150050028
150050028
    NORGREN(诺冠)
    NORGREN - 150050028 - Pneumatic Fitting, BSP, Straight Male Plug, R1/4, 18 bar, 14 mm, Brass
150050028 数据手册
Back to Selector Page Nickel Plated BSP & Hose Fittings M3, M5, 1⁄8" – 11⁄2" BSP l Suitable for use in most general industrial applications l Bright nickel plated brass l Compact design l Reliable and corrosion resistant l Washers included where necessary Technical Data Medium: Compressed air or any fluids compatible with the materials listed below Operating Pressure and Temperature: Generally limited by tubing specification except where plastic sealing washers are used (Banjo bolts M3 & M5 units). In these cases temperature limited to +70°C, pressure limited to 18 bar. Suitable for vacuum applications. Ordering Information To order, quote appropriate product number from the tables on the following pages. M3, M5, 1⁄8", 1⁄4", 3⁄8", 1⁄2", 3⁄4", 1", 11⁄4", 11⁄2" BSP threads Flow regulating banjos are limited to 1-10 bar operating range Materials Bar parts brass to BS 2874: 1986 (CZ121), bright nickel plated. Stamped parts brass to BS 2872: 1969 (CZ122), bright nickel plated. Copper sealing washers (nylon for M3 & M5 units and banjo 08/97 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/AL 9.8.001.01 Nickel Plated BSP & Hose Fittings Straight Adaptors and Connectors BULKHEAD CONNECTOR SLEEVE ADAPTOR female BSPP 16029 Page 9.8.001.03 NIPPLE ADAPTOR male BSPP 16022 Page 9.8.001.03 HEXAGON NIPPLE GAUGE ADAPTOR female BSPP to male NPTF male NPTF to male BSPT 17223 NIPPLE ADAPTOR male BSPT 15020 16020 15423 Page 9.8.001.03 Page 9.8.001.03 Page 9.8.001.04 BSP CONNECTOR reducer - male BSPT x female BSPP BSP CONNECTOR expander - male BSPT x female BSPP PLUG male BSPP PLUG male BSPT HOSE ADAPTOR metric I/D hose bore x male BSPT 15023 15023 Page 9.8.001.04 Page 9.8.001.04 Page 9.8.001.04 HOSE ADAPTOR imperial I/D hose bore x male BSPT HOSE ADAPTOR metric I/D hose bore x male BSPP SWIVEL HOSE ADAPTOR imperial I/D x female BSPP HOSE CONNECTOR imperial 30218 29217 Page 9.8.001.06 16023 16023 ADAPTOR female NPTF to male BSPT Page 9.8.001.03 Page 9.8.001.04 Page 9.8.001.06 BSP CONNECTOR expander male x female Page 9.8.001.03 15420 30117 BSP CONNECTOR reducer male x female Page 9.8.001.06 16005 Page 9.8.001.05 15005 Page 9.8.001.05 29117 Page 9.8.001.06 30014 Page 9.8.001.07 Elbow Connectors and Adaptors ELBOW 2 x female BSPP ELBOW ELBOW male BSPT x female BSPP 2 x male BSPT 16042 Page 9.8.001.04 15043 Page 9.8.001.04 ELBOW BANJO ASSEMBLY ELBOW BANJO ASSEMBLY non regulating bolt regulating out 16A51 15040 Page 9.8.001.05 Page 9.8.001.07 16K51 Page 9.8.001.07 Tee Connectors and Adaptors TEE 3 x female BSPP TEE 3 x male BSPT 16062 Page 