10TA00618
10TA00618
    NORGREN(诺冠)
10TA00618 数据手册
PNEUFIT 10 series Push-in fittings >> Port size: Ø 4 ... 14 mm O/D tube, BSP threads >> Very compact units >> Easy tube insertion for rapid assembly of pneumatic circuits >> Straight adaptors feature internal hexagon for allen key >> VMQ free ‘O’-rings >> Positive tube anchorage >> All BSP taper threads pre-coated with nonPTFE based sealant Technical features Medium: Compressed air (For other media please consult Technical Department) Operating pressure: Vacuum -18 bar (... 261 psi) (Dependent upon operating specification of tubing) Vacuum: -750 mm of Hg i.e. 98% Ambient/Media temperature: -20°C ... +80°C ( -4 ... 176 °F) “Special” low temperature options contact Norgren Technical service Tube sizes: 4, 5, 6, 8, 10, 12, 14 mm O/D Tubing types: PA 11 or 12, PUR and other plasticised or unplasticised tubing which conforms to the tolerances specified in BS 5409, Part 1, 1976, light and normal duty, DIN 73378, DIN 74234, NFE 49-100 Materials: Nickel plated brass body Nickel plated brass for collet VMQ free NBR 'O'-ring (FPM optional) Plastic sealing washer (parallel threads) Non - PTFE thread sealant (taper threads) 2. Push the tube through the collet into the fitting. 3. C  ontinue pushing the tube through the ‘O’-ring until it bottoms on the tube stop then pull back. 4. T  o disconnect push the tube into the fitting, hold down the collet and withdraw the tube. Method of assembly 90˚ 1. Ensure that the end of the tube is cut square and is free from burrs. Components 1 3 1 2 3 4 4 Collet Body Tube stop ‘O’-ring 2 Option selector 10 ˙˙˙˙˙˙˙ Thread type Thread size/tube size Shape Thread size/tube size Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd. 3/15 en 9.1.060.01 PNEUFIT 10 series Push-in fittings Straight adaptors and connectors Stem tailpiece adaptor (stem to hose bore) 10019 Straight connector (tube to tube) 10020 Straight stem connector 10022 Reducing/expanding connector 10023 Bulkhead connector (tube to tube) 10029 Mixed bulkhead connector 10031 Straight stem adaptor (BSP taper) 10115 Page 3 Page 3 Page 3 Page 3 Page 4 Page 4 Page 4 Straight stem adaptor (BSP parallel) 10215 Straight adaptor (BSP taper) 10125 Straight adaptor (BSP parallel) 10225 Female straight adaptor (female parallel BSP) 10226 Page 4 Page 5 Page 5 Page 5 Elbow adaptors, connectors and banjos Elbow connector 10040 Stem elbow connector 10043 Bulkhead swivel elbow connector 10049 Elbow adaptor (BSP taper) 10145 90° Swivel elbow adaptor (BSP taper) 10147 90° Swivel elbow adaptor (BSP parallel) 10247 Extended swivel elbow adaptor (BSP taper) 10154 Page 6 Page 6 Page 6 Page 6 Page 7 Page 7 Page 7 45° Swivel elbow adaptor (BSP parallel) 10257 Elbow banjo assembly (non-Regulating BSP parallel) 10A51 Elbow banjo assembly (regulating-out BSP parallel) 10K51 Elbow banjo assembly (regulating-out BSPT taper) 10T00 Elbow banjo assembly (regulating-out BSPT taper) 10TA0 Page 7 Page 8 Page 8 Page 8 Page 8 Tee adaptors, connectors and banjos, ‘Y’ adaptors and connectors, 4-way connectors, manifolds Tee connector (tube x 3) 10060 Tee adaptor (BSP taper) 10165 Swivel tee adaptor (BSP taper) 10167 Swivel tee adaptor (BSP parallel) 10267 Tee banjo assembly (non-regulating parallel thread) 10A71 Fixed side tee adaptor (BSP taper) 10175 Swivel tee adaptor (BSP taper) 10168 Page 9 Page 9 Page 9 Page 9 Page 10 Page 10 Page 10 Swivel