18-025-003
18-025-003
    NORGREN(诺冠)
    NORGREN - 18-025-003 - Pneumatic Fitting Accessory, Neck Mounting Bracket, 07 Series
18-025-003 数据手册
4 72 Series Modular Components Maximum Pressure: 17 bar (250 psig) Quikclamp Wall Mounting Bracket Quikclamp and Wall Mounting Bracket Sub-base Mounted Pressure Switch 2.32 (59) 2.91 (74) Use with the Quikclamp to provide Monitors air pressure and provides secure mounting to a wall, machine an electrical output when the See Quikclamp paragraph for Maximum Temperature: 4214-52(72Quikclamp&WallMntgBrktDim) panel or other flat surface. pressure drops below or exceeds descriptions and dimensions. 65°C (150°F) an adjustable preset pressure. Use 3/16" (5 mm) screws to mount Use 3/16" (5 mm) screws to mount Use with all Excelon 72 Products Installs between two Quikclamps. 4213-89(72QuikclampWallMtngBrktDim) bracket to wall. bracket to wall. to provide modular installation Also provides two additional 1/4" capability. Flanges on the outlets for auxiliary air. 0.59 products slide into V grooves in (15) P1max: 250 psig (17 bar) the Quikclamp. Two face-sealing o-rings in the Quikclamp provide Temperature: 14° to 150°F a positive seal when the clamp is Wall (-10° to 65°C) closed and the captive screw is Adjustable 30 to 150 psig 1.50 (38) tightened. Port CL (2 to 10 bar). Tighten screw with a 3 mm hex Shipped from wrench or a T15 Torx wrench. factory preset at 90 psig (6.3 bar) Quikclamp Service Kit (contains 2 Part Number: 4214-52 nitrile o-rings): 4384-570 Max. Voltage: 240 V a.c./d.c. Part Number: 4213-89 4214-51(72Quikclamp,O-ring) A Quikclamp adds 0.26" (6.5 Max. Current: 5 Amp ______________________________ mm) to the overall length of a ______________________________ Hysteresis at Midpoint: 12% combination unit. A Sub-base Mounted Pressure Porting Block Switch adds 1.13" (29 mm) to the Quikmount Pipe overall length of a combination unit. Installs between two Quikclamps Adapters to provide three additional 1/4" Use with the Quikclamp to provide outlets for auxiliary air. threaded connections to the A Porting Block adds 1.13" (28.5 system piping. mm) to the overall length of a combination unit. A pipe adapter adds 0.63" (16 Part Number: 4214-51 mm) to the overall length of a combination unit. ______________________________ Auxiliary Manifold Block Installs 4228-01/03(72MnfldBlk) with Quikclamps. Ports are threaded 3/8" pipe to provide manifolding capability for up to three components. 1.76 (45) Port Size and Thread Part Number (Quantity of 1) 1/4" PTF 4215-02 3/8" PTF 4215-03 1/4" ISO G 4215-08 3/8" ISO G 4215-09 1.98 (50) Side Port Threads Part Number 3/8" PTF 4228-01 3/8" ISO G 4228-03 Auxiliary Port Size & Thread Part Number 1/4" NPT 4216-50 1/4" IS0 G 4216-52 ______________________________ Part Number 1/4" PTF 4246-50 1/4" ISO G 4246-52 ______________________________ Transition Connector Enables connection of Excelon 72 to 74 units. Typically this will allow F74C/H high grade coalescing filters to be flow matched with R72 regulators. Replacement Pressure Switch Use only with pressure switch sub-base. Cannot be used with the standard porting block. Part Number: For further information www.norgren.com Port Threads AIR PREPARATION PRODUCTS Quikclamp Part Number: 4417-01 4246-01 APP-135 4 73 and 74 Series Modular Components Material: Zinc Quikclamp part number: 4314-51 O-ring kit part number: 4384-770 ______________________________ Use with the Quikclamp to provide secure mounting to a wall, machine panel or other flat surface. Use No. 12 (6 mm) screws to mount bracket to wall. Port size and (Qty) thread 4315-01 1/4" PTF 4315-02 3/8" PTF 4315-03 1/2" PTF 4315-04 3/4" PTF 4315-09 1/4" ISO G 4315-10 3/8" ISO G 4315-11 1/2" ISO G 4315-12 3/4" ISO G APP-136 5( Material: Aluminum Pressure switch part number: 4346-01 Material: Zinc Part number: 4313-50 ______________________________ ______________________________ Subbase Mounted Pressure Switch Quikclamp and Wall Mounting Bracket See preceding paragraphs for descriptions and dimensions. ll Wa 2.0 0( 51 CL rt 57 ) ) ) 80 5( 3.1 Material: Zinc Part number Side port threads 4328-50 3/4" PTF 4328-52 3/4"ISO Rc Monitors air pressure and provi______________________________ des an electrical output when the pressure drops below or exceeds an adjustable preset pressure. Installs Transition Connector between two Quikclamps. Also 4417-01Adapter Enables connection of Excelon 72 provides three additional 1/4" outlets 4346-50/52AccSubMtdSw to 74 units. A transition connector