532636
532636
    FESTO(费斯托)
    FESTO - 532636 - Vacuum Generator, 8 bar, 50 °C, 0.95 mm Laval Nozzle, VN Series
532636 数据手册
Vacuum generator VN-10-H-T3-PQ2-VQ2-RO1-M Part number: 532636 General operating condition Data sheet Feature Value Nominal width of Laval nozzle 0.95 mm Width dimension 14 mm Muffler construction type Open Mounting position Any Ejector characteristics Standard High negative pressure Manual override Non-detenting Integrated function Shut off valve, electric Pneumatic muffler open Structural design T-shape Symbol 00991492 Valve function 2/2 Operating pressure for max. suction rate 3 bar Operating pressure 2 bar ... 8 bar Operating pressure for max. vacuum 3.5 bar Max. vacuum 93 % Nominal operating pressure 6 bar Max. suction rate with respect to atmosphere 21.8 l/min Air supply time at nominal operating pressure 1.06 s DC operating voltage range 21.6 V ... 26.4 V Electrical power consumption 1.2 W Duty cycle 100% Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication not possible Corrosion resistance class (CRC) 1 - Low corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Temperature of medium 0 °C ... 50 °C Noise level at nominal operating pressure 71 dB(A) Degree of protection IP40 Ambient temperature 0 °C ... 50 °C Product weight 61 g Electrical connection Plug Type of mounting With through-hole With H-rail With accessories 6/1/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Pneumatic connection 1 QS-6 Pneumatic connection 3 Pneumatic muffler open Vacuum connection QS-6 Material of connecting thread Wrought aluminum alloy, anodized Note on materials RoHS-compliant Seals material NBR Female nozzle material POM Housing material PA-reinforced POM-reinforced Muffler material PE Material of screws Steel Material of jet nozzle Wrought aluminum alloy Material of pneumatic fitting Brass Nickel-plated 6/1/24 - Subject to change - Festo SE & Co. KG 2/2
532636 价格&库存
很抱歉,暂时无法提供与“532636”相匹配的价格&库存,您可以联系我们找货