tee adaptor (BSP parallel) 10268 4-way connector (tube x 4) 10090 Parallel Y-connector 10082 Parallel Y-adaptor 10188 Parallel Y-adaptor 10288 Manifold 100D6 Manifold 101D6 Page 10 Page 11 Page 11 Page 11 Page 11 Page 12 Page 12 Banjo bodies and bolts Elbow banjo body Tee banjo body 10051 Page 12 en 9.1.060.02 10071 Banjo bolt (non-regulating single stacking) 20A00 Banjo bolt (non-regulating double stacking BSP parallel) 20B00 Banjo bolt (non-regulating triple stacking BSP parallel) 20C00 Banjo bolt (non-regulating single stacking, top port BSP parallel) 20*00 Banjo bolt (regulating single stacking) 20*00 Page 12 Page 13 Page 13 Page 13 Page 13 Page 13 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd.  3/15 PNEUFIT 10 series Push-in fittings Accessories Page 14 Page 14 C Technical data ØK 4 2,8 14 7,5 10 5 3,4 15 10 11 6 4,4 15,5 11 12 T øS V 6 16,5 13 14 7,6 21 14,5 17 12 9,6 24,5 18 20,5 14 11,5 24,5 20 21 øK C ØK Model 4 30 10 100200400 5 32 11 100200500 6 33,5 12 100200600 8 35,5 14 100200800 10 44,5 17 100201000 12 51,5 20,5 100201200 14 52,5 21 100201400 Reducing/expanding connector 10023 C øA 8 10 øK Ø T*1) øV Ø S*2) øA ØA O/D tube ØA øK *1) Dimensions here and in the individual tables refer to the collet being in the ‘IN’ position. ø A1 Plug (acetal) 11004 øA Silencer (plug in) 10011 Dimensions in mm Projection/First angle Straight connector, tube to tube 10020 *2) Dimensions here (minimum bore diameter) are common per tube size for all Connectors, elbows and Tees unless otherwise stated. ø A1 øA øS C ø A2 Stem tailpiece adaptor, stem to hose bore 10019 ØA Ø A1 Ø A2 C ØS Model 4 4,5 3 34 1,8 100190403 4 6,5 5 34 2,1 100190405 5 6,5 5 35,5 2,8 100190505 6 6,5 5 36 2,8 100190605 6 8 6,5 36 4 100190606 8 8 6,5 37 4,3 100190806 8 9,5 8 38,5 5,5 100190808 10 8 6,5 41,5 4,3 100191006 10 9,5 8 43 5,5 100191008 10 12 10 44 7,3 100191010 12 9,5 8 46,5 5,5 100191208 12 12 10 46,5 7,3 100191210 12 15 12,5 47,5 9,7 100191212 14 15 12,5 47 9,7 100191412 ØA Ø A1 C ØK Model 5 4 33,5 10 100230504 6 4 34 10 100230604 6 5 35 11 100230605 8 4 31 10 100230804 8 5 33 11 100230805 8 6 36,5 12 100230806 10 4 31 12 100231004 10 5 36,5 12 100231005 10 6 37,5 12 100231006 10 8 38 14 100231008 12 4 35 14 100231204 12 5 35 14 100231205 12 6 35 14 100231206 12 8 42 14 100231208 12 10 50 17 100231210 14 6 36,5 16 100231406 14 8 37,5 16 100231408 14 10 46,5 17 100231410 14 12 53,5 20,5 100231412 øA C øK øA øS C ø A1 Reducing/expanding connector 10023 Straight stem connector 10022 ØA C ØS Model ØA Ø A1 C ØK Model 4 30 2,6 100220400 4 6 35 12 100230406 6 8 37,5 14 100230608 5 33 3,4 100220500 6 34 4 100220600 8 36 6 100220800 10 45 7,6 100221000 12 52 9,6 100221200 14 52 11,5 100221400 3/15 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd. en 9.1.060.03 PNEUFIT 10 series Push-in fittings Bulkhead connector, tube to tube 10029 Dimensions in mm Projection/First angle Mixed bulkhead connector 10031 C C B O øA B øA øA1 1 P O P E ØA B C O P Model Ø A & Ø A1 B C E O P 4 M10x1,0 30 12 9 14 100290400 4 M12x1,0 27 6 9,5 9 8 17 100310404 5 M12x1,0 32 14 9 17 100290500 6 M15x1,0 29,5 7 9,5 10 13 22 100310606 6 M14x1,5 35,5 15 10 19 100290600 8 M18x1,5 33,5 8 11 10 13 24 100310808 8 M16x1,5 36,5 16 10 22 100290800 10 M20x1,5 40 8 14,5 11 17 27 100311010 10 M20x1,5 43,5 14 11 27 100291000 12 M24x1,5 44 9 17,5 11 19 30 100311212 12 M24x1,5 50,5 15 11 30 100291200 