for auxiliary air. adds 0.06" (1.5mm) to the overall A Subbase Mounted Pressure length of a combination unit. Switch adds 1.30" (33 mm) to the overall length of a combination unit. Po Material: Zinc Part number: 4314-52 L74 1 quart 4314-55 ______________________________ Installs between two Quikclamps Part number 1) 2.2 80 (3.15) Porting Block Material: Aluminum Installs with Quikclamps. Ports are threaded 3/4" pipe to provide manifolding capability for up to three components. ) Quikmount Pipe Adapters Use with the Quikclamp to provide threaded connections to the system piping. Each pipe adapter adds 0.71" (18 mm) to the overall length of a 4315-01/12AccPipeAdptr combination unit (each kit contains one adapter). Use only with the pressure switch subbase. Cannot be used with the standard porting block. Manifold Block 24 5( 0.9 Replacement Pressure Switch 4346-01AccPressSw 4.00 (102) Use with all 73 and 74 Series Products to provide modular installation capability. Flanges on the products slide into V grooves in the Quikclamp. Two face-sealing o-rings in the Quikclamp provide a positive seal when the clamp is closed and the captive screw is tightened. A Quikclamp adds 0.54" 4314-51AccQukclmp (13.6 mm) to the overall length of a combination unit. Tighten screw with a 5/32" (4 mm) hex or T25 Torx wrench. (30 in. lbs. Torque) Quikclamp Wall Mounting Bracket 3.25 (83) AIR PREPARATION PRODUCTS Quikclamp to provide three additional 1/4" outlets for auxiliary air. A Porting Block adds 1.30" (33 4316-02/06AccPrtBlk mm) to the overall length of a combination unit. Material: Zinc Part number Auxiliary port size and thread 4316-50 1/4" PTF 4316-52 1/4" IS0 G Material: Aluminum Part Number: 4417-01 Specifications Maximum Pressure: 300 psig (20 bar) Maximum Temperature: 175°F (80°C) Adjustable Range:  30 to150 psig (2 to 10 bar) Shipped from factory preset at 90 psig (6.2 bar). Maximum Voltage: 240V ac/dc Maximum Current: 5 Amp Hysteresis at Midpoint: 12% Materials: Zinc subbase, Aluminum switch Part number Auxiliary port thread 4346-50 1/4" PTF 4346-52 1/4" ISO G For further information www.norgren.com 4 64 Series Modular Components Double Yoke 4.13 (105)* 1.46 (37) 2.91 (74) 7.28 (185)* 2.91 (74) 1.46 (37) Yoke Connector * 3/4 = 9.33 (237) 1/4 Y64A-2AA-N1N 1/4 Y64A-2AA-N2N 3/8 Y64A-3AA-N1N 3/8 Y64A-3AA-N2N 1/2 Y64A-4AA-N1N 1/2 Y64A-4AA-N2N 3/4 Y64A-6AA-N1N 3/4 Y64A-6AA-N2N Porting Block G3/8 1.63 (41.5) • (2) 1/4 outlets • (1) 3/8 outlet Adjustable Pressure Switch • 30-150 psi (2–10 bar) adjustable • Porting block mounted • DIN 43650 form C connector 3.78 (96) G1/4 1.61 (41) P1 max. = 250 psi (17 bar) T max. = 175°F (80°C) 74507-52 PTF 74507-50 ISO G 1.61 (41) P1 max. = 250 psi (17 bar) T max. = 175°F (80°C) I max. = 5 A V max. = 240 V Reset differential = 15 psi (1 bar) nominal 74503-51 End Connector • For use with end mounted porting block • 1/2 or 3/4 over porting 1.38 (35) * 3/4= 6.18 (157) AIR PREPARATION PRODUCTS Single Yoke 1.2 (26) 1/2 74505-52 PTF 3/4 74505-55 PTF 1/2 74505-50 ISO G 3/4 74505-53 ISO G 4346-99 For further information www.norgren.com APP-137 4 68 Series Modular Components AIR PREPARATION PRODUCTS Alternative 68 Series Yoke Assembly Models Y68 H - H H N - H H H Wall Mounting Bracket Substitute Shut-Off Valve and Porting Block Substitute No shut-off valve, No porting block A Without With shut-off valve, No porting block B With B With shut-off valve, With porting block E Yoke Substitute F Single 1 Substitute Double 2 No shut-off valve, With porting block Port Size N 3/4" 6 Triple 1" 8 Shut-Off Valve Type 1 1/4" A B 2-port/2-position, Padlocks open or closed, No exhaust, Black handle A 1 1/2" 3-port/2-position, Padlocks open or closed, Unthreaded exhaust, Black handle C 3-port/2-position, Not lockable, Threaded exhaust, Black handle D Threads Substitute PTF A ISO Rc taper B ISO G parallel G 3-port/2-position, Padlocks closed only, Unthreaded exhaust, Yellow handle 3 Substitute E* 2-port/2-position, Not lockable, No exhaust, Black handle G No shut-off valve N * Meets OSHA requirements. APP-138 For further information www.norgren.com 4 68 Series Modular Components Single Yoke Comprising seal, screws and nuts. Part Number 18-026-987 ______________________________ Double Yoke Assembly 4.92 (125) Mounting Bracket Part Number Single Yoke Assembly 4.26 (108) 4.25 (108) Part Number: 74785-98 ______________________________ 2.13 (54) 12.4 (315) 2.13 (54) Brackets slip over end connectors and are bolted to Yoke Assembly with nuts and