18-013-991
18-013-991
    NORGREN(诺冠)
    NORGREN - 18-013-991 - Pressure Gauge, Air, 0 Bar to 1.6 Bar, R1/8" Connection, 40mm
18-013-991 数据手册
18-015-..., V70534-..., 9273... Pressure gauges > Port size: M5, 1/8” & 1/4”, Ø 4 mm > Laboratories Inc. listed gauges available > Conform to BS EN 837-1:1998 > Wide pressure and temperature and range > Back or bottom connecton > Panel mount, stainless steel and Underwriters Technical features Medium: Compressed air, oil and gases or liquids which do not corrode copper alloys Port connections: White face scale M5, R1/8, G1/8A, G1/4A Ø 6,5 mm (for model 9273... only) Black face scale 1/8 NPT, 1/4 NPT, Ø 5/32 (for North America) Accuracy: 2,5% of full scale Ambient/Media temperature: -40 ... +65°C (-40 ... +150°F) For model 9273... only: -20 ... +52°C (-4 ... +125°F) Air supply must be dry enough to avoid ice formation at temperatures below +2°C (+35 °F) Center back connection, white face Symbol Scale range Materials: Body: ABS, steel or stainless steel Lens: steel or plastic bodies have plastic lens; stainless steel bodies has glass lens Connectors: steel or plastic bodies have brass connector; stainless steel bodies has stainless steel connector For model 9273... only: Body: PA 66 Lens: Polycarbonate ‘O’ ring: NBR Bottom connection, white face bar *1) Mpa psi Model – Diameter & Connection Ø 25 Ø 40 Ø 50 Ø 63 M5 R1/8 R1/8 R1/8 Symbol Scale range bar *1) Mpa psi Model – Diameter & Connection Ø 50 Ø 63 R1/8 G1/4 0 ... 1 — 0 ... 14 — 18-015-887 — 18-015-893 0 ... 1,6 0 ... 0,16 0 ... 23 18-015-024 — 0 ... 1,6 0 ... 0,16 0 ... 23 — 18-015-991 18-015-010 — 0 ... 4 0 ... 0,4 0 ... 58 18-015-025 — 0 ... 2,5 — 0 ... 36 — 18-015-886 — 18-015-892 0 ... 6 0 ... 0,6 0 ... 87 18-015-026 — 0 ... 4 0 ... 0,4 0 ... 58 — 18-015-990 18-015-011 — 0 ... 10 0 ... 1 0 ... 145 18-015-027 18-015-854 0 ... 6 0 ... 0,6 0 ... 87 — 18-015-885 18-015-012 18-015-891 0 ... 16 0 ... 1,6 0 ... 232 — 18-015-853 0 ... 10 0 ... 1 0 ... 145 V70534-500 *2) 18-015-989 18-015-013 18-015-890 0 ... 25 0 ... 2,5 0 ... 362 18-015-028 — 0 ... 16 0 ... 1,6 0 ... 232 — 18-015-884 — 18-015-889 0 ... 25 0 ... 2,5 0 ... 362 — 18-015-908 18-015-014 18-015-888 *1) primary scale *1) primary scale *2) bar and psi scale only Dimensions Dimensions in mm Projection/First angle E C B F G E F G A C A B ØA B C E F G Weight (g) ØA B C E F G 25 M5 28 3,5 16,5 6 12 10 50 R1/8 69 6 28 12,5 14 72 40 R1/8 45 9 26 10 14 49 63 G/14 83 6 28 15 14 104 50 R1/8 50 9 26 14 14 51 63 R1/8 48 6,5 27,5 10 14 90 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (2000 - 8192g) © 2015 Norgren Inc. Weight (g) 12/19 en 8.900.900.01 18-015-..., V70534-..., 9273... Pressure gauges Center back connection, panel mount, white face (secured from front with screws) Symbol Scale range Center back connection, panel mount, white face (secured from rear with clamping bar) Symbol bar *1) Mpa psi Model - Diameter & Connection Ø 40 Ø 63 G1/8A G1/4A bar *1) Mpa psi Model - Diameter & Connection Ø 50 Ø 63 G1/8A G1/4A 0 ... 1,6 0 ... 0,16 0 ... 23 18-015-879 18-015-883 0 ... 1,6 0 ... 0,16 0 ... 23 18-015-996 — 0 ... 6 0 ... 0,6 0 ... 