14 M26x1,5 46 11,5 18,5 11 22 32 100311414 14 M24x1,5 50,5 15 11 30 100291400 Straight stem adaptor, BSP taper 10115 1 Model Straight stem adaptor, BSP parallel 10215 C C øS øS B øA B øA øK1 G G ØA B C G ØS Model ØA B C G Ø K1 ØS 4 R1/8 30 7,5 2,1 10 101150418 4 G1/8 29 5 13,5 2,1 8 102150418 4 R1/4 33,5 11 2,1 14 101150428 4 G1/4 33 7,5 17,5 2,1 10 102150428 5 R1/8 31 7,5 3,2 11 101150518 5 G1/8 30,5 5 13,5 3,3 8 102150518 5 R1/4 35 11 3,2 14 101150528 5 G1/4 34 7,5 17,5 3,3 10 102150528 6 R1/8 32 7,5 4,1 12 101150618 6 G1/8 31 5 13,5 4 8 102150618 6 R1/4 35 11 4,1 14 101150628 6 G1/4 34,5 7,5 17,5 4 10 102150628 8 R1/8 33 7,5 7,1 14 101150818 8 G1/8 32,5 5 13,5 5 10 102150818 8 R1/4 36,5 11 5,1 14 101150828 8 G1/4 35,5 7,5 17,5 6 10 102150828 8 R3/8 40 12,5 5,1 19 101150838 8 G3/8 39 9 21,5 6 13 102150838 10 R1/4 40 11 7,7 15 101151028 10 G1/4 41,5 7,5 17,5 6,5 13 102151028 10 R3/8 45 12,5 7,7 19 101151038 10 G3/8 43,5 9 21,5 8 13 102151038 10 R1/2 48 16 8,1 22 101151048 10 G1/2 49 12 25,5 8 17 102151048 12 R3/8 48 12,5 9,1 19 101151238 12 G3/8 48,5 9 21,5 10 17 102151238 12 R1/2 51,5 16 9,1 22 101151248 12 G1/2 52,5 12 25,5 10 17 102151248 14 R1/2 51,5 16 11,2 22 101151448 14 G3/8 48,5 9 21,5 10 17 102151438 14 G1/2 52,5 12 25,5 11,5 17 102151448 en 9.1.060.04 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd.  Model 3/15 PNEUFIT 10 series Push-in fittings Straight adaptor, BSP parallel 10225 Dimensions in mm Projection/First angle Straight adaptor, BSP taper 10125 C G G B øA øK C G B øA C B øA ø K1 1 1 ØA B C G ØK Ø K1 Model ØA B C G 4 M3 21 2,5 9 – – 1,5 102250403 4 R1/8 20,5 10 4 M5 21,5 3,5 9 – – 2,5 102250405 4 R1/4 23 11 14 3 101250428 4 G1/8 19 5,5 – 14 10 3 102250418 5 R1/8 22,5 7,5 10 4 101250518 4 G1/4 21 8 – 18 10 3 102250428 5 R1/4 23 11 14 4 101250528 5 M5 23 3,5 10 – – 2,5 102250505 6 R1/8 23 7,5 11 4 101250618 5 G1/8 23,5 5,5 – 14 10 4 102250518 6 R1/4 25 11 14 4 101250628 5 G1/4 22,5 8 – 18 12 4 102250528 8 R1/8 26,5 7,5 13 5 101250818 6 M5 24 3,5 11 – – 2,5 102250605 8 R1/4 28 11 14 6 101250828 6 G1/8 25 5,5 – 14 11 4 102250618 8 R3/8 27 12,5 17 6 101250838 6 G1/4 23,5 8 – 18 13 4 102250628 8 R1/2 29 16 22 6 101250848 8 G1/8 26,5 5,5 – 14 13 5 102250818 10 R1/8 31,5 7,5 17 5 101251018 8 G1/4 28 8 – 18 14 6 102250828 10 R1/4 34 11 17 7 101251028 8 G3/8 24,5 9 – 12 17 6 102250838 10 R3/8 34 12,5 17 8 101251038 8 G1/2 28,5 11 – 26 17 6 102250848 10 R1/2 33,5 16 22 8 101251048 10 G1/8 32 5,5 – 14 17 5 102251018 12 R1/4 39 11 22 7 101251228 10 G1/4 33,5 8 – 18 17 7 102251028 12 R3/8 39 12,5 22 10 101251238 10 G3/8 32,5 9 – 22 19 8 102251038 12 R1/2 40 16 22 10 101251248 10 G1/2 30,5 11 – 26 19 8 102251048 14 R3/8 39,5 12,5 22 10 101251438 12 G1/4 36,5 8 – 18 22 7 102251228 14 R1/2 40 16 22 10 101251448 12 G3/8 37,5 9 – 22 22 10 102251238 12 G1/2 34,5 11 – 26 22 10 102251248 14 G3/8 37,5 9 – 22 22 10 102251438 14 G1/2 38,5 11 – 26 22 10 102251448 1 Model 1 10 3 101250418 Female straight adaptor, female parallel BSP 10226 B øA C G 3/15 ØA B C G 4 M5 22,5 5 10 102260405 4 G1/8 24,5 7,5 13 102260418 4 G1/4 29 5 17 102260428 5 M5 23,5 7,5 10 102260505 5 G1/8 25,5 7,5 13 102260518 5 G1/4 29,5 7,5 17 102260528 6 G1/8 26 11 13 102260618 6 G1/4 30,5 11 17 102260628 8 G1/8 27 11 13 102260818 8 G1/4 31,5 11 17 102260828 10 G1/4 36,5 11 17 102261028 10 G3/8 39 11,5 19 102261038 12 G3/8 41 11,5 19 102261238 12 G1/2 44,5 15 24 