screws provided. Note: Each kit contains 6 screws (2 x 80 mm and 4 x 35 mm) and 4 nuts. Port Size NPT 1/2 NPT 3/4 NPT 1 NPT 1-1/4 NPT 1-1/2 AIR PREPARATION PRODUCTS Yoke Connecting Kit Y68A-4AN-N2N Y68A-6AN-N2N Y68A-8AN-N2N Y68A-AAN-N2N Y68A-BAN-N2N ______________________________ 3/4" ported yoke 1" ported yoke 1-1/4" ported yoke 1-1/2" ported yoke 18-001-979 18-001-979 18-001-978 N/A ______________________________ 4.25 (108) 18-001-979 2.13 (54) 7.48 (190) 1/2" ported yoke Port Size NPT 1/2 NPT 3/4 NPT 1 NPT 1-1/4 NPT 1-1/2 Y68A-4AN-N1N Y68A-6AN-N1N Y68A-8AN-N1N Y68A-AAN-N1N Y68A-BAN-N1N ______________________________ For further information www.norgren.com APP-139 4 Filter Accessories 6212-50/51Dim 6212-50/51Bkt(Isometric) Wall bracket 1.50 (38) 3/4", 1" Ports: 6212-50 1-1/4", 1-1/2" Ports: 6212-51 0.93 (24) 18-001-962 0.22 (6) 0.34 (9) Dia. 1.02 (26) Wall bracket 1.33 (34) 0.29 (7) F22 Port C L 1.69 (43) F17 1.00 (25) 3.19 (81) 5939-06 5.13 (130) Wall bracket F17, F46 Bracket (6212-50, 6212-51) 3.00 (76) F07 5939-06Dim F07, F39 Bracket (5939-06) 1.34 (34) Part No. 2.06 (52) Accessory 1.59 (40) AIR PREPARATION PRODUCTS Product 5939-06 F46 Wall bracket 3/4", 1" Ports: 6212-50 1-1/4", 1-1/2" Ports: 6212-51 F64 Wall bracket 74504-50 1.22 (31) 6212-50/51Bkt(Isometric) 4.80 (122) 4.06 (103) 0.33 (8.5) Wall bracket 3.54 (90) F39 2.05 (52) F22 Bracket (18-001-962) 3.66 (93) 4.49 (114) 0.43 (11) 4.33 (110) 0.32 (8.2) 5.63 (143) 1.20 (30.5) 3.35 (85) 1.89 (48) F64 Bracket (74504-50) 0.57 (14.5) Dimensions in inches (mm) APP-140 For further information www.norgren.com 4 Filter Accessories F68 Wall bracket Part No. F68 Bracket (18-001-978) 1/2", 3/4", 1", 1-1/4" Ports: 18-001978 1-1/2" Ports: Not Available 2.84 (72) Accessory AIR PREPARATION PRODUCTS Product 4424-50Acc73Bkt 7.48190 (190) Wall Bracket 4424-50 0.33 (8.5) F73 4424-50Acc73Bkt 0.59 (15) 4224-50 1.97 (50) Wall bracket 3.94 (100) F72 7.48 (190)* F72 Bracket (4224-50) Visual service indicator Turns from green to red when element needs to be replaced. 5797-50 0.20 (5) 0.79 0.47 (20) (12) 0.16 (4) Port C L 0.71 (18) 1.50 (38) Port LC 4324-50DimBkt 0.71 (18) 2.40 (61) 4020-51R 0.16 (4) 0.24 (6) 5797-50AccSrvcInd 1.10 (28) 0.28 (7) Electric service indicator Rated NEMA 4 Provides electrical signal when element needs to be replaced. 4324-50 0.74 (19) Wall bracket 1.54 (39) F74 Port L C 2.36 (60) Port C L 2.64 (67) 2.37 (60) 1.77 (45) 1.89 (48) 5797-50 F73 Bracket (4424-50) 2.00 (51) 4324-50Bkt 4424-50DimBkt * Add 0.39" (10) for 1-1/4" ported yokes. 1.50 (38) Visual service indicator Turns from green to red when element needs to be replaced. 4020-51R 5797-50AccSrvcInd 0.24 (6) Electric service indicator Provides electrical signal when element needs to be replaced. Rated NEMA 4. 8.19 (208)* 4224-50Dim(72BktDim) F74 Bracket (4324-50) 1.00 (25) 3.25 (83) 0.77 (20) Port C L 1.46 (37) 2.40 (61) 0.16 (4) 1.97 (50) 0.20 (5) Port C L 0.24 (6) 2.00 (51) 2.88 (73) Dimensions in inches (mm) For further information www.norgren.com APP-141 4 Regulator Accessories 18-025-003BktDim 2962-89 18-001-021 R06 Wall bracket for R06 with plastic bonnet Bracket and plastic nut: 18-025-003 Plastic nut: 2962-89 Metal nut: 2962-04 1.50 (38) 0.29 (7) 0.93 (24) Bracket and metal nut: 18-001-021 Metal nut: 616-01 0.69 (18) Wall bracket for R06 with brass bonnet 1.63 (41) Plastic panel nut 0.63 (16) R05 R06, R07 Bracket (18-025-003) 0.22 (6) Part No. 2.47 (63) Accessory 0.38 (10) AIR PREPARATION PRODUCTS Product 18-001-021BktDim R06 Bracket for Brass Bonnet (18-001-021) Tamper resistant knob kit R07 Wall bracket with plastic nut 0.63 (16) 2.41 (61) 1.63 (41) 18-001-092 Bracket and plastic nut: 18-025-003 Plastic nut: 2962-89 Metal nut: 2962-04 1.38 (35) 0.54 (14) 1.08 (27) 3.50 (89) 4.50 (114) 0.56 (14) 3/4 PTF: MB006A R 3/4: MB006B Pipe CL 1.19 (30) Muffler 2117-01 0.28 (7) R18 5570-04BktDim R17 Bracket (5570-04) 2117-01LckWire Tamper resistant seal wire 0.38 (10) Bracket and metal nut: 5570-04 Metal nut: 5226-97 3.19 (81) Wall bracket with plastic nut 0.69 (18) 1.0 (25) 18-001-092 5570-04Bkt(Isometric) R17 0.22 (6) 0.35 (9) Tamper resistant knob kit 0.69 (18) Dimensions in inches (mm) APP-142 For further information www.norgren.com 4 Regulator Accessories Wall bracket (neck mount) Stainless steel wall bracket and metal nut: 18-001-959 Metal nut: 5988-02 2.95 (75) 4.17 (106) Reducing bushing for gauge ports 3/8 to 1/4 PTF: 5950-01 1/2 to 1/4 PTF: 2339-04 R1/4 to G1/8: 150232818 R3/8 to G1/8: 150233818 R1/2 to G1/8: 150234818 