 17 11,5 19,5 7,5 301170768 1⁄2" 3⁄4" 55,0 27 18,5 29,5 10,7 291171238 12 3⁄8" 36,0 17 11,5 19,5 9,5 301170848 5⁄8" 1⁄2" 61,0 22 16,8 38,0 14,0 291171328 13 1⁄4" 48,5 16 12,3 7,0 301170868 5⁄8" 3⁄4" 63,5 27 18,5 38,0 14,5 291171338 13 3⁄8" 49,5 17 14,25 29,5 11,0 301170948 3⁄4" 1⁄2" 61,0 22 16,8 38,0 14,0 291171348 13 1⁄2" 52,5 22 16,8 29,5 11,0 301170968 3⁄4" 3⁄4" 63,5 27 18,5 38,0 17,5 291171368 13 3⁄4" 55,0 27 18,5 29,5 11,0 301170988 3⁄4" 291171638 16 3⁄8" 36,0 19 11,5 19,5 11 301171088 1" 291171648 16 1⁄2" 39,0 22 14,0 19,5 12,5 291171668 16 3⁄4" 43,5 27 16,5 19,5 14,5 291171938 19 3⁄8" 58,5 22 14,25 38,0 11,0 291171948 19 1⁄2" 61,0 22 16,8 38,0 14,0 291171968 19 3⁄4" 63,5 27 18,5 38,0 17,5 291172568 25 3⁄4" 63,5 27 18,5 38,0 18,0 291172588 25 1" 67,5 35 21,4 38,0 22,0 291173288 32 1" 72,5 35 21,4 43,0 24,0 Product number B G D 291170418 4 32,0 12 7,5 29,5 Hose Adaptor – Metric I/D Hose Bore x Male BSPP E E ØA L A B BSPP D hose male bore thread G L 1" 67,5 35 21,4 38,0 17,55 1" 67,5 35 21,4 38,0 22,4 3011711A8 11⁄4" 11⁄4" 80,0 42 24,7 43,0 29,25 3011712B8 11⁄2" 11⁄2" 80,0 50 24,7 43,0 36,0 Swivel Hose Adaptor – Imperial I/D x Female BSPP E G A/F L ∅S min. D E ØA ØS L E G A/F B ØA ØS B G A B BSPT D hose male bore thread ØS Product number D E G A/F L ∅S min. Product number A B BSPP D hose female bore thread 302180418 1⁄4" 1⁄8" 32,3 13 4,6 302180428 1⁄4" 1⁄4" 34,8 17 6,0 22,5 5,35 302180438 1⁄4" 3⁄8" 35,8 22 6,0 22,5 5,35 292170203 2,5 M3 14,0 5 3,5 7,5 1,8 292170305 3 M5x0,8* 15,6 8 3,5 7,5 2,0 292170318 3 1⁄8" 21,0 14 7,4 7,5 2,0 292170418 4 1⁄8" 36,5 14 7,4 22,5 3,3 302180628 3⁄8" 1⁄4" 34,8 17 6,0 22,5 6,35 292170428 4 1⁄4" 40,5 19 10,0 22,5 3,3 302180638 3⁄8" 3⁄8" 35,8 22 6,0 22,5 8,33 292170518 5 1⁄8" 36,5 14 7,4 22,5 4,0 302180648 3⁄8" 1⁄2" 37,9 27 7,4 22,5 8,33 292170618 6 1⁄8" 36,5 14 7,4 22,5 5,0 302180748 1⁄2" 1⁄2" 44,9 27 7,4 29,5 10,7 292170628 6 1⁄4" 40,5 19 10,0 22,5 5,0 302180768 1⁄2" 3⁄4" 49,9 32 11,9 29,5 10,7 292170638 6 3⁄8" 43,0 22 11,4 22,5 5,0 302180968 3⁄4" 3⁄4" 58,4 32 11,9 38,0 16,5 292170918 9 1⁄8" 36,5 14 7,4 22,5 7,6 292170928 9 1⁄4" 40,5 19 10,0 22,5 7,6 292170938 9 3⁄8" 43,0 22 11,4 22,5 7,6 292170948 9 1⁄2" 47,0 27 15,0 22,5 7,6 292171328 13 1⁄4" 47,5 19 10,0 29,5 11,0 292171338 13 3⁄8" 49,5 22 11,4 29,5 11,0 292171348 13 1⁄2" 54,5 27 15,0 29,5 11,0 292171368 13 3⁄4" 59,5 32 16,3 29,5 11,0 292171968 19 3⁄4" 67,5 32 16,3 38,0 17,5 B E Hose Adaptor Imperial I/D Hose Bore x Male BSPT G L 22,5 4,0 Supplied with sealing washer N/AL 9.8.001.06 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 05/98 Nickel Plated BSP & Hose Fittings Elbow Banjo Assembly Non Regulating Bolt Hose Connector – Imperial A hose bore B G 300140303 3⁄16" 8 300140404 1⁄4" 9 47 22,5 5,35 300140505 5⁄16" 12 47 22,5 7,0 300140606 3⁄8" 13 47 22,5 8,33 300140707 1⁄2" 16 62 