9.8.001.05 TEE 2 x female BSPT x male BSPP leg 15060 Page 9.8.001.05 CROSS 4 x female BSPP 16092 15069 Page 9.8.001.05 Page 9.8.001.05 BANJO BOLT non regulating double stacking BANJO BOLT regulating single stacking BSP parallel Banjo Bodies and Bolts ELBOW BANJO BODY BANJO BOLT non regulating single stacking 16051 20A00 20K00 20B00 Page 9.8.001.07 Page 9.8.001.07 Page 9.8.001.07 Page 9.8.001.07 MANIFOLD single sided LOCKNUT metric LOCKNUT inch FLAT UNION 34050 Page 9.8.001.08 N/AL 9.8.001.02 36054 Page 9.8.001.08 34022 Page 9.8.001.08 TAPER PLUG with internal hexagon 15033 Page 9.8.001.08 25013 Page 9.8.001.08 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 08/97 Nickel Plated BSP & Hose Fittings Bulkhead Connector Product number A BSPP B metric D female male thread thread B A 160290005 M5x0,8 M10x1,0 14,0 G F E A/F F G max. E Product number D 160220505 M5x0,8 G 3,5 7,0 M5x0,8 11,0 8 - 4,0 10,0 160221805 1⁄8" M5x0,8 13,0 14 7,4 160290028 1⁄4" M20x1,5 25,0 27 4,0 16,0 160221818 1⁄8" 1⁄8" 15,0 14 - 160290038 3⁄8" M26x1,5 26,0 32 5,0 15,0 160222818 1⁄4" 1⁄8" 19,0 17 9,5 160290048 1⁄2" M28x1,5 33,0 36 6,0 21,0 160222828 1⁄4" 1⁄4" 22,0 17 - 160290068 3⁄4" M33x1,5 36,5 41 6,0 22,5 160223818 3⁄8" 1⁄8" 20,0 22 10,5 160290088 1" M42x1,5 41,5 46 8,0 24,5 160223828 3⁄8" 1⁄4" 23,0 22 10,5 1602900A8 11⁄4" M48x1,5 50,0 55 8,0 29,5 160223838 3⁄8" 3⁄8" 24,0 22 - 160224818 1⁄2" 1⁄8" 24,0 24 13,0 160224828 1⁄2" 1⁄4" 25,0 24 13,0 160224838 1⁄2" 3⁄8" 27,5 24 13,0 160224848 1⁄2" 1⁄2" 30,0 26 - 160226848 3⁄4" 1⁄2" 30,0 30 14,5 160226868 3⁄4" 3⁄4" 32,0 32 - G B A G 160228868 1" 3⁄4" 41,0 40 17 160228888 1" 1" 45,5 41 - Nipple – Male BSPT A BSPP B BSPP D male male thread thread E G1 A/F G ∅S D Product number E A BSPT B BSPT D male male thread thread E G1 A/F G ∅S min. 1⁄8" 19,5 12 7,5 7,5 5,5 150202818 1⁄4" 1⁄8" 23,5 14 11,0 7,5 5,5 150202828 1⁄4" 1⁄4" 27,6 14 11,0 11,0 6,35 150203818 3⁄8" 1⁄8" 24,0 17 11,5 7,5 150203828 3⁄8" 1⁄4" 27,5 17 11,5 11,0 8,0 150203838 3⁄8" 3⁄8" 28,0 17 11,5 11,5 11,0 11,0 150204818 1⁄2" 1⁄8" 27,0 22 14,0 7,5 10,0 8,0 8,0 150204828 1⁄2" 1⁄4" 30,5 22 14,0 11,0 8,0 24,5 24 10,0 9,0 11,0 150204838 1⁄2" 3⁄8" 31,0 22 14,0 11,5 11,0 25,5 24 10,0 10,0 15,0 150204848 1⁄2" 1⁄2" 33,5 22 14,0 14,0 15,0 27,5 30 12,0 10,0 15,0 150206828 3⁄4" 1⁄4" 37,2 27 19,0 11,1 6,35 3⁄4" 53,0 32 14,7 14,7 18,0 150206838 3⁄4" 3⁄8" 38,8 27 19,0 12,7 9,0 160208848 1" 1⁄2" 56,7 41 17,5 13,4 14,0 150206848 3⁄4" 1⁄2" 37,5 27 16,0 14,0 15,0 160208868 1" 3⁄4" 58,0 41 17,5 14,7 18,0 150206868 3⁄4" 3⁄4" 40,0 27 16,5 16,5 19,0 160208888 1" 1" 60,8 41 17,5 17,5 25,0 150208838 1" 3⁄8" 42,8 36 22,1 12,7 9,0 150208848 1" 1⁄2" 46,0 36 22,1 15,9 12,7 150208868 1" 3⁄4" 43,0 34 19,0 16,5 19,0 