2.13 (54) 0.33 (8.5) Bracket and metal nut: 18-999-412 Bracket: 18-001-996 Plastic nut: 2962-89 Metal nut: 2962-04 1.22 (31) Wall bracket with metal nut 0.98 (25) 3.39 (86) R24 2.00 (50) 18-001-962 0.33 (8.5) Stainless steel wall bracket 3.11 (79) R22 R22 Neck Bracket (18-001-959) R22 Bracket (18-001-962) 2.05 (52) Part No. 3.18 (81) Accessory AIR PREPARATION PRODUCTS Product R24 Bracket (18-999-412) 1.73 (44) 3.05 (77.5) 1.73 (44) 18-021-006 3.05 (77.5) Tamper resistant cap 1.8 (46) 1.8 (46) 1.26 (32) 3.23 (82) 2.95 (75) 2.64 (67) 2.91 (74) 0.2 (5) 0.2 (5) 1.26 (32) 1/4", 3/8", 1/2" Ports 3/4", 1", 1-1/4" Ports Dimensions in inches (mm) For further information www.norgren.com APP-143 4 Regulator Accessories Part No. R38 Bracket (18-001-974) 2.95 (75) Aluminum wall bracket and nut: 18-001-974 Aluminum nut: 5988-01 1.50 (38) Accessory R38 Stainless steel wall bracket and nut: 18-001-973 Stainless steel nut: 5988-02 2.95 (75) 2.13 (54) 74630-04 Plastic adjusting knob Bracket and metal nut: 5203-06 Plastic nut: 5191-89 Metal nut: 5191-88 2117-01LckWire 2117-01 R40, R41, R43 Bracket (5203-06) Plastic nut: 2962-89 Metal nut: 2962-04 1.0 (25) Bracket and metal nut: 18-001-021 Metal nut: 616-01 1.5 (38) Wall bracket for R44 with brass bonnet 18-025-003BktDim R44 Bracket for Brass Bonnet 18-001-021BktDim R44 Bracket (18-025-003) 2.41 (61) 0.63 (16) (18-001-021) 1.63 (41) 18-001-092 2.47 (63) Tamper resistant knob 1.50 (38) 1.38 (35) 0.22 (6) 0.69 (18) 0.38 (10) 0.69 (18) 1.0 (25) 0.35 (9) 0.69 (18) 0.38 (10) 0.29 (7) 0.93 (24) 0.66 (17) 0.27 (7) 1.5 (38) 1.63 (41) Wall bracket for R44 with plastic bonnet 1.5 (38) R44 2.5 (64) 18-001-021 Bracket and plastic nut: 18-025-003 2.75 (70) Tamper resistant seal wire 5203-06BktDimR/B08 0.63 (16) Wall bracket with metal nut 0.22 (6) R40 R41 R43 0.34 (8.5) 5203-06AccBkt 1.10 (28) AIR PREPARATION PRODUCTS Product Dimensions in inches (mm) APP-144 For further information www.norgren.com 4 Regulator Accessories 4348-89 54547-01AccLkoutHasp Cover and wire: 4355-51 54547-01 0.43 (11) 1/2", 3/4", 1", 1-1/4" Ports: 18-0014355-51TmprResCvr 978 R68 Bracket (18-001-978) 54547-01AccLkoutHasp Cover and wire: 4355-51 Wire: 2117-01 7.48190 (190) 4424-50Acc73Bkt 3.94 (100) 0.59 (15) Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. R72 2.84 (72) 1-1/2" Ports: Not Available Tamper resistant cover and wire. Install over knob to help prevent tampering of pressure setting. Use up to 4 padlocks with 5/16" (8mm) diameter shackle to secure cover. Lockout hasp may also be used. 0.57 (14.5) 54547-01 0.33 (8.5) Wall bracket 4.49 (114) 3.66 (93) Wire: 2117-01 Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. R68 5.63 (143) 0.32 (8.2) Tamper resistant cover and wire. Install over knob to help prevent tampering of pressure setting. Use up to 4 padlocks with 5/16" (8mm) diameter shackle to secure cover. Lockout hasp may also be used. 4.33 (110) 4355-51TmprResCvr 1.97 (50) Metal panel nut R64 Bracket (74504-50) 1.89 (48) 74504-50 1.20 (30.5) Part No. Wall bracket 3.35 (85) Accessory R64 AIR PREPARATION PRODUCTS Product 4224-50Dim(72BktDim) Wall bracket 5203-06BktDimR/B08 7.48 (190)* 8.19 (208)* 4224-50 * Add 0.39" (10) for 1-1/4" ported yokes. R72 Bracket (4224-50) 1.77 (45) 2.36 (60) 0.3 (8) Port C L 0.71 (18) 0.3 (8) 0.2 (4) 54547-01 1.2 (30) .60 (15) 0.16 (4) 0.79 0.47 (20) (12) 1.0 (25) Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. 0.20 (5) 1.50 (38) Cover and wire: 4255-51 Wire: 2117-01 1.54 (39) Tamper resistant cover and wire. Install over knob to help prevent tampering of pressure setting. Use up to 2 padlocks with 5/16 (8mm) diameter shackle to secure cover. Lockout hasp may also be used. Port C L 1.9 (49) 2.36 (60) 54547-01AccLkoutHasp 1.50 (38) Plastic nut: 4248-89 Metal Nut: 4248-01 2.00 (51) 4355-51LkShrudAsm Bracket and plastic nut: 74316-50 0.24 (6) Wall bracket/plastic nut R72 Neck Bracket (74316-02) Dimensions in inches (mm) For further information www.norgren.com APP-145 4 4461-50BktDimR/B08 Regulator Accessories 4424-50DimBkt 2.37 (60) 4455-51TmprResCvr 1.10 (28) 0.71 (18) Cover and wire: 4455-51 Wire: 2117-01 54547-01AccLkoutHasp Port LC 1.5 (38) 0.74 (19) Tamper resistant cover and wire. Install over knob to help prevent tampering of pressure setting. Use up to 4 padlocks with 5/16" (8mm) diameter shackle to secure cover. Lockout hasp may also be used. 1.89 (48) 0.16 (4) 2.75 (70) Bracket and metal nut: 4461-50 Metal Nut: 5191-88 Plastic Nut: 5191-89 1.5 (38) Port L C Wall bracket/metal nut 2.5 (64) 1.50 (38) 4461-50AccBkt 1.0 (25) 4424-50 1.5 (38) Wall bracket 2.64 (67) R73 R73 Neck Bracket (4461-50) R73 Bracket (4424-50) 0.24 (6) Part No. 2.40 (61) Accessory 0.28 (7) AIR PREPARATION PRODUCTS Product 0.66 (17) 0.27 (7) 4424-50Acc73Bkt 4324-50DimBkt 54547-01 Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. 