102261248 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd. Model en 9.1.060.05 PNEUFIT 10 series Push-in fittings Elbow connector 10040 Dimensions in mm Projection/First angle Stem elbow connector 10043 C E C øA øA C øA ø A1 ØA C Model ØA Ø A1 C E Model 4 17 100400400 4 4 9,5 25 100430400 5 18,5 100400500 6 6 19 27,5 100430600 6 19,5 100400600 8 8 21 29,5 100430800 8 21,5 100400800 8 5 19,5 30 100430805 10 26,5 100401000 12 31,5 100401200 14 33 100401400 Elbow adaptor, BSP taper 10145 C G C E G øA E øA øK Bulkhead swivel elbow connector 10049 G1 B øA øB ØA ØB C E G G1 ØK Model ØA B C E G 4 M12x1,0 35,5 20,5 21,5 7 10 17 100490400 4 R1/8 15 17 7,5 7 101450418 5 M12x1,0 35,5 21,5 21,5 7 11 17 100490500 4 R1/4 20 18 11 11 101450428 6 M14x1,5 40 24 24,5 7 12 19 100490600 5 R1/8 15,5 18,5 7,5 7 101450518 8 M16x1,5 45 26,5 30 7 14,5 22 100490800 5 R1/4 20 20 11 11 101450528 10 M22x1,5 49 31,5 31 9 17 27 100491000 6 R1/8 16 19,5 7,5 8 101450618 12 M24x1,5 54 38 32,5 12 20,5 30 100491200 6 R1/4 20 20 11 11 101450628 14 M26x1,5 57 38 32,5 15 22,5 32 100491400 8 R1/8 17 21,5 7,5 11 101450818 8 R1/4 20 21,5 11 11 101450828 8 R3/8 23 22 12,5 13 101450838 8 R1/2 29 24 16 17 101450848 10 R1/8 18,5 26,5 7,5 13 101451018 10 R1/4 21,5 26,5 11 13 101451028 10 R3/8 23 26,5 12,5 13 101451038 10 R1/2 29 28,5 16 17 101451048 12 R1/4 23,5 31,5 11 16 101451228 12 R3/8 25 31,5 12,5 16 101451238 12 R1/2 29 32 16 17 101451248 en 9.1.060.06 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd.  Model 3/15 PNEUFIT 10 series Push-in fittings 90o Swivel elbow adaptor, BSP taper 10147 Dimensions in mm Projection/First angle 90o Swivel elbow adaptor, BSP parallel 10247 C C 1 G G E E øA øA øK 1 B B øK1 ØA B C E G ØK B C E G Ø K1 R1/8 17 20,5 7,5 10 10 7 1 Model 101470418 ØA 4 4 M3 17 17,5 3,5 – 8 7 1 Model 102470403 4 R1/4 17 24 11 10 14 7 101470428 4 M5 17 21,5 4 8 8 7 102470405 5 R1/8 18,5 21 7,5 11 11 9 101470518 4 G1/8 17 22 5,5 14 11 7 102470418 5 R1/4 18,5 24,5 11 11 14 9 101470528 4 G1/4 17 25,5 8 18 11 7 102470428 6 R1/8 19,5 21,5 7,5 12 11 9 101470618 5 M5 18,5 20 4 8 8 9 102470505 6 R1/4 19,5 25 11 12 14 9 101470628 5 G1/8 18,5 22,5 5,5 14 11 9 102470518 6 R3/8 20 27,5 12,5 12 17 8 101470638 5 G1/4 18,5 26 8 18 11 9 102470528 8 R1/8 21,5 23 7,5 14,5 14 11 101470818 6 M5 19,5 20,5 4 8 8 9 102470605 8 R1/4 21,5 26 11 14,5 14 11 101470828 6 G1/8 19,5 23 5,5 14 11 9 102470618 8 R3/8 22 30,5 12,5 14,5 17 13 101470838 6 G1/4 19,5 26,5 8 18 11 9 102470628 8 R1/2 22 34,5 16 14,5 22 13 101470848 8 G1/8 21,5 24 5,5 14 13 11 102470818 10 R1/8 26,5 25,5 7,5 17 14 13 101471018 8 G1/4 21,5 29 8 18 17 11 102470828 10 R1/4 26,5 29 11 17 17 13 101471028 8 G3/8 22 33,5 9 22 19 13 102470838 10 R3/8 26,5 30,5 12,5 17 17 13 101471038 8 G1/2 22 39,5 11 26 19 13 102470848 10 R1/2 26,5 34,5 16 17 22 13 101471048 10 G1/8 26,5 26,5 5,5 14 17 13 102471018 12 R1/4 31,5 32 11 20,5 19 16 101471228 10 G1/4 26,5 31,5 8 18 17 13 102471028 12 R3/8 31,5 34 12,5 20,5 22 16 101471238 10 G3/8 26,5 33,5 9 22 19 13 102471038 12 R1/2 31,5 38 16 20,5 22 16 101471248 10 G1/2 26,5 39,5 11 26 19 13 102471048 14 R3/8 30,5 33 12,5 21,5 22 17 101471438 12 G1/4 31,5 35,5 8 18 19 16 102471228 14 R1/2 31,5 37 16 21,5 22 17 101471448 12 G3/8 31,5 37 9 22 19 16 102471238 12 G1/2 31,5 43 11 26 19 16 102471248 14 G3/8 30,5 36 9 22 19 17 102471438 14 G1/2 31,5 39 11 26 24 17 102471448 Extended swivel elbow