29,5 10,7 300140808 5⁄8" 19 79 38,0 14,0 300140909 3⁄4" 23 79 38,0 17,55 28 79 38,0 22,4 D 300141010 1" 22,5 4,2 A 47 Product number ØS E D1 G ØB D ∅S Product number A B D thread thread BSP BSP B D1 E A/F G ØS 16A511818 1/8" 1 29 29 14 5 6,0 16A512828 /4" 1 38 32 17 6 7,6 16A513838 3/8" 3 44 45 22 9,5 9,6 16A514848 1/2" 1 63 47 27 12 9,6 1 G ØS ØA D /8" /4" /8" /2" Female parallel BSP thread to male parallel BSP thread Both ends identical. Elbow Banjo Assembly Regulating Out B 16K511818 16K512828 16K513838 16K514848 A thread BSP 1 /8" 1 /4" 3 /8" 1 /2" B thread BSP 1 /8" 1 /4" 3 /8" 1 /2" D D1 29 38 44 63 34 37 52 58 E G A/F ∅S 14 17 22 27 6,0 7,6 9,6 9,6 D J 5,0 6,0 9,5 12,0 B Banjo Bolt – Non Regulating Single Stacking Product number B thread BSP D1 E A/F ØS E Ø J ØS 160511818 1 1 14,0 28,0 13,0 21 6,0 160512828 1 1 16,0 37,0 16,0 28 7,6 160513838 3 3 20,5 42,0 20,5 31 9,6 160514848 1 1 22.0 61.0 24,7 47 9,6 Product number E /8" /4" /8" /2" /8" /4" /8" /2" B thread BSP D1 E A/F ØS 20B000018 1/8" 44 14 4,5 20B000028 1/4" 50 17 5,5 20A000018 1 29 14 4,5 20A000028 1 33 17 5,5 20A000038 3 41 22 9,2 20B000038 3/8" 62,5 22 9,2 20A000048 1 49 27 10,5 20B000048 1/2" 74 27 10,5 /8" /4" /8" /2" Male parallel BSP thread. All banjo bolts supplied complete with sealing washers. B D Banjo Bolt – Non Regulating Double Stacking D1 D1 ØS A B C thread for BSP BSP bolt Female parallel BSP thread Arrow on bolt hexagon indicates free flow direction. Pressure range 1 -10 bar. E Product number ØS Product number A E A D1 G ØS E C D Elbow Banjo Body ØS Male parallel BSP thread B Banjo Bolt – Regulating Single stacking BSP parallel Bi-Directional Flow Regulating Out D1 E B Product number 20K000018 20K000028 20K000038 20K000048 B thread 1⁄8" 1⁄4" 3⁄8" 1⁄2" D1 34,0 36,5 51,5 57,0 E A/F 14 17 22 27 Product B number thread 20M000018 1⁄8" 20M000028 1⁄4" 20M000038 3⁄8" 20M000048 1⁄2" D1 34,0 36,5 51,5 57,0 E A/F 14 17 22 27 All banjo bolts supplied complete with sealing washers. Arrow on bolt hexagon indicates free flow direction. Pressure range 1 -10 bar. Regulating In Product number 20L000018 20L000028 20L000038 20L000048 05/98 B thread 1⁄8" 1⁄4" 3⁄8" 1⁄2" D1 34,0 36,5 51,5 57,0 E A/F 14 17 22 27 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/AL 9.8.001.07 Nickel Plated BSP & Hose Fittings Flat Union A B ∅E F C G Assembly part number Nom size A O/All Length B Length C Length D A/F Hex Thro’ E ∅ F BSPT thread G A/F Hex 150331818 150332828 150333838 1 /8" /4" 3 /8" 33,3 42,0 43,0 15,0 18,5 19,0 10,0 13,0 13,0 5 8 10 6,0 9,5 12,0 1 1 1 /8" /4" 3 /8" 15 24 27 150334848 1 52,0 23,0 17,5 14 15,0 1 30 150336868 150338888 3 56,5 68,0 25,0 29,0 19,0 23,0 17 19 20,0 24,0 3 38 46 No. of outlets A B thread BSP C D D1 /2" /4" 1" /2" /4" 1" D Single Sided Manifold D Product number B A D1 C A D2 E C ØL U D2 E