601112138
601112138
    NORGREN(诺冠)
    NORGREN - 601112138 - Valve, Ball, Miniball, 6011 Series, Light Duty, Reduced Bore, Female/Female, G...
601112138 数据手册
Back to Selector Page Brass Ball Valves 60 Series 1⁄ 8" – 4" BSP ● Ideally suited for most industrial applications ● Easy installation, simple operation and maintenance free ● Full bore passage giving minimum flow resistance Technical Data Ordering Information Medium: Compressed air, water, inert gases and any other fluid compatible with the valve materials Port Sizes: G1⁄ 8, G1⁄ 4, G3⁄ 8, G1⁄ 2, G3⁄ 4, G1, G11⁄ 4, G11⁄ 2, G2, G21⁄ 2, G3, G4. Operating Pressure: See individual details Operating Temperature: Refer to table over the page Materials Nickel plated brass body to UNI 5705-65, virgin PTFE seats, virgin PTFE, Viton or Nitrile seals, chromium plated brass ball, zinc plated steel handle with PVC grip (plastic handle on mini ball range). To order quote the appropriate product numbers from the tables on the following pages. Standard Exhausting 3–way 10/97 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. For your local Norgren Technical Sales Centre phone 0345 662266. For your local Norgren Distributor phone 0345 227777. IMI Norgren Limited, PO Box 22, Eastern Avenue, Lichfield, Staffordshire WS13 6SB N/UK 5.10.040.01 60 Series Ball Valves General Information Symbol Series Type Application Materials Body Seats & Seals Max Pressure (bar) Temp Range Thread Standards Brass PTFE & Nitrile “O” ring 10 –10 to +90ºC ISO 228/1 2 12 10 6011 Mini General, light duty 10 6018 Lockable Exhausting General, with exhaust Brass PTFE 13,6 4-60°C ISO 228/1 10 6021 Standard General purpose Brass PTFE & Viton “O” ring 45 to 10 –20 to +150ºC ISO 228/1 10 6021 Three Way General diverting Brass PTFE & Nitrile “O” ring 25 to 16 –15 to +150ºC ISO 228/1 10 6021 Exhausting General with exhaust Brass PTFE 40 to 64 –20 to +100ºC ISO 228/1 6041 Standard Commercial gas and general Brass PTFE 55 to 20 –20 to +150ºC 1 2 12 3 1 2 12 1 2 12 3 1 2 12 3 1 2 10 12 ISO 228/1 1 6011 Series: 6018 Series: 6021 Series: Light duty in-line brass ball valves suitable for a wide variety of low pressure industrial uses. Medium duty in-line brass exhausting ball valves. Venting action & lockout design adds safety feature to valve. Medium duty in-line brass ball valves for most applications. Available as a standard valve, a three way diverting valve or with a downstream exhaust option. Special, high quality in-line ball valves with approvals from British Gas, DIN-DVGW, Danish Gas, Svenska Gasfoereningen. Suitable for gas and water applications as well as more general industrial uses. 6041 Series: 6011 Series Miniball A D Reduced bore, female/female 601112118 601112128 601112138 601112148 E B Model Thread size G1⁄ 8 G1⁄ 4 G3⁄ 8 G1⁄ 2 Max. Press. 10 10 10 10 A B C D E F 19 19 19 22 20 20 21 25 37 37 41 48 22 22 24 30 5,5 5,5 8,0 10,0 19 19 21 25 F C A D D Reduced bore, male/female Model 601112218 601112228 601112238 601112248 Thread size G1⁄ 8 G1⁄ 4 G3⁄ 8 G1⁄ 2 Max. Press. 10 10 10 10 A B C D E F 19 19 19 22 20 20 21 25 37 37 41 48 22 22 24 30 5,5 5,5 8,0 10,0 19 19 21 25 A B C D E F 19 19 19 22 20 20 21 25 48 48 53 62 22 22 24 30 5,5 5,5 8,0 10,0 19 19 21 25 E B F C A Reduced bore, male/male D D Model 601112318 601112328 601112338 601112348 N/UK 5.10.040.02 Max. Press. 10 10 10 10 E B C Thread size G1⁄ 8 G1⁄ 4 G3⁄ 8 G1⁄ 2 F Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. For your local Norgren Technical Sales Centre phone 0345 662266. For your local Norgren Distributor phone 0345 227777. IMI Norgren Limited, PO Box 22, Eastern Avenue, Lichfield, Staffordshire WS13 6SB 10/97 60 Series Ball Valves 6021 Standard Ball Valve A Full bore, female/female Model F E B 602112128 602112138 602112148 602112168 602112188 6021121A8 6021121B8 6021121C8 6021121D8 6021121E8 6021121F8 C A Thread size G1⁄ 4 G3⁄ 8 G1⁄ 2 G3⁄ 4 G1 G11⁄ 4 G11⁄ 2 G2 G21⁄ 2 G3 G4 Max. Press. 