551441
551441
    FESTO(费斯托)
551441 数据手册
Plastic tubing PEN-10X1,5-SW-300 Part number: 551441 General operating condition Data sheet Feature Value Outside diameter 10 mm Bending radius relevant for flow rate 40 mm Inside diameter 7 mm Min. bending radius 23.5 mm Tubing characteristics Suitable for energy chains Temperature-dependent operating pressure -0.095 MPa ... 1 MPa Temperature-dependent operating pressure -0.95 bar ... 10 bar Temperature-dependent operating pressure -13.775 psi ... 145 psi Information on operating pressure Water: max. 0.6 MPa at 0 - 50 °C Certification German Technical Control Board (TÜV) Certificate issuing authority B 013277 0506 00 Operating medium Compressed air as per ISO 8573-1:2010 [7:-:-] Water (liquid, ice-free) LABS (PWIS) conformity VDMA24364-B2-L Cleanroom class Statically installed element, no meaningful evaluation possible according to ISO 14644-1 Ambient temperature -30 °C ... 60 °C Product weight by length 0.03766 kg/m Pneumatic connection For plug connection outside diameter 10 mm Color Black Shore hardness D 52 +/-3 Note on materials RoHS-compliant Material of pneumatic tubing PE 5/11/24 - Subject to change - Festo SE & Co. KG 1/1
551441 价格&库存
很抱歉,暂时无法提供与“551441”相匹配的价格&库存,您可以联系我们找货
