1779441
1779441
    FESTO(费斯托)
    FESTO - 1779441 - Cylinder, Piston Rod, Double Acting, 40 mm, G1/4, 0.6 bar to 12 bar, 400 mm
1779441 数据手册
ISO cylinder DSBF-C-40-400-PPSA-N3-R Part number: 1779441 General operating condition Data sheet Feature Value Stroke 400 mm Piston diameter 40 mm Piston rod thread M12x1.25 Cushioning Self-adjusting pneumatic end-position cushioning Mounting position Any Conforms to standard ISO 15552 Piston rod end External thread Structural design Piston Piston rod Profile barrel Position sensing For proximity sensor Symbol 00992970 Operating pressure 0.06 MPa ... 1.2 MPa Operating pressure 0.6 bar ... 12 bar Mode of operation Double-acting Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) Corrosion resistance class (CRC) 3 - High corrosion stress LABS (PWIS) conformity VDMA24364-B2-L Cleanroom class Class 6 according to ISO 14644-1 Ambient temperature -20 °C ... 80 °C Impact energy in the end positions 0.7 J Cushioning length 19 mm Theoretical force at 6 bar, retracting 633 N Theoretical force at 6 bar, advancing 754 N Moving mass 844 g Moving mass at 0 mm stroke 204 g Additional moving mass per 10 mm stroke 16 g Product weight 2378 g Basic weight with 0 mm stroke 778 g Additional weight per 10 mm stroke 40 g Type of mounting Optionally: With internal thread With accessories Pneumatic connection G1/4 Note on materials RoHS-compliant Cover material Die-cast aluminum, coated 5/23/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Piston seal material TPE-U(PU) Material of piston Wrought aluminum alloy Piston rod material High-alloy stainless steel Piston rod wiper material TPE-U(PU) Buffer seal material TPE-U(PU) Cushion piston material POM Material of cylinder barrel Wrought aluminum alloy, anodized Nut material High-alloy stainless steel Material of bearing POM Flange screws material Steel, galvanized 5/23/24 - Subject to change - Festo SE & Co. KG 2/2
1779441 价格&库存
很抱歉,暂时无法提供与“1779441”相匹配的价格&库存,您可以联系我们找货