adaptor, BSP taper 10154 45o Swivel elbow adaptor, BSP parallel 10257 A C øA C ø 1 G G E E 45° B B ØA B C E G 4 R1/8 17 34 7,5 1 10 7 øK1 Model ØA B C E G Ø K1 101540418 6 G1/8 17,5 19,5 5 14 Model 11 102570618 4 R1/4 17 40 11 14 7 101540428 6 G1/4 17,5 23 7,5 18 11 102570628 6 R1/8 19,5 36,5 7,5 11 9 101540618 8 G1/8 19,5 20,5 5 14 11 102570818 8 G1/4 19,5 26 7,5 18 17 102570828 6 R1/4 19,5 41 11 14 9 101540628 8 R1/8 21,5 40,5 7,5 14 11 101540818 8 R1/4 21,5 44,5 11 14 11 101540828 8 R3/8 22 51,5 12,5 17 13 101540838 10 R3/8 26,5 51,5 12,5 17 13 101541038 3/15 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd. en 9.1.060.07 PNEUFIT 10 series Push-in fittings Elbow banjo assembly, non-regulating BSP parallel 10A51 Dimensions in mm Projection/First angle Elbow banjo assembly, regulating-out BSP parallel 10K51 C E E øA 2 G 1 G øK øA C øS 1 B øS 2 B ØA B C E G ØK ØS Model ØA B C E G ØS 4 M5 18,5 22 4 9,5 2,5 8 10A510405 4 M5 18,5 27 4,5 2,5 4 G1/8 20,5 30 6 11 5 14 10A510418 4 G1/8 20,5 34 6 5 14 10K510418 5 M5 20 22 4 11 2,5 8 10A510505 5 M5 20 27 4,5 2,5 8 10K510505 5 G1/8 21,5 30 6 11,5 5 14 10A510518 5 G1/8 21,5 34 6 5 14 10K510518 6 G1/8 23,5 30 6 12,5 5 14 10A510618 6 M5 22 27 4,5 2,5 8 10K510605 6 G1/4 24 34 7,5 13 8,5 17 10A510628 6 G1/8 23,5 34 6 5 14 10K510618 8 G1/8 23,5 30 6 14 5 14 10A510818 6 G1/4 24 36,5 6 8,5 17 10K510628 8 G1/4 24,5 34 7,5 14 8,5 17 10A510828 8 G1/8 23,5 34 6 5 14 10K510818 8 G3/8 26,5 41 9 16,5 10 22 10A510838 8 G1/4 24,5 36,5 6 8,5 17 10K510828 10 G1/4 30 34 7,5 16 8,5 17 10A511028 8 G3/8 26,5 51,5 10 10 22 10K510838 10 G3/8 31 41 9 17 10 22 10A511038 10 G1/4 30 36,5 6 8,5 17 10K511028 Elbow banjo assembly, regulating out BSPT taper 10T00 Model 8 10K510405 10 G3/8 31 51,5 10 10 22 10K511038 12 G3/8 33 51,5 10 10 22 10K511238 12 G1/2 38 57,5 10 10 27 10K511248 Elbow banjo assembly, regulating out BSPT taper 10TA0 C C 1 E øA 2 1 1 2 Model ØA B C E/E1 G 10T000418 4 R1/8 22 53/22,5 9,5 B ØA B C E/E1 G 4 R1/8 22 42/22,5 9,5 1 14 16 G 1 G 1 2 E1 E1 øA 2 E 1 B 1 14 16 Model 10TA00418 6 R1/8 23 42/22,5 9,5 14 16 10T000618 6 R1/8 23 53/22,5 9,5 14 16 10TA00618 6 R1/4 25,5 54/29,5 13,5 17 20 10T000628 6 R1/4 25,5 67/29,5 13,5 17 20 10TA00628 8 R1/8 24,5 42/22,5 9,5 14 16 10T000818 8 R1/4 27 67/29,5 14,5 17 20 10TA00828 8 R1/4 27 54/29,5 13,5 17 20 10T000828 8 R3/8 28 78/33 14,5 19 22 10TA00838 8 R3/8 28 64/33 14,5 19 22 10T000838 10 R1/4 31,5 67/29,5 13,5 17 20 10TA01028 10 R1/4 31,5 54/29,5 13,5 17 20 10T001028 10 R3/8 32,5 78/33 14,5 19 22 10TA01038 12 R1/2 38 90/41,5 16 22 28 10TA01248 10 R3/8 32,5 64/33 14,5 19 22 10T001038 12 R1/2 38 72/41,5 16 22 28 10T001248 en 9.1.060.08 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd.  3/15 PNEUFIT 10 series Push-in fittings Tee connector, tube x 3 10060 Dimensions in mm Projection/First angle Tee adaptor, BSP taper 10165 C G E E øA øA C B ØA C E Model ØA B C E G 4 34 17 7 100600400 4 R1/8 34 15 7,5 5 37 18,5 7 100600500 5 R1/8 37 15,5 7,5 7 101650518 6 39 19,5 8 100600600 5 R1/4 40 20 11 11 101650528 8 42,5 21,5 11 100600800 6 R1/8 39 16 7,5 8 101650618 10 53,5 26,5 13 100601000 6 R1/4 40 20 11 11 101650628 12 63,5 31,5 16 100601200 8 R1/8 42,5 17 7,5 11 101650818 14 66,5 33 17 100601400 8 R1/4 42,5 20 11 11 101650828 Swivel tee adaptor, BSP taper 10167 101650418 8 R3/8 44 23,5 12,5 13 101650838 10 R1/4 53,5 21,5 11 13 101651028 10 R3/8 53,5 23,5 12,5 13 