150208888 1" 1" 45,5 34 19,0 19,0 23,0 11,5 8 4,0 4,0 2,0 M5x0,8 14,5 14 6,0 4,0 2,0 160201818 1⁄8" 1⁄8" 16,5 14 6,0 6,0 5,5 160202818 1⁄4" 1⁄8" 19,0 17 8,0 6,0 5,5 160202828 1⁄4" 1⁄4" 21,0 17 8,0 8,0 8,0 160203828 3⁄8" 1⁄4" 22,0 19 9,0 8,0 8,0 160203838 3⁄8" 3⁄8" 23,0 19 9,0 9,0 160204828 1⁄2" 1⁄4" 23,5 24 160204838 1⁄2" 3⁄8" 160204848 1⁄2" 1⁄2" 160206848 3⁄4" 1⁄2" 160206868 3⁄4" A M5x0,8 160201805 1⁄8" ØS B 150201818 1⁄8" 160200505 M5x0,8 BSP – Connector Reducer – Male BSPP x Female BSPP G1 G 5,5 5,5 Expander– Male BSPP x Female BSPP Product number A BSPP B BSPP D male female thread thread E A/F G max. 160231805 1⁄8" M5x0,8 10,5 14 6,0 160232805 1⁄4" M5x0,8 13,3 17 7,3 160232818 1⁄4" 1⁄8" 13,0 17 8,0 160233818 3⁄8" 1⁄8" 14,0 19 9,0 160233828 3⁄8" 1⁄4" 14,0 19 9,0 160234818 1⁄2" 1⁄8" 15,5 24 160234828 1⁄2" 1⁄4" 15,5 24 160234838 1⁄2" 3⁄8" 15,5 160236828 3⁄4" 1⁄4" 23,0 160236838 3⁄4" 3⁄8" 160236848 3⁄4" 1⁄2" D E ØS Product number A BSPP B BSPP D male female thread thread E G1 A/F ∅S G min. 14,5 14 4,0 2,0 160231828 1⁄8" 1⁄4" 19,5 17 6,0 5,5 9,5 160231838 1⁄8" 3⁄8" 21,0 22 6,0 5,5 10,5 160232838 1⁄4" 3⁄8" 22,5 22 8,0 8,0 10,5 160232848 1⁄4" 1⁄2" 26,0 26 8,0 8,0 13,0 10,0 160232868 1⁄4" 3⁄4" 32,8 32 7,3 6,5 16,3 10,0 160233848 3⁄8" 1⁄2" 27,0 26 9,0 11 13,0 24 10,0 160233868 3⁄8" 3⁄4" 34,2 32 8,7 9,5 16,3 32 14,2 160234868 1⁄2" 3⁄4" 37,8 32 11,75 13,6 16,3 17,5 30 12,0 17,5 30 12,0 B 160230518 M5x0,8 1⁄8" A E G 22 Supplied with sealing washers D E A/F 14 Product number B ØS A G1 D M16x1,5 18,0 Nipple – Male BSPP E B BSPP female thread 1⁄8" Supplied complete with locknut D A BSPP female thread 160290018 B E A D Sleeve - Female BSPP G1 G 7,4 Supplied with sealing washers Supplied with sealing washers 08/97 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/AL 9.8.001.03 Nickel Plated BSP & Hose Fittings Adaptor- Female NPTF to Male BSPT E F D B G A F ∅G H A/F Product number C 1⁄8" 1⁄4" 1⁄4" 154233838 3⁄8" 3⁄8" 38,0 9,60 12,70 2,0 16,7 22,0 154234848 1⁄2" 1⁄2" 47,0 12,70 15,90 2,0 21,7 27,0 154236868 3⁄4" 3⁄4" 50,0 17,45 19,05 2,0 26,7 36,0 ∅D A B NPTF C BSPP thread thread E F 154231818 1⁄8" 154232828 H ∅D E A B BSPT C NPTF thread thread E ∅G H A/F F 27,5 4,75 9,50 2,0 10,7 15,0 172232828 1⁄4" 1⁄4" 33,5 7,60 14,3 2,0 17,7 19,O 36,0 7,60 11,10 2,0 13,7 19,0 3⁄8" 3⁄8" 33,5 9,60 14,3 2,0 16,7 24,0 172234848 1⁄2" 1⁄2" 44,0 12,70 19,0 2,0 21,7 27,0 172233838 D B G Product number A C Gauge Adaptor Female BSPP to Male NPTF H Hexagon Nipple - Male NPTF to Male BSPT C H B G D A ∅G A NPTF thread B BSPT thread C 154201818 1⁄8" 1⁄8" 154202828 1⁄4" 1⁄4" 154203838 3⁄8" 3⁄8" 154204848 1⁄2" 1⁄2" 46,5 12,70 19,0 15,90 21,7 2,0 22,0 154206868 3⁄4" 3⁄4" 47,5 17,45 19,0 19,05 26,7 2,0 27,0 