CPE14-M1CH-3GL-1/8
CPE14-M1CH-3GL-1/8
    FESTO(费斯托)
    FESTO - CPE14-M1CH-3GL-1/8 - AIR SOLENOID VALVE, G1/8, 8BAR, 24VDC
CPE14-M1CH-3GL-1/8 数据手册
Air solenoid valve CPE14-M1CH-3GL-1/8 Part number: 550247 Data sheet Feature Value Valve function 3/2, closed, monostable Actuation type Electrical Width 14 mm Standard nominal flow rate 900 l/min Pneumatic working port G1/8 Operating voltage 24V DC Operating pressure 0.25 MPa ... 0.8 MPa Operating pressure 2.5 bar ... 8 bar Design Piston gate valve Reset method Pneumatic spring Maritime classification See certificate Degree of protection IP65 IP67 With plug socket as per IEC 60529 Nominal width 6 mm Type code CPE14 Sealing principle Soft Mounting position Any Manual override Detenting via accessory Non-detenting Type of control Pilot-controlled Pilot air supply port Internal Flow direction Non-reversible Symbol 00991655 Valve position ID Label holder Lap Overlap Switching time off 27 ms On switching time 16 ms Duty cycle 100% Max. positive test pulse with 0 signal 1200 µs Max. negative test pulse on 1 signal 900 µs Coil characteristics 24 V DC: 1.28 W Permissible voltage fluctuations -15 % / +10 % Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) 6/20/21 - Subject to change - Festo AG & Co. KG 1/2 Feature Value Vibration resistance Transport application test with severity level 2 as per FN 942017-4 and EN 60068-2-6 Shock resistance Shock test with severity level 2 as per FN 942017-5 and EN 60068-2-27 Corrosion resistance class (CRC) 2 - Moderate corrosion stress Temperature of medium -5 °C ... 50 °C Ambient temperature -5 °C ... 50 °C Max. tightening torque plug 0.4 Nm Product weight 60 g Electrical connection 4-pin M8x1 Type of mounting With through-hole Pilot exhaust air port 82 M3 Pilot air port 12 M3 Pneumatic connection 1 G1/8 Pneumatic connection 2 G1/8 Pneumatic connection 3 G1/8 Note on materials RoHS-compliant Seals material NBR Housing material Die-cast aluminum 6/20/21 - Subject to change - Festo AG & Co. KG 2/2
CPE14-M1CH-3GL-1/8 价格&库存
很抱歉,暂时无法提供与“CPE14-M1CH-3GL-1/8”相匹配的价格&库存,您可以联系我们找货
CPE14-M1CH-3GL-1/8
  • 1+1330.88838
库存:37
CPE14-M1CH-3GL-1/8
  • 1+1893.411561+244.96333
