537274
537274
    FESTO(费斯托)
    FESTO - 537274 - Pressure Booster, 40 mm Piston Diameter, 4.5 - 16 bar, Twin-Piston, Generating High...
537274 数据手册
Pressure booster DPA-40-16 Part number: 537274 General operating condition Data sheet Feature Value Piston diameter 40 mm Mounting position Any Structural design Twin-piston pressure intensifier Symbol 00991432 Pressure gauge G1/8 prepared Output pressure 2 0.45 MPa ... 1.6 MPa Outlet pressure 2 4.5 bar ... 16 bar Output pressure 2 65.25 psi ... 232 psi Operating pressure 0.25 MPa ... 1 MPa Operating pressure 2.5 bar ... 10 bar Operating pressure 36.25 psi ... 145 psi Pressure regulation range MPa 0.45 MPa ... 1.6 MPa Pressure regulation range 4.5 bar ... 16 bar Pressure regulation range psi 65.25 psi ... 232 psi Inlet pressure 1 2.5 bar ... 10 bar Inlet pressure 1 MPa 0.25 MPa ... 1 MPa Inlet pressure 1 psi 36.25 psi ... 145 psi Information on pressure regulation range If the controller spring is tensioned to the maximum, the maximum output pressure may be exceeded by 40%. Operating medium Compressed air as per ISO 8573-1:2010 [7:3:4] Information on operating and pilot media Operation with oil lubrication not possible Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Storage temperature 5 °C ... 60 °C Ambient temperature 5 °C ... 60 °C Product weight 1500 g Type of mounting With internal thread Pneumatic connection 1 G1/4 Pneumatic connection 2 G¼ Pneumatic connection 3 M7 Note on materials RoHS-compliant 6/5/24 - Subject to change - Festo SE & Co. KG 1/1
537274 价格&库存
很抱歉,暂时无法提供与“537274”相匹配的价格&库存,您可以联系我们找货