101651038 12 R1/4 63,5 23,5 11 16 101651228 12 R3/8 63 25 12,5 16 101651238 Swivel tee adaptor, BSP parallel 10267 C C øA 1 E øA 1 G G E øK Model 7 B B øK1 ØA B C E G ØK Model ØA B C E G Ø K1 4 R1/8 34 21,5 7,5 10 10 7 101670418 4 M3 34 16 3,5 – 7 8 1 Model 102670403 4 R1/4 34 24 11 10 14 7 101670428 4 M5 34 19,5 4 8 7 8 102670405 5 R1/8 37 22 7,5 11 11 9 101670518 4 G1/8 34 22 5,5 14 7 11 102670418 5 R1/4 37 24,5 11 11 14 9 101670528 5 M5 37 20 4 8 9 8 102670505 6 R1/8 39 22,5 7,5 12 11 9 101670618 5 G1/8 37 22 5,5 14 9 11 102670518 6 R1/4 39 25 11 12 14 9 101670628 5 G1/4 37 26 8 18 9 11 102670528 8 R1/8 42,5 24 7,5 14,5 14 11 101670818 6 M5 39 20,5 4 8 9 8 102670605 8 R1/4 42,5 26 11 14,5 14 11 101670828 6 G1/8 39 23 5,5 14 9 11 102670618 8 R3/8 43,5 30,5 12,5 14,5 17 13 101670838 6 G1/4 39 26,5 8 18 9 11 102670628 10 R1/4 53,5 29 11 17 17 13 101671028 8 G1/8 42,5 23,5 5,5 14 11 13 102670818 10 R3/8 53,5 30,5 12,5 17 17 13 101671038 8 G1/4 42,5 29 8 18 11 17 102670828 10 R1/2 53,5 34,5 16 17 22 13 101671048 8 G3/8 43,5 22 9 22 13 19 102670838 12 R1/4 63,5 32 11 20,5 19 16 101671228 10 G1/4 53,5 31,5 8 18 13 17 102671028 12 R3/8 63,5 34 12,5 20,5 22 16 101671238 10 G3/8 53,5 33,5 9 22 13 19 102671038 12 R1/2 63,5 38 16 20,5 22 16 101671248 12 G1/4 63,5 35,5 8 18 16 19 102671228 14 R3/8 61,5 33 12,5 22,5 22 17 101671438 12 G3/8 63,5 37 9 22 16 19 102671238 14 R1/2 63,5 37 16 22,5 22 17 101671448 14 G1/2 63,5 39 11 26 17 24 102671448 3/15 1 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd. en 9.1.060.09 PNEUFIT 10 series Push-in fittings Tee banjo assembly, non-regulating parallel thread 10A71 Dimensions in mm Projection/First angle Fixed side tee adaptor, BSP taper 10175 E C G øS C1 øA øK G øA E C B B ØA B C E G ØK ØS Model ØA B C C1 E G 4 M5 37,5 22 4 9,5 2,5 8 10A710405 4 R1/8 32 15 17 7,5 4 G1/8 41 30 6 11 5 14 10A710418 5 R1/8 34 15,5 18,5 7,5 7 101750518 5 M5 40,5 22 4 11 2,5 8 10A710505 5 R1/4 40 20 20 11 11 101750528 5 G1/8 43,5 30 6 11,5 5 14 10A710518 6 R1/8 35,5 16 19,5 7,5 8 101750618 6 M5 41,5 22 4 11,5 2,5 8 10A710605 6 R1/4 40 20 20 11 11 101750628 6 G1/8 47,5 30 6 12,5 5 14 10A710618 8 R1/8 38 17 21,5 7,5 11 101750818 6 G1/4 48,5 34 7,5 13 8,5 17 10A710628 8 R1/4 41,5 20 21,5 11 11 101750828 8 G1/8 47,5 30 6 14 5 14 10A710818 8 R3/8 45,5 23,5 22 12,5 13 101750838 8 G1/4 49,5 34 7,5 14 8,5 17 10A710828 10 R1/4 48,5 21,5 26,5 11 13 101751028 10 R3/8 50 23,5 26,5 12,5 13 101751038 12 R1/4 55 23,5 31,5 11 16 101751228 12 R3/8 56,5 25 31,5 12,5 16 101751238 Swivel tee adaptor, BSP parallel 10268 E C C1 C1 C øA E 101750418 øA Swivel tee adaptor, BSP taper 10168 Model 7 G G 1 B B ø K1 ØA B C C1 E G Model ØA B C C1 E G Ø K1 4 R1/8 38,5 20,5 17 7,5 7 10 101680418 4 M3 34 17 17 3,5 - 8 102680403 4 R1/4 41 24 17 11 7 14 101680428 4 M5 36,5 19,5 17 4 8 8 102680405 5 R1/8 40,5 22 18,5 7,5 9 11 101680518 4 G1/8 38,5 22 17 5,5 14 11 102680418 5 R1/4 43 24,5 18,5 11 9 14 101680528 5 M5 39 20 18,5 4 8 8 102680505 6 R1/8 42 22,5 19,5 7,5 9 11 101680618 5 G1/8 40,5 22,5 18,5 5,5 14 11 102680518 6 R1/4 44,5 25 19,5 11 9 14 101680628 5 G1/4 44,5 26 18,5 8 18 11 102680528 8 R1/8 45 24 21,5 7,5 11 14 101680818 6 G1/8 42,5 23 19,5 5,5 14 11 102680618 8 R1/4 47,5 26 21,5 11 11 14 101680828 6 G1/4 46 26,5 19,5 8 18 11 102680628 8 R3/8 52,5 30,5 22 12,5 13 17 101680838 8 G1/8 45 24 21,5 5,5 14 13 102680818 10 R1/4 55,5 29 26,5 11 13 17 101681028 