4500011
4500011
    FESTO(费斯托)
    FESTO - 4500011 - FINGER LEVER VALVE, 1/8"-27NPT, 10BAR
4500011 数据手册
Finger lever valve VHEF-LT-M32-M-N18 Part number: 4500011 Data sheet Feature Value Valve function 3/2, open/closed, monostable Actuation type Manual Width 20 mm Standard nominal flow rate 750 l/min Pneumatic working port 1/8 NPT Operating pressure -0.095 MPa ... 1 MPa Operating pressure -0.95 bar ... 10 bar Design Plate seat Reset method Mechanical spring Nominal width 5.6 mm Type code VHEF Exhaust air function With flow control option Application note Operate by hand only Sealing principle Soft Mounting position Any Type of control Direct Flow direction Reversible Symbol 00995684 Lap Zero overlap Max. switching frequency 0.5 Hz Explosion prevention and protection Zone 1 (ATEX) Zone 2 (ATEX) Zone 21 (ATEX) Zone 22 (ATEX) Operating medium Compressed air as per ISO 8573-1:2010 [7:-:-] Information on operating and pilot media Operation with oil lubrication possible (required for further use) Corrosion resistance class (CRC) 1 - Low corrosion stress Temperature of medium -10 °C ... 60 °C Ambient temperature -10 °C ... 60 °C Actuating force 14 N Product weight 156 g Type of mounting With through-hole Pneumatic connection 1 1/8 NPT Pneumatic connection 2 1/8 NPT Pneumatic connection 3 1/8 NPT Note on materials RoHS-compliant 6/20/21 - Subject to change - Festo AG & Co. KG 1/2 Feature Value Seals material NBR Housing material Wrought aluminum alloy, anodized Lever material PA-reinforced 6/20/21 - Subject to change - Festo AG & Co. KG 2/2
4500011 价格&库存
很抱歉,暂时无法提供与“4500011”相匹配的价格&库存,您可以联系我们找货