45 40 35 30 25 20 20 16 16 10 10 A B C E F 85 85 85 105 105 130 130 165 248 248 248 36 36 40 47 51 63 69 83 99 110 129 48 49 60 69 83 96 106 129 159 182 219 8 10 15 20 25 32 40 50 65 80 100 23 24 30 38 46 58 70 86 111 135 167 A B C E F 85 85 85 105 105 130 36 36 40 47 51 63 50 54 65 75 86 99 8 10 15 20 25 32 23 24 30 38 46 58 D L Thro Bore 8 52 10 54 15 69 20 77 25 89 32 103 M A/F 22 22 27 33 40 50 B Full bore, male/female 602112228 602112238 602112248 602112268 602112288 6021122A8 F E Model C Thread size G1⁄ 4 G3⁄ 8 G1⁄ 2 G3⁄ 4 G1 G11⁄ 4 Max. Press. 45 40 35 30 25 20 For T handle valves, substitute 2 for 1 at 4th digit. Pressure/Temperature diagram Bar 50 1/ 4 3/ 8 1/ 2 3/ 4 " " " " 1" 1/ 1 4" - 11/2" 2" 3" - 4" 40 30 20 10 –20° 0° +25° +50° +75° +100° +125° +150° °C 6021 Exhausting Ball Valve A Full bore, female/female B Model C D M (Across Flats) 602113128EX 602113138EX 602113148EX 602113168EX 602113188EX 6021131A8EX Thread size G1⁄ 4 G3⁄ 8 G1⁄ 2 G3⁄ 4 G1 G11⁄ 4 Max. Press. 64 64 50 50 50 40 A B C 100 100 100 120 120 150 61 61 64 76 80 98 29 29 36 45 54 65 For T handle valves, substitute 2 for 1 at 4th digit. Exhaust L 10/97 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. For your local Norgren Technical Sales Centre phone 0345 662266. For your local Norgren Distributor phone 0345 227777. IMI Norgren Limited, PO Box 22, Eastern Avenue, Lichfield, Staffordshire WS13 6SB N/UK 5.10.040.03 60 Series Ball Valves 6021 3–Way Ball Valve A Full bore, female/female/female F E 602114428 602114438 602114448 602114468 6021144A8 J E B Model Thread size G1⁄ 4 G3⁄ 8 G1⁄ 2 G3⁄ 4 G11⁄ 4 Max. Press. 25 25 25 16 10 A B C E F J 98 98 98 118 118 42 42 45 57 66 52 52 64 74 100 10 10 15 20 32 22 22 27 32 50 26,0 26,0 33,5 39,5 54,5 E C Test specification differs from standard. Please consult our Technical Service for futher details. 6041 Gas Approved Ball Valve A Full bore, female/female Model F E B 604112128 604112138 604112148 604112168 604112188 6041121A8 6041121B8 6041121C8 C Thread size G1⁄ 4 G3⁄ 8 G1⁄ 2 G3⁄ 4 G1 G11⁄ 4 G11⁄ 2 G2 Max. Press. 55 50 45 40 35 25 25 20 A B C E F 85 85 85 105 105 130 130 165 41 41 44 53 57 70 76 92 48 49 61 70 84 98 108 130 8 10 15 20 25 32 40 50 23 24 32 40 48 60 72 88 For T handle valves, substitute 2 for 1 at 4th digit. Pressure/Temperature diagram Bar 60 1/ 4 3/ 8 1/ 2 3/ 4 " " " " 1" 50 40 30 11/4" - 11/2" 2" 20 10 –20° 0° N/UK 5.10.040.04 +25° +50° +75° +100° +125° +150° °C Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. For your local Norgren Technical Sales Centre phone 0345 662266. For your local Norgren Distributor phone 0345 227777. IMI Norgren Limited, PO Box 22, Eastern Avenue, Lichfield, Staffordshire WS13 6SB 10/97 60 Series Ball Valves 6018 Lockable Exhausting Ball Valve A Full bore, female/female 7,5 Model C B G (Across Flats) F M5 x 0,8 Exhaust Port Thread size 601812128 1⁄ 4 601812138 3⁄ 8 601812148 1⁄ 2 601812168 3⁄ 4 601812188 1 Max. Press. 13,6 bar 13,6 bar 13,6 bar 13,6 bar 13,6 bar A B 93 93 93 114 114 45 45 50 57 61 C Thro Bore 8 9 14 19 24 F 44 44 58 64 81 G A/F 20 20 24 30 40 Lever lockable only in closed position. Standard handle accepts Ø 7mm shackle. Test specification differs from standard. Please consult our Technical Service for futher details. Warning These products are intended for use in industrial compressed air systems only. Do not use these products where pressures and temperatures can exceed those listed under ‘Technical Data’. Before using these products with fluids other than those specified, for non-industrial applications, life-support systems, or other applications not within published specifications, consult Norgren. Through misuse, age, or malfunction, components used in fluid power systems can fail in various modes. The system designer is warned to consider the failure modes of all component parts used in fluid power systems and to provide adequate safeguards to prevent personal injury or damage to equipment in the event of such failure. System designers must provide a warning to end users in the system instructional manual if protection against a failure mode cannot be adequately provided. System designers and end users are cautioned to review specific warnings found in instruction sheets packed and shipped with these products where applicable. 