F E ∅D Product number E F H J 27,0 4,75 9,5 9,50 10,7 2,0 3,50 7,60 14,3 11,10 13,7 2,0 14,0 37,0 9,60 14,3 12,70 16,7 2,0 17,0 11,0 J Adaptor Fittings - Allow connection between components and system using BSP or NPT threads BSP Connector Reducer – Male BSPT x Female BSPP 1⁄8" 1⁄4" 22,0 17 7,5 5 9,5 150231838 1⁄8" 3⁄8" 22,5 22 7,5 5 10,5 5,5 7,4 11,0 5,5 7,4 150232828 1⁄4" 1⁄4" 26,0 17 11,0 8,0 9,5 150231848 1⁄8" 1⁄2" 31,0 27 8,6 5 15,0 3⁄8" 1⁄8" 11,5 5,5 7,4 150232838 1⁄4" 3⁄8" 27,0 22 11,0 8 10,5 150233828 3⁄8" 1⁄4" 16,5 17 11,5 8,0 9,5 150232848 1⁄4" 1⁄2" 30,0 26 11,0 8 13,0 150233838 3⁄8" 3⁄8" 27,5 22 11,5 11,0 10,5 150232868 1⁄4" 3⁄4" 37,3 32 11,1 7 16,3 150234818 1⁄2" 1⁄8" 19,5 22 14,0 5,5 7,4 150233848 3⁄8" 1⁄2" 30,5 26 11,5 11 13,0 1⁄2" 1⁄4" 19,5 22 14,0 8,0 9,5 150233868 3⁄8" 3⁄4" 38,3 32 12,7 11 16,3 150234838 1⁄2" 3⁄8" 19,5 22 14,0 11,0 10,5 150234868 1⁄2" 3⁄4" 35,0 32 14,0 15 14,5 150234848 1⁄2" 1⁄2" 33,0 26 14,0 15,0 13,0 150236888 3⁄4" 1" 47,5 41 19,05 18 19,0 150236828 3⁄4" 1⁄4" 29,5 27 19,05 11,5 11,0 150236838 3⁄4" 3⁄8" 23,5 27 16,5 11,0 10,5 150236848 3⁄4" 1⁄2" 23,5 27 16,5 15,0 13,0 150238838 1" 3⁄8" 34,5 35 22,1 15,0 11,4 150238848 1" 1⁄2" 26,5 34 19,0 15,0 13,0 150238868 1" 3⁄4" 26,5 34 19,0 19,0 16,5 Product number A BSPT B BSPP E G1 G J1 J male female A/F min. thread thread ∅S 150430018 1⁄8" 1⁄8" 12 8 7,0 21 18,5 5,5 150430028 1⁄4" 1⁄4" 13 11 9,5 25,5 24 150430038 3⁄8" 3⁄8" 16 11,5 11,5 28 27 150430048 1⁄2" 1⁄2" 20 14 150430068 3⁄4" 3⁄4" 27 14,5 14,5 36,5 32 16,5 17 B A 7,5 16,0 14 G G1 Elbow – Male BSPT x Female BSPP G min. J ∅S J1 G 160420018 1⁄8" 12 7,0 21 5,5 160420028 1⁄4" 13 9,5 25,5 8 160420038 3⁄8" 16 11,5 28 11 160420048 1⁄2" 20 15,0 32 15 160420068 3⁄4" 27 14,5 36,5 19 E B A BSPP E female A/F thread G1 ØS A 150231828 20,0 14 1⁄8" Product number G A BSPT B BSPP D male female thread thread 1⁄8" Elbow – 2 x Female BSPP J E G1 ∅S G A/F min. min. Product number 150232818 1⁄4" 150234828 E E 150231818 1⁄8" 150233818 G D J B A E ØS G1 E G1 ∅S G A/F min. min. A BSPT B BSPP D male female thread thread ØS Product number D Expander – Male BSPT x Female BSPP A 8 11 13,0 32 29,5 15 19 ØS N/AL 9.8.001.04 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 08/97 Nickel Plated BSP & Hose Fittings Tee – 3 x Female BSPP Elbow – 2 x Male BSPT Product number A BSPT male thread E A/F G J ∅S 150400018 1⁄8" 12 7,5 18,5 6 150400028 1⁄4" 13 11 24 8 150400038 3⁄8" 16 12 27 11 150400048 1⁄2" 20 14 29,5 15 D E A ØS J J G J E G A Product number A BSPP D female thread E A/F G min. J ∅S 160620018 1⁄8" 39 12 7,4 19,5 6 160620028 1⁄4" 49 13 9,5 24,5 8 160620038 3⁄8" 54 16 10,5 27 11 160620048 1⁄2" 64 20 13,0 29 15 160620068 3⁄4" 73 27 14,5 36,5 19 ØS Tee – 3 x