L U 34 0504 01 4 1 /8" 71 5 81 16,0 25,0 15 5,5 17 34 0504 02 4 1 /4" 99 5 109 23,0 31,0 20 5,5 23 34 0504 03 4 3 115 6 127 25,4 34,9 23 6,5 27 34 0506 01 6 1 105 5 115 16,0 25,0 15 5,5 17 34 0506 02 6 1 145 5 155 23,0 31,0 20 5,5 23 34 0506 03 6 3 169 6 181 25,4 34,9 23 6,5 27 /8" /8" /4" /8" Product is unplated brass 4 Way Block Cross Connector Product number A B C 160940018 1 4,3 4,5 25,0 160940028 1 6,5 5,5 40,0 160940038 3 7,5 5,5 50,0 160940048 1 7,5 5,5 50,0 /8" /4" /8" /2" L Product is aluminium Locknut - Metric E Product number B thread BSP A E A/F Product number B thread BSP A E A/F 360546 01 1⁄8" 4,8 13 360546 02 1⁄4" 6,4 17 340223 01 1⁄8" 0,19 0,53 340223 02 1⁄4" 0,25 360546 03 3⁄8" 6,4 22 0,71 340223 03 3⁄8" 0,25 360546 04 1⁄2" 6,4 0,82 27 340223 04 1⁄2" 0,25 1,01 360546 06 3⁄4" 360546 07 7⁄8" 7,1 32 360546 06 3⁄4" 0,28 1,30 7,9 36 340223 07 7⁄8" 0,31 360546 08 1,48 1" 8,7 41 340223 08 1" 0,34 1,67 360546 09 11⁄4" 8,7 50 Product is unplated brass 360546 10 11⁄2" 9,5 55 B A A B Locknut - Inch E Product is unplated brass N/AL 9.8.001.08 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 05/98 Nickel Plated BSP & Hose Fittings Taper plug Brass - unplated E C A Product number A B thread BSPT C 250130018 1⁄8" 8 6 250130028 1⁄4" 10 8 250130038 3⁄8" 11 8 250130048 1⁄2" 13 250130068 3⁄4" 250130088 1" E A/F Product number A thread BSPT B C E A/F 5 250130018FZ 1⁄8" 8 6 5 6 250130028FZ 1⁄4" 10 8 6 8 250130038FZ 3⁄8" 11 8 8 8 10 250130048FZ 1⁄2" 13 8 10 17 11 14 250130068FZ 3⁄4" 17 11 14 19 13 17 19 13 17 B C E B Taper plug Steel - zinc plated A 250130088FZ 1" Warning These products are intended for use in industrial compressed air systems only. Do not use these products where pressures and temperatures can exceed those listed under ‘Technical Data’. Before using these products with fluids other than those specified, for non-industrial applications, life-support systems, or other applications not within published specifications, consult Norgren. Through misuse, age, or malfunction, components used in fluid power systems can fail in various modes. The system designer is warned to consider the failure modes of all component parts used in fluid power systems and to provide adequate safeguards to prevent personal injury or damage to equipment in the event of such failure. System designers must provide a warning to end users in the system instructional manual if protection against a failure mode cannot be adequately provided. System designers and end users are cautioned to review specific warnings found in instruction sheets packed and shipped with these products where applicable. 05/98 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/AL 9.8.001.09
150234828 价格&库存
很抱歉,暂时无法提供与“150234828”相匹配的价格&库存,您可以联系我们找货
    • 1+148.60546
    • 5+145.55420
    • 10+142.50295
    库存:130