10/97 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. For your local Norgren Technical Sales Centre phone 0345 662266. For your local Norgren Distributor phone 0345 227777. IMI Norgren Limited, PO Box 22, Eastern Avenue, Lichfield, Staffordshire WS13 6SB N/UK 5.10.040.05 Back to Selector Page Carbon Steel Ball Valves 62 Series 1⁄ 4" – 1" BSP ● Ideally suited for most industrial applications ● Easy installation, simple operation and maintenance free ● 1⁄ 4, 3⁄ 8, 1⁄ 2 BSP ball valves for high pressure applications ● Lever or tee handle options Technical Data Ordering Information Medium: Compressed air, water, inert gases and any other fluid compatible with the valve materials Port Sizes: 1⁄ 4, 3⁄ 8, 1⁄ 2, 3⁄ 4, 1 BSPP Operating Pressure: 140 bar (PTFE seats) 208 bar (Nylon seats) Operating Temperature: -30°C to 220°C Materials: Body: Steel Stem: Carbon Steel Thrust washer: Reinforced PTFE Stem Seal: Reinforced PTFE Follower: Stainless steel, type 304 Spring Washer: Zinc plated steel Handle: Zinc plated steel with vinyl grip Ball: Chrome plated carbon steel Seats: Reinforced PTFE or nylon End Cap: Carbon Steel To order quote the appropriate product numbers from the tables on the following pages. 11/97 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. For your local Norgren Technical Sales Centre phone 0345 662266. For your local Norgren Distributor phone 0345 227777. IMI Norgren Limited, PO Box 22, Eastern Avenue, Lichfield, Staffordshire WS13 6SB N/UK 5.10.042.01 62 Series Ball Valves General Information Series Handle 625112 625212 626212 Lever Tee Tee Material Seat PTFE PTFE Nylon Max Pressure (bar) 140 140 208 Thread Standards ISO 228/1 ISO 228/1 ISO 228/1 Lever Handle - 625112 F A E D Model 625112128 625112138 625112148 625112168 625112188 Thread Max Press A BSPP (bar) Through Bore 1⁄ 4 140 10 3⁄ 8 140 10 1⁄ 2 140 14 3⁄ 4 140 17 1 140 22 B C D E F 51 51 63,5 75 89 25,4 25,4 32 37,5 44 96 96 96 129,5 129,5 41 41 44 53 58 13,5 13,5 16 20,5 25,4 C B Tee Handle - 625212 F A Model C 625212128 625212138 625212148 625212168 625212188 Thread Max Press A BSPP (bar) Through Bore 1⁄ 4 140 10 3⁄ 8 140 10 1⁄ 2 140 14 3⁄ 4 140 17 1 140 22 B C F 51 51 63,5 75 89 25,4 25,4 32 37,5 44 13,5 13,5 16 20,5 25,4 B Tee Handle - 626212 (High Pressure) Thread Max Press A BSPP (bar) Through Bore 626212128 1⁄ 4 208 10 626212138 3⁄ 8 208 10 626212148 1⁄ 2 208 14 B C F 51 51 63,5 25,4 25,4 32 13,5 13,5 16 F A Model C B Warning These products are intended for use in industrial compressed air systems only. Do not use these products where pressures and temperatures can exceed those listed under ‘Technical Data’. Before using these products with fluids other than those specified, for non-industrial applications, life-support systems, or other applications not within published specifications, consult Norgren. Through misuse, age, or malfunction, components used in fluid power systems can fail in various modes. The system designer is warned to consider the failure modes of all component parts used in fluid power systems and to provide adequate safeguards to prevent personal injury or damage to equipment in the event of such failure. System designers must provide a warning to end users in the system instructional manual if protection against a failure mode cannot be adequately provided. System designers and end users are cautioned