4324-50Bkt 2.88 (73) 54547-01AccLkoutHasp Port C L 3.37 (86) 2.06 (52) 2.2 (56) 1.38 (35) 1.00 (25) 0.95 (24) 0.28 (7) Cover and wire: 4355-51 Wire: 2117-01 1.46 (37) 0.77 (20) Tamper resistant cover and wire. Install over knob to help prevent tampering of pressure setting. Use up to 4 padlocks with 5/16" (8mm) diameter shackle to secure cover. Lockout hasp may also be used. 0.16 (4) 1.97 (50) 0.20 (5) Bracket and metal nut: 4368-51 4355-51TmprResCvr Metal Nut: 4348-89 0.9 (23) Port C L Wall bracket/metal nut 3.5 (89) 3.25 (83) 4324-50 2.40 (61) 4368-51AccBkt/Nut 0.24 (6) Wall bracket 2.00 (51) R74 R74 Neck Bracket (4368-51) R74 Bracket (4324-50) 54547-01 Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. Dimensions in inches (mm) APP-146 For further information www.norgren.com 4 Regulator Accessories Part No. R81 R82 R83 R84 Wall bracket 5095-51 R81, R82, R83, R84 Bracket (5095-51) Nipple 1/4 PTF: 2891-97 2.75 (70) Pipe plug, hex socket 0.28 (7) Typ 0.31 (8) Typ Accessory AIR PREPARATION PRODUCTS Product 1/4 PTF male: 18-006-067 Cylinder connector, carbon dioxide service, 0.830-14 RH internal thread 8) 2 (51) 3( CGA No. 580: 18-008-004 1( 0.5 (13) 1.0 Cylinder connector, nitrogen service, 0.906-14 RH external thread 0.3 26 ) CGA No 320: 18-008-002 With 2.25" (57mm) long nipple: 18-008-015 Replacement gasket: 1390-02 Dimensions in inches (mm) For further information www.norgren.com APP-147 4 Regulator Accessories 18-025-003BktDim Tamper resistant knob 1.50 (38) 18-001-092 0.29 (7) 11-002 Wall bracket 1.63 (41) Bracket and plastic nut: 18-025-003 Plastic nut: 2962-89 Metal nut: 2962-04 0.63 (16) Wall bracket with plastic nut R91 Bracket (18-025-003) 0.93 (24) 0.69 (18) 0.22 (6) R91 Part No. 2.47 (63) Accessory 0.38 (10) AIR PREPARATION PRODUCTS Product 18-001-003 11-002 Bracket 11-008 Bracket (Units with 1/2" Ports) (18-001-003) 2.44 (62) 1.25 (32) 1.88 (48) 0.28 (7) 0.63 (16) 2.25 (57) 10-003-001AccHndWhel 18-003-004 Panel mount kit with T-bar adjustment Bonnet included 0.44 (11) 3.25 (83) 18-003-003AccTBar 18-003-002 11-008 Bracket (Units with 3/4" and 1" Ports) (18-001-027) 4.88 (124) Panel mount kit with screw adjustment Bonnet included 18-003-006 2.94 (75) 18-003-005 5.38 (137) Panel mount kit with hand wheel adjustment Bonnet included 3.27 (83) Units with 1/2" ports: 18-001-003 Units with 3/4" and 1" ports: 18-001-027 3.31 (84) Wall bracket 0.32 (8) 11-008 Dimensions in inches (mm) APP-148 For further information www.norgren.com 4 Regulator Accessories 18-001-029BktDim 11-009 Bracket (18-001-029) 4.88 (124) 11-018 1095-02 Tamper resistant cap 0.63 (16) 3.25 (83) 0.31 (8) Screw adjustment 3.19 (81) Port CL 639-02 2.00 (51) Part No. 18-001-029 0.50 (13) 1095-02 3.19 (81) Wall bracket 2.94 (75) Accessory 11-009 Port CL 18-025-003BktDim Wall bracket with plastic nut 11-044 Bracket (18-025-003) Bracket and plastic nut: 18-025-003 Plastic nut: 2962-89 Metal nut: 2962-04 1140020AL11-104- 18-001-003 0.69 (18) Wall bracket 0.93 (24) 0.38 (10) 18-001-092 0.63 (16) 1.50 (38) 0.29 (7) Tamper resistant knob 1.63 (41) 11-044 3/4 PTF: MB006A R3/4: MB006B 0.22 (6) Muffler 2.47 (63) 11-042 AIR PREPARATION PRODUCTS Product 11400- Bracket 20AL Bracket (18-001-003) 2.25 (57) 2.44 (62) 1.25 (32) 0.28 (7) 0.63 (16) 1.88 (48) 0.44 (11) 3.25 (83) Dimensions in inches (mm) For further information www.norgren.com APP-149 4 Filter/Regulator Accessories 18-025-003BktDim B05 Plastic Panel Nut 2962-89 B07 Wall bracket with plastic nut Bracket and plastic nut: 18-025-003 Plastic nut: 2962-89 Metal nut: 2962-04 B07, B39 Bracket (18-025-003) 0.63 (16) 1.63 (41) Part No. 2.47 (63) Accessory 0.29 (7) 18-001-092 0.69 (18) Tamper resistant knob 0.93 (24) 0.22 (6) 1.50 (38) 0.38 (10) AIR PREPARATION PRODUCTS Product Aluminum wall bracket and nut: 18-001-974 Aluminum nut: 5988-01 Plastic adjusting knob 2.95 (75) B38 1.50 (38) B38 Bracket (18-001-974) Stainless steel wall bracket and nut: 18-001-973 Stainless steel nut: 5988-02 2.95 (75) 2.13 (54) Wall bracket with plastic nut Tamper resistant knob Bracket and plastic nut: 18-025-003 Plastic nut: 2962-89 Metal nut: 2962-04 1.10 (28) B39 0.34 (8.5) 74630-04 18-001-092 Dimensions in inches (mm) APP-150 