162509
162509
    FESTO(费斯托)
    FESTO - 162509 - Vacuum Generator, 8 bar, 60 °C, 1.4 mm Laval Nozzle, VADMI Series
162509 数据手册
Vacuum generator VADMI-140 Part number: 162509 General operating condition Data sheet Feature Value Nominal width of Laval nozzle 1.4 mm Width dimension 22 mm Muffler construction type Closed Mounting position Any Ejector characteristics High vacuum Grade of filtration ≤40 µm Manual override Non-detenting Integrated function Ejector pulse valve, electric Flow control Shut off valve, electric Compressed air filter Non-return valve Symbol 00991305 Valve function Closed Operating pressure 0.2 MPa ... 0.8 MPa Operating pressure 2 bar ... 8 bar Operating pressure 29 psi ... 116 psi Max. vacuum 85 % Nominal operating pressure 0.6 MPa Nominal operating pressure 6 bar Nominal operating pressure 87 psi Air supply time at nominal operating pressure with ejector pulse 0.19 s DC operating voltage range 21.6 V ... 26.4 V Duty cycle 100% Certification c UL us - Recognized (OL) Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication not possible Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Temperature of medium 0 °C ... 60 °C Degree of protection IP65 Ambient temperature 0 °C ... 60 °C Product weight 320 g Electrical connection Plug 6/3/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Type of mounting Optionally: With through-hole With internal thread Pneumatic connection 1 G1/8 Pneumatic connection 3 Pneumatic muffler integrated Vacuum connection G1/4 Note on materials RoHS-compliant Seals material NBR Female nozzle material Brass, nickel-plated Compressed air filter material PA Material of filter housing PC Housing material Wrought aluminum alloy Muffler material PE POM Material of piston POM Material of jet nozzle Brass, nickel-plated 6/3/24 - Subject to change - Festo SE & Co. KG 2/2
162509 价格&库存
很抱歉,暂时无法提供与“162509”相匹配的价格&库存,您可以联系我们找货