Male BSPT Product number D 150600028 E A BSPT D male thread E A/F 1⁄4" 13 46 G ∅S J Product number D 11 23 8 E J G J1 G1 J A A ØS ØS J Tee – 2 x Female BSPP x Male BSPT Leg G A BSPP B BSPT D E G1 G J1 female male A/F min. thread thread J ∅S 150690018 1⁄8" 1⁄8" 39 12 8 8,5 17,5 19,5 6 150690028 1⁄4" 1⁄4" 49 13 11 11 23 150690038 3⁄8" 3⁄8" 54 16 11,5 12 25,5 27 11 150690048 1⁄2" 1⁄2" 64 20 14 15 29 32 15 150690068 3⁄4" 3⁄4" 73 27 14,5 16,5 32 36,5 19 24,5 8 B Cross – 4 x Female BSPP A BSPP female thread D J 160920018 1⁄8" 39 160920028 1⁄4" 50 11 25 8 160920038 3⁄8" 56 12 28 11 160920048 1⁄2" 64 15 32 15 Product number A 8,5 19,5 D 6 G C ØS A G ∅S Product number E D J Plug – Male BSPP B A B C BSPP D male thread A/F E Ø 160050005 8,0 4,5 M5 8 - 160050018 10,0 6,5 1⁄8" 14 13,4 160050028 13,0 9 1⁄4" 17 17,6 160050038 13,5 9,5 3⁄8" 19 20,9 160050048 14,5 10 1⁄2" 24 26,4 160050068 16 11 3⁄4" 30 32,4 160050088 17 12 1" 40 38,9 Supplied with sealing washer Plug – Male BSPT A D G 08/97 E Product number A BSPT male thread D E G 150050018 1⁄8" 14,5 10 150050028 1⁄4" 16,5 14 11,1 150050038 3⁄8" 19 17 12,7 150050048 1⁄2" 22,5 22 15,9 150050068 3⁄4" 27 27 19,05 150050088 1" 30 36 22,1 A/F 9,5 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/AL 9.8.001.05 Nickel Plated BSP & Hose Fittings Hose Adaptor Metric I/D Hose Bore x Male BSPT ∅S min. D ØA ØS L ∅S min. Product number A B BSPT D hose male bore thread E G A/F L 301170318 3⁄16" 1⁄8" 36 10 8,3 22,5 4,2 301170328 3⁄16" 1⁄4" 41 14 12,3 22,5 4,2 301170418 1⁄4" 1⁄8" 36 10 8,3 22,5 5,35 14 12,3 22,5 5,35 1⁄8" 32,0 12 7,5 19,5 3,2 291170618 6 1⁄8" 32,0 12 7,5 19,5 3,2 291170628 6 1⁄4" 35,5 14 11,0 19,5 3,2 291170638 6 3⁄8" 42,5 17 14,3 22,5 5,0 301170428 1⁄4" 1⁄4" 41 291170718 7 1⁄8" 32,0 12 7,5 19,5 5,0 301170438 1⁄4" 3⁄8" 42,5 17 14,25 22,5 5,35 291170728 7 1⁄4" 35,5 14 11,0 19,5 6,0 301170448 1⁄4" 1⁄2" 45,5 22 16,8 22,5 5,35 291170738 7 3⁄8" 36,0 17 11,5 19,5 6,0 301170518 5⁄16" 1⁄8" 36 12 8,3 22,5 5 291170828 8 1⁄4" 35,5 14 11,0 19,5 7,5 301170528 5⁄16" 1⁄4" 41 14 12,3 22,5 7 291170838 8 3⁄8" 36,0 17 11,5 19,5 7,5 301170618 3⁄8" 1⁄8" 36 12 8,3 22,5 5 291170918 9 1⁄8" 36,0 13 8,3 22,5 5,0 301170628 3⁄8" 1⁄4" 41 14 12,3 22,5 7 291170928 9 1⁄4" 41,0 14 12,3 22,5 7,6 301170638 3⁄8" 3⁄8" 42,5 17 14,25 22,5 8,33 291170938 9 3⁄8" 42,5 17 14,25 22,5 7,6 301170648 3⁄8" 1⁄2" 45,5 22 16,8 22,5 8,33 291170948 9 1⁄2" 45,5 22 16,8 22,5 7,6 301170728 1⁄2" 1⁄4" 48,5 17 12,3 29,5 7 291171018 10 1⁄8" 36,0 13 8,3 22,5 8,8 301170738 1⁄2" 3⁄8" 49,5 17 14,25 29,5 10,7 291171028 10 1⁄4" 35,5 14 11,0 19,5 7,5 301170748 1⁄2" 1⁄2" 52,5 22 16,8 29,5 10,7 291171038 10 3⁄8" 36,0 17 11,5 19,5 7,5 301170768 1⁄2" 3⁄4" 55,0 27 18,5 29,5 10,7 291171238 12 