565398
565398
    FESTO(费斯托)
    FESTO - 565398 - Flow Sensor, Air & Gas, 2 to 200 l/min, 10bar, 15 to 30 VDC, 3 % O.M.V, 0.3 % FS Ac...
565398 数据手册
Flow sensor SFAB-200U-HQ10-2SV-M12 Part number: 565398 General operating condition Data sheet Feature Value Symbol 00992242 Certification RCM compliance mark c UL us - Recognized (OL) CE marking (see declaration of conformity) As per EU EMC directive As per EU RoHS directive UKCA marking (see declaration of conformity) To UK instructions for EMC To UK RoHS instructions Certificate issuing authority UL E322346 Note on materials RoHS-compliant Measured variable Volume Volumetric flow rate Flow direction Unidirectional P1 -> P2 Measuring principle Thermal Method of measurement Heat loss Flow measuring range start value 2 l/min Flow measuring range end value 200 l/min Operating pressure 0 MPa ... 1 MPa Operating pressure 0 bar ... 10 bar Operating pressure 0 psi ... 145 psi Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Nitrogen Temperature of medium 0 °C ... 50 °C Ambient temperature 0 °C ... 50 °C Nominal temperature 23 °C Accuracy of flow rate ± (3% o.m.v. + 0.3% FS) Zero point repetition accuracy in ± %FS 0.2 %FS Repetition accuracy margin in ± %FS 0.8 %FS Temperature co-efficient margin in ± %FS/K typ. 0. 1%FS/K Pressure influence of margin in ±%FS/bar 0.5 %FS/b. Switching output 2 x PNP or 2 x NPN switchable Switching function Window comparator Threshold value comparator Switching element function N/C contact/N/O contact switchable Max. output current 100 mA Analog output 0 - 10 V Flow characteristic curve, start value 0 l/min 5/21/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Flow characteristic curve, end value 200 l/min Output characteristic curve initial value 0V End value output characteristic curve 10 V Min. load resistance of voltage output 10 kOhm Short-circuit protection yes Overload protection Available DC operating voltage range 15 V ... 30 V Idle current 120 mA Reverse polarity protection for all electrical connections Electrical connection 1, connection type Plug Electrical connection 1, connection technology M12x1 A-coded as per EN 61076-2-101 Electrical connection 1, number of pins/wires 5 Electrical connection for input 1, connection pattern 00995383 Type of mounting With through-hole With H-rail Mounting position Any Pneumatic connection For pneumatic tubing outside diameter 10 mm Product weight 160 g Housing material PA-reinforced Display type Illuminated LCD, multi-color Displayable unit(s) l l/h l/min m3 scf scfm Setting options Teach-in Via display and pushbuttons Protection against tampering PIN code Degree of protection IP65 Pressure drop
565398 价格&库存
很抱歉,暂时无法提供与“565398”相匹配的价格&库存,您可以联系我们找货
