BL64-401
BL64-401
    NORGREN(诺冠)
    NORGREN - BL64-401 - Filter/Regulator, Lubricator, Combination, Olympian Plus, G1/2, Shut-0ff, Valve...
BL64-401 数据手册
Back to Selector Page BL64 Olympian Plus Combinations Filter-Regulator and Lubricator G1⁄4 to G3⁄4 ● Olympian Plus plug in design ● High Efficiency water and particle removal ● Quick release bayonet bowls ● High visibility prismatic sight glass* ● Push to lock adjusting knob with tamper resistant option ● Constant oil density output with varying flow * UK and other patents pending Technical Data Medium: Compressed Air Maximum pressure: 17 bar metal bowl 10 bar guarded transparent bowl Operating Temperature: -20°C* to +80°C metal bowl -20°C *to +50°C guarded transparent bowl * Consult our technical service for use below +2°C Gauge Ports: Rc1⁄8 Maximum flow with 10 bar inlet pressure, 6,3 bar outlet pressure and pressure drop of 1 bar: 37 dm3/s Filter-Regulator Filter Element: 40 µm nominal standard 5 µm nominal optional Recommended Regulating Pressure Ranges†: 0,3 – 10 bar standard 0,3 – 4 bar optional 2 – 16 bar optional Ordering Information To order a standard Olympian Plus, filter-regulator, lubricator combination quote model number from table overleaf. For non-standard models substitute appropriate digits as instructed. † Can be adjusted to zero bar outlet and, generally, to pressures in excess of those specified. Lubricator Start point at 6,3 bar: 1,5 dm3/s Nominal Bowl capacity: 0,2 litres standard Materials: Aluminium bowl standard, guarded polycarbonate bowl optional. Zinc alloy body and yoke. Synthetic rubber elastomeric materials. Grilamid prismatic sight glass lens standard. Pyrex sight glass optional for metal bowl. Filter-Regulator: Aluminium bonnet. Sintered plastic filter element. Lubricator: Polycarbonate sight dome. 3/95 8.4.051.01 Issue No.2 Revision 0 BL64 Typical Performance Characteristics FLOW CHARACTERISTICS 8 10 bar INLET ELEMENT 40 MICRON OUTLET PRESSURE - bar 7 6 5 4 3 2 1 0 0 10 20 30 40 50 60 70 80 90 100 110 120 AIR FLOW - dm3/s Ordering Information Standard models are supplied with automatic drains, 40µm elements, 10 bar range relieving filter regulators, Micro-Fog lubricators and metal bowls with prismatic sight glass. Port Size G1⁄2 Shut-0ff Valve ✔ ✔ ✔ Gauge ✔ ✔ Bracket ✔ Model BL64-401 BL64-402 BL64-404 BL64-408 Weight kg 3,37 3,12 3,11 2,73 Alternative Models B L 6 4 Size G1/4 G3/8 G1/2 G3/4 4 0 1 Options Filter Drain Lubricator Automatic Micro-Fog Oil-Fog Micro-Fog Manual Oil-Fog Substitute 2 3 4 6 Substitute 0 1 2 3 Please contact our technical service for details of non standard models including other thread forms, 5µm filter elements, ‘T’ bar adjust, maximum pressure stop, 4 or 16 bar range adjustment and metal bowl with pyrex sight glass. Accessories Bracket Kit 74504-50 Gauges 0– 6 bar: 0–10 bar: 0–25 bar: 18-013-012 18-013-013 18-013-014 3/2 Shut-off Valve* G1⁄4 T64T-2GB-P1N G3⁄8 T64T-3GB-P1N G1⁄2 T64T-4GB-P1N G3⁄4 T64T-6GB-P1N Tamper Resistant Kit 4355-50 * UK and other patents pending Quick Fill Nipple Tamper Resistant Wire 18-011-024 2117-01 (Pack of 10) 8.4.051.02 Issue No.2 Revision 0 3/95 BL64 D B† A† 125† Dimensions (mm) 74 36,5 C Dimension Description A† Maximum overall height B Minimum clearance to remove unit C For port sizes G1⁄4, G3⁄8, G1⁄2, (G3⁄4) D Combination without shut-off valve, port sizes G1⁄4, G3⁄8, G1⁄2, (G3⁄4) † Reduces by 4 mm with knob in locked position. Add 37 mm for unit with ‘T’ handle. Bracket Mounting Drain Automatic 287 303 233 (262) 185 (237) Manual 294 310 233 (262) 185 (237) Bracket Kit reference 223 Model All Models Part No. 74504-50 93 11 110 30,5 8,2 194 14,5 85 48 Service Kits Item Service kit Service kit Service kit Type Relieving Filter-Regulator Non-relieving Filter-Regulator Lubricator 40 µm Replacement elements 5 µm Prismatic (standard B64) Replacement sight Prismatic (standard L64) glass Pyrex Automatic Replacement drains Manual Part number 4383-200 4383-201 4382-200 4338-02 4338-01 4380-040 4380-042 4380-041 3000-97 684-84 Filter-Regulator service kit includes port seals, lourve ‘O’ ring, bowl ‘O’ ring and drain gasket, slip ring, valve assembly, valve spring and diaphragm. Lubricator service kit includes all seals, flow sensor, eyelet, dome screen, ball and spring. 3/95 8.4.051.03 Issue No.2 Revision 0
BL64-401 价格&库存
很抱歉,暂时无法提供与“BL64-401”相匹配的价格&库存,您可以联系我们找货
BL64-401
  • 1+5789.66644
库存:1