3⁄8" 36,0 17 11,5 19,5 9,5 301170848 5⁄8" 1⁄2" 61,0 22 16,8 38,0 14,0 291171328 13 1⁄4" 48,5 16 12,3 29,5 7,0 301170868 5⁄8" 3⁄4" 63,5 27 18,5 38,0 14,5 291171338 13 3⁄8" 49,5 17 14,25 29,5 11,0 301170948 3⁄4" 1⁄2" 61,0 22 16,8 38,0 14,0 291171348 13 1⁄2" 52,5 22 16,8 29,5 11,0 301170968 3⁄4" 3⁄4" 63,5 27 18,5 38,0 17,5 291171368 13 3⁄4" 55,0 27 18,5 29,5 11,0 301170988 3⁄4" 1" 67,5 35 21,4 38,0 17,55 291171638 16 3⁄8" 36,0 19 11,5 19,5 11 301171088 1" 1" 67,5 35 21,4 38,0 22,4 291171648 16 1⁄2" 39,0 22 14,0 19,5 12,5 3011711A8 11⁄4" 11⁄4" 80,0 42 24,7 43,0 29,25 291171668 16 3⁄4" 43,5 27 16,5 19,5 14,5 3011712B8 11⁄2" 11⁄2" 80,0 50 24,7 43,0 36,0 291171938 19 3⁄8" 58,5 22 14,25 38,0 11,0 291171948 19 1⁄2" 61,0 22 16,8 38,0 14,0 291171968 19 3⁄4" 63,5 27 18,5 38,0 17,5 291172568 25 3⁄4" 63,5 27 18,5 38,0 18,0 291172588 25 1" 67,5 35 21,4 38,0 22,0 291173288 32 1" 72,5 35 21,4 43,0 24,0 Product number B G D 291170418 4 Hose Adaptor – Metric I/D Hose Bore x Male BSPP E E ØA L A B BSPP D hose male bore thread G L Swivel Hose Adaptor – Imperial I/D x Female BSPP E G A/F L ∅S min. D E ØA ØS L E G A/F B ØA ØS B G A B BSPT D hose male bore thread ØS Product number D E G A/F L ∅S min. Product number A B BSPP D hose female bore thread 302180418 1⁄4" 1⁄8" 32,3 13 4,6 22,5 4,0 302180428 1⁄4" 1⁄4" 34,8 17 6,0 22,5 5,35 302180438 1⁄4" 3⁄8" 35,8 22 6,0 22,5 5,35 302180628 3⁄8" 1⁄4" 34,8 17 6,0 22,5 6,35 292170203 2,5 M3 14,0 5 3,5 7,5 1,8 292170305 3 M5x0,8* 15,6 8 3,5 7,5 2,0 292170318 3 1⁄8" 21,0 14 7,4 7,5 2,0 292170418 4 1⁄8" 36,5 14 7,4 22,5 3,3 292170428 4 1⁄4" 40,5 19 10,0 22,5 3,3 302180638 3⁄8" 3⁄8" 35,8 22 6,0 22,5 8,33 292170518 5 1⁄8" 36,5 14 7,4 22,5 4,0 302180648 3⁄8" 1⁄2" 37,9 27 7,4 22,5 8,33 292170618 6 1⁄8" 36,5 14 7,4 22,5 5,0 302180748 1⁄2" 1⁄2" 44,9 27 7,4 29,5 10,7 292170628 6 1⁄4" 40,5 19 10,0 22,5 5,0 302180768 1⁄2" 3⁄4" 49,9 32 11,9 29,5 10,7 292170638 6 3⁄8" 43,0 22 11,4 22,5 5,0 302180968 3⁄4" 3⁄4" 58,4 32 11,9 38,0 16,5 292170918 9 1⁄8" 36,5 14 7,4 22,5 7,6 292170928 9 1⁄4" 40,5 19 10,0 22,5 7,6 292170938 9 3⁄8" 43,0 22 11,4 22,5 7,6 292170948 9 1⁄2" 47,0 27 15,0 22,5 7,6 292171328 13 1⁄4" 47,5 19 10,0 29,5 11,0 292171338 13 3⁄8" 49,5 22 11,4 29,5 11,0 292171348 13 1⁄2" 54,5 27 15,0 29,5 11,0 292171368 13 3⁄4" 59,5 32 16,3 29,5 11,0 292171968 19 3⁄4" 67,5 32 16,3 38,0 17,5 B E Hose Adaptor Imperial I/D Hose Bore x Male BSPT G L Supplied with sealing washer N/AL 9.8.001.06 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 08/97 Nickel Plated BSP & Hose Fittings Hose Connector – Imperial A hose bore B G 300140303 3⁄16" 8 300140404 1⁄4" 9 47 22,5 5,35 300140505 5⁄16" 12 47 22,5 7,0 300140606 3⁄8" 13 47 22,5 8,33 300140707 1⁄2" 16 62 29,5 10,7 300140808 