F07-200-M3TG
F07-200-M3TG
    NORGREN(诺冠)
    NORGREN - F07-200-M3TG - Filter, General Purpose, Miniature, 07 Series, 10Bar, G1/4, Transparent Bow...
F07-200-M3TG 数据手册
F07 Miniature Series 07 General Purpose Filter 1/8" and 1/4" Port Sizes ● Compact design ● Protects air operated devices by removing liquid and solids contaminants ● Screw-on bowl reduces maintenance time ● Can be disassembled without the use of tools or removal from the air line Technical Data Ordering Information Fluid: Compressed air Maximum pressure: Transparent bowl: 10 bar (145 psig) Metal bowl: 17 bar (250 psig) Operating temperature:* Transparent bowl: -20° to +50°C (0° to +125°F) Metal bowl: -20° to +80°C (0° to +175°F) See Ordering Information on the following pages. * Air supply must be dry enough to avoid ice formation at temperatures below +2°C (+35°F) Particle removal: 5 µm or 40 µm filter element Air quality: Within ISO 8573-1, Class 3 and Class 5 (particulates) Typical flow at 6,3 bar (90 psig) inlet pressure at 0,3 bar (5 psig) pressure drop: 1/8" Ports, 5 µm element: 9 dm3/s (19 scfm) 1/4" Ports, 5 µm element:11,5 dm3/s (24 scfm) Nominal bowl size: 31 ml (1 oz) Drain connection: 1/8" pipe Automatic drain operation: Spitter type drain operates momentarily when a rapid change in air flow occurs or when the supply pressure is reduced. Materials: Body: Zinc Bowl: Transparent: Polycarbonate Metal: Zinc Element: Sintered polypropylene Elastomers: Neoprene & nitrile 1/97 ISO Symbols Automatic drain Our policy is one of continuous research and development. We reserve the right to amend, without notice, the specifications given in this document. Manual drain N/AL.8.300.100.01 F07 Typical Performance Characteristics bar g psig FLOW CHARACTERISTICS PORT SIZE: 1/4" 40 µm ELEMENT 0,8 INLET PRESSURE: bar g (psig) 1,6 2,5 4,0 6,3 8 10 (23) (36) (58) (91) (116) (145) OUTLET PRESSURE 10 1 (14) 0,6 8 6 0,4 4 0,2 2 0 0 0 0 4 8 8 16 12 24 16 20 32 40 dm3/s 48 scfm AIR FLOW Ordering Information. Models listed include ISO G threads, automatic drain, transparent bowl and 40 µm element. Port Size G1/8 G1/4 Model Numbers F07-100-A3TG F07-200-A3TG Flow dm3/s (scfm) * 9 (19) 11,5 (24) Weight kg (lbs) 0.13 (0.28) 0.13 (0.28) * Approximate flow at 6.3 bar (90 psig) inlet pressure and 0.3 bar (5 psig) pressure drop. Alternative Models F 0 7 - ★★ ★ - ★★★★ Port Size 1/8" 1/4" Substitute 1 2 Threads PTF ISO Rc taper ISO G parallel Substitute A B G Option Not applicable Substitute 0 Bowl Transparent Metal Substitute T M Option Not applicable Substitute 0 Element 5 µm 40 µm Substitute 1 3 Drain Automatic Manual Substitute A M Accessories Wall Mounting Bracket and Body Screws 5939-06 N/AL.8.300.100.02 Our policy is one of continuous research and development. We reserve the right to amend, without notice, the specifications given in this document. 1/97 F07 Dimensions mm (inches) 4 (0.157) Dia ** 13 (0.5) Deep ** 23 (0.91) 37 (1.45) 42 (1.63) 10 (0.38) Manual Drain 104 (4.10) 154 (6.07) * 108 (4.25) 158 (6.22) * 10 (0.38) 23 19 (0.91) (0.73) Automatic Drain * Minimum clearance to remove bowl. ** Mounting holes. Bracket Mounting Bracket Kit Reference Use 1/8" (3mm) screws to mount bracket to wall. Part Number 5939-06 52 (2.06) 34 (1.34) Item All models 38 (1.50) 35 (1.39) 43 (1.71) 7 (0.29) 6 (0.22) 24 (0.93) Service Kits Item Type 5 µm element Service kit 40 µm element Manual Replacement drains Automatic Part number 3652-17 3652-18 773-03 3654-02 Service kit includes element, element gasket, and bowl o-ring. 1/97 Our policy is one of continuous research and development. We reserve the right to amend, without notice, the specifications given in this document. N/AL.8.300.100.03 F07 Warning These products are intended for use in industrial compressed air systems only. Do not use these products where pressures and temperatures can exceed those listed under ‘Technical Data’. Before using these products with fluids other than those specified, for non-industrial applications, life-support systems, or other applications not within published specifications, consult NORGREN. Through misuse, age, or malfunction, components used in fluid power systems can fail in various modes. The system designer is warned to consider the failure modes of all component parts used in fluid power systems and to provide adequate safeguards to prevent personal injury or damage to equipment in the event of such failure. System designers must provide a warning to end users in the system instructional manual if protection against a failure mode cannot be adequately provided. System designers and end users are cautioned to review specific warnings found in instruction sheets packed and shipped with these products. Water vapor will pass through these units and will condense into liquid if air temperature drops in the downstream system. Install an air dryer if water condensation could have a detrimental effect on the application. N/AL.8.300.100.04 Our policy is one of continuous research and development. We reserve the right to amend, without notice, the specifications given in this document. 1/97
F07-200-M3TG 价格&库存
很抱歉,暂时无法提供与“F07-200-M3TG”相匹配的价格&库存,您可以联系我们找货
F07-200-M3TG
  • 1+489.35662
库存:30
