559323
559323
    FESTO(费斯托)
    FESTO - 559323 - Round Cylinder, Piston Rod, Double Acting, 50 mm, G1/4, 1 bar to 10 bar, 250 mm
559323 数据手册
Round cylinder DSNU-50-250-PPS-A Part number: 559323 General operating condition Data sheet Feature Value Stroke 250 mm Piston diameter 50 mm Piston rod thread M16x1.5 Cushioning Self-adjusting pneumatic end-position cushioning Mounting position Any Structural design Piston Piston rod Cylinder barrel Position sensing For proximity sensor Symbol 00992970 Operating pressure 0.1 MPa ... 1 MPa Operating pressure 1 bar ... 10 bar Mode of operation Double-acting Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Ambient temperature -20 °C ... 80 °C Cushioning length 20 mm Theoretical force at 6 bar, retracting 989.6 N Theoretical force at 6 bar, advancing 1178.1 N Moving mass 1038 g Product weight 2087 g Type of mounting With accessories Pneumatic connection G1/4 Note on materials RoHS-compliant Cover material Wrought aluminum alloy Seals material NBR TPE-U(PU) Piston rod material High-alloy steel Material of cylinder barrel High-alloy stainless steel 5/8/24 - Subject to change - Festo SE & Co. KG 1/1
559323 价格&库存
很抱歉,暂时无法提供与“559323”相匹配的价格&库存,您可以联系我们找货