to review specific warnings found in instruction sheets packed and shipped with these products where applicable. N/UK 5.10.042.02 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. For your local Norgren Technical Sales Centre phone 0345 662266. For your local Norgren Distributor phone 0345 227777. IMI Norgren Limited, PO Box 22, Eastern Avenue, Lichfield, Staffordshire WS13 6SB 11/97 Back to Selector Page Stainless Steel Ball Valves 61 Series 1⁄ 4" – 1" BSP ● Ideally suited for most industrial applications ● Easy installation, simple operation and maintenance free ● Full bore passage giving minimum flow resistance ● Suitable for process, chemical or food industries ● Lever or tee handle options Technical Data Ordering Information Medium: Compressed air, water, inert gases and any other fluid compatible with the valve materials Port Sizes: 1⁄ 4, 3⁄ 8, 1⁄ 2, 3⁄ 4, 1 Operating Pressure: 100 bar (1⁄ 4,3⁄ 8,1⁄ 2), 64 bar (3⁄ 4,1) Operating Temperature: -20°C to 150°C Materials Body: Stainless Steel Investment casting AISI 316 Stem: Stainless Steel AISI 316 Ball Seats: Virgin PTFE Lower & upper stem packing: virgin PTFE Static gasket: Virgin PTFE Ball: Stainless Steel AISI 316 Viton ‘O’ rings Lever handle: Stainless Steel AISI 304 End connection: Stainless Steel investment casting AISI 316 To order quote the appropriate product numbers from the tables on the following pages. 11/97 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. For your local Norgren Technical Sales Centre phone 0345 662266. For your local Norgren Distributor phone 0345 227777. IMI Norgren Limited, PO Box 22, Eastern Avenue, Lichfield, Staffordshire WS13 6SB N/UK 5.10.041.01 61 Series Ball Valves General Information Series Handle 615112 615212 Lever Tee Thread Standards ISO 7/1 Rp ISO 7/1 Rp Lever Handle - 615112 B A Thread Rp 615112128 1⁄ 4 615112138 3⁄ 8 615112148 1⁄ 2 615112168 3⁄ 4 615112188 1 C D Model L Max Press A (bar) B C 100 100 100 64 64 52,0 52,0 55,0 66,0 70,0 29,0 29,0 34,0 42,5 50,5 B C 38 38 41 52 56 29,0 29,0 34,0 42,5 50,5 110 110 110 140 140 D through bore 8 10 15 20 25 L M A/F 50 50 60 70 85 21,5 21,5 26,5 31,5 40,5 L M A/F 50 50 60 70 85 21,5 21,5 26,5 31,5 40,5 Tee Handle - 615212 A C D B Model L Thread Max Press A Rp (bar) 615212128 1⁄ 4 615212138 3⁄ 8 615212148 1⁄ 2 615212168 3⁄ 4 615212188 1 100 100 100 64 64 47 47 47 56 56 D through bar 8 10 15 20 25 Warning These products are intended for use in industrial compressed air systems only. Do not use these products where pressures and temperatures can exceed those listed under ‘Technical Data’. Before using these products with fluids other than those specified, for non-industrial applications, life-support systems, or other applications not within published specifications, consult Norgren. Through misuse, age, or malfunction, components used in fluid power systems can fail in various modes. The system designer is warned to consider the failure modes of all component parts used in fluid power systems and to provide adequate safeguards to prevent personal injury or damage to equipment in the event of such failure. System designers must provide a warning to end users in the system instructional manual if protection against a failure mode cannot be adequately provided. System designers and end users are cautioned to review specific warnings found in instruction sheets packed and shipped with these products where applicable. N/UK 5.10.041.02 Our policy is one of continued research and development. We therefore reserve the right to amend, without notice, the specifications given in this document. For your local Norgren Technical Sales Centre phone 0345 662266. For your local Norgren Distributor phone 0345 227777. IMI Norgren Limited, PO Box 22, Eastern Avenue, Lichfield, Staffordshire WS13 6SB 11/97
601112138 价格&库存
很抱歉,暂时无法提供与“601112138”相匹配的价格&库存,您可以联系我们找货