5⁄8" 19 79 38,0 14,0 300140909 3⁄4" 23 79 38,0 17,55 28 79 38,0 22,4 D 300141010 1" 22,5 4,2 A 47 Product number ØS E D1 G ØB D ∅S Product number B A B D thread thread BSP BSP D1 E A/F G ØS 16A511818 1/8" 1/8" 29 29 14 5 6,0 1/4" 1/4" 38 32 17 6 7,6 16A513838 3/8" 3/8" 44 45 22 9,5 9,6 16A514848 1/2" 1/2" 63 47 27 12 9,6 16A512828 G ØS ØA D Elbow Banjo Assembly Non Regulating Bolt Female parallel BSP thread to male parallel BSP thread Both ends identical. Elbow Banjo Assembly Regulating Out B 16K511818 16K512828 16K513838 16K514848 A thread BSP 1/8" 1/4" 3/8" 1/2" B thread BSP 1/8" 1/4" 3/8" 1/2" D D1 29 38 44 63 34 37 52 58 E G A/F ∅S 14 17 22 27 6,0 7,6 9,6 9,6 D J 5,0 6,0 9,5 12,0 B Banjo Bolt – Non Regulating Single Stacking Product number B thread BSP D1 E A/F ØS E Ø J ØS 160511818 1/8" 1/8" 14,0 28,0 13,0 21 6,0 160512828 1/4" 1/4" 16,0 37,0 16,0 28 7,6 160513838 3/8" 3/8" 20,5 42,0 20,5 31 9,6 160514848 1/2" 1/2" 22.0 61.0 24,7 47 9,6 20A000018 1/8" 20A000028 1/4" 20A000038 20A000048 Product number B thread BSP D1 E A/F ØS 29 14 4,5 33 17 5,5 20B000018 1/8" 44 14 4,5 20B000028 1/4" 50 17 3/8" 41 22 5,5 9,2 20B000038 3/8" 62,5 22 1/2" 49 27 9,2 10,5 20B000048 1/2" 74 27 10,5 E Male parallel BSP thread. All banjo bolts supplied complete with sealing washers. B D Banjo Bolt – Non Regulating Double Stacking D1 D1 ØS A B C thread for BSP BSP bolt Female parallel BSP thread Arrow on bolt hexagon indicates free flow direction. Pressure range 1 -10 bar. E Product number ØS Product number A E A D1 G ØS E C D Elbow Banjo Body ØS Male parallel BSP thread B Banjo Bolt – Regulating Single stacking BSP parallel Bi-Directional Flow Regulating Out D1 E B Product number 20K000018 20K000028 20K000038 20K000048 B thread 1⁄8" 1⁄4" 3⁄8" 1⁄2" D1 34,0 36,5 51,5 57,0 E A/F 14 17 22 27 Product B number thread 1 20M000018 ⁄8" 20M000028 1⁄4" 20M000038 3⁄8" 20M000048 1⁄2" D1 34,0 36,5 51,5 57,0 E A/F 14 17 22 27 All banjo bolts supplied complete with sealing washers. Arrow on bolt hexagon indicates free flow direction. Pressure range 1 -10 bar. Regulating In Product number 20L000018 20L000028 20L000038 20L000048 08/97 B thread 1⁄8" 1⁄4" 3⁄8" 1⁄2" D1 34,0 36,5 51,5 57,0 E A/F 14 17 22 27 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/AL 9.8.001.07 Nickel Plated BSP & Hose Fittings Flat Union A B ∅E F C G Assembly part number Nom size A O/All Length B Length C Length D A/F Hex Thro’ E ∅ F BSPT thread G A/F Hex 150331818 150332828 150333838 1/8" 15,0 18,5 19,0 10,0 13,0 13,0 5 8 10 6,0 9,5 12,0 1/8" 3/8" 33,3 42,0 43,0 15 24 27 150334848 1/2" 52,0 23,0 17,5 14 15,0 1/2" 30 150336868 150338888 3/4" 25,0 29,0 19,0 23,0 17 19 20,0 24,0 3/4" 1" 56,5 68,0 38 46 No. of outlets A B