533342
533342
    FESTO(费斯托)
    FESTO - 533342 - AIR SOLENOID VALVE, 10BAR, 5/2 WAY
533342 数据手册
Air solenoid valve VMPA1-M1H-M-PI Part number: 533342 General operating condition Data sheet Feature Value Valve function 5/2, monostable Actuation type Electrical Valve size 10 mm Standard nominal flow rate 360 l/min Operating voltage 24V DC Operating pressure -0.09 MPa ... 1 MPa Operating pressure -0.9 bar ... 10 bar Structural design Piston gate valve Reset method Pneumatic spring Certification c UL us - Recognized (OL) Degree of protection IP65 as per IEC 60529 Sealing principle Soft Mounting position Any Manual override Detenting Non-detenting Type of control Pilot-controlled Flow direction Reversible Symbol 00991050 Lap Overlap Signal status display yes Pilot pressure MPa 0.3 MPa ... 0.8 MPa Pilot pressure 3 bar ... 8 bar Suitability for vacuum yes Standard nominal flow rate with QS-6 360 l/min Switching time off 20 ms On switching time 10 ms Max. positive test pulse with 0 signal 400 µs Max. negative test pulse on 1 signal 200 µs Permissible voltage fluctuations +/- 25 % Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) Vibration resistance Transport application test with severity level 2 as per FN 942017-4 and EN 60068-2-6 Shock resistance Shock test with severity level 2 as per FN 942017-5 and EN 60068-2-27 Corrosion resistance class (CRC) 1 - Low corrosion stress 5/18/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value LABS (PWIS) conformity VDMA24364-B1/B2-L Storage temperature -20 °C ... 40 °C Temperature of medium -5 °C ... 50 °C Relative air humidity Max. 90 % at 40 °C Ambient temperature -5 °C ... 50 °C Max. tightening torque for valve mounting 0.25 Nm Product weight 49 g Type of mounting With through-hole Note on materials RoHS-compliant Seals material NBR Housing material Die-cast aluminum 5/18/24 - Subject to change - Festo SE & Co. KG 2/2
533342 价格&库存
很抱歉,暂时无法提供与“533342”相匹配的价格&库存,您可以联系我们找货
  • 1+878.015131+113.57630
  • 5+815.380885+105.47420
库存:4
533342
  • 1+880.31113
  • 5+817.45059
库存:4