87 18-015-878 18-015-882 0 ... 4 0 ... 0,4 0 ... 58 18-015-995 — 0 ... 10 0 ... 1 0 ... 145 18-015-877 18-015-881 0 ... 6 0 ... 0,6 0 ... 87 18-015-994 — 0 ... 16 0 ... 1,6 0 ... 232 — 18-015-880 0 ... 10 0 ... 1 0 ... 145 18-015-993 18-015-852 0 ... 16 0 ... 1,6 0 ... 232 — 18-015-851 0 ... 25 0 ... 2,5 0 ... 362 18-015-992 — *1) primary scale Scale range Dimensions in mm Projection/First angle B øJ øK øL B D A *1) primary scale R K P L G A M F P C C ØA B C ØD F G ØK ØL P R Weight (g) ØA B C ØJ ØK ØL M P 42 G1/8A 42,5 3,6 25 12 53,5 60,5 23 1 11 81 50 G1/8A 62 48 52 66 0 ... 4,5 30 17 110 63 G1/4A 46,5 3,6 29 16 75 85 26 2 14 79 63 G1/4A 62 62 65 74 0 ... 4,5 37 17 140 Stainless steel gauges Center back connection, white face Symbol Scale range Weight (g) Gauge kit Center back connection, white face bar *1) Mpa lbf/in Model - Diameter & Connection Ø 40 1/8 PTF 1/4 PTF bar Mpa psi Ø 26 0 ... 6 — 0 ... 87 — 18-015-913 0 ... 12 *1) — 0 ... 175 9273KIT-01 0 ... 10 — 0 ... 145 18-015-844 18-015-909 0 ... 12 0 ... 1,2 *1) — 9273KIT-02 0 ... 25 — 0 ... 362 — 18-015-905 2 *1) primary scale Symbol Scale range Model – Diameter *2) *1) primary scale *2) part number = pack of 5 gauges, ‘O’ rings and screw driver ° 38,3 O R B P B 1 G E G A F M F E C 1 H M A N C ‘O’ ring B C E F G M Weight (g) ØA B +0,2 C E F G H +0,2 M N O P R +0,2 Weight (g) 40 1/8 PTF 36 6,5 22 6 9 12 58 26 6,3 2,3 10,5 4,7 2,2 23,5 25,8 33,4 3,8 7 40 1/4 PTF 46,5 7,5 25 11 9 14 74 30° 20,4 N7 6,75 + 0,2 1,68 + 0,17 Interface 17,5 4,25 + 0,3 ØA 1,45 +0,2 3,55 + 0,2 4,85 + 0,3 en 8.900.900.02 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (2000 - 8192g) © 2015 Norgren Inc.  12/19 18-015-..., V70534-..., 9273... Pressure gauges Center back connection, black face (for North America) Symbol Bottom back connection, black face (for North America) Scale range psig *1) bar Mpa Model - Diameter & Connection Ø 1.5” (Ø 40 mm) Ø 2” (Ø 50 mm) Ø 2” (Ø 50 mm) 1/8 NPT 1/8 NPT 1/4 NPT Symbol Scale range psig *1) bar Mpa *4) Model - Diameter & Connection Ø 1.5” (Ø 40 mm) Ø 2” (Ø 50 mm) 1/8 NPT 1/4 NPT 0 ... 30 0 ... 2 0 ... 0.2 18-015-214 18-015-201 18-015-207 0 ... 15 0 ... 1 – – 18-015-082 0 ... 60 0 ... 4 0 ... 0.4 18-015-211 18-015-202 18-015-208 0 ... 30 0 ... 2 0 ... 0.2 18-015-224 18-015-030 *2) 0 ... 100 0 ... 7 0 ... 0.7 – 18-015-203 18-015-235 0 ... 60 0 ... 4 0 ... 0.4 18-015-225 18-015-083 *2) 0 ... 160 0 ... 11 0 ... 1.1 18-015-212 18-015-204 18-015-209 0 ... 100 0 ... 7 0 ... 0.7 18-015-265 18-015-084 *2) 0 ... 300 0 ... 20 0 ... 2.1 18-015-275 18-015-205 18-015-210 0 ... 160 0 ... 11 0 ... 1.1 18-015-273 18-015-085 *2) 0 ... 400 0 ... 28 0 ... 2.8 – 18-015-206 – 0 ... 300 0 ... 20 – – 18-015-086 *2) 0 ... 2000 0 ... 135 – – 18-015-244 *3) 0 ... 3000 0 ... 