8 G1/4 50,5 29 21,5 8 18 17 102680828 10 R3/8 57 30,5 26,5 12,5 13 17 101681038 8 G3/8 55 33 21,5 9 22 19 102680838 12 R1/4 63,5 32 31,5 11 16 19 101681228 10 G1/4 58,5 31,5 26,5 8 18 17 102681028 12 R3/8 66 34 31,5 12,5 16 22 101681238 10 G3/8 60 33,5 26,5 9 22 19 102681038 12 R1/2 70 38 31,5 16 16 22 101681248 12 G1/4 67 35,5 31,5 8 18 19 102681228 14 R3/8 66,5 33 33 12,5 17 22 101681438 12 G3/8 68,5 37 31,5 9 22 19 102681238 14 R1/2 70 37 33 16 17 22 101681448 14 G3/8 69 36 33 9 22 19 102681438 14 G1/2 72,5 39 33 11 26 24 102681448 en 9.1.060.10 1 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd.  Model 3/15 PNEUFIT 10 series Push-in fittings Parallel Y-Connector 10082 Dimensions in mm Projection/First angle Parallel Y-Adaptor 10188 C C B L N øA øK L øA1 N øA G øD 1 For tupe ø 4 ... 8 = ø 3 For tupe ø 10 = ø 4 O O 1 ØA Ø A1 C ØD L N ØK O Model ØA B C G L N O 4 4 34 3 11 22 11 10,5 100820400 4 R1/8 43,5 7,5 11 22,5 10,5 Model 10 101880418 6 6 38,5 3 14 27 13 12,5 100820600 6 R1/8 48 7,5 14 28 12,5 11 101880618 6 4 38 3 14 27 13 12,5 100820604 8 R1/8 51 7,5 16 32 13,5 14 101880818 8 8 40,5 3 16 31 15 13,5 100820800 8 R1/4 54,5 11 16 32 13,5 11 101880828 8 6 40,5 3 16 31 15 13,5 100820806 10 R3/8 67 12,5 22 42,5 15 19 101881038 10 R1/2 70 16 22 42,5 15 22 101881048 10 10 49,5 4 20,5 42 20 15 100821000 10 8 49,5 4 20,5 42 20 15 100821008 Parallel Y-Adaptor 10288 C B L N øA G O ø3 ØA B C G L N O 4 M5 42,5 4 11 22,5 10,5 10 102880405 Model 6 M5 47 4 14 28 12,5 11 102880605 4-way connector, tube x 4 10090 C øA øK C ØA C ØK 4 42 10,5 10 100900400 5 45,5 11 10 100900500 6 47,5 12 10 100900600 8 57,5 14,5 13 100900800 10 68,5 17 13 100901000 3/15 Model Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd. en 9.1.060.11 PNEUFIT 10 series Push-in fittings Dimensions in mm Projection/First angle Manifold 100D6 C N E L øA1 1 øA H 2 D N1 Ø A/Ø A1 C ØD E H L N N1 Model 8/4 68 3,4 42 9 13 12,5 20 100D60804 8/6 68 3,4 42 9 13 12,5 20 100D60806 10/6 83 3,4 48 10,5 15 17 22,5 100D61006 10/8 83 3,4 48 10,5 15 17 22,5 100D61008 Manifold 100D6 C E N øA1 L G 2 D H 1 B 1 2 øA For tupe ø 8 = ø 16 For tupe ø 10 = ø 20 For tupe ø 8 = ø 14 For tupe ø 10 = ø 16 N1 ØA Ø A1 B C ØD E G H L N N1 8 4 R1/4 83 3,4 42 11 9 13 12,5 20 17 101D60428 8 4 R3/8 85 3,4 42 12,5 9 13 12,5 20 19 101D60438 8 6 R1/4 83 3,4 42 11 9 13 12,5 20 17 101D60628 8 6 R3/8 85 3,4 42 12,5 9 13 12,5 20 19 101D60638 10 8 R3/8 100 3,4 48 12,5 10,5 15 17 22,5 19 101D60838 10 8 R1/2 104 3,4 48 16 10,5 15 17 22,5 22 101D60848 Elbow banjo body 10051 Model Tee banjo body 10071 C G øA øK G øK øA C B B ØA B for screw C G ØK Model ØA B for screw C G ØK 4 M5 18,5 12,5 9,5 100510405 4 M5 37,5 12,5 9,5 100710405 4 G1/8 20,5 14 11 100510418 4 G1/8 41 14 11 100710418 5 M5 20 12,5 11 100510505 5 M5 40 12,5 11 100710505 5 G1/8 21,5 14 11,5 100510518 5 R1/8 43 14 11,5 100710518 6 M5 22 12,5 12,5 100510605 6 M5 41,5 12,5 11,5 100710605 6 G1/8 23,5 14 12,5 100510618 6 G1/8 47,5 14 12,5 100710618 6 G1/4 24 16 13 100510628 6 G1/4 48,5 16 13 100710628 8 G1/8 23,5 14 14 100510818 8 G1/8 47,5 14 14 100710818 8 G1/4 24,5 16 14 100510828 8 G1/4 49,5 16 14 100710828 8 G3/8 26,5 20,5 16,5 100510838 10 G1/4 30 16 16 100511028 10 G3/8 31 20,5 17 100511038 12 G3/8 33 20,5 17,5 100511238 12 G1/2 38 22 17,5 100511248 en 9.1.060.12 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd.  