For further information www.norgren.com 4 Filter/Regulator Accessories 74504-50 Cover and wire: 4355-51 54547-01AccLkoutHasp Wire: 2117-01 Wall bracket 4.49 (114) 54547-01 Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. B68 5.63 (143) 3.66 (93) Tamper resistant cover and wire. Install over knob to help prevent tampering of pressure setting. Use up to 4 padlocks with 5/16" (8mm) diameter shackle to secure cover. Lockout hasp may also be used. 3.35 (85) 4355-51TmprResCvr 0.43 (11) 1/2", 3/4", 1", 1-1/4" Ports: 18-001-978 4355-51TmprResCvr 1-1/2" Ports: Not Available 4.33 (110) Wall bracket 1.89 (48) B64 B64 Bracket (74504-50) 1.20 (30.5) Part No. 0.32 (8.2) Accessory AIR PREPARATION PRODUCTS Product 0.57 (14.5) 54547-01AccLkoutHasp Cover and wire: 4355-51 7.48190 (190) 0.59 (15) 0.33 (8.5) 54547-01 1.97 (50) Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. Wire: 2117-01 3.94 (100) Tamper resistant cover and wire. Install over knob to help prevent tampering of pressure setting. Use up to 4 padlocks with 5/16" (8mm) diameter shackle to secure cover. Lockout hasp may also be used. 2.84 (72) B68 Bracket (18-001-978) 7.48 (190)* 8.19 (208)* * Add 0.39" (10) for 1-1/4" ported yokes. Dimensions in inches (mm) For further information www.norgren.com APP-151 5203-06BktDimR/B08 Filter/Regulator Accessories 4 4224-50Dim(72BktDim) 4424-50Acc73Bkt B72 Bracket (4224-50) 1.10 (28) 0.74 (19) L 2.36 (60) 1.50 (38) 0.2 (4) 2.75 (70) 1.5 (38) 4324-50DimBkt B74 Neck Bracket (4368-51) B74 Bracket (4324-50) 2.06 (52) 3.25 (83) 2.00 (51) Port C L Bracket and metal nut: 4368-51 Metal Nut: 4348-89 54547-01 0.9 (23) 1.38 (35) 2.2 (56) 0.24 (6) 1.00 (25) 0.95 (24) 0.77 (20) Port C L 1.46 (37) 2.40 (61) (4) 1.97 (50) Cover and wire: 4355-51 Wire: 2117-01 0.20 (5) 0.16 54547-01AccLkoutHasp 3.37 (86) 3.5 (89) 2.88 (73) 0.28 (7) 54547-01 4324-50 Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. 0.66 (17) 4324-50Bkt Wall bracket Tamper resistant cover and wire. Install over knob to help prevent tampering of pressure setting. Use up to 4 padlocks with 5/16" (8mm) diameter shackle to secure cover. Lockout hasp may also be used. 1.0 (25) 1.89 (48) 0.28 (7) Cover and wire: 4455-51 Wire: 2117-01 1.5 (38) 1.5 (38) 0.16 (4) 54547-01AccLkoutHaspPort C 4355-51TmprResCvr APP-152 0.71 (18) 2.40 (61) Bracket and metal nut: 4461-50 Metal Nut: 5191-88 Plastic Nut: 5191-89 2.5 (64) 0.27 (7) 4424-50 4455-51TmprResCvr Wall bracket/metal nut .60 (15) 2.37 (60) 4368-51AccBkt/Nut B74 B73 Neck Bracket (4461-50) B73 Bracket (4424-50) Port L C Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. 4461-50BktDimR/B08 4424-50DimBkt 4424-50Acc73Bkt Tamper resistant cover and wire. Install over knob to help prevent tampering of pressure setting. Use up to 4 padlocks with 5/16" (8mm) diameter shackle to secure cover. Lockout hasp may also be used. 0.3 (8) 54547-01 4461-50AccBkt Wall bracket/metal nut 1.0 (25) 0.24 (6) Port C L 0.71 (18) 2.64 (67) Wall bracket 0.16 (4) 0.24 (6) Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. Cover and wire: 4255-51 Wire: 2117-01 1.2 (30) 1.54 (39) Tamper resistant cover and wire. Install over knob to help prevent tampering of pressure setting. Use up to 2 padlocks with 5/16" (8mm) diameter shackle to secure cover. Lockout hasp may also be used. 0.79 0.47 (20) (12) 0.3 (8) Bracket and plastic nut: 74316-50 Plastic nut: 4248-89 Metal Nut: 4248-01 54547-01AccLkoutHasp 0.20 (5) B73 1.9 (49) Port C L 4355-51LkShrudAsm Wall bracket/plastic nut B72 Neck Bracket (74316-02) 1.77 (45) 2.36 (60) 4224-50 2.00 (51) Part No. Wall bracket 1.50 (38) Accessory B72 1.50 (38) AIR PREPARATION PRODUCTS Product Dimensions in inches (mm) For further information www.norgren.com 4 Lubricator Accessories 18-025-003BktDim 6212-50/51Bkt(Isometric) L17 Wall bracket - use with 1 and 2 quart reservoirs only 1.63 (41) Bracket and plastic nut: 18-025-003 Plastic nut: 2962-89 Metal nut: 2962-04 0.63 (16) Wall bracket with plastic nut L07 Bracket (18-025-003) 1.50 (38) 3/4", 1" Ports: 6212-50 1-1/4", 1-1/2" Ports: 6212-51 0.93 (24) 5605-60 0.69 (18) 0.38 (10) 0.29 (7) 0.22 (6) L07 Part No. 2.47 (63) Accessory 18-001-039/056 Pyrex dome and metal fill plug 5605-60 6212-50/51Dim L17 Strap (18-001-039/056) L17 Bracket (6212-50, 6212-51) A 3.19 (81) 5.13 (130) 5301-52 B 1.00 (25) Port C L 1.50 (38) 5301-52 1.69 (43) Fill plug with 1/8 PTF tapped hole. Use with customer supplied pressurized oil source to refill reservoir without shutting off air supply. Replaces standard fill plug. 