566500
566500
    FESTO(费斯托)
    FESTO - 566500 - Air Solenoid Valve, 5/2 Way, Bistable, G1/8, 1.5 bar to 8 bar, 24 VDC, 780 l/min
566500 数据手册
Air solenoid valve VUVG-L14-B52-T-G18-1P3 Part number: 566500 General operating condition Data sheet Feature Value Valve function 5/2, bistable Actuation type Electrical Valve size 14 mm Standard nominal flow rate 700 l/min ... 780 l/min Pneumatic working port G1/8 Operating voltage 24V DC Operating pressure 0.15 MPa ... 0.8 MPa Operating pressure 1.5 bar ... 8 bar Structural design Piston gate valve Certification RCM compliance mark c UL us - Recognized (OL) Degree of protection IP40 IP65 With plug socket Nominal width 5.6 mm Exhaust air function With flow control option Sealing principle Soft Mounting position Any Manual override Detenting Non-detenting Covered Type of control Pilot-controlled Pilot air supply port Internal Symbol 00992897 Lap Overlap Pilot pressure MPa 0.15 MPa ... 0.8 MPa Pilot pressure 1.5 bar ... 8 bar Suitability for vacuum no Changeover time 8 ms Duty cycle 100% Max. positive test pulse with 0 signal 700 µs Max. negative test pulse on 1 signal 900 µs Coil characteristics 24 V DC: 1.0 W 24 V DC: low-current phase 0.3 W, high-current phase 1.0 W Permissible voltage fluctuations +/- 10 % Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) 5/9/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Vibration resistance Transport application test with severity level 2 as per FN 942017-4 and EN 60068-2-6 Restricted ambient and media temperature -5 - 50 °C Without holding power reduction Shock resistance Shock test with severity level 2 as per FN 942017-5 and EN 60068-2-27 Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Temperature of medium -5 °C ... 60 °C Ambient temperature -5 °C ... 60 °C Product weight 89 g Electrical connection Via electrical sub-base Type of mounting Optionally: On terminal strip With through-hole Pneumatic connection 1 G1/8 Pneumatic connection 2 G1/8 Pneumatic connection 3 G1/8 Pneumatic connection 4 G1/8 Pneumatic connection 5 G1/8 Note on materials RoHS-compliant Seals material HNBR NBR Housing material Wrought aluminum alloy 5/9/24 - Subject to change - Festo SE & Co. KG 2/2
566500 价格&库存
很抱歉,暂时无法提供与“566500”相匹配的价格&库存,您可以联系我们找货