thread BSP C D D1 34 0504 01 4 1/8" 71 5 81 34 0504 02 4 1/4" 99 5 34 0504 03 4 3/8" 115 6 34 0506 01 6 1/8" 105 34 0506 02 6 1/4" 34 0506 03 6 3/8" 1/4" 1/4" 3/8" 1" D Single Sided Manifold D Product number B A D1 C A D2 E C ØL U D2 E L U 16,0 25,0 15 5,5 17 109 23,0 31,0 20 5,5 23 127 25,4 34,9 23 6,5 27 5 115 16,0 25,0 15 5,5 17 145 5 155 23,0 31,0 20 5,5 23 169 6 181 25,4 34,9 23 6,5 27 Product is unplated brass Locknut - Metric E Product number B thread BSP A E A/F Product number B thread BSP A E A/F 360546 01 1⁄8" 4,8 13 360546 02 1⁄4" 6,4 17 340223 01 1⁄8" 0,19 0,53 340223 02 1⁄4" 0,25 360546 03 3⁄8" 6,4 22 0,71 340223 03 3⁄8" 0,25 0,82 360546 04 1⁄2" 6,4 360546 06 3⁄4" 7,1 27 340223 04 1⁄2" 0,25 1,01 32 360546 06 3⁄4" 0,28 1,30 360546 07 7⁄8" 7,9 36 340223 07 7⁄8" 360546 08 1" 0,31 1,48 8,7 41 340223 08 1" 0,34 360546 09 1,67 11⁄4" 8,7 50 Product is unplated brass 360546 10 11⁄2" 9,5 55 B A A B Locknut - Inch E Product is unplated brass Taper plug Brass - unplated E C A N/AL 9.8.001.08 Product number A B thread BSPT C 250130018 1⁄8" 8 6 250130028 1⁄4" 10 250130038 3⁄8" 250130048 E A/F Product number A thread BSPT B C E A/F 5 250130018FZ 1⁄8" 8 6 5 8 6 250130028FZ 1⁄4" 10 8 6 11 8 8 250130038FZ 3⁄8" 11 8 8 1⁄2" 13 8 10 250130048FZ 1⁄2" 13 8 10 250130068 3⁄4" 17 11 14 250130068FZ 3⁄4" 17 11 14 250130088 1" 19 13 17 19 13 17 B C E B Taper plug Steel - zinc plated A 250130088FZ 1" Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. 08/97 Nickel Plated BSP & Hose Fittings Warning These products are intended for use in industrial compressed air systems only. Do not use these products where pressures and temperatures can exceed those listed under ‘Technical Data’. Before using these products with fluids other than those specified, for non-industrial applications, life-support systems, or other applications not within published specifications, consult Norgren. Through misuse, age, or malfunction, components used in fluid power systems can fail in various modes. The system designer is warned to consider the failure modes of all component parts used in fluid power systems and to provide adequate safeguards to prevent personal injury or damage to equipment in the event of such failure. System designers must provide a warning to end users in the system instructional manual if protection against a failure mode cannot be adequately provided. System designers and end users are cautioned to review specific warnings found in instruction sheets packed and shipped with these products where applicable. 08/97 Our policy is one of continuous research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. N/AL 9.8.001.09
150050028 价格&库存
很抱歉,暂时无法提供与“150050028”相匹配的价格&库存,您可以联系我们找货