Model 3/15 PNEUFIT 10 series Push-in fittings Banjo bolt, non-regulating stacking 20A00, 20B00, 20C00 Dimensions in mm Projection/First angle Banjo bolt, non-regulating single stacking with top port BSP parallel 20*00 C C B1 øS øS B B B C ØS Execution Model B B1 C ØS M5 22 2,5 single 8 20A000005 M5 M5 25,5 2,5 8 20D000505 G1/8 29 5 single 14 20A000018 M5 G1/4 34 8,5 17 20D000528 G1/4 33 8,5 single 17 20A000028 M5 G3/8 41 10 22 20D000538 G3/8 41 10 single 22 20A000038 G1/8 G1/8 36 5 14 20E001818 G1/2 49 11,5 single 27 20A000048 G1/8 G1/4 35,5 6 17 20E001828 M5 34,5 2,5 double 8 20B000005 G1/8 G3/8 41 10 22 20E001838 G1/8 46,5 5 double 14 20B000018 G1/4 G1/4 45 8,5 17 20F002828 G1/4 52,5 8,5 double 17 20B000028 G3/8 G3/8 52 10 22 20G003838 G3/8 64 10 double 22 20B000038 G1/2 72,5 11,5 double 27 20B000048 G1/8 63 5 triple 14 20C000018 G1/4 71,5 8,5 triple 17 20C000028 G3/8 87 10 triple 22 20C000038 Regulating out banjo bolts single stacking, (screwdriver adjustable), regulating out 20K00 Model 1 C C Regulating out banjo bolts, single stacking, (screwdriver adjustable), regulating in 20L00 2 1 2 B B B C Operating pressure Model B C Operating pressure M5 27,5 10 bar 8 20K000005 M5 27,5 10 bar 8 Model 20L000005 G1/8 34 10 bar 14 20K000018 G1/8 34 10 bar 14 20L000018 G1/4 36,5 10 bar 17 20K000028 G1/4 36,5 10 bar 17 20L000028 G3/8 51,5 10 bar 22 20K000038 G3/8 51,5 10 bar 22 20L000038 G1/2 57 10 bar 27 20K000048 G1/2 57 10 bar 27 20L000048 C Regulating out banjo bolts, single stacking (screwdriver adjustable), bi-directional 20M00 B B C Operating pressure M5 27,3 10 bar 8 20M000005 G1/8 34 10 bar 14 20M000018 G1/4 36,5 10 bar 17 20M000028 G3/8 51,5 10 bar 22 20M000038 G1/2 57 10 bar 27 20M000048 3/15 Model Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd. en 9.1.060.13 PNEUFIT 10 series Push-in fittings Silencer, plug in 10011 Dimensions in mm Projection/First angle Plug (Acetal) 11004 C C øA øK øA øK F ØA C F ØK Model ØA C ØK Model 4 31,5 16,5 11 100110400 4 26,5 9,5 110040400 6 33,5 18,5 11 100110600 5 28 10,5 110040500 8 40,5 19,5 13 100110800 6 28,5 11,5 110040600 10 53,5 24 19 100111000 8 29,5 12,5 110040800 12 57 27,5 19 100111200 10 34 15,5 110041000 12 37,5 16,5 110041200 14 37,5 19,5 110041400 Warning These products are intended for use in industrial compressed air systems only. Do not use these products where pressures and temperatures can exceed those listed under »Technical features/data«. Before using these products with fluids other than those specified, for non-industrial applications, life-support systems or other applications not within published specifications, consult IMI NORGREN. Through misuse, age, or malfunction, components used in fluid power systems can fail in various modes. en 9.1.060.14 The system designer is warned to consider the failure modes of all component parts used in fluid power systems and to provide adequate safeguards to prevent personal injury or damage to equipment in the event of such failure. System designers must provide a warning to end users in the system instructional manual if protection against a failure mode cannot be adequately provided. System designers and end users are cautioned to review specific warnings found in instruction sheets packed and shipped with these products. Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (1999 - 900d) © 2015 Norgren Ltd.  3/15
10TA00618 价格&库存
很抱歉,暂时无法提供与“10TA00618”相匹配的价格&库存,您可以联系我们找货
