189286
189286
    FESTO(费斯托)
    FESTO - 189286 - Suction Cup, Round Flat, 10 mm Dia, M4, VMQ Silicon, ESS Series
189286 数据手册
Vacuum suction cup ESS-10-SS Part number: 189286 General operating condition Data sheet Feature Value Min. workpiece radius 30 mm Nominal width 2 mm Suction cup diameter 10 mm Suction cup volume 0.05 cm³ Connection position Top Mounting position Any Symbol 00991485 Classification of suction cup holder Size 3 Suction cup shape Round, flat Operating pressure -0.095 MPa ... 0 MPa Operating pressure -0.95 bar ... 0 bar Operating pressure -13.775 psi ... 0 psi Nominal operating pressure -0.07 MPa Nominal operating pressure -0.7 bar Nominal operating pressure -10.15 psi Operating medium Atmospheric air based on ISO 8573-1:2010 [7:-:-] Corrosion resistance class (CRC) 1 - Low corrosion stress LABS (PWIS) conformity VDMA24364 zone III For use in the food industry See supplementary material information Ambient temperature -30 °C ... 180 °C Holding force at nominal operating pressure 3.9 N Lateral force at nominal operating pressure 4N Product weight 1.5 g Type of mounting Via vacuum connection Vacuum connection M4 Color Transparent Shore hardness 50 +/- 5 Material of screwed plug Brass, nickel-plated Note on materials RoHS-compliant Suction cup material VMQ (silicone) 5/16/24 - Subject to change - Festo SE & Co. KG 1/1
189286 价格&库存
很抱歉,暂时无法提供与“189286”相匹配的价格&库存,您可以联系我们找货