205 – – 18-015-087 *3) *1) primary scale *1) primary scale *2) Underwriters Laboratories Inc. listed *3) S  hipped with pulsation dampener installed. Please add -9D to the end of model number *4) Mpa scale for Ø 1.5” only Dimensions in inches (mm) Dimensions in inches (mm) Dimensions in inch (mm) Projection/Third angle F E C B Dimensions in inch (mm) Projection/Third angle E G (G) A F C A B ØA B C E F (G) Weight (lb) ØA B C E F G 1.5 (40) 1/8 NPT 1.60 (41) 0.97 (25) 0.23 (6) 0.40 (10) 0.43 (11) 0.12 (54 g) 1.5 (40) 1/8 NPT 2.2 (56) 0.31 (8) 0.90 (23) 1.11 (28) 0.43 (11) 0.14 (64 g) 2 (50) 1/8 NPT 1.73 (44) 1.03 (26) 0.23 (6) 0.47 (12) 0.55 (14) 0.17 (77 g) 2 (50) 1/4 NPT 2.7 (69) 0.31 (8) 1.06 (27) 1.42 (36) 0.55 (14) 0.22 (100 g) 2 (50) 1/4 NPT 1.73 (44) 1.03 (26) 0.23 (6) 0.47 (12) 0.55 (14) 0.18 (81 g) 12/19 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (2000 - 8192g) © 2015 Norgren Inc. Weight (lb) en 8.900.900.03 18-015-..., V70534-..., 9273... Pressure gauges Center back connection, panel mounted, black face (for North America) Scale range psig *1) bar Mpa Model - Diameter & Connection Ø 1.5” (Ø 40 mm) 1/8 NPT male & 10 - 32 female 0 ... 30 0 ... 2 0 ... 0.2 5PG-406-000 0 ... 60 0 ... 4 0 ... 0.4 5PG-412-000 0 ... 100 0 ... 7 0 ... 0.7 5PG-420-000 Scale range psig *1) bar Mpa Model Ø 1.5” (Ø 40 mm) Ø 5/32” PIF (Ø 4 mm) 0 ... 100 0 ... 7 0 ... 0.7 18-015-538 *1) primary scale M B G A M P P C C ØA B C G ØJ ØK ØA ØB C ØJ ØK 1.5 (40) 1/8 NPT 1.69 (43) 0.60 (15) 1.61 (41) 1.63 (41) 1,5 (40) 0.156 (4) 1.71 (43) 1.61 (41) 1.63 (41) ØL M P Weight (lb) ØL M P 2.1 (53) 0.18 (4,5) 1.04 (27) 0.15 (68 g) 2.1 (53) 0.18 (5) 0.86 (22) 0.55 (14) øL Dimensions in inch (mm) Projection/Third angle Dimensions in inches (mm) øL øK B A øJ Dimensions in inch (mm) Projection/Third angle Dimensions in inches (mm) øK *1) primary scale Symbol øJ Symbol Center back connection, panel mounted, black face (for North America) Weight (lb) 0.55 (14) 0.15 (68 g) EN - Englisch Warning These products are intended for use in industrial compressed air systems only. Do not use these products where pressures and temperatures can exceed those listed under »Technical features/data«. Before using these products with fluids other than those specified, for non-industrial applications, life-support systems or other applications not within published specifications, consult IMI Precision Engineering, Norgren GmbH. en 8.900.900.04 Through misuse, age, or malfunction, components used in fluid power systems can fail in various modes. The system designer is warned to consider the failure modes of all component parts used in fluid power systems and to provide adequate safeguards to prevent personal injury or damage to equipment in the event of such failure. System designers must provide a warning to end users in the system instructional manual if protection against a failure mode cannot be adequately provided. System designers and end users are cautioned to review specific warnings found in instruction sheets packed and shipped with these products. All Gauges listed are RoHS2 compliant and in accordance with the Directive 2011/65/EU Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. (2000 - 8192g) © 2015 Norgren Inc.  12/19
18-013-991
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输出低电平电流为16mA,输出高电平电流为2mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,输入端控制发光二极管发光,输出端光电晶体管导通或截止。
6. 应用信息:EL817广泛应用于开关电源、信号隔离、工业控制等领域。
7. 封装信息:EL817采用DIP6封装形式,尺寸为9.1x3.6mm。
18-013-991 价格&库存
很抱歉,暂时无法提供与“18-013-991”相匹配的价格&库存,您可以联系我们找货