18-011-021 3.00 (76) Quick fill cap. Use with 18-010-003 oil pump, pail, and hose assembly (see catalog sheet NC-26) to refill reservoir without shutting off air supply. Replaces fill plug. Wall bracket 0.56 (14) Dia. Bracket A B 18-001-056 3.00 8.84 (76) (225) 18-001-039 5.00 13.0 (127) (330) 0.34 (9) Dia. L22 AIR PREPARATION PRODUCTS Product 18-001-962 4.80 (122) 4.06 (103) 0.33 (8.5) 1.22 (31) 3.54 (90) 2.05 (52) L22 Bracket (18-001-962) Dimensions in inches (mm) For further information www.norgren.com APP-153 4 Lubricator Accessories Remote fill - use with 7 ounce reservoir only Use with customer supplied pressurized oil source to automatically refill reservoir. Wall bracket 5.63 (143) 18-011-024 5335-50 1/2", 3/4", 1", 1-1/4" Ports: 18-001-978 1-1/2" Ports: Not Available 2117-01LckWire Tamper resistant seal wire for sightfeed dome 4.49 (114) 0.43 (11) 5.3 (134) Quick fill cap Use with 18-010-003 oil pump, pail, and hose assembly (see catalog sheet NC-26) to refill reservoir without shutting off air supply. Replaces fill plug. 1 qt reservoir: 18-023-610 36.6 (93) Low oil level switch. Provides electrical signal for warning or shutdown when oil level is low. 2117-01 3.62 (92) Tamper resistant seal wire for sightfeed dome L68 7 ounce bowl: 74504-50 1 quart bowl: 74504-52 2117-01LckWire 12 (30.5) Wall bracket L64 Bracket (74504-52) 5.09 (129) L64 Part No. 0.32 (8.2) Accessory 0.57 (14.5) L68 Bracket (18-001-978) 2.84 (72) AIR PREPARATION PRODUCTS Product 2117-01 7.48190 (190) Remote fill - use with 1 qt reservoirs only Use with customer supplied pressurized oil source to automatically refill reservoir. 0.33 (8.5) 18-011-021 1.97 (50) Quick fill cap. Use with 18-010-003 oil pump, pail, and hose assembly (see catalog sheet NC-26) to refill reservoir without shutting off air supply. Replaces fill plug. 3.94 (100) 0.59 (15) 7.48 (190)* 8.19 (208)* * Add 0.39" (10) for 1-1/4" ported yokes. 5335-52 Dimensions in inches (mm) APP-154 For further information www.norgren.com 4 Lubricator Accessories 4424-50Acc73Bkt 4424-50Acc73Bkt 4424-50 4.49 (114) 3.66 (93) 18-011-024 4324-50Bkt 4424-50DimBkt 0.43 (11) 2.37 (60) Low oil level switch - use with 1 qt reservoir only Provides electrical signal for warning or shut down when oil level is low. 1.10 (28) 18-023-610 Remote fill - use with 7 ounce reservoir only Use with customer supplied pressurized oil source to automatically refill reservoir. 1.89 (48) 4324-50DimBkt 18-011-024 L74 Bracket (4324-50) 2.88 (73) 5335-50 2.00 (51) Quick fill cap. Use with 18-010-003 oil pump, pail, and hose assembly (see catalog sheet NC-26) to refill reservoir without shutting off air supply. Replaces fill plug. Port LC 0.71 (18) 0.74 (19) 0.28 (7) 0.16 (4) 2.64 (67) Port L C 2.40 (61) L73 Bracket (4424-50) 0.24 (6) 7 ounce bowl: 4324-50 1 quart bowl: 4324-51 0.16 (4) 1.00 (25) 0.77 (20) Port C L 1.46 (37) 1.97 (50) 0.20 (5) Port C L 3.25 (83) Wall bracket 1.50 (38) L74 0.57 (14.5) 0.24 (6) Quick fill cap. Use with 18-010-003 oil pump, pail, and hose assembly (see catalog sheet NC-26) to refill reservoir without shutting off air supply. Replaces fill plug. 5.63 (143) 2.40 (61) Wall bracket 0.32 (8.2) L73 4.33 (110) 4224-50 1.89 (48) Wall bracket L64 Bracket (74504-50) 1.20 (30.5) L72 Part No. 3.35 (85) Accessory AIR PREPARATION PRODUCTS Product Dimensions in inches (mm) For further information www.norgren.com APP-155 4 Relief Valve Accessories 18-025-003BktDim Bracket and metal nut: 18-001-021 Metal nut: 616-01 0.63 (16) 1.63 (41) Wall bracket for V06 with brass bonnet (18-001-021) 0.63 (16) Bracket and plastic nut: 18-025-003 Plastic nut: 2962-89 Metal nut: 2962-04 1.50 (38) 74504-50 Muffler 1/2 PTF: MB004A R1/2: MB004B 0.43 (11) 4.33 (110) Wall bracket 4.49 (114) 3.66 (93) V64 0.69 (18) 1.89 (48) 5.63 (143) 1.20 (30.5) 18-001-092 V64 Bracket (74504-50) 0.32 (8.2) Tamper resistant knob kit Bracket and plastic nut: 18-025-003 Plastic nut: 2962-89 Metal nut: 2962-04 0.38 (10) Wall bracket with plastic nut 3.35 (85) V07 0.69 (18) 0.35 (9) 1.0 (25) 0.29 (7) 0.69 (18) 18-001-092 1.38 (35) 0.22 (6) Tamper resistant knob kit 0.93 (24) 0.22 (6) Wall bracket for V06 with plastic bonnet 2.41 (61) V06 18-001-021BktDim V06 Bracket for Brass Bonnet V06, V07 Bracket (18-025-003) 1.63 (41) Part No. 2.47 (63) Accessory 0.38 (10) AIR PREPARATION PRODUCTS 18-001-021 Product 0.57 (14.5) 7.48 (190) 1/2 PTF: MB008A R1/2: MB008B 0.59 (15) 3.94 (100) Muffler 3/4", 1", 1-1/4" Ports: 18-001-978 1-1/2" Ports: Not Available 0.33 (8.5) Wall bracket 1.97 (50) V68 2.84 (72) V68 Bracket (18-001-978) 7.48 (190)* 8.19 (208)* * Add 0.39" (10) for 1-1/4" ported yokes. Dimensions in inches (mm) APP-156 For further information www.norgren.com 5203-06BktDimR/B08 Relief Valve Accessories 4 4224-50Dim(72BktDim) 4424-50Acc73Bkt Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. 0.16 (4) 54547-01AccLkoutHasp Port C L 0.71 (18) Cover and wire: 4255-51 Wire: 2117-01 2.36 (60) 1.50 (38) 4324-50DimBkt 54547-01 V74 Neck Bracket (4368-51) V74 Bracket (4324-50) 3.5 (89) Port C L 2.06 (52) 4324-50 4368-51AccBkt/Nut 3.25 (83) 2.00 (51) Wall bracket 0.95 (24) 0.28 (7) 1.38 (35) 1.00 (25) 0.9 (23) Port C L 1.46 (37) 2.40 (61) 4355-51TmprResCvr 0.16 (4) 0.24 (6) Bracket and metal nut: 4368-51 Metal Nut: 4348-89 1.97 (50) Wall bracket/metal nut 0.20 (5) 2.2 (56) 3.37 (86) 4324-50Bkt 2.88 (73) V74 0.3 (8) 0.3 (8) 0.79 0.47 (20) (12) 1.54 (39) Tamper resistant cover and wire. Install over knob to help prevent tampering of pressure setting. Use up to 2 padlocks with 5/16" (8mm) diameter shackle to secure cover. Lockout hasp may also be used. 0.20 (5) 0.2 (4) 4355-51LkShrudAsm 1.2 (30) 1.0 (25) Bracket and plastic nut: 74316-50 Bracket and metal nut: 74316-51 Plastic nut: 4248-89 Metal Nut: 4248-01 1.9 (49) 0.24 (6) Port C L Wall bracket/plastic nut V72 Neck Bracket (74316-02) .60 (15) 1.77 (45) 2.36 (60) V72 Bracket (4224-50) 4224-50 2.00 (51) Part No. Wall bracket 1.50 (38) Accessory V72 AIR PREPARATION PRODUCTS Product 0.77 (20) 54547-01AccLkoutHasp Tamper resistant cover and wire. Install over knob to help prevent tampering of pressure setting. Use up to 4 padlocks with 5/16" (8mm) diameter shackle to secure cover. Lockout hasp may also be used. Cover and wire: 4355-51 Wire: 2117-01 Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. 54547-01 Dimensions in inches (mm) For further information www.norgren.com APP-157 4 Accessories 54463-01AccDifuser Part No. T72 Bracket (4224-50) 4224-50 1.77 (45) Port C L Mufflers (T72T) Diffuser (10-32 and M5): 54547-01AccLkoutHasp 54463-01 Muffler (10-32): MS000A Muffler (M5): T40M0500 0.20 (5) 0.16 (4) Port C L 0.71 (18) Lockout hasp.(use only with T72E and T72T) Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. 0.79 0.47 (20) (12) 2.00 (51) Wall bracket 1.50 (38) T72 0.24 (6) Accessory 1.54 (39) AIR PREPARATION PRODUCTS 4424-50Acc73Bkt Product 2.36 (60) 4224-50Dim(72BktDim) 54547-01 54547-01AccLkoutHasp T64 Muffler (T64T) Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. Muffler (1/8 PTF): MS001A Muffler (R1/8): T40B1800 54547-01AccLkoutHasp 54547-01 54463-01AccDifuser T68 Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. T73 Mufflers (T73T) 54547-01 54547-01AccLkoutHasp Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. Diffuser (10-32 and M5): 54463-01 Muffler (10-32): MS000A Muffler (M5): T40M0500 54547-01 54547-01AccLkoutHasp T74 Muffler (T74T) Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. Muffler (1/8 PTF): MS001A Muffler (R1/8): T40B1800 54547-01 Dimensions in inches (mm) APP-158 For further information www.norgren.com 4 Accessories 54547-01 Wall bracket 74504-50 P64F 5.63 (143) 4.49 (114) Muffler 3.66 (93) 54547-01AccLkoutHasp 1/2 PTF: MB004A R1/2: MB004B 0.43 (11) Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. 54547-01 Wall bracket 3/4", 1", 1-1/4" Ports: 18-001-978 1-1/2" Ports: Not Available 0.57 (14.5) P68 Bracket (18-001-978) 2.84 (72) P68F 4.33 (110) Lockout hasp for P72F. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. 1.89 (48) 1/4 PTF: MB002A R1/4: MB002B 1.20 (30.5) Mufflers for P72C and P72F 3.35 (85) P72 P64 Bracket (74504-50) 0.32 (8.2) Accessory AIR PREPARATION PRODUCTS 54547-01AccLkoutHasp Part No. Product 7.48190 (190) 54547-01AccLkoutHasp 4324-50Bkt 4324-50DimBkt 7.48 (190)* 8.19 (208)* Wall bracket 4324-50 * Add 0.39" (10) for 1-1/4" ported yokes. P74 Bracket (4324-50) 2.88 (73) 0.16 (4) Port C L 1.46 (37) 1.00 (25) 1.97 (50) 54547-01 Port C L 0.77 (20) Lockout hasp for P74F and P74C with lockout slide: Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. 1/2 PTF: MB004A R1/2: MB004B 0.20 (5) Mufflers for P74C and P74F 2.00 (51) 54547-01AccLkoutHasp 3.25 (83) 54547-01 2.40 (61) Lockout hasp. Allows use of up to 6 padlocks with 5/16" (8mm) diameter shackle. 0.24 (6) P74 0.33 (8.5) 1" PTF: MB008A R1 : MB008B 1.97 (50) 3.94 (100) Muffler 0.59 (15) Dimensions in inches (mm) For further information www.norgren.com APP-159
18-025-003 价格&库存
很抱歉,暂时无法提供与“18-025-003”相匹配的价格&库存,您可以联系我们找货
    • 1+100.62718
    库存:1
